LeeG,
I went back to 3.3.6 like you requested and deleted the troublesome KPL from the ISY. I then re-linked it and wiped all existing links from the device. Just in case I had also hard reset the KPL before re-linking. After the ISY had added the KPL, the first thing I attempted to do was set the led brightness. Nothing seems to happen on the KPL. I attached a screenshot of the following levels being set: 0/5, 2/10, and 7/15.
Jacob
My 3.3.6 Admin Console is using a different option in the 2E command when setting LED Brightness on my v.36 KPL.
What does Help | About show for the Firmware and UI level.
Is it correct the progress bar is now completing?
The command issued on my system is using 07 as the 2E variant. The command in your post shows the 03 variant. Since both are v.36 KPLs I would expect both commands to use the same variant. The 7/15 (7F) is setting the same brightness level
Sun 12/16/2012 03:26:42 PM : [iNST-TX-I2 ] 02 62 16 7D 60 1F 2E 00 00 03 7F 00 00 00 00 00 00 00 00 00 50
Sun 12/16/2012 07:20:41 PM : [iNST-TX-I2 ] 02 62 15 9A F9 1F 2E 00 01 07 7F 00 00 00 00 00 00 00 00 00 00 4B
Both the UI and firmware report version 3.3.6 with the exact same date code after them. The progress bar does seem to complete now. BTW, I tried setting a different KPL backlight and it worked. I noticed the commands were different preceding the brightness HEX value when talking to the other KPL. Obviously the address was different, but the commands looked different too. Could the ISY be retaining some config for this KPL after deleting it? This is just weird. When I tried the upgrade again BTW, all the KPLs exhibited the problem again. Restoring from my last 3.3.5 backup which have all but the one KPL working restored the other KPLs to a working status. So something is going wrong during the upgrade of my configuration I would think.
Jacob
One thing for sure, stop playing with various backups. Restore the 3.3.6 backup. Nothing from a previous device definition should carry forward after deleting and adding the device back from scratch. Is the v.36 KPL a Relay or a Dimmer.
The progress bar situation is resolved with everything at 3.3.6. Let’s stick with that and find the answer to the command variation question.
So I looked up the command in the insteon command table and found that the command decodes as so:
02 62 16 7D 60 1F 2E 00 00 03 05 00 00 00 00 00 00 00 00 00 00 CA
02 - STX
62 - Extended Message
16 7D 60 - Address
2E 00 - Extended Get/Set
00 - Button/Group number 0
03 - Set LED-Off mask for button
05 - Mask (if bit = 0, LED not affected, if bit = 1, LED turns off when button pressed)
Rest ignored
This makes some sense since after issuing this command the keypad LED's misbehave, but the link table is corrupted as well which I don't understand.
The 07 in place of the 03 would set the Global LED brightness.
Jacob
You have access to internal documentation that I do not. The wrong 2E variant is being used for a LED Brightness change. I will leave it up to UDI to clear this up. Suggest opening a ticket with UDI tech support.
Installed 3.3.6.
Seems to be fully functional, but looks like there might be an issue with the admin interface.
If the gui isn't maximized. it seems to have trouble painting the ELK security status/buttons.
Screenshot attached.
I do have the elk module.
Jacob,
As LeeG suggested, it's VERY important not to go back and forth between backup/firmware releases. when upgrading to 3.3.6, all database files are upgraded. We might have an issue with the upgrade process. This said, going back to firmware 3.2.6 will only exacerbate issues. Again, as LeeG suggested, please:
1. Restore a backup from 3.2.6
2. Remove the KPL in question
3. Add it back in
Let me know if you have the same issues with other KPLs as you have with the one in question.
Hi tunaman,
What operating system and Java version?
I also have Elk module. Win 7 64 bit. Java ver 7 update 9. and the Elk area gets messed up as the previous screen capture. What I noticed is that it gets drawn correctly, and only when the mouse cursor is moved over individual buttons (without clicking) that the buttons get copied over as if they were tool tip and copied to where the mouse was dragged.
I am having an issue with alerts.
Any NEW or MODIFIED alerts since installing the 3.3.x series will not be sent via teXt message.
Existing alerts are sent just fine, for any program.
