Is your local weather station not close enough...
jmed999
My local weather station was over 10 miles away and lot of times I would get rain at my house but the local weather station detected no rain. I really wanted to use evapotranspiration (ET) with my EZRain sprinkler system.
So I purchased a weather station, put it in my backyard and now my ISY is using my station for ET. I bought a Davis Vantage Pro 2 with a 24 hour fan. I bought the WeatherlinkIP which came with a data logger. http://www.rainmanweather.com/site/products/Davis-Vantage-Pro2-24-Hr-Fan-and-WeatherLinkIP-Package'>http://www.rainmanweather.com/site/products/Davis-Vantage-Pro2-24-Hr-Fan-and-WeatherLinkIP-Package As a package deal I paid $705. Be sure to enter your e-mail addy on that page to see the rock bottom price. You could also use this package if you wanted http://www.rainmanweather.com/site/products/Davis-Vantage-Pro2-24-Hr-Fan-and-WeatherLinkIP-Package For less than $450. I just wanted to step it up a notch. The WeatherlinkIP allows you to connect the console to the internet without having your computer running 24/7.
I was told I would also need a Meteohub but the guys at Weatherbug Backyard stations have figured out how to upload data without the Meteohub. You can instead use this method for $18/year...
http://www.wxforum.net/index.php?topic=16420.0 and this http://weather.albury.net.au/weatherlink/index.htm
I hope this is helpful to some of you! I not only use it for ET but also for alarming me when the wind speed is over a certain value and to notify me when it rains and total daily rain.
Go here...
http://backyard.weatherbug.com/profiles/blogs/weatherbug-publishing
And post on that blog like I did and they will tell you how to sign up.
They will tell you to go here...
Put in some dummy answer to the two blanks and it will go to the next screen. You can enter your info there. He will give you a free 7 day trail. You may want to post questions on the blog since they are there to help and not here. It is only $18/yr. That alone is worth not having a computer running 24/7/365.
Hope this helps!
OK, so where do you find station id?
I put p15937 and found out your weather.
Hello George,
I'm thinking you are trying to find the ID of a backyard station near you. Not at all intuitive - as you'll see.
1) Navigate to the weatherbug site and enter your ZIP code (if it hasn't picked up the location from your browser).
2) Weatherbug will select a Station near you. It will NOT select a backyard station (which may be closer).
3) Select "Change Weather Station".
4) Weatherbug will bring up a map of local stations. You may need to pan back to find your actual location. Backyard stations are shown in yellow as depicted in the graphic below. I am in the little burg of Granger, which happens to be close to the KD8FW station.
5) Select the backyard station, click "set station", and you'll be returned the the main station page as shown below. The station ID will be similar to the highlighted ID I'm showing in the address bar (p04609 in this case). Enter this into the ISY "location ID" and click save. It should bring up the readings for that station.
Be careful in selecting your station. Not all stations provide rainfall, wind speed, etc. Worse yet, not all stations are "maintained". My selection of KD8FW was based on good consistent readings, the fact that he's a HAM (speaks well in my mind). The fact that I've know him since grade school doesn't even enter into the equation.
Hope this helps,
IM
I have put in a weather station and WeatherLink and now working on linking it to weatherbug. Feel stupid but I'm sure I will find the link. I hade a problem with my Cisco box, had only 10 user and just moved it up to 50 user at my house. It was creating all kinds of strange stuff.
So I have found the link from WeatherBug, installed it on my WeatherLinkIP and registered with Weatherbug. How long does Weatherbug take to register my new location?
Or should I ask if I have dome everything. I don't see my wather station on Weatherbug, have put my p15331 in the WeatherBug setting on location ID. I put someone else P.... id in and it brought me their weather so I think the problem is with WeatherBug.
