GSutherland
  • Posts
    45
Everything posted by GSutherland
  1. Question.... Hue devices use Matter that the new bridge supports V2 API But can I use Matter on the EISY to add and program HUE control my lights Or should I wait till a New Version API that support hue again on EISY NODES thanks
  2. I've noticed the bridge is really faster than the previous in response to my iPhone control for all my whole house network and also I feel like it reaches farther so I don't have lights on the outside of the perimeter having issues. It's nice to have Wi-Fi and wired built into it....... and the amount of lights you can add to. It's pretty impressive cause I'm at 49 went away from the previous one that would not take anymore. This one I believe goes up to 150.
  3. Hello all, Well, the Hue saga never ends with me obviously. I just updated to the New Black Hue Bridge Pro, and as you can see below, I am having nothing but problems getting it connected or even finding it. I've done all the steps I've done previously with no luck. Can someone let me know if the New Bridge Hue Pro works with the current plug-in. 2025-09-17 15:13:45.511 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message stop 2025-09-17 15:13:45.511 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message stop 2025-09-17 15:13:45.512 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING stop 2025-09-17 15:13:45.512 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS stop message {} from Polyglot 2025-09-17 15:13:45.512 Command udi_interface.interface INFO interface:_handleInput: Received stop from Polyglot... Shutting Down. 2025-09-17 15:13:45.512 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING stop 2025-09-17 15:13:45.512 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS stop message {} from Polyglot 2025-09-17 15:13:45.512 Command udi_interface.interface INFO interface:_handleInput: Received stop from Polyglot... Shutting Down. 2025-09-17 15:13:45.512 Thread-34 (stop) udi_interface INFO hue:stop: Hue NodeServer is stopping 2025-09-17 15:13:45.512 Thread-34 (stop) udi_interface INFO hue:stop: Hue NodeServer is stopping 2025-09-17 15:13:50.008 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: UDI interface initializing 2025-09-17 15:13:50.008 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: UDI interface initializing 2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: User=None 2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b902651c_1 2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b902651c_1 2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NjU6MWMiLCJwcm9maWxlTnVtIjoxLCJsb2dMZXZlbCI6IkRFQlVHIiwidG9rZW4iOiJDbXo0c1JWcmZQKnpTJmFLIiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjMuMjEiLCJpc3lWZXJzaW9uIjoiNS45LjEiLCJlZGl0aW9uIjoiRnJlZSJ9 2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: User=None 2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b902651c_1 2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b902651c_1 2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NjU6MWMiLCJwcm9maWxlTnVtIjoxLCJsb2dMZXZlbCI6IkRFQlVHIiwidG9rZW4iOiJDbXo0c1JWcmZQKnpTJmFLIiwibXF0dEhvc3QiOiJsb2NhbGhvc3QiLCJtcXR0UG9ydCI6ODg4Mywic2VjdXJlIjoxLCJpc1BHM3giOnRydWUsInBnM1ZlcnNpb24iOiIzLjMuMjEiLCJpc3lWZXJzaW9uIjoiNS45LjEiLCJlZGl0aW9uIjoiRnJlZSJ9 2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: Loading interface module 2025-09-17 15:13:50.008 MainThread udi_interface INFO __init__:<module>: Loading interface module 2025-09-17 15:13:50.038 MainThread udi_interface INFO interface:<module>: Loading MQTT module 2025-09-17 15:13:50.038 MainThread udi_interface INFO interface:<module>: Loading MQTT module 2025-09-17 15:13:50.529 MainThread udi_interface INFO interface:<module>: MQTT module loaded 2025-09-17 15:13:50.529 MainThread udi_interface INFO interface:<module>: MQTT module loaded 2025-09-17 15:13:50.750 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module 2025-09-17 15:13:50.750 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module 2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: Loading node module 2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: Loading custom module 2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: Loading isy module 2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: Loading OAuth module 2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: Loading node module 2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: Loading custom module 2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: Loading isy module 2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: Loading OAuth module 2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: UDI interface initialized 2025-09-17 15:13:50.752 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.3.18 Starting... 2025-09-17 15:13:50.751 MainThread udi_interface INFO __init__:<module>: UDI interface initialized 2025-09-17 15:13:50.752 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.3.18 Starting... 2025-09-17 15:13:50.754 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.3.21 [ISY: 5.9.1, Slot: 1] 2025-09-17 15:13:50.754 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.3.21 [ISY: 5.9.1, Slot: 1] 2025-09-17 15:13:50.754 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.1.51', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'} 2025-09-17 15:13:50.755 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:8883 2025-09-17 15:13:50.755 MainThread udi_interface.interface WARNING interface:start: No node server version specified. Using deprecated server.json version 2025-09-17 15:13:50.755 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b902651c_1.cert key: 0021b902651c_1.key ca: /usr/local/etc/ssl/certs/ud.ca.cert 2025-09-17 15:13:50.754 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.1.51', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'} 2025-09-17 15:13:50.755 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:8883 2025-09-17 15:13:50.755 MainThread udi_interface.interface WARNING interface:start: No node server version specified. Using deprecated server.json version 2025-09-17 15:13:50.755 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b902651c_1.cert key: 0021b902651c_1.key ca: /usr/local/etc/ssl/certs/ud.ca.cert 2025-09-17 15:13:50.756 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: huebridge not found in database. 2025-09-17 15:13:50.756 MainThread udi_interface.interface INFO interface:addNode: Adding node Hue(huebridge) [None] 2025-09-17 15:13:50.756 MainThread udi_interface INFO hue:__init__: Started Hue Protocol 2025-09-17 15:13:50.756 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: huebridge not found in database. 2025-09-17 15:13:50.756 MainThread udi_interface.interface INFO interface:addNode: Adding node Hue(huebridge) [None] 2025-09-17 15:13:50.756 MainThread udi_interface INFO hue:__init__: Started Hue Protocol 2025-09-17 15:13:50.758 Interface udi_interface.interface INFO interface:_startMqtt: MQTT keepalive is 300 seconds. 2025-09-17 15:13:50.758 Interface udi_interface.interface INFO interface:_startMqtt: MQTT keepalive is 300 seconds. 