Weird anomaly on KPL button H?
romeo_echo
Hi All,
Pretty new to the UDI scene (recently upgraded/replaced all my old X10 to Insteon) and only been lurking here for a short while, but I have something that's really bugging me and I need to post my first question... so thanks in advance...
Short version of the question: I have a KPL that, when I reset it to factory and do a Restore Device, 2 of the 3 buttons that I have defined as non-toggle OFF ("D" and "F") work fine, but a third KPL button ("H") defined as non-toggle OFF is not working correctly, it appears to be always set to non-toggle ON.
Programming appears to go successfully. Attached is a log of when I program the KPL.
When I check and compare the ISY links table to the device links table, it appears to be a 100% match (except for the last "ignore" entry).
If I do a factory reset on the KPL, and simply manually toggle the "H" button mode before any programming (by using the "hold-Set-down 3 times method), I can successfully put the "H" button into non-toggle mode, so I have no reason to suspect that the KPL itself is bad...?
However, any time I program it up, the H button appears to now have 3 states I can switch it between: toggle, non-toggle-ON, and another non-toggle ON. If (after programming) I try to manually set the toggle mode of H button, I have to cycle through what are apparently two distinct non-toggle-ON modes before I get back to Toggle mode, which is strange.
I am trying to assign a "whole floor OFF" scene to this H button.
I'm running v3.3.10 across the board on a Mac computer. I have a total of 6 KPL's programmed successfully now, including one other KPL which has an H button that has an "all OFF" non-toggle-OFF button/scene successfully programmed. I have a few Filterlincs in place and programming everything else seems to be going pretty smoothly nowadays.
I have tried removing the H button as a controller for that "floor OFF" scene and re-adding it, but that did not help.
Weird bug in 3.3.10? Broken KPL? Any suggestions would be greatly appreciated, thanks tons!
Ralph
P.S. Hmmm. that's weird, the forum claims I cannot attach a file with a .txt extension so I am pasting the log file below. Sorry for the large paste! Do I have to be authorized to post files?
Sat 02/09/2013 12:44:43 PM : [ 1F 2A C0 1] Preparing Device 'studio_KPL.A_Studio_' for Restore
Sat 02/09/2013 12:44:43 PM : [ 1F 2A C0 1] Device 'studio_KPL.A_Studio_' ready for Full Restore
Sat 02/09/2013 12:44:43 PM : [iNST-TX-I1 ] 02 62 1F 2A C0 0F 0D 00
Sat 02/09/2013 12:44:43 PM : [iNST-ACK ] 02 62 1F.2A.C0 0F 0D 00 06 (00)
Sat 02/09/2013 12:44:43 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 0D 02 (02)
Sat 02/09/2013 12:44:43 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:43 PM : [1F 2A C0 0 ] Calibrating engine version
Sat 02/09/2013 12:44:43 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0
Sat 02/09/2013 12:44:44 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 0D 02 (02)
Sat 02/09/2013 12:44:44 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 02/09/2013 12:44:44 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 00 00 00 01 00 00 00 00 00 00 00 00 D0 06 (00)
Sat 02/09/2013 12:44:44 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:44 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:44 PM : [iNST-ERX ] 02 51 1F 2A C0 21 33 67 11 2F 00 00 01 0F FF 00 A2 28 21 33 67 FF 1F 05 1A
Sat 02/09/2013 12:44:44 PM : [Ext-Direct ] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sat 02/09/2013 12:44:44 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F FF 08 A2 28 21 33 67 FF 1F 05 11
Sat 02/09/2013 12:44:44 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F FF 08 A2 28 21 33 67 FF 1F 05 11 06 (00)
Sat 02/09/2013 12:44:45 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:45 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:45 PM : [MNG-LNK-RSP ] 02 6F 40 E2 28 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:45 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F F7 08 A2 1F 21 33 67 00 1F 08 1E
Sat 02/09/2013 12:44:46 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F F7 08 A2 1F 21 33 67 00 1F 08 1E 06 (00)
Sat 02/09/2013 12:44:46 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:46 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:46 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1F 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:46 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F EF 08 A2 1F 21 33 67 00 1F 07 27
Sat 02/09/2013 12:44:47 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F EF 08 A2 1F 21 33 67 00 1F 07 27 06 (00)
Sat 02/09/2013 12:44:47 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:47 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:47 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1F 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:47 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F E7 08 A2 1E 21 33 67 FF 1F 03 35
Sat 02/09/2013 12:44:48 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F E7 08 A2 1E 21 33 67 FF 1F 03 35 06 (00)
Sat 02/09/2013 12:44:48 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:48 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:48 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1E 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:48 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F DF 08 A2 1D 21 33 67 FF 1F 02 3F
Sat 02/09/2013 12:44:49 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F DF 08 A2 1D 21 33 67 FF 1F 02 3F 06 (00)
Sat 02/09/2013 12:44:49 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:49 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:49 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1D 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:49 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F D7 08 A2 1C 21 33 67 00 1F 03 46
Sat 02/09/2013 12:44:50 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F D7 08 A2 1C 21 33 67 00 1F 03 46 06 (00)
Sat 02/09/2013 12:44:50 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:50 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:50 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1C 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:50 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F CF 08 A2 1C 21 33 67 00 1F 02 4F
Sat 02/09/2013 12:44:51 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F CF 08 A2 1C 21 33 67 00 1F 02 4F 06 (00)
Sat 02/09/2013 12:44:51 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:51 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:51 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1C 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:51 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F C7 08 A2 1B 21 33 67 FF 1F 03 58
Sat 02/09/2013 12:44:52 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F C7 08 A2 1B 21 33 67 FF 1F 03 58 06 (00)