Luckily I have 2 "general" alerts which still function, but the new alerts I have created with specific information about the alert are not working.
I tried creating new alerts after installing 3.3.6 and the problem persists.
Any ideas????
UPDATE:
Sending NEW or MODIFIED alerts via email works just fine. Only sending as a text is not working which makes no sense as the isy sends an email either way...????
As I said, existing alerts are working fine as texts.
~John
(BTW: love my ISY!)
Michel,
I've tested the link to 3.3.5 and it all works correctly. I then went back to 3.3.6 and it works correctly as well. I've tested in both normal and maximized windows and I can't replicate the error. I then erased all of the Java cache and downloaded new 3.3.6 and it works correctly. I'll report if the problem repeats itself.
Michel,
Everything, including Elk Module with secure port seems to work but I just took a peak at the Error Log and here is the copy from the last few minutes.
My ISY is on .160 and my laptop where I'm accessing the admin console is .31 Where should I start to troubleshoot why there is such a flood of socket errors and these GET /desc requests?
Mon 2012/12/17 18:54:41 System -170001 [HTTP] 192.168.44.31:49597->80
Mon 2012/12/17 19:06:44 System -170001 [HTTP] 192.168.44.31:49790->80
Mon 2012/12/17 19:06:44 System -170001 [HTTP] 192.168.44.31:49791->80
Mon 2012/12/17 19:06:44 System -170001 [HTTP] 192.168.44.31:49792->80
Mon 2012/12/17 19:06:44 System -170001 [HTTP] 192.168.44.31:49793->80
Mon 2012/12/17 19:06:44 System -170001 [HTTP] 192.168.44.31:49794->80
Mon 2012/12/17 19:06:44 System -170001 [HTTP] 192.168.44.31:49795->80
Mon 2012/12/17 19:06:45 System -170001 [HTTP] 192.168.44.31:49796->80
Mon 2012/12/17 19:06:45 System -170001 [HTTP] 192.168.44.31:49797->80
Mon 2012/12/17 19:06:45 System -170001 [HTTP] 192.168.44.31:49800->80
Mon 2012/12/17 19:07:13 System -170001 [HTTP] 192.168.44.31:49803->80
Mon 2012/12/17 19:07:13 System -170001 [HTTP] 192.168.44.31:49806->80
Mon 2012/12/17 19:07:13 System -170001 [HTTP] 192.168.44.31:49809->80
Mon 2012/12/17 19:07:15 System -170001 [HTTP] 192.168.44.160:2480->80
Mon 2012/12/17 19:07:15 System -170001 0: GET-->/desc
Mon 2012/12/17 19:07:15 System -170001 [HTTP] 192.168.44.160:2481->80
Mon 2012/12/17 19:07:15 System -170001 [HTTP] Socket not active#2 26
Mon 2012/12/17 19:07:15 System -170001 [HTTP] 192.168.44.160:2482->80
Mon 2012/12/17 19:07:15 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:07:15 System -170001 [HTTP] 192.168.44.160:2483->80
Mon 2012/12/17 19:07:15 System -170001 [HTTP] Invalid socket 26
Mon 2012/12/17 19:07:15 System -170001 [HTTP] 192.168.44.160:2488->80
Mon 2012/12/17 19:07:15 System -170001 [HTTP] 192.168.44.160:2489->80
Mon 2012/12/17 19:07:15 System -170001 [HTTP] 192.168.44.160:2490->80
Mon 2012/12/17 19:07:15 System -170001 [HTTP] 192.168.44.160:2491->80
Mon 2012/12/17 19:07:15 System -170001 [HTTP] 192.168.44.160:2497->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2498->80
Mon 2012/12/17 19:07:16 System -170001 0: GET-->/desc
Mon 2012/12/17 19:07:16 System -170001 [HTTP] Socket not active#2 26