2025-09-17 15:13:50.808 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with Reason code: Success 2025-09-17 15:13:50.808 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with Reason code: Success 2025-09-17 15:13:50.808 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:65:1c_1 - MID: 2 Result: 0 2025-09-17 15:13:50.849 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Successfully for Message ID: 2. Reason codes: ['Granted QoS 0'] 2025-09-17 15:13:50.808 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:65:1c_1 - MID: 2 Result: 0 2025-09-17 15:13:50.849 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Successfully for Message ID: 2. Reason codes: ['Granted QoS 0'] 2025-09-17 15:13:50.896 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getAll 2025-09-17 15:13:50.896 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getAll 2025-09-17 15:13:50.896 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getAll 2025-09-17 15:13:50.896 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getAll 2025-09-17 15:13:50.896 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '1220b861-bdaf-4e9a-b14a-b036e5f81906', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'customparams', 'value': '{"bridges":"[\\"192.168.17.253\\"]","Debug":""}', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.897 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:load: CUSTOM: load {'bridges': '["192.168.17.253"]', 'Debug': ''} 2025-09-17 15:13:50.896 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': '1220b861-bdaf-4e9a-b14a-b036e5f81906', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'customparams', 'value': '{"bridges":"[\\"192.168.17.253\\"]","Debug":""}', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.897 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:load: CUSTOM: load {'bridges': '["192.168.17.253"]', 'Debug': ''} 2025-09-17 15:13:50.897 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'cf26dfa8-0433-4556-88bb-22ca5caf8e17', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'customtypeddata', 'value': '{}', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.897 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:load: CUSTOM: -- checking bridges / ["192.168.17.253"] 2025-09-17 15:13:50.897 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'cf26dfa8-0433-4556-88bb-22ca5caf8e17', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'customtypeddata', 'value': '{}', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.897 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:load: CUSTOM: -- checking bridges / ["192.168.17.253"] 2025-09-17 15:13:50.897 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'e8411887-ff53-4071-908d-1338a65fcda8', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'notices', 'value': '{}', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.899 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getNsInfo 2025-09-17 15:13:50.897 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'e8411887-ff53-4071-908d-1338a65fcda8', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'notices', 'value': '{}', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.899 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message getNsInfo 2025-09-17 15:13:50.899 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:load: CUSTOM: -- checking Debug / 2025-09-17 15:13:50.900 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {} 2025-09-17 15:13:50.900 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving 2025-09-17 15:13:50.899 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:load: CUSTOM: -- checking Debug / 2025-09-17 15:13:50.900 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {} 2025-09-17 15:13:50.900 Thread-2 (parameter_handler) udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving 2025-09-17 15:13:50.900 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'df6ae4f6-0863-41f2-a051-a12910732623', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'nsdata', 'value': 'null', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.900 Thread-2 (parameter_handler) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2025-09-17 15:13:50.900 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'df6ae4f6-0863-41f2-a051-a12910732623', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'nsdata', 'value': 'null', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.900 Thread-2 (parameter_handler) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2025-09-17 15:13:50.900 Command udi_interface.interface DEBUG interface:_handleInput: Key nsdata should be passed to node server. 2025-09-17 15:13:50.900 Thread-2 (parameter_handler) udi_interface INFO hue:connect: Saved bridges information is not found 2025-09-17 15:13:50.901 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'c51c5480-5d5a-4624-9846-4b57d30d1493', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'oauth', 'value': 'null', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.901 Thread-2 (parameter_handler) udi_interface INFO hue:connect: Reading bridges configuration: ['192.168.17.253'] 2025-09-17 15:13:50.901 Command udi_interface.interface DEBUG interface:_handleInput: Key oauth should be passed to node server. 2025-09-17 15:13:50.900 Command udi_interface.interface DEBUG interface:_handleInput: Key nsdata should be passed to node server. 2025-09-17 15:13:50.900 Thread-2 (parameter_handler) udi_interface INFO hue:connect: Saved bridges information is not found 2025-09-17 15:13:50.901 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getAll message {'id': 'c51c5480-5d5a-4624-9846-4b57d30d1493', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'key': 'oauth', 'value': 'null', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.901 Thread-2 (parameter_handler) udi_interface INFO hue:connect: Reading bridges configuration: ['192.168.17.253'] 2025-09-17 15:13:50.901 Command udi_interface.interface DEBUG interface:_handleInput: Key oauth should be passed to node server. 2025-09-17 15:13:50.901 Thread-2 (parameter_handler) udi_interface INFO phue:connect: Attempting to connect to the bridge... 2025-09-17 15:13:50.901 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getNsInfo 2025-09-17 15:13:50.901 Thread-2 (parameter_handler) udi_interface INFO phue:connect: Attempting to connect to the bridge... 2025-09-17 15:13:50.901 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING getNsInfo 2025-09-17 15:13:50.902 Thread-2 (parameter_handler) udi_interface INFO phue:connect: Error opening config file, will attempt bridge registration 2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '137fb83b-0c96-47dc-b395-a75f847075d4', 'uuid': '00:21:b9:02:65:1c', 'name': 'Twinkly', 'nsid': 'f5f38126-56f2-4f1d-a1d4-a175b0639096', 'expires': 0, 'nickname': None, 'profileNum': 6, 'developerMode': 0, 'timeAdded': 1719296895682, 'timeStarted': 1758085659768, 'timeModified': 1758085664245, 'version': '3.0.0', 'edition': 'Free', 'branch': 'main', 'url': 'https://github.com/UniversalDevicesInc-PG3/udi-twinkly-nodeserver.