Programs not working.
mcrean
I posted this before, but I have had no resolution. I am at a loss.
These 3 programs are in a folder that enables at 10:00 PM.
For the first program, I have tried Deck Spots is Off along with Not On.
10:01 Deck Spots Status
       Time is 10:01:00PM
   And Status  'Deck Spots' is not On
       Run Program 'Deck Spots Turns Off Night'
Deck Spots Turns Off Night:
       Control 'KeypadLinc A (Deck Spots)' is switched Off
       Wait  1 hour
       Set 'Malibu Lights' On
       Wait  4 minutes
       Set 'Malibu Lights' Off
       Wait  1 minute
       Set Scene 'Deck Spots Button' On
Deck Spots Turns On Night:
       Control 'KeypadLinc A (Deck Spots)' is switched On
       Stop program 'Deck Spots Turns Off Night'
When I test this setup, say set the 'If' time to two minutes away and then have the Deck Spots Off, it works fine. If I even test the whole setup, folder enables 2 minutes from now and 'If' time 3 minutes from now, it works too. When I put the program in actual play (the times noted in the code) it does not work. Tonight I turned off the deck spots at 7:00 PM and after 10:01, the Deck Spots Turns Off Night was not "Running Then". Am I doing something wrong?
To fix your problem, remove 'Deck Spot Status' from the Folder because it doesn't need to be controlled by the Folder conditions anyway.
As for why it isn't working, I'd have to see the exact Folder conditions and see if I can recreate the problem. You are correct in assuming that if the Folder enables programs to run at 10:00PM, then your 'Deck Spots Status' program should run at 10:01PM if 'Deck Spots' is not On.
Are you saying that when the folder opens up, the Deck Spots Turns Off Night will automatically run? I was hoping the status request would trigger the hour timer.
The reason for this setup is if I turn off the deck spots to go sit in the spa, I want to not worry about having to turn them back on if I forget. If I am in the spa too long. the malibu lights flash to warn me the spots are looming. If I turn the deck spots off in the evening for a party, I just don't want them coming on until 11:00PM (Or if I hit the A button first). But If I go in the spa say at 10:50, I do not want them coming on in 10 minutes.
The Folder parameters are:
Folder Conditions for 'Deck Spots Night'
Add conditions to limit when programs in this folder are allowed to run.
       From    10:00:00PM
       To      Sunrise (next day)
The other folder I have, which is not really needed:
Folder Conditions for 'Deck Spots Day'
       From    Sunrise
       To      10:00:00PM (same day)
The Programs in the Day folder are If Turns Off/On Then do Nothing.
mcrean,
As Chris indicated, I don't see anything incorrect with your programs.
I tested the Deck Spot Status and folder conditions and everything appeared to work properly.
You mentioned that "you turned the deck spots off at 7:00 and at 10:01, the Deck Spots Turns off Night was not running" -
1) Was the folder running (true) at that point. Is it possible you switched the night and day conditions between folders? I don't mean to insult your intelligence. I bring it up because I've made this mistake (multiple occasions).
2) How did you "turn off" the deck spots (ISY or at the switch). Is it possible that there is a noise source that prevented the ISY from registering the "off event"?
Short of that, I don't see any problem. I do have a couple of observations (unrelated):
1) Beware of the condition "And Status 'Deck Spots' is not On". A level between 1% and 99% is considered "not on". You may want to change this to a status of "off".
2) The time conditions between your two folders have a possibility of overlapping (not sure how the ISY handles this). Chris would be far more knowledgeable here, but I typically use a underlap of 1min between daytime and nighttime conditions.
IM
Ok, I have deleted the day folder altogether.
I stated in the first post that it works fine when tested "On The Bench" so to speak. I tested the program six ways from Sunday on the bench and had positive results.
I verified that I did not switch the folder times. In fact the program runs fine if I switch off the scene after 10:00 PM.
The folder shows true after 10:00 PM.
I turn off the deck spots at the keypadlinc. The ISY will show the status as Off for the module. No times have I looked and that particular status disagreed with the actual module state. I even had a query program running right before the Deck Spots status and it did not help.
I have tried both Not On and Off.