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2499->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2500->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2514->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2515->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2516->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] Invalid socket 26
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2517->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] Invalid socket 32
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2527->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2528->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2529->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2530->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2535->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2536->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2537->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2538->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2544->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2545->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2546->80
Mon 2012/12/17 19:07:16 System -170001 [HTTP] 192.168.44.160:2547->80
Mon 2012/12/17 19:07:28 System -170001 [HTTP] 192.168.44.160:2555->80
Mon 2012/12/17 19:07:28 System -170001 0: GET-->/desc
Mon 2012/12/17 19:07:28 System -170001 [HTTP] Socket not active#2 26
Mon 2012/12/17 19:07:28 System -170001 [HTTP] 192.168.44.160:2556->80
Mon 2012/12/17 19:07:28 System -170001 [HTTP] 192.168.44.160:2557->80
Mon 2012/12/17 19:07:28 System -170001 [HTTP] 192.168.44.160:2558->80
Mon 2012/12/17 19:07:53 System -170001 [HTTP] 192.168.44.160:2563->80
Mon 2012/12/17 19:07:53 System -170001 0: GET-->/desc
Mon 2012/12/17 19:07:53 System -170001 [HTTP] 192.168.44.160:2564->80
Mon 2012/12/17 19:07:53 System -170001 [HTTP] Socket not active#2 26
Mon 2012/12/17 19:07:53 System -170001 [HTTP] 192.168.44.160:2565->80
Mon 2012/12/17 19:07:53 System -170001 [HTTP] 192.168.44.160:2566->80
Mon 2012/12/17 19:08:18 System -170001 [HTTP] 192.168.44.160:2572->80
Mon 2012/12/17 19:08:18 System -170001 0: GET-->/desc
Mon 2012/12/17 19:08:18 System -170001 [HTTP] Socket not active#2 26
Mon 2012/12/17 19:08:18 System -170001 [HTTP] 192.168.44.160:2573->80
Mon 2012/12/17 19:08:18 System -170001 [HTTP] Invalid socket 32
Mon 2012/12/17 19:08:18 System -170001 [HTTP] 192.168.44.160:2574->80
Mon 2012/12/17 19:08:18 System -170001 [HTTP] 192.168.44.160:2575->80
Mon 2012/12/17 19:08:30 System -170001 [HTTP] 192.168.44.31:49810->80
Mon 2012/12/17 19:08:30 System -170001 [HTTP] 192.168.44.31:49813->80
Mon 2012/12/17 19:08:30 System -170001 [HTTP] 192.168.44.31:49816->80
Mon 2012/12/17 19:08:43 System -170001 [HTTP] 192.168.44.160:2594->80
Mon 2012/12/17 19:08:43 System -170001 0: GET-->/desc
Mon 2012/12/17 19:08:43 System -170001 [HTTP] 192.168.44.160:2595->80
Mon 2012/12/17 19:08:43 System -170001 [HTTP] 192.168.44.160:2596->80
Mon 2012/12/17 19:08:43 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:08:43 System -170001 [HTTP] 192.168.44.160:2597->80
Mon 2012/12/17 19:09:08 System -170001 [HTTP] 192.168.44.160:2620->80
Mon 2012/12/17 19:09:08 System -170001 0: GET-->/desc
Mon 2012/12/17 19:09:08 System -170001 [HTTP] Invalid socket 32
Mon 2012/12/17 19:09:08 System -170001 [HTTP] 192.168.44.160:2621->80
Mon 2012/12/17 19:09:08 System -170001 [HTTP] 192.168.44.160:2622->80