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_6', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'twinkly_poly.py', 'shortPoll': 60, 'longPoll': 300, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '', 'noLicense': 0, 'latestVersion': '3.0.0', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '1cd02c69-534c-4de5-a782-ff0edb8a384f', 'uuid': '00:21:b9:02:65:1c', 'name': 'Ecobee', 'nsid': 'af1f50a2-7aaf-43c1-aa53-276b2587cb22', 'expires': 0, 'nickname': None, 'profileNum': 12, 'developerMode': 0, 'timeAdded': 1719297099268, 'timeStarted': 1758085660972, 'timeModified': 1758085664024, 'version': '3.1.5', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Ecobee.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_12', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":2,"name":"Debug + Session Verbose","value":"DEBUG_SESSION_VERBOSE","level":8},{"id":1,"name":"Debug + Session","value":"DEBUG_SESSION","level":9}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'ecobee-poly.py', 'shortPoll': 60, 'longPoll': 180, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '503a1f86-943d-4f44-8c0c-ed4e9c4fd2e1', 'noLicense': 0, 'latestVersion': '3.1.5', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '59504506-250f-419b-bef3-67048712c138', 'uuid': '00:21:b9:02:65:1c', 'name': 'Blink', 'nsid': '02b66257-0f05-4624-9c27-6855c828c844', 'expires': 0, 'nickname': None, 'profileNum': 8, 'developerMode': 0, 'timeAdded': 1719297099290, 'timeStarted': 1758085659353, 'timeModified': 1758085663771, 'version': '0.4.8', 'edition': 'Standard', 'branch': 'main', 'url': 'https://github.com/Panda88CO/udi-Blink.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_8', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'udiBlinkController.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '119ff071-becc-4671-9134-501a040a40ef', 'noLicense': 0, 'latestVersion': '0.4.8', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.902 Thread-2 (parameter_handler) udi_interface INFO phue:connect: Error opening config file, will attempt bridge registration 2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '137fb83b-0c96-47dc-b395-a75f847075d4', 'uuid': '00:21:b9:02:65:1c', 'name': 'Twinkly', 'nsid': 'f5f38126-56f2-4f1d-a1d4-a175b0639096', 'expires': 0, 'nickname': None, 'profileNum': 6, 'developerMode': 0, 'timeAdded': 1719296895682, 'timeStarted': 1758085659768, 'timeModified': 1758085664245, 'version': '3.0.0', 'edition': 'Free', 'branch': 'main', 'url': 'https://github.com/UniversalDevicesInc-PG3/udi-twinkly-nodeserver.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_6', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'twinkly_poly.py', 'shortPoll': 60, 'longPoll': 300, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '', 'noLicense': 0, 'latestVersion': '3.0.0', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '1cd02c69-534c-4de5-a782-ff0edb8a384f', 'uuid': '00:21:b9:02:65:1c', 'name': 'Ecobee', 'nsid': 'af1f50a2-7aaf-43c1-aa53-276b2587cb22', 'expires': 0, 'nickname': None, 'profileNum': 12, 'developerMode': 0, 'timeAdded': 1719297099268, 'timeStarted': 1758085660972, 'timeModified': 1758085664024, 'version': '3.1.5', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Ecobee.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_12', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":2,"name":"Debug + Session Verbose","value":"DEBUG_SESSION_VERBOSE","level":8},{"id":1,"name":"Debug + Session","value":"DEBUG_SESSION","level":9}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'ecobee-poly.py', 'shortPoll': 60, 'longPoll': 180, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '503a1f86-943d-4f44-8c0c-ed4e9c4fd2e1', 'noLicense': 0, 'latestVersion': '3.1.5', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '59504506-250f-419b-bef3-67048712c138', 'uuid': '00:21:b9:02:65:1c', 'name': 'Blink', 'nsid': '02b66257-0f05-4624-9c27-6855c828c844', 'expires': 0, 'nickname': None, 'profileNum': 8, 'developerMode': 0, 'timeAdded': 1719297099290, 'timeStarted': 1758085659353, 'timeModified': 1758085663771, 'version': '0.4.8', 'edition': 'Standard', 'branch': 'main', 'url': 'https://github.com/Panda88CO/udi-Blink.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_8', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'udiBlinkController.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '119ff071-becc-4671-9134-501a040a40ef', 'noLicense': 0, 'latestVersion': '0.4.8', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '4f558c4c-e814-4cc0-93ea-1b03ce8dec7c', 'uuid': '00:21:b9:02:65:1c', 'name': 'FlumeWater', 'nsid': '3437f14b-7a1c-4361-815f-91476a627007', 'expires': 0, 'nickname': None, 'profileNum': 11, 'developerMode': 0, 'timeAdded': 1719297099301, 'timeStarted': 1758085660259, 'timeModified': 1758085665689, 'version': '3.1.1', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/FlumeWater.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_11', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":5,"name":"Debug + Modules","value":"DEBUG_MODULES","level":9},{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'flumewater-poly.py', 'shortPoll': 30, 'longPoll': 240, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '731353c7-6151-4d79-a92b-29133377ec78', 'noLicense': 0, 'latestVersion': '3.1.1', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '4f558c4c-e814-4cc0-93ea-1b03ce8dec7c', 'uuid': '00:21:b9:02:65:1c', 'name': 'FlumeWater', 'nsid': '3437f14b-7a1c-4361-815f-91476a627007', 'expires': 0, 'nickname': None, 'profileNum': 11, 'developerMode': 0, 'timeAdded': 1719297099301, 'timeStarted': 1758085660259, 'timeModified': 1758085665689, 'version': '3.1.1', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/FlumeWater.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_11', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":5,"name":"Debug + Modules","value":"DEBUG_MODULES","level":9},{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'flumewater-poly.py', 'shortPoll': 30, 'longPoll': 240, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '731353c7-6151-4d79-a92b-29133377ec78', 'noLicense': 0, 'latestVersion': '3.1.1', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'dccefcdb-7335-410b-9dee-46cacbad10ba', 'uuid': '00:21:b9:02:65:1c', 'name': 'Kasa', 'nsid': '47434058-cf83-4ad5-b7ed-c0faa511fe60', 'expires': 0, 'nickname': None, 'profileNum': 7, 'developerMode': 0, 'timeAdded': 1719297399369, 'timeStarted': 1758085663448, 'timeModified': 1758146397061, 'version': '3.1.4', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Kasa.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_7', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":5,"name":"Debug + Modules","value":"DEBUG_MODULES","level":9},{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'kasa-poly.py', 'shortPoll': 30, 'longPoll': 240, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'tplkasactl', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '4b3754d8-1092-45a5-8f69-e1c9dccf66ea', 'noLicense': 0, 'latestVersion': '3.1.4', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '4a3345c7-51a5-4730-a148-5edaa75384ff', 'uuid': '00:21:b9:02:65:1c', 'name': 'ST-Inventory', 'nsid': 'c126923a-afcd-4e6d-9e46-58576796f551', 'expires': 0, 'nickname': None, 'profileNum': 2, 'developerMode': 0, 'timeAdded': 1719297399376, 'timeStarted': 1758085659573, 'timeModified': 1758085661423, 'version': '1.0.12', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/pg3_inventory.