Isy 99i and Elk Wireless keyfob
I have the ELK module for ISY.
I have been using my Elk sensors to trigger isy events without issues.
Today I wanted to have my Elk wireless keyfob trigger the lights to come on.
I cannot see the keyfob in the listing of elk devices.
I can see the zones ahead and behind it.
Any thoughts?
I don't have the official Elk keyfob, but based on your description, it sounds like it is not currently a supported device for ISY.
Simple solution is to use an Elk rule that turns an elk output on when you hit the keyfob as go-between to ISY.
ie
Whenever
keyfob x is pressed
turn output y on for 1 second
Now in ISY
Elk output y is on
Set scene z on
