Irrigation Module Question...
My allowable depletion says its, 0.165" and the irrigation requirement is 1.6214" in the climate tab. The program's irrigation requirement says if the irrigation requirement is >0.5" then the sprinklers are to start.
For some reason the irrigation module never triggers my sprinklers to start.
Any ideas what the problem could be?
can you manually turn on the valves through the ISY directly?
Yes and I can run the sprinkler program through the ISY. It's just that the irrigation module doesn't initiate it.
I have the following programs for my irrigation system...
Sprinkler Run 1
       Time is Sunrise -  2 hours
   And Module 'Climate' Irrigation Requirement is 0.5 inches
   And Module 'Climate' Temperature > 34 °F
       Run Program 'Sprinkler Run 3' (Then Path)
Sprinkler Run 2
   And Program 'Sprinkler Run 1' is False
       Run Program 'Sprinkler Run 3' (Else Path)
Sprinkler Run 3
       Send Notification to 'My e-mail' content 'Lawn Sprinklers Started'
       Set 'Sprinkler System / 9-Side (at Road)' On
       Wait  15 minutes
       Set 'Sprinkler System / 8-Side (Near Driveway)' On
       Wait  10 minutes
       Set 'Sprinkler System / 7-Back Flowers and Trees' On
       Wait  2 minutes
       Set 'Sprinkler System / 6-Back Near Pond' On
       Wait  10 minutes
       Set 'Sprinkler System / 5-Back Right and Bushes' On
       Wait  15 minutes
       Set 'Sprinkler System / 5-Back Right and Bushes' Off
       Set 'Sprinkler System / 4-Front Bushes' On
       Wait  5 minutes
       Set 'Sprinkler System / 2-Front Middle' On
       Wait  10 minutes
       Set 'Sprinkler System / 1-Front Left (Near Tina)' On
       Wait  15 minutes
       Set 'Sprinkler System / 3-Front Right (Near Driveway)' On
       Wait  15 minutes
       Set 'Sprinkler System / 3-Front Right (Near Driveway)' Off
       Irrigation - Cycle Complete
       Send Notification to 'My e-mail' content 'Lawn Sprinklers Stopped'
       Send Notification to 'My e-mail' content 'Lawn Sprinklers Didn't Run'
Hi jmed999,
If you go to Program Summary, is the irrigation program you are referring to set to True? And, what is the last runtime?
All 3 programs were false the last run time (this morning) and it was way over 34 degrees.
Any ideas? Thanks!
The If requires a specific 0.5 inches and only 0.5 inches. Is that what you wanted?
No, I wanted it to be greater than 0.5". Shoot I didn't even see that mistake. That's the problem!
Thanks for your help Lee! Problem solved.