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_2', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'node', 'executable': 'st-inventory.js', 'shortPoll': 300, 'longPoll': 600, 'allowIsyAccess': 1, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': 'bf792bfd-00e9-44c2-8399-ef547f9bbd88', 'noLicense': 0, 'latestVersion': '1.0.12', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '0c1e8d33-1ae8-456b-8e19-d4a50712e775', 'uuid': '00:21:b9:02:65:1c', 'name': 'Bluetooth', 'nsid': '40b26907-c607-4a7d-be8d-86d1776525b2', 'expires': 0, 'nickname': None, 'profileNum': 14, 'developerMode': 0, 'timeAdded': 1719297399379, 'timeStarted': 1758085659726, 'timeModified': 1758085663567, 'version': '1.0.7', 'edition': 'Free', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/bluetooth-1.0.7.tar.gz', 'home': '/var/polyglot/pg3/ns/0021b902651c_14', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'bluetooth.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': 'c0c55d0d-9fb8-472f-8099-271c2be07c75', 'noLicense': 0, 'latestVersion': '1.0.7', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '8a6bea85-6ccb-4cf4-b327-e85fa24720bc', 'uuid': '00:21:b9:02:65:1c', 'name': 'AudioPlayer', 'nsid': 'c582beed-644f-44c8-8145-d676b4f035fd', 'expires': 0, 'nickname': None, 'profileNum': 15, 'developerMode': 0, 'timeAdded': 1719297399383, 'timeStarted': 1758085659456, 'timeModified': 1758085664325, 'version': '1.3.7', 'edition': 'Professional', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/audio-player-1.3.7.pro.tar.gz', 'home': '/var/polyglot/pg3/ns/0021b902651c_15', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'audio-player.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 600, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '10726ac8-0534-4ae5-b420-0ac193173365', 'noLicense': 0, 'latestVersion': '1.3.7', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'b0e96f94-9512-466f-b625-4ddf29d34b37', 'uuid': '00:21:b9:02:65:1c', 'name': 'Notification', 'nsid': '132e8dd7-e452-41dd-80f1-6a7da660f00b', 'expires': 0, 'nickname': None, 'profileNum': 3, 'developerMode': 0, 'timeAdded': 1719297699427, 'timeStarted': 1758085659974, 'timeModified': 1758085664371, 'version': '3.6.16', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Notification.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_3', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'notification-poly.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '94dd0ef7-6d1d-4c34-81bd-dcb87632c130', 'noLicense': 0, 'latestVersion': '3.6.16', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'bafc00c2-44da-47f9-9c84-0e5a749a99c6', 'uuid': '00:21:b9:02:65:1c', 'name': 'udiTeslaEV2', 'nsid': '50dfa8d4-e3cf-4eb6-a4de-ffa59b84ed1d', 'expires': 1749513600000, 'nickname': None, 'profileNum': 4, 'developerMode': 0, 'timeAdded': 1733199479420, 'timeStarted': 1739322036051, 'timeModified': 1749612568895, 'version': '0.1.53', 'edition': 'Standard', 'branch': 'main', 'url': 'https://github.com/Panda88CO/udi-TeslaEV2', 'home': '/var/polyglot/pg3/ns/0021b902651c_4', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'TeslaEV2main.py', 'shortPoll': 600, 'longPoll': 7200, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 1, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '4d74d631-e454-48cd-8015-5b1b2b29b18d', 'noLicense': 0, 'latestVersion': '0.1.53', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'ca83ef2c-0c3d-44e1-a759-da87d9a1121c', 'uuid': '00:21:b9:02:65:1c', 'name': 'udiTeslaPW2', 'nsid': '09a306c6-ba96-4ed6-8beb-e915947d826a', 'expires': 0, 'nickname': None, 'profileNum': 5, 'developerMode': 0, 'timeAdded': 1733543469307, 'timeStarted': 1758085660562, 'timeModified': 1758085967347, 'version': '0.1.30', 'edition': 'Standard', 'branch': 'main', 'url': '\thttps://github.com/Panda88CO/udi-teslaPW2', 'home': '/var/polyglot/pg3/ns/0021b902651c_5', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'TeslaPW2main.py', 'shortPoll': 300, 'longPoll': 1800, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 1, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '2866fa15-622e-4147-9436-a7051a13e261', 'noLicense': 0, 'latestVersion': '0.1.30', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'e0e6f8cc-28ee-455b-8ff9-7a89b1cae867', 'uuid': '00:21:b9:02:65:1c', 'name': 'BambuLab', 'nsid': 'e9d207b0-a165-40e9-b747-38eafa498f2d', 'expires': 0, 'nickname': None, 'profileNum': 9, 'developerMode': 0, 'timeAdded': 1756887683457, 'timeStarted': 1758085660766, 'timeModified': 1758085663587, 'version': '1.0.2', 'edition': 'Standard', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/udi-bambu-poly.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_9', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'bambu_poly.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '6505bfd9-eae9-493c-bb18-f484a55166b8', 'noLicense': 0, 'latestVersion': '1.0.2', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '3049e206-a3d8-43cd-b872-f84d65752f63', 'uuid': '00:21:b9:02:65:1c', 'name': 'Hue', 'nsid': 'e3adc119-1d74-4986-84c6-cfebb19e94df', 'expires': 0, 'nickname': None, 'profileNum': 1, 'developerMode': 0, 'timeAdded': 1758088049234, 'timeStarted': 1758147229924, 'timeModified': 1758147230875, 'version': '0.1.11', 'edition': 'Free', 'branch': 'master', 'url': 'https://github.com/exking/udi-hue-pg3.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_1', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'hue.py', 'shortPoll': 15, 'longPoll': 60, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '', 'noLicense': 0, 'latestVersion': '0.1.11', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.902 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'dccefcdb-7335-410b-9dee-46cacbad10ba', 'uuid': '00:21:b9:02:65:1c', 'name': 'Kasa', 'nsid': '47434058-cf83-4ad5-b7ed-c0faa511fe60', 'expires': 0, 'nickname': None, 'profileNum': 7, 'developerMode': 0, 'timeAdded': 1719297399369, 'timeStarted': 1758085663448, 'timeModified': 1758146397061, 'version': '3.1.4', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Kasa.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_7', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":5,"name":"Debug + Modules","value":"DEBUG_MODULES","level":9},{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'kasa-poly.py', 'shortPoll': 30, 'longPoll': 240, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': 'tplkasactl', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '4b3754d8-1092-45a5-8f69-e1c9dccf66ea', 'noLicense': 0, 'latestVersion': '3.1.4', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '4a3345c7-51a5-4730-a148-5edaa75384ff', 'uuid': '00:21:b9:02:65:1c', 'name': 'ST-Inventory', 'nsid': 'c126923a-afcd-4e6d-9e46-58576796f551', 'expires': 0, 'nickname': None, 'profileNum': 2, 'developerMode': 0, 'timeAdded': 1719297399376, 'timeStarted': 1758085659573, 'timeModified': 1758085661423, 'version': '1.0.12', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/pg3_inventory.