Sat 02/09/2013 12:44:52 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:52 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:52 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1B 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:52 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F BF 08 A2 1B 21 33 67 FF 1F 02 61
Sat 02/09/2013 12:44:53 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F BF 08 A2 1B 21 33 67 FF 1F 02 61 06 (00)
Sat 02/09/2013 12:44:53 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:53 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:53 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1B 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:53 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F B7 08 A2 16 21 33 67 FF 1F 07 69
Sat 02/09/2013 12:44:54 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F B7 08 A2 16 21 33 67 FF 1F 07 69 06 (00)
Sat 02/09/2013 12:44:54 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:54 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:54 PM : [MNG-LNK-RSP ] 02 6F 40 E2 16 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:54 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F AF 08 A2 14 21 33 67 FF 1F 07 73
Sat 02/09/2013 12:44:55 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F AF 08 A2 14 21 33 67 FF 1F 07 73 06 (00)
Sat 02/09/2013 12:44:55 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:55 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:55 PM : [MNG-LNK-RSP ] 02 6F 40 E2 14 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:55 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F A7 08 A2 12 21 33 67 FF 1F 07 7D
Sat 02/09/2013 12:44:56 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F A7 08 A2 12 21 33 67 FF 1F 07 7D 06 (00)
Sat 02/09/2013 12:44:56 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:56 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:56 PM : [MNG-LNK-RSP ] 02 6F 40 E2 12 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:56 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 9F 08 A2 11 21 33 67 00 1B 08 88
Sat 02/09/2013 12:44:57 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 9F 08 A2 11 21 33 67 00 1B 08 88 06 (00)
Sat 02/09/2013 12:44:57 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:57 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:57 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:57 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 97 08 A2 11 21 33 67 00 1B 07 91
Sat 02/09/2013 12:44:58 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 97 08 A2 11 21 33 67 00 1B 07 91 06 (00)
Sat 02/09/2013 12:44:58 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:58 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:58 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:58 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 8F 08 A2 11 21 33 67 00 1B 06 9A
Sat 02/09/2013 12:44:59 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 8F 08 A2 11 21 33 67 00 1B 06 9A 06 (00)
Sat 02/09/2013 12:44:59 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:44:59 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:44:59 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:44:59 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 87 08 A2 11 21 33 67 00 1B 05 A3
Sat 02/09/2013 12:45:00 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 87 08 A2 11 21 33 67 00 1B 05 A3 06 (00)
Sat 02/09/2013 12:45:00 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:00 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:00 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:00 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 7F 08 A2 11 21 33 67 00 1B 04 AC
Sat 02/09/2013 12:45:01 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 7F 08 A2 11 21 33 67 00 1B 04 AC 06 (00)
Sat 02/09/2013 12:45:01 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:01 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:01 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:01 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 77 08 A2 11 21 33 67 00 1B 03 B5
Sat 02/09/2013 12:45:02 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 77 08 A2 11 21 33 67 00 1B 03 B5 06 (00)
Sat 02/09/2013 12:45:02 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:02 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:02 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:02 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 6F 08 A2 11 21 33 67 00 1B 02 BE
Sat 02/09/2013 12:45:03 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 6F 08 A2 11 21 33 67 00 1B 02 BE 06 (00)
Sat 02/09/2013 12:45:03 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:03 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:03 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:03 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 67 08 A2 08 1F 29 94 00 1F 08 A4
Sat 02/09/2013 12:45:04 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 67 08 A2 08 1F 29 94 00 1F 08 A4 06 (00)
Sat 02/09/2013 12:45:04 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:04 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:04 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 5F 08 A2 08 1F 29 94 00 1F 07 AD
Sat 02/09/2013 12:45:04 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 5F 08 A2 08 1F 29 94 00 1F 07 AD 06 (00)
Sat 02/09/2013 12:45:05 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:05 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:05 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 57 08 A2 08 1F 29 94 00 1F 06 B6
Sat 02/09/2013 12:45:05 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 57 08 A2 08 1F 29 94 00 1F 06 B6 06 (00)
Sat 02/09/2013 12:45:06 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:06 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:06 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 4F 08 A2 08 1F 29 94 00 1F 05 BF
Sat 02/09/2013 12:45:06 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 4F 08 A2 08 1F 29 94 00 1F 05 BF 06 (00)
Sat 02/09/2013 12:45:06 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00)
Sat 02/09/2013 12:45:06 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 02/09/2013 12:45:06 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 47 08 A2 08 1F 29 94 00 1F 04 C8
Sat 02/09/2013 12:45:06 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 47 08 A2 08 1F 29 94 00 1F 04 C8 06 (00)
Sat 02/09/2013 12:45:06 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 3F 08 A2 08 1F 29 94 00 1F 03 D1
Sat 02/09/2013 12:45:07 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 3F 08 A2 08 1F 29 94 00 1F 03 D1 06 (00)
Sat 02/09/2013 12:45:07 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:07 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:07 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 37 08 A2 08 1F 29 94 00 1F 02 DA
