EDS OWServer Interface
gadgetguru69
Hey Guys
Been looking around the forum and online to try to see if i can get the ISY units to get the info out of a EDS OWServer unit and into the ISY. Does anyone know if this is possible? I have seen that the CAI stuff can be used but i need many more inputs than they provide.
  • 3 weeks later...
I'd be happy to look into it if you can give me some info on your device/server. The name means nothing to me.
gadgetguru69-
Cool. Looks a lot like the CAI web control but industrialized. I see no DIRECT way of enabling data to pass from the EDS unit to the ISY. It would require a middleman to query the EDS sensor data and post to the ISY using the /REST interface. That is exactly what the CAIWC program does for me between the CAI board and my ISY994. I'm running CAIWC on a Pogoplug with Archlinux. Others are running the same on the Raspberry PI. Both are good low power solutions but either will require some coding to get this working for you.
I currently have 3 DS1822 sensors wired to my CAI board reporting temps to the ISY as well as 3 CT switches reporting status/runtime of washer/dryer and oil burner. Still have a bunch of inputs available for more temp sensors (3 of 8 used), TTL inputs (3 of 8 used), Humidity (1 of 1 unused) and a few analog inputs (don't remember the specs on those off hand). CAIWC updates the ISY as soon as anything changes on any of the monitored inputs. Also, I believe that a newer version of the CAI board firmware can post some data directly to the ISY now without the Pogo/Pi middleman.
Xathros
I have been looking for some documentation to see what would need to be done code wise to get the info into the ISY I just haven't found it yet. I was thinking this was what would need to be done and that's doable for sure I am in process of getting the data into a python script now to log it to a database so code to send data to ISY can be implemented there also. Can you point me in the right direction as far as documentation or code examples?
      38k
      379k
