Chris McKean
Everything posted by Chris McKean
  1. How will we know when the scripts and instrucrtions are updated?
  2. Left for about 4 hours and when I returned home it is now working.
  3. Still no joy. Upgraded to MyQ node version 3.2.23 and PG3x version 3.2.10. Getting 429 Client error: Too many requests....
  4. In regard to the question about whether I have special characters in the password, the MyQ app requires at least one symbol in the password. What do you regard as a special character? Are there symbols that you can use in the password that won't be a problem?
  5. I have had the same error after upgrading PG3x to 3.2.9 this morning. I am running the latest version of the MyQ node server. I stopped the nodeserver and waited 40 minutes and then started it. Still getting the same error. You said to shutdown the node server. Is that the same as stopping it?
  6. I have upgraded to the new release, but after the upgrade, it shows that the current version on the ISY dashboard is still at version 3.0.22. I have tried stopping Kasa, upgrading then starting the node. It shows the current version is 3..1.0 after the upgrade, but when I start the node server, it reverts back to 3.0.22. Am I doing something wrong?
  7. Just converted to Eisy from Polisy Pro yesterday. Conversion went fairly smoothly. Question, is there a way to determine the utilization of memory, disk, and cpu on the Eisy?
  8. Waking up the devices as documented in the manual fixed the problem.
  9. They are both battery operated. They seem to be working (nodes display the proper information), however all the nodes need changes to be written. It appears that I am not able to wake up the devices. "Keep awake" is on, but "is awake" is false. When I query the device, the "is awake" changes briefly to True, but then I get an error saying request failed.
  10. Yes, it is a Polisy Pro with the ZMatter board installed.
  11. I have two Zwave devices, a ZSE40 and a ZEN34 that display in the Polisy as if they need changes to be written to the devices. I have executed "write changes" with no effect as well as under zwave "rewrite all device links". Neither one updates the display. All of my other Zwave devices appear normal in the Polisy Main menu. Any idea how to fix this?
  12. Upgraded to 5.5.4 and the Zooz Zen34 still not working correctly.
  13. My configuration until recently was an ISY 994i ZW+ IR PRO and a Polisy PRO running PG3 nodes servers. I moved off of the ISY 994i onto the Polisy Pro. So, now everything is on the Polisy Pro. Once the ZWave/Zmatter board is stable for all my Zwave devices, I'll buy an eisy and move everything over to it and get off the Polisy Pro. Since UD has announced dropping support this year for the ISY 994i, I'm sure that the Polisy will not be far behind. The 994i has been a great controller, but the weak link has been the microSD cards. I've had two microSD cards get corrupted and had to rebuild. The remote control for the all the fans uses a single button to turn on and off the light. So, I'll probably not do anything with the lights via programs. With what you described regarding sync problems between the bond bridge and the remote control, it looks like more headache than it is worth. However, I can do some programming around the fans now.
  14. Here is the log file. The fans and lights respond briskly now in IoX. Before I rebuilt them in the bond bridge, if they responded at all, it was only after 6-10 seconds. I think this is going to work. Thanks for your help. pg3_1-18-2023_111415-AM.zip
  15. I just finished rebuilding all of the fans in the bond bridge. Didn't see your request for a debug log file until just now. I am going to delete the bond node server, reinstall and discover all the devices. I will put it in debug mode and send you results of the discovery. Don't know if that will help you or not. After I rebuilt the first fan in the bond bridge, it works reliably in IoX, so I am hopeful that this will fix my problem. I'll send another reply with the log file in it.
  16. I deleted one of the fans in the bond bridge and added it back in. I previously installed the fan using a default configuration on the bridge. This time I configured the fan manually and installed only the commands that I want to use. That seems to have fixed my issue. I'll go and delete and reinstall the other fans on the bond bridge. Pilot error, it seems. Thanks....
