Global Cache IP2IR for stereo av control
arw01
I do not think Houselinc will talk to the global catch at all. Very limited software in a lot of ways.
yes i know but since i cannot use the PLM in israel (we use 220v 50hz and not 110V 60hz) i must use a power converter that blocks all the signals
Some folks here on the forum have for one reason or another deliberately plugged in their PLM into a filterlinc which blocks the wireline signal, relying instead successfully on RF communication between the PLM & access points and/or dual band devices. Is that something that would work for you? The Hub doesn't come anywhere close to the ISY.
Sent from my SPH-D710 using Tapatalk 2
could work.
but i would still need to connect the filterlinc into a power converter to convert 110V to 220V.
wouldnt that disturb the work of the filterlinc ?
i know the HUB is not even close to the ISY
but i know i can use houselinc as the main software and use the HUB just to broadcast the signal.
is the houselinc that bad compared to ISY?
i need to do IF THEN programming and i understand that i can use houselinc to do so,
could work.
Sorry if I wasn't clear enough. You don't need a filterlinc. I was just saying that some people here in the U.S. are using a PLM with a filterlinc which blocks out wireline communication, but the PLM is still communicating perfectly via RF with access points and dual band devices. So I was suggesting that the same might work for you. You mentioned that your 110 to 220 adapter blocked the wireline communication from your PLM, but perhaps your PLM would still be able to communicate via RF.
While I did use a smartlinc of which the hub is a successor, I never used the Houselinc software so I don't know. Others here would know more. But I think the programming in Houslinc is limited to time conditions only.
hi
since version 2.10.08 of houselinc you can add a ITACH device as an INSTEON device.
anyone know how i can configure the IP of the IP2IR and configure ir commands?
thanks
      37.8k
      377.3k
