Help with my program for motion lights
I have outside lights I want to be on at dusk till 11pm, then only turn on with motion from 11pm to sunrise.
Right now they stay on all the time...
Here is my programs:
From Sunset
To 11:10:00PM (same day)
Set 'Outside Garage' On
Disable Program 'Garage Outside Motion'
Set 'Outside Garage' Off
Enable Program 'Garage Outside Motion'
Run Program 'Garage Outside Motion' (Else Path)
Status 'Outside Garage Motion-Sensor' is On
Or Elk Zone 'Motion - Front' is Violated
And From Sunset
To Sunrise (same day)
Wait 15 minutes
This Program needs parens
And From Sunset
Wait 15 minutes
Also need to know what motion sensor options are in effect. Things like On Only mode can affect how a Program like this is coded.
Given your program, this could also be caused by the configuration of the motion sensor. I believe thay can be set to send only "on" commands. If yours is set this way, your program would not turn the lights off (except at sunrise).
I am also assuming your elk zone is not in a constand "violated" state.
I do believe that the time condition of "From Sunset to Sunrise (Same Day)" may be a problem as well. I think you want "From Sunset to Sunrise (Next Day)"
-Xathros
