TRI0N
  1. What was suppose to be a 30 minute add now running into 3 hours and had to cancel 2 client appointments. Not good. It want's to authenticate with KASA Cloud apparently. Username is actually the Kasa Username or email? Because you when you login to Kasa it's email NOT the username. So lets try to get clarified before I cause another account lock out for 10 minutes so I can play Guess BS Again Game.
  2. So what it looks like right now is there is a separate Beta version. Am I to install this along with the current not working one which would mean loosing all my programing for the devices OR install the beta and remove the old one installed?
  3. Title pretty much say it all. Getting the same error messages that were discussed 2 months ago with no actual solution to the "Error processing....due to high volume"... License not showing as purchased. You can try to throw another $30 at it but even that comes up with Error. Can't update it, can't re-install it.
  4. Nobody talking about their perpetual license no longer being active? Not to mention you can't buy it either? ERROR and more ERRORS... Jesus...
  5. Kasa/TP-Link Matter + Energy Monitoring for starters. The eISY App can't read the QRC Codes, can't enter the ID manually, Kasa Plugin via Polly doesn't pass Matter Device through to be used as Wi-Fi so eISY can't even use them. I'm down to either moving to Home Assist as the Primary Development Platform or wait another year for UD to release a Beta version. Yeah the whole wait a year isn't going to happen. I have 20 new matter devices that won't work and need to make a final decision on what platform to move forward on and it needs to be made soon. Even Samsung SmartThings detected the Matter Devices that needed to be paired without even touching a button. That's even made it look worse...
  6. So we're ALPHA Testers now? 30 years of programing and NEVER did we EVER release ALPHA to public testing. This has got to be the worst investment I have ever dumped money into.
  7. TRI0N replied to TRI0N's topic in eisy
    Been waiting for a Fan Control for ages. There was once a Z-Wave one that the company went under and nobody picked up the idea till now with a Zigbee one. Up until I found this there was only WiFi ones that are complete junk. Will see what happens when it gets here. Cheers, TRI0N
  8. TRI0N replied to TRI0N's topic in eisy
    Yeah I checked that. Didn't see it. It's a fan controller. https://inovelli.com/products/zigbee-blue-series-smart-fan-light-canopy-module I'll post it there too if it doesn't work out.. Might as well find out if it works. Can always use my HA sever to make it work like the Govee devices since Govee for eISY is not being developed. Cheers! TRI0N
  9. TRI0N replied to tpolito's topic in eisy
    Late response but have you tried the default username and password? I have had eISY reset the password several times after updates to the point that I haven't changed it back because it's a royal pain in the rear end. Try admin/admin. Cheers! TRI0N
  10. TRI0N posted a topic in eisy
    Is Zigbee ready to use for the eISY? I have the dongle of course. Just found a Ceiling Fan controller that is based on Zigbee. So I want to make sure before I spend $50 on it. Cheer! TRI0N
  11. I will have to test it more from the office location. Maybe it was a momentary problem. But I still like adding external IP's to my white list that I trust. Like my domain database connecting to my home server to update the external backup databases. Just a peeve I suppose. Cheers! TRI0N
  12. Yes I have a portal account. So what I need to find out is how that portal or other other request are sent from what IP? That's all I'm asking for. I want to white list UD server so it can't be blocked from an external service that is designed to block unknown connections. The local hostname is NOT what I'm looking for. But I'll continue my search.. Cheers! TRI0N
  13. I did some testing. Since I have T-Mobile as well and notice my Battery Notification mail was not working since I read your post and found some sensors were below the threshold of my programs that were suppose to notify me. So I checked my email settings in eisy to make sure there were there and such for the group that is to be notified and everything is as it was suppose to be. Using the default SMTP Setting I performed a test. It failed to send SMS/MMS but did send my email copy. Note that I do put the country code in my number as I talked about above. So I tested it without the country code and it failed again with email copy working. So I setup a eisy email account off one of my domains, setup the SMTP to use my domain MX Server, put the 1 country code back into my address for SMS/MMS and performed the test again. Both the SMS/MMS and email copy were successful. This might have to do with either UD in house MX Servers or MX Providers. If providers they may not allow phone numbers or specifically @tmomail.net due to SPAM problems to mobile phones using this. It's something UD will need to look into.. Cheers! TRI0N
  14. Yeah my network is all reserved IP's... But that's not what I'm thinking about. This is more of a service that monitors all incoming connection via WAN. But earlier I was seeing connection failures in the UD Mobile App to the home system from the office location but the office location was fine. But when I returned home the home eisy restored it's connection and the the office eisy was still fine. I'm sure the eisy uses a UPnP call for making a outside connections for ports but what I want to do is add the eisy portal IP's that all this connects to into the white list table of the NETGEAR Armor (external service - not inhouse software) so that it will not block any suspicious connects. I'm pretty sure eisy is pretty unknown to these services. Cheers! TRI0N
  15. Have you tired using your 11 digit number that includes your country code? 1xxxxxxxxxx@tomomail.net? It's suppose to work both ways but I have heard that it only works in some areas if you include the country code. 1 being United States. You can just simply test this with your email client before doing any changes to eisy. Just send an email to your mobile number. Cheers, TRI0N