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_2', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'node', 'executable': 'st-inventory.js', 'shortPoll': 300, 'longPoll': 600, 'allowIsyAccess': 1, 'nsInfoPoll': 0, 'discover': 1, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': 'bf792bfd-00e9-44c2-8399-ef547f9bbd88', 'noLicense': 0, 'latestVersion': '1.0.12', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '0c1e8d33-1ae8-456b-8e19-d4a50712e775', 'uuid': '00:21:b9:02:65:1c', 'name': 'Bluetooth', 'nsid': '40b26907-c607-4a7d-be8d-86d1776525b2', 'expires': 0, 'nickname': None, 'profileNum': 14, 'developerMode': 0, 'timeAdded': 1719297399379, 'timeStarted': 1758085659726, 'timeModified': 1758085663567, 'version': '1.0.7', 'edition': 'Free', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/bluetooth-1.0.7.tar.gz', 'home': '/var/polyglot/pg3/ns/0021b902651c_14', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'bluetooth.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': 'c0c55d0d-9fb8-472f-8099-271c2be07c75', 'noLicense': 0, 'latestVersion': '1.0.7', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '8a6bea85-6ccb-4cf4-b327-e85fa24720bc', 'uuid': '00:21:b9:02:65:1c', 'name': 'AudioPlayer', 'nsid': 'c582beed-644f-44c8-8145-d676b4f035fd', 'expires': 0, 'nickname': None, 'profileNum': 15, 'developerMode': 0, 'timeAdded': 1719297399383, 'timeStarted': 1758085659456, 'timeModified': 1758085664325, 'version': '1.3.7', 'edition': 'Professional', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/audio-player-1.3.7.pro.tar.gz', 'home': '/var/polyglot/pg3/ns/0021b902651c_15', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'audio-player.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 600, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '10726ac8-0534-4ae5-b420-0ac193173365', 'noLicense': 0, 'latestVersion': '1.3.7', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'b0e96f94-9512-466f-b625-4ddf29d34b37', 'uuid': '00:21:b9:02:65:1c', 'name': 'Notification', 'nsid': '132e8dd7-e452-41dd-80f1-6a7da660f00b', 'expires': 0, 'nickname': None, 'profileNum': 3, 'developerMode': 0, 'timeAdded': 1719297699427, 'timeStarted': 1758085659974, 'timeModified': 1758085664371, 'version': '3.6.16', 'edition': 'Standard', 'branch': '', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/Notification.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_3', 'log': 'logs/debug.log', 'logLevel': 'WARNING', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'notification-poly.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': 'controller', 'status_driver': 'ST', 'orderId': None, 'store': 'Production', 'option': '94dd0ef7-6d1d-4c34-81bd-dcb87632c130', 'noLicense': 0, 'latestVersion': '3.6.16', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'bafc00c2-44da-47f9-9c84-0e5a749a99c6', 'uuid': '00:21:b9:02:65:1c', 'name': 'udiTeslaEV2', 'nsid': '50dfa8d4-e3cf-4eb6-a4de-ffa59b84ed1d', 'expires': 1749513600000, 'nickname': None, 'profileNum': 4, 'developerMode': 0, 'timeAdded': 1733199479420, 'timeStarted': 1739322036051, 'timeModified': 1749612568895, 'version': '0.1.53', 'edition': 'Standard', 'branch': 'main', 'url': 'https://github.com/Panda88CO/udi-TeslaEV2', 'home': '/var/polyglot/pg3/ns/0021b902651c_4', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'TeslaEV2main.py', 'shortPoll': 600, 'longPoll': 7200, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 1, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '4d74d631-e454-48cd-8015-5b1b2b29b18d', 'noLicense': 0, 'latestVersion': '0.1.53', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'ca83ef2c-0c3d-44e1-a759-da87d9a1121c', 'uuid': '00:21:b9:02:65:1c', 'name': 'udiTeslaPW2', 'nsid': '09a306c6-ba96-4ed6-8beb-e915947d826a', 'expires': 0, 'nickname': None, 'profileNum': 5, 'developerMode': 0, 'timeAdded': 1733543469307, 'timeStarted': 1758085660562, 'timeModified': 1758085967347, 'version': '0.1.30', 'edition': 'Standard', 'branch': 'main', 'url': '\thttps://github.com/Panda88CO/udi-teslaPW2', 'home': '/var/polyglot/pg3/ns/0021b902651c_5', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'TeslaPW2main.py', 'shortPoll': 300, 'longPoll': 1800, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 1, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '2866fa15-622e-4147-9436-a7051a13e261', 'noLicense': 0, 'latestVersion': '0.1.30', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': 'e0e6f8cc-28ee-455b-8ff9-7a89b1cae867', 'uuid': '00:21:b9:02:65:1c', 'name': 'BambuLab', 'nsid': 'e9d207b0-a165-40e9-b747-38eafa498f2d', 'expires': 0, 'nickname': None, 'profileNum': 9, 'developerMode': 0, 'timeAdded': 1756887683457, 'timeStarted': 1758085660766, 'timeModified': 1758085663587, 'version': '1.0.2', 'edition': 'Standard', 'branch': 'null', 'url': 'https://pg3store.isy.io/v2/nodeservers/production/udi-bambu-poly.zip', 'home': '/var/polyglot/pg3/ns/0021b902651c_9', 'log': 'logs/debug.log', 'logLevel': 'INFO', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'bambu_poly.py', 'shortPoll': 60, 'longPoll': 600, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '6505bfd9-eae9-493c-bb18-f484a55166b8', 'noLicense': 0, 'latestVersion': '1.0.2', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.903 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS getNsInfo message {'id': '3049e206-a3d8-43cd-b872-f84d65752f63', 'uuid': '00:21:b9:02:65:1c', 'name': 'Hue', 'nsid': 'e3adc119-1d74-4986-84c6-cfebb19e94df', 'expires': 0, 'nickname': None, 'profileNum': 1, 'developerMode': 0, 'timeAdded': 1758088049234, 'timeStarted': 1758147229924, 'timeModified': 1758147230875, 'version': '0.1.11', 'edition': 'Free', 'branch': 'master', 'url': 'https://github.com/exking/udi-hue-pg3.git', 'home': '/var/polyglot/pg3/ns/0021b902651c_1', 'log': 'logs/debug.log', 'logLevel': 'DEBUG', 'logLevelList': '[{"id":4,"name":"Debug","value":"DEBUG","level":10},{"id":3,"name":"Info","value":"INFO","level":20},{"id":2,"name":"Warning","value":"WARNING","level":30},{"id":1,"name":"Error","value":"ERROR","level":40},{"id":0,"name":"Critical","value":"CRITICAL","level":50}]', 'enabled': 1, 'connected': 1, 'devMode': 0, 'type': 'python3', 'executable': 'hue.py', 'shortPoll': 15, 'longPoll': 60, 'allowIsyAccess': 0, 'nsInfoPoll': 0, 'discover': 0, 'oauth': 0, 'requestId': 0, 'status_node': None, 'status_driver': None, 'orderId': None, 'store': 'Production', 'option': '', 'noLicense': 0, 'latestVersion': '0.1.11', 'dbVersion': 1} from Polyglot 2025-09-17 15:13:50.904 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]} 2025-09-17 15:13:50.904 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]} 2025-09-17 15:13:50.906 Thread-2 (parameter_handler) udi_interface ERROR hue:connect: Cannot find Hue Bridge 2025-09-17 15:13:50.906 Thread-2 (parameter_handler) udi_interface ERROR hue:connect: Cannot find Hue Bridge 2025-09-17 15:13:50.918 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom 2025-09-17 15:13:50.918 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom 2025-09-17 15:13:50.918 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{}'} from Polyglot 2025-09-17 15:13:50.918 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot 2025-09-17 15:13:50.918 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {} 2025-09-17 15:13:50.918 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom 2025-09-17 15:13:50.918 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom 2025-09-17 15:13:50.918 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{}'} from Polyglot 2025-09-17 15:13:50.918 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot 2025-09-17 15:13:50.918 