RPerrault
Everything posted by RPerrault
  1. might work to tell her to discover devices if not - try deleting the device in the ud portal - have her discover devices - add it back to the portal and discover devices again
  2. x10 is powerline only. in the early days of insteon, the wired devices were deceptively sold to us as both powerline and radio. which was not true. the early insteon devices were powerline only. that brought in the phase coupler devices. leaving the question in my mind 'how do you propagate the powerline signals without a phase coupler?' the answer i was given is that powerline based data is sent on the leg of one phase to the transformer and back in on the other power leg. which means i am sending powerline communications to every home serviced by the same transformer. i am unsure if its true, but if its a lie, it satisfied my curiosity to the point i no longer researched it. i was also told that transformers filter the signal from being sent to homes on other transformers. if that is true, and both meters are serviced by the same transformer, and you put in at least one wired insteon device - it might work now. could be worth trying one wired insteon device in the building to see. obviously, this would only work for insteon devices. but i'd love to know if it works. as for my little bash of insteon's early days, i was a champ. and had a lot of company. it was a fun battle with the fan boiz of insteon but those days are past. sigh. the new owners were not smarthome and am so grateful they saved those of us with substantial insteon investments from migrating to a new technology. but i do wish they would stock some single dimmer white outlets. *coughgetthedamnthings*
  3. ha nerdz are constantly begging for a constraint - but can never identify the constraint, just throw money into guessing until a 'solution' is found bmercier gave the answer to the question you are not cpu constrained - you are not memory constrained - the data bus architecture is not a problem - not wifi - not a slow powerline - all that stuff is speculation here upgrade for new functions or features - or just because its fun
  4. um - no love for the isy26?
  5. RPerrault replied to verkuild's topic in eisy
    it would probably depend on the application my interest is for under cabinet lighting. but i have some specific requirements so i have not had much luck finding what i want. among the requirements: 120v dimmable with insteon dimming products warm white high lumen output per foot the shortest cutting increments possible discrete appearance highest cri i can find i'd like to find something weather resistant for outdoor use i'd prefer not to have to use tracks to house the strips widest beam angle possible best dimming performance i can get i thought i had found it here https://www.superbrightleds.com/led-strips-and-bars/led-strip-lights-by-voltage/120-volt-led-strip-lights/stacd-axk90-c8d-14sxm-120v+length_in-164~ft~5~m so i ordered some. tested it on a plug in dimmer. does not work.
  6. i have a sunset program that turns on several lights every night. i turn most off at a set time and one that turns off at sunrise - every night - no one knows if you are at home or away and there is an ambient level of lighting to navigate the house. but if you want to do it your way, i'd enable a sunset program when you arm your system and disable it when you disarm the security system. that way, your lights are not on during the day when you don't need them and no one outside the house knows they are on i'd also manipulate the turn off a time to turn off program when the system is armed/disarmed
  7. RPerrault replied to sjenkins's topic in AudioPlayer
    to be clear - i am not attacking ud or its products there are two truths in life the day you have no bumper to bumper warranty for your bmw or mb, that is the day that i will no longer own that vehicle vehicle the day i no longer have an isy, that is the day i rip out insteon
  8. RPerrault replied to sjenkins's topic in AudioPlayer
    is this bluetooth only? i assume the bt radio is in the eisy. if so, the speakers will have to be close. maybe i look for solutions that are more whole house than others. i have echos throughout the house - and sonos. another single use box in every room? the advantage might be that setting up spoken responses are easier than echo routines. but it is possible to do and alexa's voice is pleasant. and i have always been impressed with the echo device sound quality (for a small box). but the sound quality from sonos amazes me. my todo list is to set up preferred speakers for echo devices to use sonos. i love my eisy (or isy or whatever) but my approach to home automation is less reliant or it compared to years ago. With insteon, its a must have. for other things, its nice but not involved. i do not need the eisy for hvac control. echo handles that. same for televisions. (but being a nerd, i have the plugins) i have migrated more to voice control - but only where i can avoid formulaic speech. "turn on the den left sofa lamp" is not something anyone will ever use. "turn on the lights" is something people will use. with echo (and the eisy) its possible to use 'turn on the lights' in any room and it works for each room. (when ud put in the synonym function of its portal, that was genius - it helps to reduce formulaic speak.) i'd vote to integrate it into sonos. but i know that could be problematic. the best news is we now have a choice - bt speakers or echo routines.
  9. thanks for talking me through it
  10. the battery is its own unit - plugs into the motor - i have extra units that i can rob a battery from
  11. tried exclude device with it plugged in - it excluded might be the battery - i'll replace it
  12. oh - yes - i tried that - no response i am using the eisy with whatever radio it uses for z-wave - i do NOT have 'zmatter'' enabled (whatever that is) i do have z-wave enabled
  13. yes - but have never used the replace on a z-wave how do i remove the device rather than the node?
  14. using the motor control node the device stopped responding so i was replacing it - worked fine for a week - then nothing - no responding at all - so i was going to replace it - after removing the failed node
  15. not sure what the difference is - this is what the devices look like i think this one was added twice - and i might have a battery problem - it should be fully charged but i powered it with the charging device and it might be responding - it might be that i included it with it plugged in and it is not seen as a battery powered device lemme look at x-ray
  16. placed the isy in exclude - then pressed the button - nothing used the 'remove failed node' and get the above
  17. battery - blinds motor
  18. has no power but i still get this
  19. nothing new - all 3 are in a hallway in a scene to make them into a 3-way switch setup all 3 dropped at the same time - the hallway has my equipment closet in it i suspect these might be first generation devices though
  20. interesting - a query to the keypad would take it back to outstanding writes status the restore fails for button a and i get the red exclamation mark for that button but the writes continue and eventually completes a query on the dimmers never work - and a reatore on the dimmer shows this
  21. using the eisy - 5.7.1 that worked for two keypads i had with outstanding writes - thanks still have 3 dimmers (all in a 3-way scene) that cannot be queried
  22. i moved it closer to the eisy - i reset the device then tried again it still works but i cant change scenes when i need to update this device i have others that won't update
  23. RPerrault replied to DNewkirk's topic in eisy
    wireshark the answer to so many problems
  24. you might try the z-wave - synchronize - update with interview but when i migrated to the eisy, i had to exclude/include all of them