Sat 02/09/2013 12:45:07 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 37 08 A2 08 1F 29 94 00 1F 02 DA 06 (00)
Sat 02/09/2013 12:45:08 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:08 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:08 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 2F 08 A2 06 1F 2D 18 FF 1F 05 5A
Sat 02/09/2013 12:45:08 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 2F 08 A2 06 1F 2D 18 FF 1F 05 5A 06 (00)
Sat 02/09/2013 12:45:08 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 27 08 A2 06 1F 2C C1 FF 1F 05 BA
Sat 02/09/2013 12:45:08 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 27 08 A2 06 1F 2C C1 FF 1F 05 BA 06 (00)
Sat 02/09/2013 12:45:09 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:09 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:09 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 1F 08 A2 05 1F 2D 18 FF 1F 03 6D
Sat 02/09/2013 12:45:09 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 1F 08 A2 05 1F 2D 18 FF 1F 03 6D 06 (00)
Sat 02/09/2013 12:45:10 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:10 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:10 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 17 08 A2 05 1F 2D 18 FF 1F 02 76
Sat 02/09/2013 12:45:10 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 17 08 A2 05 1F 2D 18 FF 1F 02 76 06 (00)
Sat 02/09/2013 12:45:10 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 0F 08 A2 05 1F 2C C1 FF 1F 03 D5
Sat 02/09/2013 12:45:10 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 0F 08 A2 05 1F 2C C1 FF 1F 03 D5 06 (00)
Sat 02/09/2013 12:45:11 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:11 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:11 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0F 07 08 A2 05 1F 2C C1 FF 1F 02 DE
Sat 02/09/2013 12:45:11 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0F 07 08 A2 05 1F 2C C1 FF 1F 02 DE 06 (00)
Sat 02/09/2013 12:45:12 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:12 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:12 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E FF 08 A2 04 1C 3F A4 FF 1F 07 F0
Sat 02/09/2013 12:45:12 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E FF 08 A2 04 1C 3F A4 FF 1F 07 F0 06 (00)
Sat 02/09/2013 12:45:12 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E F7 08 A2 03 1F 29 94 FF 1F 07 1C
Sat 02/09/2013 12:45:12 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E F7 08 A2 03 1F 29 94 FF 1F 07 1C 06 (00)
Sat 02/09/2013 12:45:13 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00)
Sat 02/09/2013 12:45:13 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 02/09/2013 12:45:13 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E EF 08 A2 02 1F 29 94 FF 1F 07 25
Sat 02/09/2013 12:45:13 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E EF 08 A2 02 1F 29 94 FF 1F 07 25 06 (00)
Sat 02/09/2013 12:45:13 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:13 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:13 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E E7 08 A2 02 1C 3F A4 FF 1F 07 0A
Sat 02/09/2013 12:45:13 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E E7 08 A2 02 1C 3F A4 FF 1F 07 0A 06 (00)
Sat 02/09/2013 12:45:14 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:14 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:14 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E DF 08 A2 01 1F 29 94 FF 1F 07 36
Sat 02/09/2013 12:45:14 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00)
Sat 02/09/2013 12:45:14 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 02/09/2013 12:45:23 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E DF 08 A2 01 1F 29 94 FF 1F 07 36
Sat 02/09/2013 12:45:23 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E DF 08 A2 01 1F 29 94 FF 1F 07 36 06 (00)
Sat 02/09/2013 12:45:24 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:24 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:24 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E D7 08 A2 01 1C 3F A4 FF 1F 07 1B
Sat 02/09/2013 12:45:24 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E D7 08 A2 01 1C 3F A4 FF 1F 07 1B 06 (00)
Sat 02/09/2013 12:45:25 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:25 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:25 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E CF 08 A2 00 21 33 67 FF 1F 05 6A
Sat 02/09/2013 12:45:25 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E CF 08 A2 00 21 33 67 FF 1F 05 6A 06 (00)
Sat 02/09/2013 12:45:25 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:25 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E C7 08 A2 1C 21 33 67 00 1F 01 59
Sat 02/09/2013 12:45:26 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E C7 08 A2 1C 21 33 67 00 1F 01 59 06 (00)
Sat 02/09/2013 12:45:26 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:26 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:26 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1C 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:26 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E BF 08 A2 1B 21 33 67 FF 1F 01 63
Sat 02/09/2013 12:45:27 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E BF 08 A2 1B 21 33 67 FF 1F 01 63 06 (00)
Sat 02/09/2013 12:45:27 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:27 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:27 PM : [MNG-LNK-RSP ] 02 6F 40 E2 1B 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:27 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E B7 08 A2 11 21 33 67 00 1B 01 78
Sat 02/09/2013 12:45:28 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E B7 08 A2 11 21 33 67 00 1B 01 78 06 (00)
Sat 02/09/2013 12:45:28 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:28 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:29 PM : [MNG-LNK-RSP ] 02 6F 40 E2 11 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:29 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E AF 08 A2 08 1F 29 94 00 1F 01 64
Sat 02/09/2013 12:45:29 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E AF 08 A2 08 1F 29 94 00 1F 01 64 06 (00)
Sat 02/09/2013 12:45:29 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:29 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:29 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E A7 08 A2 05 1F 2D 18 FF 1F 01 E8
Sat 02/09/2013 12:45:29 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E A7 08 A2 05 1F 2D 18 FF 1F 01 E8 06 (00)
Sat 02/09/2013 12:45:30 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:30 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:30 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 9F 08 A2 05 1F 2C C1 FF 1F 01 48
