KPL Not lit
Hi guys;
I must have had a power failure today (while I was at work)
and I think a KPL has burned out.
I just wanted to pass it by the forum in case there's a solution before I go ahead and make a Smarthome order.
The KPL in question is not lit at all (no LEDS) and of course it doesn't work as a switch.
Its a version 1.66 one (probably from my first order years ago)
I've never had a KPL or SWL burn out so I',m just checking to see if there's a reboot or anything I can do before I chuck it out and replace it.
Drew
Pull the Air Gap switch out for a few minutes. Push it in flush with the KPL frame. Do not push it in past the frame as that could initiate a factory reset. Some of my older KPLs go dark after a power failure. Usually one of very short duration. It will take a few seconds for the LEDs to come on after restoring the Air Gap switch to its normal position.
I have had short power interruptions confuse a few of my older hardware revisions ApplianceLincs.
Power cycle corrects the problem.
The same for my KPL's, the AirGap fix has worked dozens of times and 100% so far.
aLf
  • 3 months later...
Me again;
Another power failure.
I need to try to airgap the one KPL.
The other one I stupidly pushed in the reset tab after leaving it out for a few seconds
(now its factory reset)
but when I try to re-add it to the scenes etc… it tells me that its already part of the scene.
Do I have to remove all instances of the KPL and start again on it?
(or is there a stupidity process I can do to save a lot of reprogramming)
Drew
Didn't seem to work.
I air gapped the one kpl as well and no luck.
Nothing seems to happen on the GUI when I 'restore device'
Should I see something working away?
(Ps I screwed up both kpls it seems, I need a nap)
If not requested for the Primary KPL button try the Restore Device for the Primary button. There is a System Busy popup indicating restore progress. For this Admin Console session do all the devices show Current State information.
      37.3k
      373.4k