So at this point, the only thing new for tonight is the non-overlapping folders, and making sure the status is Off (not "Not ON"). I have deleted the day folder.
Is there anything else you can think of?
I urge you to try the program as written and let it go for the night and see if it did indeed work the next morning. If it works, then make no changes and try again tomorrow night.
I will let you know if deleting the folder helped.
mcrean,
If I had to guess, I'd say that the original failure was due to your Insten Device not properly communicating a off status to the ISY.
Last night, when you monitored the conditions and status, everything worked properly (as it should).
This could be due to general noise/signal absorption in the vicinity of the Insteon device (reducing margin) or it could be something that is turning on at night (cfl's and outdoor photocells that activate at night are prime candidates).
Keep us posted,
IM
Ok, so it worked last night and is not working tonight. I have verified the following:
The Deck Spots module shows Off in ISY. (I shut it off via KeypadLinc at around 7PM)
The Folder is showing True right now (After 10)
The last run for the Deck Spots Status is 10:01PM 3/13/2008 (Tonight) and Status shows False (expected).
The last run for Deck Spots Turns Off Night is at 10:01 PM 3/12/2008 (Last night). (BUT SHOWS TRUE RIGHT NOW!)
Did that Sunrise(Next Day) bug ever get worked out? I came across a post about someone using the (Same Day) and it worked, but (Next Day) did not.
I think it is a bug...
It's possible that it is a bug. Not long ago I had problems with some programs that I had running in a folder. They would sometimes work, and sometimes not.
I thought that maybe I was just constructing the programs incorrectly. I had two types of conditionals, with the programs using Time conditionals, and then the programs being placed in a folder that utilized a KPL button Control conditional.
Functionality was so intermittent that I finally had to remove them from the folder, and build AND conditionals directly into each program.
Only then everything finally started working properly and consistently.
I figured that if it wasn't just me, that sooner or later someone would stumble across the same problem. So maybe you have indeed done so.
Best wishes,
mcrean,
First, I apologize for my last post - I had missed the fact that you had aleady taken steps to correlate the ISY status with your KPL.
From your post below, I'm not sure where You believe the problem is -
Actually, I would have expected the Deck Spots Status program to show "True".
       Time is 10:01:00PM
The "event" in the above is the Time 10:01:00PM. At that time the entire conditional is evaluated. It will retain that evaluation until it is retriggered (10:01 the next day, or the deck spots are activated). I would expect this to show "true" if your spots were off at 10:01PM. A false indication indicates the "then" was not executed.
Please try the following :
From 10:01:00PM
For 1 minute
Assuming that you did not turn your Deck Spots on while the folder was active, I believe the "True" is correct for this program.
       Wait  1 hour
       Wait  4 minutes
       Wait  1 minute
Like the program above, this is showing the status of the last call (event) on 3/12/2008. Since you are calling the "Then" statement directly, is has no choice but to reflect a "true" status. As I indicated above, the then loop was not called on 3/13.
You may be referring to a discussion between myself and Linuxguy. If that's the case, we were not discussing a "bug" in the nextday condition. We were discussing the fact that it's not possible to troubleshoot a nextday condition (other than letting the clock run). I use this condition in many folders and programs and don't have an issue.
From your description, your folder appears to be enabling correctly.
Please try adding the "1 minute window" to your program. I will try checking some things tonight.
IM
Indy Mike,
Thank you for your continued help.
I have put in the minute timer as you requested and made it "Not On".
I will let you know.
Michael
Michael,
To be honest, if the "1 minute" suggestion works I won't be able to explain why. All I can say is that this is the way that I structure my schedules (definite time period). I still don't see anything "wrong" with your original (single ended) schedule.
I have three different versions of your schedule running now. They all functioned as I expected at 2:30PM today. We'll see what happens tomorrow.
IM
Frank,
I've been a bit remiss in not posting this earlier - nice to have you back guy!
Your AWOL period must have invigorated you - you've been active (to the forums benefit).
In regard to your post regarding folder/program schedules, if you have some examples that you could provide, I'd be happy to spend some time running tests. My curiosity has been "peaked".