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {} 2025-09-17 15:13:50.957 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2025-09-17 15:13:50.957 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2025-09-17 15:13:51.025 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message addnode 2025-09-17 15:13:51.025 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message addnode 2025-09-17 15:13:51.026 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING addnode 2025-09-17 15:13:51.026 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS addnode message {'id': '00a0f77b-8805-4636-8324-cd0b06f6f83e', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'address': 'huebridge', 'name': 'Hue', 'nodeDefId': 'HUEBR', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': 'huebridge', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1758142636749, 'timeModified': 1758142636749, 'dbVersion': 1} from Polyglot 2025-09-17 15:13:51.026 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING addnode 2025-09-17 15:13:51.026 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS addnode message {'id': '00a0f77b-8805-4636-8324-cd0b06f6f83e', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'address': 'huebridge', 'name': 'Hue', 'nodeDefId': 'HUEBR', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': 'huebridge', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1758142636749, 'timeModified': 1758142636749, 'dbVersion': 1} from Polyglot 2025-09-17 15:13:51.026 Thread-5 (start) udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot. 2025-09-17 15:13:51.026 Thread-5 (start) udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving 2025-09-17 15:13:51.026 Command udi_interface.interface DEBUG interface:_handleAddNode: add node response: {'id': '00a0f77b-8805-4636-8324-cd0b06f6f83e', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'address': 'huebridge', 'name': 'Hue', 'nodeDefId': 'HUEBR', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': 'huebridge', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1758142636749, 'timeModified': 1758142636749, 'dbVersion': 1} 2025-09-17 15:13:51.026 Thread-5 (start) udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot. 2025-09-17 15:13:51.026 Thread-5 (start) udi_interface.custom DEBUG custom:clear: CUSTOM: Clear ...saving 2025-09-17 15:13:51.026 Command udi_interface.interface DEBUG interface:_handleAddNode: add node response: {'id': '00a0f77b-8805-4636-8324-cd0b06f6f83e', 'uuid': '00:21:b9:02:65:1c', 'profileNum': 1, 'address': 'huebridge', 'name': 'Hue', 'nodeDefId': 'HUEBR', 'nls': None, 'hint': '0x00000000', 'controller': 0, 'primaryNode': 'huebridge', 'private': None, 'isPrimary': 1, 'enabled': 1, 'timeAdded': 1758142636749, 'timeModified': 1758142636749, 'dbVersion': 1} 2025-09-17 15:13:51.027 Thread-5 (start) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2025-09-17 15:13:51.030 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'installprofile': {'reboot': False}} 2025-09-17 15:13:51.027 Thread-5 (start) udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2025-09-17 15:13:51.030 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'installprofile': {'reboot': False}} 2025-09-17 15:13:51.031 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]} 2025-09-17 15:13:51.031 Thread-1 (send_thread) udi_interface.interface DEBUG interface:_send: PUBLISHING {'set': [{'key': 'notices', 'value': {}}]} 2025-09-17 15:13:51.083 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom 2025-09-17 15:13:51.083 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message custom 2025-09-17 15:13:51.083 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom 2025-09-17 15:13:51.084 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{}'} from Polyglot 2025-09-17 15:13:51.084 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot 2025-09-17 15:13:51.083 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING custom 2025-09-17 15:13:51.084 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS custom message {'notices': '{}'} from Polyglot 2025-09-17 15:13:51.084 Command udi_interface.interface DEBUG interface:_handleInput: Process custom message notices from Polyglot 2025-09-17 15:13:51.084 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {} 2025-09-17 15:13:51.122 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2025-09-17 15:13:51.084 Command udi_interface.custom DEBUG custom:load: CUSTOM: load {} 2025-09-17 15:13:51.122 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2025-09-17 15:13:52.028 MQTT udi_interface.interface INFO interface:_message: Profile installation finished 2025-09-17 15:13:52.028 MQTT udi_interface.interface INFO interface:_message: Profile installation finished 2025-09-17 15:14:04.928 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:14:04.928 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:14:04.928 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:14:04.929 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:14:19.933 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:14:04.928 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:14:04.929 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:14:19.933 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:14:19.934 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:14:19.934 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:14:34.937 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:14:19.934 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:14:19.934 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:14:34.937 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:14:34.937 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:14:34.938 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:14:49.924 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2025-09-17 15:14:34.937 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:14:34.938 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:14:49.924 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2025-09-17 15:14:49.924 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2025-09-17 15:14:49.924 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot 2025-09-17 15:14:49.965 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:14:49.924 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2025-09-17 15:14:49.924 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot 2025-09-17 15:14:49.965 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:14:49.965 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:14:49.965 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:14:49.965 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:14:49.965 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:15:04.942 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:15:04.942 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:15:19.947 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:15:19.947 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:15:19.947 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:15:34.951 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:15:34.951 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:15:34.951 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:15:49.961 