How to copy the program txt from web ui ?
@Javi Happy Thanksgiving! Can I suggest this: If copy to clipboard is greyed out, then you would be forced to use copy special with the full menu. Perhaps in the copy special section you include a dialogue window that explains why copy to clipboard would be greyed out. The copy special name is in keeping with ms excel paste special. I think the terminology "duplicate program" is concise and unambiguous compared to "copy". In addition, drag and drop sure would be nice. It would also be nice to have a select multiple. Since html doesn't let you ctrl-click multiple things, you need to trigger a box of check boxes next to items and then you can then select multiple to complete an action on. Example is unifi screenshotted below. You see the manage button at the bottom, clicking that opens check boxes next to each item where you can select multiple and take an action. I'm not sure if you have looked at unifi console, but it is functioning very much like eisy. It is a local piece of hardware that you can connect to directly or you can connect through a portal. The console runs in a web browser. Like eisy, it has a lot of complexity in its configuration. While I find fault with it in places, I think it does a pretty good job with a pretty complex situation.
Eisy_Backup Has Its Own Thread
You are in pg3x. Please migrate the plugin to eisy plugins. Then it will have full functionality and will have future support. That goes for all of your plugins. The backup triggering program you wrote is correct, but if you haven't configured a google drive/nas/usb drive, then you will only have one backup saved and it will be saved locally on eisy. The point of the plugin is to have regularly scheduled backups with multiple backups available at any given time. Configuring a google drive is pretty quick and easy. As I mentioned, it is done from eisy plugins, you don't even need the html page unless you are getting fancy with a usb drive or nas. I save a backup weekly to google drive and have it set to keep 52 of them, so a years worth of backups. I don't bother with usb or nas, I just put them there since I had some requests for it. I tested usb backups and they work, I assume nas backups work, I don't have a nas so I never tested it. You can still do manual backups to a computer, but be aware, they will be double sized. My plugin keeps one local backup on eisy, so there will be the most recent plugin backup inside of your manual backup doubling its size. Not a big deal, but worth understanding. When you trigger a backup from my plugin, the first thing it does is delete the local backup, other wise you would get recursive backups and it would just keep getting bigger and bigger.
Are you using eisy ui? What firmware are you on? This will probably work in pg3x, on a system with eisy ui, but definitely not on a pre-eisy ui firmware. This plugin triggers the eisy ui backup sub-routine and if that sub-routine isn't there, it won't work. In pg3x, I believe the api activation "switch" is on the configuration page below long poll setting. Not 100% on that. But again, I wouldn't be installing anything in pg3x at this point. Finally, you don't need the html configurating page unless you plan to save to usb drive or a NAS. If you want to use google drive, that is all configured from the plugin configuration page. Again, this isn't really designed for pg3x install, but I believe you should find the "authenticate" button on the configuration page of pg3x. I could be wrong, never tested in pg3x. Again, pg3x is depricated. Below are screenshots of allow api and authenticate using eisy ui plugin page.
Did you allow api access on the config page?
I don't understand why the need for all the pop-ups and confirms. As troublesome as the java ad con is, it is much faster and simpler for so many things. Every time I start using the new eisy ui console I get frustrated by the unnecessary steps and delays and go back to using java. Just do right click, whatever, done. All of the confirms and acknowledge popups that are halfway across the screen serve no purpose. In the old ad con I can disable AND then reenable a program faster than just disabling OR enabling in the new. If it is big deal item that isn't readily reversible, I get it. The eisy ui has you moving your mouse all over the place back and forth clicking multiple times to complete simple tasks not scary blow the whole thing up by accident tasks. Similar story with enabling/disabling a program. Eisy-ui ->Right click/enable./mouse half way across the screen/OK/OK/mouse back across screen to where you were working. Why not just right click/enable. . .done? Regarding confusion of copy. Call it 1) Duplicate Program and 2) Copy to Clipboard. Right click and have these choices directly.
Tuya Smart Life Plugin Updated for Cross Subnet
I updated the Tuya Smart life plugin so it will now work across vlan's. So you can put all your tuya smartlife stuff in an iot vlan and open just a single port between eisy and the iot vlan subnet. Process is as follows. 1) Click to retrieve cloud devices and keys. 2) Enter your tuya/smarlife device subnet (/24 to scan the entire range). Unclick "include local network. . " to save time if no devices are on the same subnet as eisy. Click "scan networks". It will pop up all the devices on that vlan and offer you to add it to eisy or if it is already configured but has a new ip address, it will offer you to just update the ip. The update IP feature works just as well for devices that have a new ip address for any reason, not just changing subnets. Don't forget to open a firewall hole between your eisy and TCP 6668 on the tuya/smartlife containing subnet.
@Javi My observations: Issues with this as it stands is there are a lot of moving your mouse around and clicking multiple times. Might I suggest that copy (making a duplicate program) is its own button separate from copy to clipboard. And I would only do copy to clipboard. I don't understand why it says it needs https to copy to clipboard and why that is greyed out. the page is running in https. But copy to clipboard is the only feature anyone would want. Copying to some file that ends up on your drive would never be the goal, you would have to then open that file and copy it again to wherever it is you actually wanted it to be. Copy to json could have use if there were something to import it into that wanted in that format, but I don't know what that is. Perhaps you have something in the works?