IM
Frank,
IM
Hello Mike:
Thanks for the kind words! I see that since I've been away, Darrell has joined UDI, and he is picking up Michel's tradition of staying close to the user base. Welcome aboard, Darrell ! Hopefully, this will make things a bit easier for Michel.
You know, I wish that I had really documented the problems with my folders. But I found that I was just more frustrated that my "AWAY" scene was not functioning properly. I tried several permutations and then just gave up on the concept of having the programs in a conditional folder. I still have them in a folder, but there are no conditions associated with it.
Since you're interested, the purpose of the programs is to turn lights on and off while we're away, to give the impression that we are "moving" around the house from room to room. What is supposed to trigger the programs are two conditions: Hall KPL G button, and the time of day.
The idea was that when we leave the house, say, in the afternoon, I could push the button which would allow the programs to run when the proper time was reached. If we were already in one of the evening time periods when the button was pushed, the THEN statements should start running immediately.
So here is what I had:
AWAY SCENE ON SUB 1
       Status  'Hall KPL G - Away Scene' is On
       Repeat 3 times
          Send X10 'G7/Off (11)'
          Wait  2 seconds
This program would turn off the X10 light in my office, which is a visual letting me know that that at least the ISY is acknowleding the button press.
AWAY SCENE SUB 2
   And From     7:00:00PM
       Repeat 1 times
          Wait  10 minutes  (Random)
          Set Scene 'Kitchen Main Group' On
          Wait  15 minutes
          Set Scene 'Living Room Ceiling Group' On
          Wait  10 minutes
          Set Scene 'Master Bed Light Group' On
          Wait  7 minutes
          Set Scene 'Master Bed Light Group' Off
          Wait  2 minutes
          Wait  3 minutes
          Wait  5 minutes
          Set Scene 'Basement Game Group' On
          Wait  5 minutes
          Set Scene 'Living Room Ceiling Group' Off
          Wait  3 minutes
       Repeat 3 times
          Send X10 'G7/On (3)'
          Wait  2 seconds
This program started the first sequence of events.
AWAY SCENE SUB 3
   And From    11:00:00PM
       To       1:00:00AM (next day)
       Wait  10 seconds (Random)
       Set Scene 'Basement Game Group' Off
       Wait  1 minute
       Wait  5 seconds
       Set Scene 'Kitchen Main Group' Off
       Wait  2 minutes
       Set 'Master Bed Dimmer' On
       Wait  1 hour and 2 minutes
       Repeat 3 times
          Wait  2 seconds
       Repeat 1 times
          Wait  10 minutes
          Set 'Master Bed Dimmer' Off
This program initiated the second sequence of events, and then eventually turned all the involved devices back off
AWAY SCENE OFF
       Control 'Hall KPL G - Away Scene' is switched Off
       Repeat 3 times
          Wait  2 seconds
       Repeat 1 times
          Stop program 'Away Scene ON Sub 2'
          Stop program 'Away Scene ON Sub 3'
This last program forced a stop of all the AWAY programs, and turned all involved devices back off when KPL G would be toggled off.
When I had the programs in folders, I think that I may have had the folder conditional set to respond the the KPL G button control or status ON. I really don't remember now. But I know that sometimes the programs would start running when they shouldn't have, even if the KPL G button was never pressed. At other times, the programs wouldn't run when the button had been pressed.
At any rate, this current setup seems to work.
If you can suggest anything better, I'll listen!
Thanks and Best wishes,
Frank,
Thank you for your kind words, both here and in some other threads as well!
Tonight the program is working. I am out of town for a week so this is the last test until I get back. Thanks again!
Michael,
I've had three different versions of your program running for ~ 5 days now. All have performed properly. I've tried numerous things and haven't been able to "trip them up".
Let us know how things are going when you return,
IM
Hello,
I am back. I tried again and it failed this evening. The 'Deck Spots Status' program now shows having run and last completed at 10:02 (because of the 1 minute delay) and shows false . The 'Deck spots turns off at night' shows blank on the last run time and complete time (had to reset ISY last night).
Should I re-write the programs to not use a folder, but use a time frame?