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2025-09-17 15:15:49.961 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2025-09-17 15:15:49.961 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot 2025-09-17 15:15:50.002 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:15:50.002 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:15:50.002 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:16:04.959 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:16:04.959 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:16:04.959 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:16:34.967 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:16:34.967 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:16:34.967 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:16:49.928 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2025-09-17 15:16:49.928 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2025-09-17 15:16:49.928 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot 2025-09-17 15:16:49.969 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:16:49.969 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:16:49.969 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:17:04.971 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:17:04.971 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:17:04.971 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:17:19.980 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:17:19.980 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:17:19.980 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:17:34.988 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:17:34.988 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:17:34.988 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:17:49.930 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2025-09-17 15:17:49.930 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2025-09-17 15:17:49.930 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot 2025-09-17 15:17:49.989 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:17:49.989 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:17:49.989 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:18:04.993 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:18:04.993 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:18:04.993 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:18:34.996 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:18:34.996 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:18:34.996 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:18:49.937 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2025-09-17 15:18:49.937 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2025-09-17 15:18:49.937 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot 2025-09-17 15:18:49.997 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:18:49.997 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:18:49.997 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:19:05.001 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:19:05.001 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:19:05.001 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:19:20.003 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:19:20.003 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:19:20.003 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:19:35.011 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:19:35.012 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:19:35.012 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:20:05.016 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:20:05.016 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:20:05.016 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:20:20.020 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:20:20.020 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:20:20.020 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:20:35.026 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:20:35.026 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:20:35.026 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:20:49.945 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2025-09-17 15:20:49.945 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2025-09-17 15:20:49.945 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot 2025-09-17 15:20:50.028 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:20:50.028 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:20:50.028 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:21:05.037 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:21:05.037 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:21:05.037 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:21:20.045 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:21:20.046 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:21:20.046 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:21:35.047 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:21:35.047 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:21:35.047 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:22:35.059 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:22:35.059 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:22:35.059 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot 2025-09-17 15:22:49.964 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2025-09-17 15:22:49.964 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2025-09-17 15:22:49.964 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot 2025-09-17 15:22:50.059 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message shortPoll 2025-09-17 15:22:50.060 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING shortPoll 2025-09-17 15:22:50.060 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS shortPoll message {} from Polyglot
  4. I also wanted to send you some errors that I am seeing
  5. Hello, thank you for getting back to me but here's another screenshot. I don't see what you were speaking of in regards of being below where I input it all this information.
  6. Hello, I must be doing something wrong. I want to send you the files you asked for and also screenshot the information from both my printers. Please call me and let me know where I drop off Thank You very much! Stephen Gary Sutherland BambuLab_9-3-2025_125720_AM.zip BambuLab_9-3-2025_125722_AM.zip
  7. Just got back in town and following up on all my emails. I'll be sending you the log file shortly.
  8. Hello, I want to give you a couple of screenshots so you can see which version I'm on. Thank you I will be making a ticket when I get a chance. I have power cycle system, and waiting to capture a log
  9. For quite some time I've been getting this high volume every time I make any changes to any of my notes. What the heck does this mean and how do I fix it?
  10. After rebooting this just comes up over and over and over and I can't get past it
  11. Hello, I’ve done updates on the app and I’ve done it logged in neither one completes the updates and I’ve been doing this for three days straight and I can’t get any of the updates to finish or even to try to install…. so where do I go from here? Any thoughts?