Mon 2012/12/17 19:09:08 System -170001 [HTTP] 192.168.44.160:2623->80
Mon 2012/12/17 19:09:25 System -170001 [HTTP] 192.168.44.31:49817->80
Mon 2012/12/17 19:09:25 System -170001 [HTTP] 192.168.44.31:49820->80
Mon 2012/12/17 19:09:25 System -170001 [HTTP] 192.168.44.31:49823->80
Mon 2012/12/17 19:09:47 System -170001 [HTTP] 192.168.44.160:2628->80
Mon 2012/12/17 19:09:47 System -170001 0: GET-->/desc
Mon 2012/12/17 19:09:47 System -170001 [HTTP] 192.168.44.160:2629->80
Mon 2012/12/17 19:09:47 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:09:47 System -170001 [HTTP] 192.168.44.160:2630->80
Mon 2012/12/17 19:09:47 System -170001 [HTTP] Socket not active#2 26
Mon 2012/12/17 19:09:47 System -170001 [HTTP] 192.168.44.160:2631->80
Mon 2012/12/17 19:09:58 System -170001 [HTTP] 192.168.44.160:2637->80
Mon 2012/12/17 19:09:58 System -170001 0: GET-->/desc
Mon 2012/12/17 19:09:58 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:09:58 System -170001 [HTTP] 192.168.44.160:2638->80
Mon 2012/12/17 19:09:58 System -170001 [HTTP] Invalid socket 26
Mon 2012/12/17 19:09:58 System -170001 [HTTP] 192.168.44.160:2639->80
Mon 2012/12/17 19:09:58 System -170001 [HTTP] Socket not active#2 26
Mon 2012/12/17 19:09:58 System -170001 [HTTP] 192.168.44.160:2641->80
Mon 2012/12/17 19:10:12 System -170001 [HTTP] 192.168.44.31:49838->80
Mon 2012/12/17 19:10:12 System -170001 [HTTP] 192.168.44.31:49839->80
Mon 2012/12/17 19:10:19 System -170001 [HTTP] 192.168.44.31:49840->80
Mon 2012/12/17 19:10:23 System -170001 [HTTP] 192.168.44.160:2654->80
Mon 2012/12/17 19:10:23 System -170001 0: GET-->/desc
Mon 2012/12/17 19:10:23 System -170001 [HTTP] Socket not active#2 26
Mon 2012/12/17 19:10:23 System -170001 [HTTP] 192.168.44.160:2655->80
Mon 2012/12/17 19:10:23 System -170001 [HTTP] 192.168.44.160:2656->80
Mon 2012/12/17 19:10:23 System -170001 [HTTP] 192.168.44.160:2657->80
Mon 2012/12/17 19:10:48 System -170001 [HTTP] 192.168.44.160:2662->80
Mon 2012/12/17 19:10:48 System -170001 0: GET-->/desc
Mon 2012/12/17 19:10:48 System -170001 [HTTP] Socket not active#2 26
Mon 2012/12/17 19:10:48 System -170001 [HTTP] 192.168.44.160:2663->80
Mon 2012/12/17 19:10:48 System -170001 [HTTP] 192.168.44.160:2664->80
Mon 2012/12/17 19:10:48 System -170001 [HTTP] 192.168.44.160:2665->80
Mon 2012/12/17 19:11:13 System -170001 [HTTP] 192.168.44.160:2670->80
Mon 2012/12/17 19:11:13 System -170001 0: GET-->/desc
Mon 2012/12/17 19:11:13 System -170001 [HTTP] Socket not active#2 26
Mon 2012/12/17 19:11:13 System -170001 [HTTP] 192.168.44.160:2671->80
Mon 2012/12/17 19:11:13 System -170001 [HTTP] 192.168.44.160:2672->80
Mon 2012/12/17 19:11:13 System -170001 [HTTP] 192.168.44.160:2673->80
Mon 2012/12/17 19:11:13 System -170001 [HTTP] Invalid socket 26
Mon 2012/12/17 19:11:38 System -170001 [HTTP] 192.168.44.160:1914->80
Mon 2012/12/17 19:11:38 System -170001 0: GET-->/desc
Mon 2012/12/17 19:11:38 System -170001 [HTTP] Socket not active#2 26
Mon 2012/12/17 19:11:38 System -170001 [HTTP] 192.168.44.160:1915->80
Mon 2012/12/17 19:11:38 System -170001 [HTTP] 192.168.44.160:1916->80
Mon 2012/12/17 19:11:38 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:11:38 System -170001 [HTTP] 192.168.44.160:1917->80
Mon 2012/12/17 19:11:51 System -170001 [HTTP] 192.168.44.31:49843->80
