Irrigation Module Question
At the end of my sprinkler program I added Irrigation - Cycle Complete, which did not seem to do anything. The irrigation requirments were still the same. I had to add Irrigation - Reset Variables to clear the irrigation requirements. What does cycles complete do?
Bob Moore
Mr. Moore,
Are you certain that NOTHING changed? Please note that cycle complete uses the following algorithm:
Absorption Factor * Water Applied per Irrigation Cycle. So, if absorption factor is less than 100%, then the number might be too small for you to notice.
I just made a simple test and it works fine here.
I tested it again and it did change the irrigation requirement.
Bob Moore