Verizon email to text is being shutdown.
I have started getting bunches of texts from many hours ago. So this must be a google server failure.
So after telling you about google email to text, for the first time ever since I've been using this it stopped working. And I have been using it for a very long time, probably 15 years. I assume there is a temporary issues with the google email to txt server. My inbox is loaded with temporary failure to send messages. I am not currently able to reply to any text from anyone using email. The emails all arrive with the message that I can reply to the email, so I assume this is a temporary outage, not a cx of feature. EDIT: Seems to be a problem specific to this acct. I tried two other GV/GM accts and I can send email to texts on both of them. Is Google mad at me? I can send sms like normal from that acct, just not from gm.
New plugins available (my first published ones)
I put some updated code on github for you to review as a pull request. Changed the icons and added the unix/epoch stuff.
these 3 lines do it to convert the light bulbs to the generic controller icon, you will need to alter the slot number as I have it in 24, yours is likely not 24. sudo sh -c 'mkdir -p /var/eisyui/ns/plugin_24/profile && cd /var/isy/FILES/CONF/DEF/f10/i24 && cp -R nls nodedef linkdef editor /var/eisyui/ns/plugin_24/profile/ && chown -R plugin_24:polyglot /var/eisyui/ns/plugin_24/profile' sudo sh -c 'cd /var/eisyui/ns/plugin_24/profile/nls && mv -f en_US.TXT en_us.txt && for node in controller caltoday caltomorrow calmonth calweekday caltime calrule; do printf "\nND-%s-ICON = GenericCtl\n" "$node"; done >> en_us.txt' sudo sed -i '' '/LOGGER.info("Profile update response:/a\ polyglot.updateProfile() ' /var/eisyui/ns/plugin_24/main.py
@Guy Lavoie Yes, I enabled api and now sunrise/set show up. But the error message you get if you don't enable it says you need to enable the "hub". Might change that to say api. And yes, you can select from a relatively short list of icons. Supposedly as part of moving to eisy ui, this list will increase. But light bulb is what shows up if you don't do anything. I tend to use what they call "generic" for a lot of stuff. And I will confirm that it does not install on my polisy which is on the production repo.
What, no Julian calendar option? Seriously, though. It installs fine on my machine and I am on the staging repo. It looks to be working nicely with a lot of good values. One issue is it isn't giving me sunrise/set and it says I didn't allow hub access. What is the hub? I noticed the allow api access button is enabled, is that what it means by hub? Finally, one suggestion. Consider adding "days since epoch". Epoch is a standard day counter with 0 being Jan 1, 1970. Anyway, doesn't really matter what day 0 was, what matter is that it always increases by 1 each day. The point here is to run something every "x" days. You just divide/remainder epoch by "x" and then you get a regular cycle. Like divide/remainder by 3 and it goes 0,1,2,0,1,2,etc. So you can have an every 3rd day thing (just pick whichever of the 3 values puts your every 3rd at the spot in the cycle you want). Also works for every other week, divide/remain by 14 and again pick the value from 0 to 13 that works for your needs. Like today would be 4, so anything triggered by the answer being 4 would happen every other Monday starting today. Using day of year would work until you cycle over to the next year and then your cycle gets shifted by some number of days depending on the details. Eisy has unix time, which is seconds since MN Jan 1, 1970. So divide by 86400 to get epoch day. You might also display unix time. It could be useful for having something repeat every x seconds. EDIT: One last suggestion. The default node icon is a light bulb, which you left as default. Might change it to something else since a light bulb doesn't really fit. EDIT AGAIN: Unix time is seconds since MN Jan 1, 1970 UTC. So you would need to adjust for the time zone before dividing by 86400.
6 Button Switch Controller Programing
It does not appear that you put both button a and b in your scenes. ALL the kpl buttons need to be in EACH scene. I assume 58 8d 94 is your kpl. I only see button 1 listed in the scene. Where is button 2? Please look at my scene. You need ALL of the button in ALL of the scenes. Please note for my 4 speed fan, buttons 3,4,5, and 6 (c,d,e,f) are all in this scene with "on level:" set to "off" for all of the buttons that aren't the one that is supposed to be on at this fan speed. This is the fan "off" speed, button 5 (e) is lit when the fan is off, so only button 5 has its on level set to on. All the other buttons have the on level set to off.
getting an error when trying to backup using EISY-UI
If it never gave you the option to download the backup, then effectively it failed. If you don't have the backup file on your computer, then whatever happened in eisy doesn't matter. You might try installing my plugin for handling backups and see if that works. The plugin saves the backup to a file on eisy and does not use the eisy download tool, only the eisy backup tool. Once the backup is complete, the plugin saves it locally to eisy for optional download. It also optionally lets you send the backup to google drive, usb drives, or a nas device. So if your backup failure is strictly in the eisy ui download tool the plugin may still succeed in giving you a backup. That would isolate the error to the eisy download tool.
apostolakisl
Joined
Last visited
