automatewhatican
Members-
Posts
15 -
Joined
Last visited
Everything posted by automatewhatican
ZMatter and Aeotec Home Energy Meter (ZW095)
automatewhatican replied to automatewhatican's topic in ZMatter
Thanks dbuss. Were you seeing successful reception of Zwave message frames, but failure to transmit? -
I don't think it's a USB issue as the failure has presented w/ and w/o a short (3ft) intervening USB cable AND when the dongle is plugged directly into various of the USB ports of the EISY. I'll pull a ticket. -
Since transitioning from ISY944/500series ZWave to EISY/ZMatter, I have had a problem with ZWave communication failures that affect ZWave communication with my entire ZWave network (20-30 devices) is no longer controllable. The failure seems to present after a week or two of uptime and I've been "fixing" by rebooting and removing power cycling various components (including the EISY and ZMatter). Rather than power cycling, today I went looking for clues. I noted the following based on event logs and behaviors: outbound communications from the EISY/ZMatter show failure (in logs). This is consistent with the observable that device states do NOT change based on commands initiated at UDMobile or admin console. inbound communications do seem to be being received, even when the ability to control ZWave devices is down, and mirrored states are generally being updated based on states changed at ZWave devices. during normal operation, I would expect periodic and somewhat frequent (once a minute) telemetry from an Aeotec ZW095 Home Energy Meter. However, during the ZWave down condition, I'm not receiving those. Today, rebooting EISY and removing/restoring power to the ZW095 seemed to resolve the problem. For years my ISY944 was rock solid with the network of the same ZWave devices. This period human-in-the-loop reboot that I'm now experiencing is not going to work. For a while, I just assumed that a forthcoming IoX release would fix; however, the failures remain after updating to 5.8.3. Any ideas? How do I open a ticket? ... and what other data should I try to collect?
Z-Wave alliance site, 500 or 700 series units?
automatewhatican replied to oskrypuch's topic in Z-Wave - Series 700
Yes, on the z-wave alliance site, "Z-Wave Plus Version 2" signifies a series 700 device. -
Resolved with Pro upgrade. I concur with @MrBill, non-Pro node limit is easy to hit, particularly with some of the newer Z-Wave devices that result in many subsidiary ISY nodes. Based on a quick manual count, I’m carrying 30 physical devices that are Z-Wave and 22 that are Insteon (including 5 KPLs).
Thanks. Done both. Same problem. Went on to delete some extraneous device nodes and got further on next add node try, but this time got a series of "too many nodes" messages after first three nodes added. Seems like the node count tallies more quickly than I would have thought. Maybe all the subsidiary nodes of newer Z-wave devices? Will try a PRO upgrade next.
I've been trying (and failing) to add a new Z-Wave device to the ISY. I've gone through multiple remove/add cycles but get the same result as illustrated below: Sun 12/26/2021 10:51:52 AM : Listening for Z-Wave devices to remove from the network Sun 12/26/2021 10:51:55 AM : Removing Z-Wave devices stopped Sun 12/26/2021 10:51:56 AM : Device 79 excluded from Z-Wave network Sun 12/26/2021 10:52:07 AM : Listening for Z-Wave devices to add to the network Sun 12/26/2021 10:52:15 AM : Z-Wave device detected, retrieving info 2 Sun 12/26/2021 10:52:15 AM : Z-Wave device detected, retrieving info 3 Sun 12/26/2021 10:52:22 AM : Z-Wave device detected, retrieving info 5 Sun 12/26/2021 10:52:23 AM : Adding Z-Wave devices stopped Sun 12/26/2021 10:52:24 AM : Z-Wave device detected, retrieving info 6 Sun 12/26/2021 10:52:24 AM : Device 80 of type 4.16.6 included into Z-Wave network Sun 12/26/2021 10:52:30 AM : Add Node failed: Cannot create primary node for new device Sun 12/26/2021 10:52:31 AM : Add Node failed: Cannot create primary node for new device Sun 12/26/2021 10:52:31 AM : Add Node failed: Cannot create primary node for new device From the logs, it appears that the device is being added to the Z-wave network, but that the ISY is unable to create a new primary node. Any ideas? I'm running the following (device and firmware info): I don't have a Polisy or other local polyglot to add an ISY Inventory nodeserver, but would be somewhat surprised if I've hit the 256-node limit. Any other good way to count? In case it might matter, the device that first presented the problem is an alarm.com ADC-SWM150 water meter/shutoff, but I am seeing the same pattern with other devices that I have since tried, including an Aeotech Smart Switch 7. Solutions? ... ideas?
ISY support for S2 security framework?
automatewhatican replied to automatewhatican's topic in Z-Wave - Series 300/500
Fair enough. Kind of figured the answer was not until Z-Wave support in Polisy/ISY and then based on a 700 series USB dongle. Agree on speed issue for lighting. Will continue to use Insteon for anything with multi-responder scenes. -
Issues with Aeotec Home Energy Monitor GEN5
automatewhatican replied to cwitter's topic in Z-Wave - Series 300/500
Hi Craig, where did you obtain the updated firmware and what is the update mechanism? -
I haven't really looked in great detail, but my understanding is that there are some significant advantages both in the key exchange technique employed by S2 (vs. S0) during device enrollment and in the encryption level employed for transport. So ... yes on security against hacking into the over the air communications. My recollection is that there were some pretty widely recognized weaknesses in S0 that basically exposed the network key to any attacker within RF range during device pairing. Out-of-band aspects of the S2 key exchange (device specific codes) are meant to address that. But even with S2 here are published exploits that demonstrate attacks to force a back-compatibility downgrade to S0. No panacea here, obviously, but now that security is more the responsibility of the protocol framework and less an ad hoc vendor-by-vendor thing, it kind of begs the when question for ISY. FWIW, I believe there are also some communication (and therefore power consumption for a battery-powered device) efficiencies due to a single frame transmission [S2] vs. three frames [S0]. To your question of what the ISY would do with a bad frame, I'd like to think that the S2 framework has some basic robustness to denial of service flooding or amplification attacks, but don't really know. For the RF attack surface, there are at least some practical spatial/physical limitations on sources of malicious inbound frames, though the limited channel bandwidth may be easy to saturate even from a small number of in-range transceivers. -
I understand that the ISY994 ZW has not, to date, supported the S2 framework for Z-Wave security. Is there a reason? ... will that change? Most every Z-Wave device I have (all series 500 or 700) supports S2, but that support is meaningless without support at the hub as well. I suppose a related question is when will ISY implementations/firmware support Z-Wave Plus V2 (series 700), which requires S2 support?
Recently bought a pair of the new Aeotec Smart Switch 7 plug-in type B (ZWA023-A) modules (series 700). After numerous failed pairing/pairing/factory-reset sequences, I finally got one paired. Can't seem to even get the second one fully paired. When the ISY even reacts to the pairing button push (which seems random), it reports errors in the log stream. While there is clearly a communication problem, I don't think it is signal. I've got plenty of repeater pathways in the mesh, and even in the failed partial pairings, end up showing 6 nearby Z-Wave nodes as neighbors. Any thoughts? Several items of note: (1) running 5.3.3 with a series 500 dongle. (2) all Z-Wave nodes (except the two new ZWA023-As) are Z-Wave Plus