Mon 2012/12/17 19:12:03 System -170001 [HTTP] 192.168.44.160:1925->80
Mon 2012/12/17 19:12:03 System -170001 0: GET-->/desc
Mon 2012/12/17 19:12:03 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:12:03 System -170001 [HTTP] 192.168.44.160:1926->80
Mon 2012/12/17 19:12:03 System -170001 [HTTP] 192.168.44.160:1927->80
Mon 2012/12/17 19:12:03 System -170001 [HTTP] 192.168.44.160:1928->80
Mon 2012/12/17 19:12:28 System -170001 [HTTP] 192.168.44.160:1933->80
Mon 2012/12/17 19:12:28 System -170001 0: GET-->/desc
Mon 2012/12/17 19:12:28 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:12:28 System -170001 [HTTP] 192.168.44.160:1934->80
Mon 2012/12/17 19:12:28 System -170001 [HTTP] Invalid socket 32
Mon 2012/12/17 19:12:28 System -170001 [HTTP] 192.168.44.160:1935->80
Mon 2012/12/17 19:12:28 System -170001 [HTTP] 192.168.44.160:1936->80
Mon 2012/12/17 19:12:53 System -170001 [HTTP] 192.168.44.160:1941->80
Mon 2012/12/17 19:12:53 System -170001 0: GET-->/desc
Mon 2012/12/17 19:12:53 System -170001 [HTTP] 192.168.44.160:1942->80
Mon 2012/12/17 19:12:53 System -170001 [HTTP] Invalid socket 32
Mon 2012/12/17 19:12:53 System -170001 [HTTP] 192.168.44.160:1943->80
Mon 2012/12/17 19:12:53 System -170001 [HTTP] 192.168.44.160:1944->80
Mon 2012/12/17 19:13:18 System -170001 [HTTP] 192.168.44.160:1949->80
Mon 2012/12/17 19:13:18 System -170001 0: GET-->/desc
Mon 2012/12/17 19:13:18 System -170001 [HTTP] 192.168.44.160:1950->80
Mon 2012/12/17 19:13:18 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:13:18 System -170001 [HTTP] 192.168.44.160:1951->80
Mon 2012/12/17 19:13:18 System -170001 [HTTP] Invalid socket 32
Mon 2012/12/17 19:13:18 System -170001 [HTTP] 192.168.44.160:1952->80
Mon 2012/12/17 19:13:43 System -170001 [HTTP] 192.168.44.160:1961->80
Mon 2012/12/17 19:13:43 System -170001 0: GET-->/desc
Mon 2012/12/17 19:13:43 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:13:43 System -170001 [HTTP] 192.168.44.160:1962->80
Mon 2012/12/17 19:13:43 System -170001 [HTTP] 192.168.44.160:1963->80
Mon 2012/12/17 19:13:43 System -170001 [HTTP] 192.168.44.160:1964->80
Mon 2012/12/17 19:13:43 System -170001 [HTTP] Invalid socket 32
Mon 2012/12/17 19:14:08 System -170001 [HTTP] 192.168.44.160:1969->80
Mon 2012/12/17 19:14:08 System -170001 0: GET-->/desc
Mon 2012/12/17 19:14:08 System -170001 [HTTP] 192.168.44.160:1970->80
Mon 2012/12/17 19:14:08 System -170001 [HTTP] 192.168.44.160:1971->80
Mon 2012/12/17 19:14:08 System -170001 [HTTP] Invalid socket 32
Mon 2012/12/17 19:14:08 System -170001 [HTTP] 192.168.44.160:1972->80
Mon 2012/12/17 19:14:33 System -170001 [HTTP] 192.168.44.160:1982->80
Mon 2012/12/17 19:14:33 System -170001 0: GET-->/desc
Mon 2012/12/17 19:14:33 System -170001 [HTTP] 192.168.44.160:1983->80
Mon 2012/12/17 19:14:33 System -170001 [HTTP] 192.168.44.160:1984->80
Mon 2012/12/17 19:14:33 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:14:33 System -170001 [HTTP] 192.168.44.160:1985->80
Mon 2012/12/17 19:14:58 System -170001 [HTTP] 192.168.44.160:1990->80
Mon 2012/12/17 19:14:58 System -170001 0: GET-->/desc
Mon 2012/12/17 19:14:58 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:14:58 System -170001 [HTTP] 192.168.44.160:1991->80
Mon 2012/12/17 19:14:58 System -170001 [HTTP] 192.168.44.160:1992->80
