Correct Way To Remove Dead Device
I just had one of my insteon devices completely fail. The ISY-99 can no longer see it and none of the LEDs illuminate. I removed the device from the ISY-99 using the Remove command and it appeared to delete successfully. I then viewed the PLM link table and noticed that the address of the removed device still shows up a few times. Is this expected?
Is there any other way to completely remove a dead device from the ISY-99?
Adam
So there is nothing further that needs to be done?
I just wanted to make sure that successful device communication wasn't necessary to properly remove the device from the ISY / PLM since communication is no longer possible due to the failure.
Adam
