KPL button control
Either the answer is embarassingly obvious, or it cannot be done:
Can ISY directly control the individual buttons on a KeypadLinc? I know the buttons can be added to scenes and they will function correctly, but can you send a discrete on or off command to a single button?
I am asking this beacuse, not only can't I figure it out in ISY, but I am trying to have my ELK M1G contol the status of these buttons. I found that if I send a status change to a button (ie C), it actually controls the main load only, and not the button intended.
Yes it can and I use it.
Create a scene where the button is a Responder and control that scene from a program.
Yes, I am aware that they can be added to scenes and controlled. I want to know if they can individually and specifically be turned on and off.
Actually controlling it manually, directly, does not look like it. I added mine to a scene and I turned the scene on and off and it turns just the button on and off (LED).
The only way would be to create a separate scene for each KPL secondary button you want to control. Call the scenes "KPL Button B", "KPL Button C", etc..
Ah yes. That makes sense. Thanks!