Sat 02/09/2013 12:45:30 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 9F 08 A2 05 1F 2C C1 FF 1F 01 48 06 (00)
Sat 02/09/2013 12:45:31 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:31 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:31 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 97 08 A2 00 21 33 67 FF 1F 01 A6
Sat 02/09/2013 12:45:31 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 97 08 A2 00 21 33 67 FF 1F 01 A6 06 (00)
Sat 02/09/2013 12:45:32 PM : [MNG-LNK-RSP ] 02 6F 40 E2 00 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:32 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 8F 08 E2 01 1A EA AD FF 1F 01 77
Sat 02/09/2013 12:45:32 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 8F 08 E2 01 1A EA AD FF 1F 01 77 06 (00)
Sat 02/09/2013 12:45:32 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:32 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:32 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 87 08 E2 01 1A F5 20 FF 1F 01 01
Sat 02/09/2013 12:45:32 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 87 08 E2 01 1A F5 20 FF 1F 01 01 06 (00)
Sat 02/09/2013 12:45:33 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:33 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:33 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 7F 08 E2 01 1F 2C C1 FF 1F 01 2C
Sat 02/09/2013 12:45:33 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 7F 08 E2 01 1F 2C C1 FF 1F 01 2C 06 (00)
Sat 02/09/2013 12:45:34 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:34 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:34 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 77 08 E2 01 1F 2D 18 FF 1F 01 DC
Sat 02/09/2013 12:45:34 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 77 08 E2 01 1F 2D 18 FF 1F 01 DC 06 (00)
Sat 02/09/2013 12:45:35 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:35 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:35 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 6F 08 E2 01 21 33 67 FF 1F 01 8D
Sat 02/09/2013 12:45:35 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 6F 08 E2 01 21 33 67 FF 1F 01 8D 06 (00)
Sat 02/09/2013 12:45:35 PM : [MNG-LNK-RSP ] 02 6F 41 A2 01 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:35 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 67 08 E2 02 1A EA AD FF 1F 02 9D
Sat 02/09/2013 12:45:35 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00)
Sat 02/09/2013 12:45:35 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 02/09/2013 12:45:36 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 67 08 E2 02 1A EA AD FF 1F 02 9D 06 (00)
Sat 02/09/2013 12:45:36 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:36 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:36 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 5F 08 E2 02 21 33 67 FF 1F 02 9B
Sat 02/09/2013 12:45:36 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 5F 08 E2 02 21 33 67 FF 1F 02 9B 06 (00)
Sat 02/09/2013 12:45:37 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:37 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:37 PM : [MNG-LNK-RSP ] 02 6F 41 A2 02 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:37 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 57 08 E2 03 1A F5 20 FF 1F 03 2D
Sat 02/09/2013 12:45:37 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 57 08 E2 03 1A F5 20 FF 1F 03 2D 06 (00)
Sat 02/09/2013 12:45:38 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:38 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:38 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 4F 08 E2 03 21 33 67 FF 1F 03 A9
Sat 02/09/2013 12:45:38 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 4F 08 E2 03 21 33 67 FF 1F 03 A9 06 (00)
Sat 02/09/2013 12:45:39 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:39 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:39 PM : [MNG-LNK-RSP ] 02 6F 41 A2 03 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:39 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 47 08 E2 04 21 33 67 FF 1F 04 AF
Sat 02/09/2013 12:45:39 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 47 08 E2 04 21 33 67 FF 1F 04 AF 06 (00)
Sat 02/09/2013 12:45:40 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:40 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:40 PM : [MNG-LNK-RSP ] 02 6F 41 A2 04 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:40 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 3F 08 E2 05 1A F5 87 FF 1F 05 DA
Sat 02/09/2013 12:45:40 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 3F 08 E2 05 1A F5 87 FF 1F 05 DA 06 (00)
Sat 02/09/2013 12:45:41 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:41 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:41 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 37 08 E2 05 1F 2C C1 FF 1F 05 6C
Sat 02/09/2013 12:45:41 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 37 08 E2 05 1F 2C C1 FF 1F 05 6C 06 (00)
Sat 02/09/2013 12:45:41 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 2F 08 E2 05 1F 2D 18 FF 1F 05 1C
Sat 02/09/2013 12:45:41 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 2F 08 E2 05 1F 2D 18 FF 1F 05 1C 06 (00)
Sat 02/09/2013 12:45:42 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:42 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:42 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 27 08 E2 05 21 33 67 FF 1F 05 CD
Sat 02/09/2013 12:45:42 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 27 08 E2 05 21 33 67 FF 1F 05 CD 06 (00)
Sat 02/09/2013 12:45:43 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:43 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:43 PM : [MNG-LNK-RSP ] 02 6F 41 A2 05 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:43 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 1F 08 E2 06 21 33 67 FF 1F 06 D3
Sat 02/09/2013 12:45:43 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 1F 08 E2 06 21 33 67 FF 1F 06 D3 06 (00)
Sat 02/09/2013 12:45:44 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:44 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:44 PM : [MNG-LNK-RSP ] 02 6F 41 A2 06 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:44 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 17 08 E2 07 1A EA A7 FF 1F 07 E9
Sat 02/09/2013 12:45:44 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 17 08 E2 07 1A EA A7 FF 1F 07 E9 06 (00)
Sat 02/09/2013 12:45:45 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:45 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:45 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 0F 08 E2 07 1A F4 4F FF 1F 07 3F
Sat 02/09/2013 12:45:45 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 0F 08 E2 07 1A F4 4F FF 1F 07 3F 06 (00)
Sat 02/09/2013 12:45:46 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:46 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:46 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0E 07 08 E2 07 1A F5 66 FF 1F 07 2F