Indy Mike,
Are you making changes to your unit that is testing my program? It seems any change to any programming triggers it to run properly, for the day. Maybe set this unit aside and let it run on its own? I assume you are running other tests on it. I dunno.
Interesting. I turned on the Deck Spots via the KeypadLinc (after 10:00 PM) and now 'Deck Spots Turns On Night' program is showing 'Running Then', although there is no delay in the Then statement. It does show a last completed time at the same time it was started. Maybe it is a clue?
Michael,
I haven't made a change to the ISY in over a week (I've been away as well). Each time I've checked the programs indicate that they have been executing properly. I'm actually activating a X10 device with the equivalent "deck spots turns off night" program. My X10 CM15a interface confirms that the X10 commands are being sent at the proper times.
Folder Conditions
Folder Conditions for 'Test Program mcrean'
       From     2:30:00PM
       For      15 minutes
Trigger Program 1
       Status  'Entry Patio' is Off
   And Time is  2:31:00PM
       Run Program 'mcrean2'
Trigger Program 2
   And From     2:36:00PM
       For      1 minute
       Run Program 'mcrean4'
Trigger Program 3
   And Time is  2:33:00PM
       Run Program 'mcrean6'
       Run Program 'mcrean5' (Else Path)
Called program (3 programs - same code)
       Control 'Master Fan' is switched Off
       Send X10 'E1/On (3)'
       Wait  10 seconds
       Send X10 'E1/Off (11)'
As I indicated, I've tried a number of things to trip these programs up.
1) Direct program call from another folder - outside time window.
2) Program stop from another folder - outside time window.
3) Direct program call from another folder - within time window.
4) Program stop from another folder - within time window.
None of these attempts had any effect on the execution.
I'd like to say that moving your time conditionals into the actual programs would work for you. Problem is, I don't understand why it's not working currently.
IM
Hello,
Indy Mike,
That's a bit wild. Could you please confirm that you're still running the following code?
       Time is 10:01:00PM
       Wait  1 hour
       Wait  4 minutes
       Wait  1 minute
If your code is the same as above, my best guess would be that your PLM locked up or your program is looping (I don't understand why).
I just tried a similar "program stop command" and had no problems with beta 2.6.3. I'm at a loss at the moment.
It's beginning to look like you're in need of the services of an expert (Mr. Jahn).
IM
Frank,
IM
Hello Mike:
Earlier in this thread I did post examples of what I had been using for my "foldered" programs that were triggered by a button press. I don't know if you've had a chance to look at them.
But the present discussion reminds me a little of the problems that I had been seeing. Just very weird, inconsistent behavior. That is why I stopped using folders for this purpose.
Like mcrean, it seemed as though I was actually getting my buttons presses being properly registered by the ISY. In fact, for all my "cleanup" programs, the button presses always trigger the "Then" statements properly.
But with the example that I posted earlier in this thread, this was not true. There were two major failures: the "Then" statements should have started running and stayed running, but would instead start and stop at the same time. And the second error was that the program would sometimes start on its own, with no button press being recorded. This latter error was probably due to some logic error on my part, but I couldn't find it.
I wish that I had done a better job of documenting the code so that I could reconstruct the series of events. But all that I remember is what I posted here earlier.
Ever since I stopped using the folders for this purpose, the programs that I wrote to handle my "Away" scene are working properly.
Best wishes,
Frank,
Thank you for the additional background. I don't doubt for a second that both you and Michael have (are) experienced problems with folder conditions. To date, I haven't been able to throw the right set of inputs at the routines to initiate a problem.
I have tried some cursory tests using the routines that you provided. To date I've come up with a few methods to stop them from executing. I haven't come up with a way to cause them to execute with the folder condition false.
Still looking...
IM
Well, yesterday I moved the programs out of the conditional folder and made the programs themselves time conditional. Last night and tonight they have functioned properly. I wonder if my unit has some weird problem? The end result is that the status program never went true at 10:01 PM while in the conditional folder. The folder condition was from 10:00 PM to Sunrise (next Day) That is the only thing I can say is different between my programs and IndyMike's test programs. Let me know if you stumble across the same thing.
Thank you for your help.
      38.2k
      381.2k