Mon 2012/12/17 19:14:58 System -170001 [HTTP] 192.168.44.160:1993->80
Mon 2012/12/17 19:15:23 System -170001 [HTTP] 192.168.44.160:2002->80
Mon 2012/12/17 19:15:23 System -170001 0: GET-->/desc
Mon 2012/12/17 19:15:23 System -170001 [HTTP] Invalid socket 32
Mon 2012/12/17 19:15:23 System -170001 [HTTP] 192.168.44.160:2003->80
Mon 2012/12/17 19:15:23 System -170001 [HTTP] 192.168.44.160:2004->80
Mon 2012/12/17 19:15:23 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:15:23 System -170001 [HTTP] 192.168.44.160:2005->80
Mon 2012/12/17 19:15:48 System -170001 [HTTP] 192.168.44.160:2010->80
Mon 2012/12/17 19:15:48 System -170001 0: GET-->/desc
Mon 2012/12/17 19:15:48 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:15:48 System -170001 [HTTP] 192.168.44.160:2011->80
Mon 2012/12/17 19:15:48 System -170001 [HTTP] 192.168.44.160:2012->80
Mon 2012/12/17 19:15:48 System -170001 [HTTP] 192.168.44.160:2013->80
Mon 2012/12/17 19:15:49 System -170001 [HTTP] 192.168.44.31:49875->80
Mon 2012/12/17 19:15:50 System -170001 [HTTP] 192.168.44.31:49878->80
Mon 2012/12/17 19:15:52 System -170001 [HTTP] 192.168.44.31:49881->80
Mon 2012/12/17 19:16:13 System -170001 [HTTP] 192.168.44.160:2018->80
Mon 2012/12/17 19:16:13 System -170001 0: GET-->/desc
Mon 2012/12/17 19:16:13 System -170001 [HTTP] 192.168.44.160:2019->80
Mon 2012/12/17 19:16:13 System -170001 [HTTP] 192.168.44.160:2020->80
Mon 2012/12/17 19:16:13 System -170001 [HTTP] 192.168.44.160:2021->80
Mon 2012/12/17 19:16:38 System -170001 [HTTP] 192.168.44.31:49884->80
Mon 2012/12/17 19:16:38 System -170001 [HTTP] 192.168.44.160:2752->80
Mon 2012/12/17 19:16:38 System -170001 0: GET-->/desc
Mon 2012/12/17 19:16:38 System -170001 [HTTP] 192.168.44.160:2753->80
Mon 2012/12/17 19:16:38 System -170001 [HTTP] Invalid socket 26
Mon 2012/12/17 19:16:38 System -170001 [HTTP] 192.168.44.160:2754->80
Mon 2012/12/17 19:16:38 System -170001 [HTTP] Socket not active#2 26
Mon 2012/12/17 19:16:38 System -170001 [HTTP] 192.168.44.160:2755->80
Mon 2012/12/17 19:17:03 System -170001 [HTTP] 192.168.44.160:2763->80
Mon 2012/12/17 19:17:03 System -170001 0: GET-->/desc
Mon 2012/12/17 19:17:03 System -170001 [HTTP] 192.168.44.160:2764->80
Mon 2012/12/17 19:17:03 System -170001 [HTTP] 192.168.44.160:2765->80
Mon 2012/12/17 19:17:03 System -170001 [HTTP] Socket not active#2 32
Mon 2012/12/17 19:17:03 System -170001 [HTTP] 192.168.44.160:2766->80
tunaman,
I had the same problem and Michel posted a link to 3.3.5 UI in a reply to my message. I tried it and the Elk area worked fine. I then cleared my Java cache and tried 3.3.6 UI and it is working fine. I'm also on Win 7 with Java 7 update 9. Try that and see if that fixes your problem.
Oskar
Hello Oskar,
Thanks for the update on the UI/ELK issue.
The entries in the error log are 100% benign. They are just showing detailed access information. If you see socket inactive error, it means that the socket was improperly closed ... in short, you are OK.
I downloaded v3.3.6 and found that the firmware now displays as:
Insteon_UD99 v.3.3.6 but the UI shows:
Insteon_UD994 v.3.3.6.
My equipment is the UD99 Pro.
Is this something I should be concerned about?
mike
Join the conversation
Reply to this topic...
  Only 75 emoji are allowed.
      38k
      379.4k