Sat 02/09/2013 12:45:46 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0E 07 08 E2 07 1A F5 66 FF 1F 07 2F 06 (00)
Sat 02/09/2013 12:45:46 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D FF 08 E2 07 1A F5 AD FF 1F 07 F1
Sat 02/09/2013 12:45:46 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D FF 08 E2 07 1A F5 AD FF 1F 07 F1 06 (00)
Sat 02/09/2013 12:45:46 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00)
Sat 02/09/2013 12:45:46 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 02/09/2013 12:45:46 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D F7 08 E2 07 1A F5 BC FF 1F 07 EA
Sat 02/09/2013 12:45:47 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D F7 08 E2 07 1A F5 BC FF 1F 07 EA 06 (00)
Sat 02/09/2013 12:45:47 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:47 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:47 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D EF 08 E2 07 1A F7 CB FF 1F 07 E1
Sat 02/09/2013 12:45:47 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D EF 08 E2 07 1A F7 CB FF 1F 07 E1 06 (00)
Sat 02/09/2013 12:45:48 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:48 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:48 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D E7 08 E2 07 1D 0B 75 FF 1F 07 28
Sat 02/09/2013 12:45:48 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D E7 08 E2 07 1D 0B 75 FF 1F 07 28 06 (00)
Sat 02/09/2013 12:45:48 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D DF 08 E2 07 1D 0B 81 FF 1F 07 24
Sat 02/09/2013 12:45:48 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D DF 08 E2 07 1D 0B 81 FF 1F 07 24 06 (00)
Sat 02/09/2013 12:45:49 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:49 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:49 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D D7 08 E2 07 1D 0E 39 FF 1F 07 71
Sat 02/09/2013 12:45:49 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D D7 08 E2 07 1D 0E 39 FF 1F 07 71 06 (00)
Sat 02/09/2013 12:45:50 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:50 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:50 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D CF 08 E2 07 1D 0F 5E FF 1F 07 53
Sat 02/09/2013 12:45:50 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D CF 08 E2 07 1D 0F 5E FF 1F 07 53 06 (00)
Sat 02/09/2013 12:45:50 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D C7 08 E2 07 1D 0F 7A FF 1F 07 3F
Sat 02/09/2013 12:45:50 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D C7 08 E2 07 1D 0F 7A FF 1F 07 3F 06 (00)
Sat 02/09/2013 12:45:51 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:51 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:51 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D BF 08 E2 07 1D 10 3E FF 1F 07 82
Sat 02/09/2013 12:45:51 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D BF 08 E2 07 1D 10 3E FF 1F 07 82 06 (00)
Sat 02/09/2013 12:45:52 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:52 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:52 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D B7 08 E2 07 1F 29 94 FF 1F 07 19
Sat 02/09/2013 12:45:52 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D B7 08 E2 07 1F 29 94 FF 1F 07 19 06 (00)
Sat 02/09/2013 12:45:52 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D AF 08 E2 07 1F 2C C1 FF 1F 07 F1
Sat 02/09/2013 12:45:52 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D AF 08 E2 07 1F 2C C1 FF 1F 07 F1 06 (00)
Sat 02/09/2013 12:45:53 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:53 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:53 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D A7 08 E2 07 21 33 67 FF 1F 07 4A
Sat 02/09/2013 12:45:53 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D A7 08 E2 07 21 33 67 FF 1F 07 4A 06 (00)
Sat 02/09/2013 12:45:54 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:54 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:54 PM : [MNG-LNK-RSP ] 02 6F 41 A2 07 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:45:54 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 9F 08 E2 08 1A EA A7 FF 1F 08 60
Sat 02/09/2013 12:45:54 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00)
Sat 02/09/2013 12:45:54 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 02/09/2013 12:45:54 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 9F 08 E2 08 1A EA A7 FF 1F 08 60 06 (00)
Sat 02/09/2013 12:45:55 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:55 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:55 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 97 08 E2 08 1A F4 4F FF 1F 08 B6
Sat 02/09/2013 12:45:55 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 97 08 E2 08 1A F4 4F FF 1F 08 B6 06 (00)
Sat 02/09/2013 12:45:55 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 8F 08 E2 08 1A F4 7A FF 1F 08 93
Sat 02/09/2013 12:45:55 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 8F 08 E2 08 1A F4 7A FF 1F 08 93 06 (00)
Sat 02/09/2013 12:45:56 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:56 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:56 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 87 08 E2 08 1A F4 95 FF 1F 08 80
Sat 02/09/2013 12:45:56 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 87 08 E2 08 1A F4 95 FF 1F 08 80 06 (00)
Sat 02/09/2013 12:45:57 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:57 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:57 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 7F 08 E2 08 1A F5 66 FF 1F 08 B6
Sat 02/09/2013 12:45:57 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 7F 08 E2 08 1A F5 66 FF 1F 08 B6 06 (00)
Sat 02/09/2013 12:45:57 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 77 08 E2 08 1A F5 AD FF 1F 08 77
Sat 02/09/2013 12:45:57 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 77 08 E2 08 1A F5 AD FF 1F 08 77 06 (00)
Sat 02/09/2013 12:45:58 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:58 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:58 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 6F 08 E2 08 1A F5 BC FF 1F 08 70
Sat 02/09/2013 12:45:58 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 6F 08 E2 08 1A F5 BC FF 1F 08 70 06 (00)
Sat 02/09/2013 12:45:59 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:45:59 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:45:59 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 67 08 E2 08 1A F6 34 FF 1F 08 FF
Sat 02/09/2013 12:45:59 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 67 08 E2 08 1A F6 34 FF 1F 08 FF 06 (00)
Sat 02/09/2013 12:45:59 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 5F 08 E2 08 1A F7 0E FF 1F 08 2C
Sat 02/09/2013 12:45:59 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 5F 08 E2 08 1A F7 0E FF 1F 08 2C 06 (00)
