Adam Ant
Everything posted by Adam Ant
  1. Hello, I ran into the same problem with a Kwikset model 206. I have 4 locks (all new). The first two added fine but the 2nd two added as 'entry control" devices that are not controllable. I raised a ticked two days ago but have not heard back. I spent allot money on these locks because i have used them in the past with no issues. Would appreciate any suggestions. I have done a factory reset of the devices but have not done a reset of the dongle (because i don't understand what that would do).
  2. I am going the tailwind direction anyway. Hoping someone builds a nodesever though. I could always use HA or Iftt but rather use the node server route.
  3. Is anyone planning on building a Tailwind (https://gotailwind.com/) Node server? With MyQ no longer supporting third party would think this is an increasing need. I found previous posts but no answers... Happy Veterans day! Adam
  4. Brilliant! Have changed to this approach! Thank you!
  5. Yeah, i considered that but my away temp settings weren't high/low enough for me. Wanted to make sure it never came on. Good approach though.. got me reconsidering...
  6. @Jimbo.Automates had suggested the fix offline but took me a while to find it. I had another program that was fighting me that i was not seeing. Thanks
  7. I had used 89 for the last couple of years but it looks like it changed at some point. Even though my range still goes up to 89 on the thermostat, it now only seems to allow 80 as the max. Your suggestion got me looking in the right direction. Thanks! Do you by chance use indefinite hold? That quit working for me as well. In case anyone is wondering, i do this adjustment of a high temperature when doors or windows are left open. That way i am not trying to cool the outside.
  8. Hello, Is anyone having issues with making updates to Ecobee.. I am able to set the mode (off/heat/cool etc) but can not set the setpoint like below. The log on the ecobee node server shows it received the update just fine but the change never takes place on the ecobee controller. I am running on PG3x. ----- Use this to test Copy - [ID 0036][Parent 00E3] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set 'Ecobee - Main Floor' Cool Setpoint 89°F Else - No Actions - (To add one, press 'Action')
  9. I am having a similar issue. Thought programs were not running as well but I have discovered that my programs were starting ok but then something made all the running programs suddenly stop. Nothing in the error log. Going to try the simp startup like you did to see if that fixes my issue as well
  10. i am having the same issue. I followed the guidance in this thread and still getting the error. I am finding the UID/isy and verified i am using udx-3.5.1_4.
  11. Thank you! Proves every 1 matters
  12. HI Everyone, I am getting quite a few of these errors in my error log. The error messages wiki page says it is a VECTOR MAX CAPCITY error. Anyone know what causes these? Does that mean a function was expecting a different number of parameters? Anything to worry about? Wed 2023/02/22 02:10:05 PM 0 -170001 <s:Envelope><s:Body><u:Subscribe xmlns:u="urn:udi-com:service:X_Insteon_Lighting_Service:1"><reportURL>REUSE_SOCKET</reportURL><duration>infinite</duration></u:Subscribe></s:Body></s:Envelope>
  13. Recently jumped in on the move from Zooz to Zmatter. Thought I would share some lessons I learned. Sorry if they are obvious to others but they sure weren't for me. 1. I had to remove the zwave devices before I could add to Zmatter. Michael indicated that is always a best practice 2. Obviously if you remove your devices you will have to fix all your programs. The quickest way to do that is go to the Programs - Summary tab and then sort on the activity column and look for the yellow "- Not Loaded" programs. Those are the ones you need to fix. 3. One of my zwave devices (kwikset lock) had a pin near the QR code that I had not seen. You must use that Pin to add the device when prompted in the AC. You will never be able to add it even if you turn off security otherwise. At that was my experience. I had misunderstood the purpose of the Pin up to that point. 4. Mobilinc does not support the zwave devices anymore after the move to zmatter. Whereas I used to be able to have devices like a zwave lock directly on my widget screen that no longer works. I now use a program to toggle the device and that works fine. Hope this helps at least one person.
  14. thanks again! have a great weekend!
  15. That fixed the issue! Will I need to stay on the beta moving forward?
  16. Wow! Strange! That's my Home Assistant unit. I really appreciate your help!
  17. Not sure why but could not reinstall. it wanted me to select the node and would not allow me to select the current node. I just deleted it and reinstalled. please see log attached. thanks!
  18. I will be on the lookout for it. Thanks! Adam
  19. Thank you! Here you go! I let it run for about 5 min...
  20. Hello, i am have recently purchased the Roku Node server. It installed fine but is not finding any devices. When using a Roku iphone app it is finding all my roku devices (5 of them) just fine so no network issue etc. They all have normal names (like "living Room") with no special characters so not running into that bug.. I have left the polling numbers at the default values with no luck and tried 5/60 instead with no improvement. I had used the previous ( free) version and it had been working great a while back. Attached is the log. Any ideas?
  21. Thank you! I see in the admin tool that PG2 was marked as "depreciated". In my experience with software development, that typically means it is no longer used. Sounds like we aren't quite there yet. Thanks again!!
  22. Does anyone know if there are instructions to remove PG2? I have everything I want on PG3 now.
  23. Looks like that($1,100) is what the bid is already up to.. ? looks like I will need to dig mine out!
  24. Just realized that one of my devices returning to default is not a zwave. It is a wifi device being controlled by a PG3 Node server. That seems to expand the scope of the bug beyond zwave and Zooz. I am however NOT seeing the issue with insteon devices.