  17. Response to your 5 points... 1. Attached are how the nodes show in IoX and how they show in the bond phone app. Porch fan 1 is how four of the five MinkaAire fans show in the bond phone app. Fan bbq2 is how the other MinkaAire fan shows in the bond phone app. So that one is different in the phone app. The guest room fan (Hunter fan) is the last image and it is different in the phone app than any of the other fans. Should I delete fans in the phone app and reload them to see if I can get them to be the same? 2. I believe that the phone app works 100%. I went to the fans and tested to make sure that they worked. 3. The bond server nodes on the fans that have the 3 nodes don't really match what is on the bond phone app. Should I reinstall them on the phone app and see if I can get them to match when the bond server discovers them? 4. Sometimes, but toggling the fan light in IoX doesn't match what is on the phone app. It doesn't appear that it is reliable response when doing the toggle in IoX, but through the phone app it is very reliable. I will delete the fans on the bond phone app and reinstall them to see if the bond server discovers them differently. I believe the wifi connection to the bridge is solid because the phone app works over wifi and is very reliable. The Polisy connection is over an ethernet cable to my router, so that should be solid too.
  18. Sorry, I don't have Postman nor do I know how to use it. It appears to be a programming tool and I am not a programmer. I did do some additional testing and the phone app controls the fans without a problem. However, when I submit commands through IoX, it does not reliably work. Sometimes the command works, but most of the time it does not. I don't see the bond bridge disconnecting at any time. However, I did see this error message attached one time when testing the connection. I believe the node server has worked well in the past. At that point I was running ISY on my 994i and node servers running on Polisy. This week, I moved off the ISY and am now running IoX on my Polisy Pro. Don't know if that has anything to do with the bridge not working reliably or not.
  19. The bond bridge shows connected = true in the admin console. The firmware on the Bond hub is the latest v3.8.4. Bond hub model BD-1000 Not sure what you mean "are you able to poll it manually when it times out" I don't see any timeouts within the admin console.
  20. I have 6 fans tied to a bond bridge, 5 are MinkaAire (all same model) and 1 Hunter fan. All work properly (fans and lights) from the Bond phone app. I was recently working to add some programs to control the fans and fan lights. The fans work fine, but I am not able to control the lights from the IoX using the Bond Node Server on my Polisy Pro. Four of the MinkaAire fans have three nodes on each fan (fan, up light, down light). One MinkaAire fan has two nodes (fan, light). All MinkaAire fans are the same model and were purchased that the same time. The Hunter has two nodes (fan, fan light). The fans that have three nodes default to up light (off) and down light (on). Toggling either the up light or down light doesn't turn on the light. The fans that have only one node for light won't turn on the light when I toggle it on in IoX. I have deleted the bond server several times, reinstalled it, rediscovered the devices and the lights still don't work. I am running the latest packages and bios on the Polisy Pro. IoX version 5.5.3, PG3 version 3.1.16, and Bond Node Server 3.0.10. Attached is a log file... Any thoughts on how to get the fan lights to work within IoX? Bond_1-17-2023_32253-PM.zip
  21. This is the only Zooz Zwave device I have, so it may not be compatible yet. Thanks for the info.
  22. Just migrated from ISY994i ZW+ IR PRO to Polisy IoX with Zwave/Zmatter board yesterday. Everything is working fine except for one device. I have 6 or so Zwave devices that I had to manually install and was able to get all of them to work except for the Zooz Zen34. I am able to get it installed without a problem, but it won't control any devices. It has three options on the switch, Wall Controller, Wake Up, and Basic Control. The basic control, which I assume I would use to control other devices through scenes or programs doesn't have an option to turn it on or off via the ISY. It only has Query. I am able to install it in a scene with the Basic Control as the controller and my light as a responder, but it won't work. Also, if I create a program with IF as the Basic Control on and then the light, still doesn't work when I press the Zen34 switch. I have deleted all of the Zwave devices and reset the Z-wave dongle on the Polisy and reinstalled all devices once already. Any thoughts?
  23. I am at v5.5.0, but have not clicked the button on the Polisy Pro (IoX) configuration page to move to Zmatter. I was told yesterday by UDI support that there were additional patches that needed to be applied before I should do that. All of my Zwave devices are currently on my ISY994i with integrated Zwave, but would eventually like to migrate everything over to my Polisy Pro or possibly get the eisy when it becomes available. Right now I'll just play with the Zmatter on the Polisy to learn how that works. But don't want to migrate until it is safe to do.
  24. How do you then check and update z-wave device firmware?