Sat 02/09/2013 12:46:00 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:00 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:00 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 57 08 E2 08 1A F7 C7 FF 1F 08 7B
Sat 02/09/2013 12:46:00 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 57 08 E2 08 1A F7 C7 FF 1F 08 7B 06 (00)
Sat 02/09/2013 12:46:01 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 27 2F 00 (00)
Sat 02/09/2013 12:46:01 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=1
Sat 02/09/2013 12:46:01 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 4F 08 E2 08 1A F7 CB FF 1F 08 7F
Sat 02/09/2013 12:46:01 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 4F 08 E2 08 1A F7 CB FF 1F 08 7F 06 (00)
Sat 02/09/2013 12:46:02 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:02 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:02 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 47 08 E2 08 1A F9 7B FF 1F 08 D5
Sat 02/09/2013 12:46:02 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 47 08 E2 08 1A F9 7B FF 1F 08 D5 06 (00)
Sat 02/09/2013 12:46:02 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00)
Sat 02/09/2013 12:46:02 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 02/09/2013 12:46:02 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 3F 08 E2 08 1A FA 3D FF 1F 08 1A
Sat 02/09/2013 12:46:02 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 3F 08 E2 08 1A FA 3D FF 1F 08 1A 06 (00)
Sat 02/09/2013 12:46:02 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 37 08 E2 08 1D 0B 75 FF 1F 08 D6
Sat 02/09/2013 12:46:03 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 37 08 E2 08 1D 0B 75 FF 1F 08 D6 06 (00)
Sat 02/09/2013 12:46:03 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:03 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:03 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 2F 08 E2 08 1D 0B 81 FF 1F 08 D2
Sat 02/09/2013 12:46:04 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:04 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:13 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 2F 08 E2 08 1D 0B 81 FF 1F 08 D2
Sat 02/09/2013 12:46:13 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 2F 08 E2 08 1D 0B 81 FF 1F 08 D2 06 (00)
Sat 02/09/2013 12:46:13 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:13 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:13 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 27 08 E2 08 1D 0E 39 FF 1F 08 1F
Sat 02/09/2013 12:46:13 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 27 08 E2 08 1D 0E 39 FF 1F 08 1F 06 (00)
Sat 02/09/2013 12:46:14 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:14 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:14 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 1F 08 E2 08 1D 0F 5E FF 1F 08 01
Sat 02/09/2013 12:46:14 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 1F 08 E2 08 1D 0F 5E FF 1F 08 01 06 (00)
Sat 02/09/2013 12:46:14 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 17 08 E2 08 1D 0F 7A FF 1F 08 ED
Sat 02/09/2013 12:46:14 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 17 08 E2 08 1D 0F 7A FF 1F 08 ED 06 (00)
Sat 02/09/2013 12:46:15 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:15 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:15 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 0F 08 E2 08 1D 10 3E FF 1F 08 30
Sat 02/09/2013 12:46:15 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 0F 08 E2 08 1D 10 3E FF 1F 08 30 06 (00)
Sat 02/09/2013 12:46:16 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:16 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:16 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0D 07 08 E2 08 1D F4 0B FF 1F 08 87
Sat 02/09/2013 12:46:16 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0D 07 08 E2 08 1D F4 0B FF 1F 08 87 06 (00)
Sat 02/09/2013 12:46:17 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:17 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:17 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C FF 08 E2 08 1F 29 94 FF 1F 08 D0
Sat 02/09/2013 12:46:17 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C FF 08 E2 08 1F 29 94 FF 1F 08 D0 06 (00)
Sat 02/09/2013 12:46:17 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C F7 08 E2 08 1F 2C C1 FF 1F 08 A8
Sat 02/09/2013 12:46:17 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C F7 08 E2 08 1F 2C C1 FF 1F 08 A8 06 (00)
Sat 02/09/2013 12:46:18 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:18 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:18 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C EF 08 E2 08 1F 2C D6 FF 1F 08 9B
Sat 02/09/2013 12:46:18 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C EF 08 E2 08 1F 2C D6 FF 1F 08 9B 06 (00)
Sat 02/09/2013 12:46:19 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:19 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:19 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C E7 08 E2 08 1F 2D 18 FF 1F 08 60
Sat 02/09/2013 12:46:19 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C E7 08 E2 08 1F 2D 18 FF 1F 08 60 06 (00)
Sat 02/09/2013 12:46:19 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C DF 08 E2 08 21 33 67 FF 1F 08 11
Sat 02/09/2013 12:46:19 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C DF 08 E2 08 21 33 67 FF 1F 08 11 06 (00)
Sat 02/09/2013 12:46:20 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2F 00 (00)
Sat 02/09/2013 12:46:20 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 02/09/2013 12:46:20 PM : [MNG-LNK-RSP ] 02 6F 41 A2 08 1F 2A C0 01 1C 41 15
Sat 02/09/2013 12:46:20 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C D7 08 00 00 00 00 00 00 00 00 E4
Sat 02/09/2013 12:46:20 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:20 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:20 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C D7 08 00 00 00 00 00 00 00 00 E4 06 (00)
Sat 02/09/2013 12:46:21 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:21 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:21 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 00 0C CF 01 00 00 00 00 00 00 00 00 F5
Sat 02/09/2013 12:46:21 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 00 0C CF 01 00 00 00 00 00 00 00 00 F5 06 (00)
Sat 02/09/2013 12:46:22 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:22 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:22 PM : [iNST-ERX ] 02 51 1F 2A C0 21 33 67 11 2F 00 00 01 0C CF 00 00 00 00 00 00 00 00 00 F5
Sat 02/09/2013 12:46:22 PM : [Ext-Direct ] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sat 02/09/2013 12:46:22 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 00 0C CF 01 00 00 00 00 00 00 00 00 F5
Sat 02/09/2013 12:46:22 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 00 0C CF 01 00 00 00 00 00 00 00 00 F5 06 (00)
Sat 02/09/2013 12:46:23 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:23 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:23 PM : [iNST-ERX ] 02 51 1F 2A C0 21 33 67 11 2F 00 00 01 0C CF 00 00 00 00 00 00 00 00 00 F5
Sat 02/09/2013 12:46:23 PM : [Ext-Direct ] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=1, Hops Left=0
Sat 02/09/2013 12:46:23 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2F 00 00 02 0C CF 08 00 00 00 00 00 00 00 00 EC
Sat 02/09/2013 12:46:23 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2F 00 00 02 0C CF 08 00 00 00 00 00 00 00 00 EC 06 (00)
Sat 02/09/2013 12:46:24 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2F 00 (00)
Sat 02/09/2013 12:46:24 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:24 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 08 06 00 00 00 00 00 00 00 00 00 00 00 C4
Sat 02/09/2013 12:46:24 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 08 06 00 00 00 00 00 00 00 00 00 00 00 C4 06 (00)
Sat 02/09/2013 12:46:24 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00)
Sat 02/09/2013 12:46:24 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 08 05 1F 00 00 00 00 00 00 00 00 00 00 A6
Sat 02/09/2013 12:46:24 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 08 05 1F 00 00 00 00 00 00 00 00 00 00 A6 06 (00)
Sat 02/09/2013 12:46:25 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00)
Sat 02/09/2013 12:46:25 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:25 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 06 FF 00 00 00 00 00 00 00 00 00 00 CC
Sat 02/09/2013 12:46:25 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 06 FF 00 00 00 00 00 00 00 00 00 00 CC 06 (00)
Sat 02/09/2013 12:46:25 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2E 00 (00)
Sat 02/09/2013 12:46:25 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 02/09/2013 12:46:25 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 05 1F 00 00 00 00 00 00 00 00 00 00 AD
Sat 02/09/2013 12:46:25 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 05 1F 00 00 00 00 00 00 00 00 00 00 AD 06 (00)
Sat 02/09/2013 12:46:26 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00)
Sat 02/09/2013 12:46:26 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:26 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 07 7F 00 00 00 00 00 00 00 00 00 00 4B
Sat 02/09/2013 12:46:26 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 07 7F 00 00 00 00 00 00 00 00 00 00 4B 06 (00)
Sat 02/09/2013 12:46:26 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 0B 51 00 00 00 00 00 00 00 00 00 00 75
Sat 02/09/2013 12:46:27 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00)
Sat 02/09/2013 12:46:27 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:36 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 0B 51 00 00 00 00 00 00 00 00 00 00 75
Sat 02/09/2013 12:46:36 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 0B 51 00 00 00 00 00 00 00 00 00 00 75 06 (00)
Sat 02/09/2013 12:46:37 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00)
Sat 02/09/2013 12:46:37 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:37 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 08 03 40 00 00 00 00 00 00 00 00 00 00 87
Sat 02/09/2013 12:46:37 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 08 03 40 00 00 00 00 00 00 00 00 00 00 87 06 (00)
Sat 02/09/2013 12:46:37 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 08 A8 00 00 00 00 00 00 00 00 00 00 21
Sat 02/09/2013 12:46:37 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 08 A8 00 00 00 00 00 00 00 00 00 00 21 06 (00)
Sat 02/09/2013 12:46:38 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00)
Sat 02/09/2013 12:46:38 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:38 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 08 02 00 00 00 00 00 00 00 00 00 00 00 C8
Sat 02/09/2013 12:46:38 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 08 02 00 00 00 00 00 00 00 00 00 00 00 C8 06 (00)
Sat 02/09/2013 12:46:39 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00)
Sat 02/09/2013 12:46:39 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:39 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 02 06 00 00 00 00 00 00 00 00 00 00 C9
Sat 02/09/2013 12:46:39 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 02 06 00 00 00 00 00 00 00 00 00 00 C9 06 (00)
Sat 02/09/2013 12:46:39 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 06 FF 00 00 00 00 00 00 00 00 00 00 CC
Sat 02/09/2013 12:46:39 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 06 FF 00 00 00 00 00 00 00 00 00 00 CC 06 (00)
Sat 02/09/2013 12:46:39 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 23 2E 00 (00)
Sat 02/09/2013 12:46:39 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=0
Sat 02/09/2013 12:46:39 PM : [iNST-TX-I2CS] 02 62 1F 2A C0 1F 2E 00 01 05 1F 00 00 00 00 00 00 00 00 00 00 AD
Sat 02/09/2013 12:46:40 PM : [iNST-ACK ] 02 62 1F.2A.C0 1F 2E 00 01 05 1F 00 00 00 00 00 00 00 00 00 00 AD 06 (00)
Sat 02/09/2013 12:46:40 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00)
Sat 02/09/2013 12:46:40 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:40 PM : [iNST-TX-I1 ] 02 62 1F 2A C0 0F 24 00
Sat 02/09/2013 12:46:40 PM : [iNST-ACK ] 02 62 1F.2A.C0 0F 24 00 06 (00)
Sat 02/09/2013 12:46:41 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 2E 00 (00)
Sat 02/09/2013 12:46:41 PM : [std-Direct Ack] 1F.2A.C0-->ISY/PLM Group=0, Max Hops=3, Hops Left=2
Sat 02/09/2013 12:46:41 PM : [iNST-SRX ] 02 50 1F.2A.C0 21.33.67 2B 24 00 (00)
Ralph, just a stab in the dark, try right clicking on the node in the tree and choose diagnostics, querry insteon engine. Then try setting the button again for it's mode.
Does the ISY show it as a 8 button device or a 6 button device in the tree?
Hi there and thanks for replying,
KPL definitely shows 8 button: KPL%20pic%201.jpg
Did as you suggested, and the button H went from Toggle-mode (which I had manually set) back to non-toggle-ON:
Welcome to any other suggestions. It's such a minor thing, I can manually set it to Toggle mode and that's almost as good, but it just seems.. well, it annoys me :)
Ralph
If it helps, here are 3 mini-logs, one for when I set the button to Toggle, another when I set it to non-toggle-ON, and another when I set it to non-toggle-OFF.
https://dl.dropbox.com/u/18937746/1_setting_to_Toggle.txt
https://dl.dropbox.com/u/18937746/2_setting_to_non-toggle-ON.txt
https://dl.dropbox.com/u/18937746/3_setting_to_non-toggle-OFF.txt
I'm guessing these look "normal", since I can see a difference between file #2 and file #3.... however, to recap, setting the button H to either non-toggle-ON or non-toggle-OFF results in behavior at the KPL of non-toggle-ON. I cannot achieve a button state of non-toggle-OFF via my ISY 3.3.10 interface running on my Mac...
Ralph
Hi Ralph,
Quite strange indeed.
To recap:
1. Factory reset
2. Program button H to non-toggle-off
3. Add it to a scene (or any other type of programming) and then it goes back to non-toggle-on
If this is accurate, can you tell me whether or not you have other buttons from the same KPL in the scene.
We had reports (by johnnyt) of KPL v36 having button H corrupted as well. Just want to figure out whether or not there are any relationships:
viewtopic.php?f=25&t=10662
More data. I have a brand new 6 button v.41 switch that I just installed and i'm seeing the same behavior when programmed through the current release. The button says it is programmed non-toggle off via the admin console but it is in non-toggle on mode when used (and ISY sees an ON not an OFF). I've reset it quite a few times now with the same results. So suspect either a firmware change or a bug in the release effecting this. If there are tests I can run, happy to do so.
Bill
Hello Michel and thanks for your response,
Yes, that's more or less correct. After a factory reset, but before any programming, I could set button H to non-toggle-OFF. But after programming it up, when ISY was showing it as a controller of scene, and ISY showing mode as non-toggle-OFF, it would act as a non-toggle-ON.
JohnnyT's problem does sound remarkably similar.
However, I think I fixed it. I think there might still be a bug in the software though; I was able to reproduce the problem once, but now using the same steps I cannot.
Here's what I did to make it work:
1. remove H from all scenes (it was a controller for one scene and a responder for another)
2. factory reset
3. restore KPL (other buttons besides H are still scene members/controllers)
4. set H to non-toggle-OFF via software. Non-toggle-OFF works correctly.
5. add H to scene as controller
6. Non-toggle-OFF still working!
Now, I was able to break it -- just once -- by doing the following, after the above steps were completed: I went to the scene, and adjusted the "On Level" of the H button to "Off". This caused the button's behavior to flip to non-toggle-ON and stay there. Again, I was able to do this only once; I have tried to recreate this behavior two more times now, but the H button is staying in non-toggle-OFF mode... thankfully!
Trying to switch the "On Level" of the H button to Off (within the scene) makes sense from an intuitive standpoint - if I'm looking at an "All Off" scene, it's an easy visual check to see that all devices are "Off". However, strictly speaking, it does not matter whether the state of "H" is On or Off in the scene, since it has been set to be a non-toggle-OFF button anyway.
Anyway, not sure if there's a minor bug in the software that could use fixing, or if there was some type of scene corruption due to buggy communications maybe? Not a high priority for me since it's fixed now! It's just a little odd to me that the ISY software was apparently showing everything in the correct state, and yet a factory reset/restore does not resolve the issue... I don't mind performing a little voodoo-jiu-jitsu to get things working, but it would be nicer if I didn't have to... of course...
Any suggestions as to what I might have been doing wrong would be most welcome. Apparently the trick is to set the Toggle mode of the button before adding it to any scenes? Maybe? I wish I could do a better job of reproducing the problem now!
Anyway, thanks all for your time and consideration, I hope this info might help someone else...
Ralph
P.S. when I try to attach a file of type TXT, I'm still getting the message "The extension txt is not allowed." I would love to be able to upload files, can anyone tell me what's wrong? Do I have to be approved for uploading files?
Thanks again...
Hi Ralph,
To recap:
1. Factory reset
Hi Ralph,
Thanks so very much for the details. At the moment, I really do not know what to suggest since we have not been able to reproduce it at all here. So, there might be some intermittent bug somewhere that we would need to track down.
We did increase the storage and you are correct: .txt is not allowed. I shall have it reported immediately.
Hi Ralph,
I think I'm seeing this too on a 6 button. I can not set the D button to always off. I think the issue was found in another thread, putting the button into a scene as a responder and setting its On level to 0 (it was for a fanlinc scene) seems to have caused it. It says is ISY always off but instead is always lit up and always generates an ON.
Just one more note. FYI only. I experienced this problem again, with Button H this time as well.
This happened on a completely different KPL, but again button H had previously been successfully programmed to have a "House OFF" scene and was working fine in Non-Toggle OFF mode.
All I did this time was to add some new devices to the "House OFF" scene, and suddenly that KPL's Button H toggled over to "Toggle ON" and couldn't be changed back via normal means.
The solution: Remove Button H from ALL scenes, set to Toggle mode, then set to Non-Toggle OFF (& confirmed it was working as such), then add it back to the House OFF Scene as a controller. Once it was a member of the Scene as a controller, I did not attempt to change Button H's "state" to "Off" in the scene-- doesn't matter since it's a Toggle-Off button anyway.
Again, it's a minor bug if anything, but kind of annoying. Just wanted to highlight it, especially the solution, in hopes it will help someone else.
P.S. FYI -- When I try to search in this forum for "button H" it tells me that the "H" is being ignored in the search. Is there a way that I am missing to search for a phrase such as "button H" that include just a single letter? It would be unfortunate if it were impossible to search for phrases such as that...
Thanks much,
Ralph
Hi Ralph,
Just wanted to chime in and let you know that we have had reports of corrupted KPL database on v41. We did have a customer with 5 v41 KPLs which exhibited the same type of intermittent and erratic behavior. Restore didn't fix it either. We did report the issue to SmartHome and are waiting for a response.
To make sure you have the same issue:
1. Make sure yo have Event Viewer on at Level 3
2. Try adding/removing one of the KPL buttons to/from a scene
3. Right mouse click | Diagnostics | Show Device Link Table
4. Once done, click on the compare button
Two questions:
1. Do you see an [std-Direct Nack] anywhere in the event viewer?
2. Are the link tables identical?
      376.7k