  12. I have done this firm update over and over and over and also I've done the package updates and it still says there is a version available... Please let me know where to go from here on the firmware update, so I stopped getting this available for her notification popping up Thank You for your time
  13. Well, it hasn't worked for a while and I was just sick of it today so I fully erased the EISY and restored it and everything came back online I just had to fix some Z wave door locks, but it's working again fully Thank you all for trying to get me the help I needed to get this fixed, but I think it was too far gone and there's no way of getting all the systems back up and running with the Insteon, Zwave the Zigby.... So I needed just to clean it out and start over...... This file of all my devices and everything started with day one the very first universal devices 994 you could buy..... This file is very very old over decade
  14. I want to reach out because Im still have no luck with my EISY working with IoX 5.8.3 is not connected. What m I missing ... thank u
  15. Hello brain trust I want to reach out again I still have no luck with my EIS. Why working? It still shows that my IoX Version: 5.8.3 is not connected. Can anyone please help me get this fixed because it's wreaking havoc with programs and you not working
  16. All great suggestions I've tried all and nothing seems to repair the problem
  17. Thank you for that information and yes, I’ve done that a few times with no luck and have rebooted my system and then done it again with no luck. This all happened after I did the update FYI.
  18. any thoughts on how to fix this
  19. and now all my nodes also offline too
  20. rebooting, reload packages, login local
  21. Hello all, This happened the other day and I can't get the IoX Version: 5.8.3 connected again. Please let me know what I am doing wrong
  22. Hello, this is been a concern since we switched over to Polygot 3 where the Hue will work for a couple of months and then it won't be able to find the bridge. I'll do everything under the sun and then randomly it will work for a while and then it breaks again. Can you please shed light on exactly why this is happening or how we can fix this because I know I'm not the only person this is happening to.. Thank You very much! 2023-12-05 11:26:55,627 MainThread udi_interface INFO polylogger:set_basic_config: set_basic_config: enable=True level=30 2023-12-05 11:26:55,627 MainThread udi_interface INFO __init__:<module>: UDI interface initializing 2023-12-05 11:26:55,627 MainThread udi_interface INFO __init__:<module>: User=0021b902651c_1 2023-12-05 11:26:55,628 MainThread udi_interface INFO __init__:<module>: Home=/var/polyglot/pg3/ns/0021b902651c_1 2023-12-05 11:26:55,628 MainThread udi_interface INFO __init__:<module>: Node Server Path=/var/polyglot/pg3/ns/0021b902651c_1 2023-12-05 11:26:55,628 MainThread udi_interface INFO __init__:<module>: PG3INIT=eyJ1dWlkIjoiMDA6MjE6Yjk6MDI6NjU6MWMiLCJwcm9maWxlTnVtIjoxLCJsb2dMZXZlbCI6IklORk8iLCJ0b2tlbiI6IkZNeUNxJnExeG9EcFRLZzEiLCJtcXR0SG9zdCI6ImxvY2FsaG9zdCIsIm1xdHRQb3J0Ijo4ODgzLCJzZWN1cmUiOjEsImlzUEczeCI6dHJ1ZSwicGczVmVyc2lvbiI6IjMuMi4xNiIsImlzeVZlcnNpb24iOiI1LjcuMSIsImVkaXRpb24iOiJGcmVlIn0= 2023-12-05 11:26:55,628 MainThread udi_interface INFO __init__:<module>: Loading interface module 2023-12-05 11:26:55,673 MainThread udi_interface INFO interface:<module>: Loading MQTT module 2023-12-05 11:26:56,193 MainThread udi_interface INFO interface:<module>: MQTT module loaded 2023-12-05 11:26:56,423 MainThread udi_interface INFO __init__:<module>: Loading udi_interface module 2023-12-05 11:26:56,424 MainThread udi_interface INFO __init__:<module>: Loading node module 2023-12-05 11:26:56,424 MainThread udi_interface INFO __init__:<module>: Loading custom module 2023-12-05 11:26:56,424 MainThread udi_interface INFO __init__:<module>: Loading isy module 2023-12-05 11:26:56,424 MainThread udi_interface INFO __init__:<module>: UDI interface initialized 2023-12-05 11:26:56,424 MainThread udi_interface INFO __init__:<module>: UDI Python Interface for Polyglot version 3 3.2.6 Starting... 2023-12-05 11:26:56,427 MainThread udi_interface.interface INFO interface:__init__: Initialization received from Polyglot V3 3.2.16 [ISY: 5.7.1, Slot: 1] 2023-12-05 11:26:56,427 MainThread udi_interface.interface INFO interface:__init__: Connect: Network Interface: {'addr': '192.168.1.97', 'netmask': '255.255.255.0', 'broadcast': '192.168.1.255'} 2023-12-05 11:26:56,427 Interface udi_interface.interface INFO interface:_startMqtt: Connecting to MQTT... localhost:8883 2023-12-05 11:26:56,428 Interface udi_interface.interface INFO interface:_startMqtt: Using SSL cert: 0021b902651c_1.cert key: 0021b902651c_1.key ca: /usr/local/etc/ssl/certs/ud.ca.cert 2023-12-05 11:26:56,428 MainThread udi_interface.interface WARNING interface:start: No node server version specified. Using deprecated server.json version 2023-12-05 11:26:56,429 MainThread udi_interface.interface WARNING interface:db_getNodeDrivers: huebridge not found in database. 2023-12-05 11:26:56,429 MainThread udi_interface.interface INFO interface:addNode: Adding node Hue(huebridge) [None] 2023-12-05 11:26:56,429 MainThread udi_interface INFO hue:__init__: Started Hue Protocol 2023-12-05 11:26:56,478 MQTT udi_interface.interface INFO interface:_connect: MQTT Connected with result code 0 (Success) 2023-12-05 11:26:56,479 MQTT udi_interface.interface INFO interface:_connect: MQTT Subscribing to topic: udi/pg3/ns/clients/00:21:b9:02:65:1c_1 - MID: 2 Result: 0 2023-12-05 11:26:56,522 MQTT udi_interface.interface INFO interface:_subscribe: MQTT Subscribed Succesfully for Message ID: 2 - QoS: (0,) 2023-12-05 11:26:56,624 Thread-2 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-12-05 11:26:56,625 Thread-2 udi_interface INFO hue:connect: Saved bridges information is not found 2023-12-05 11:26:56,625 Thread-2 udi_interface INFO hue:connect: No bridge configuration found, trying discovery... 2023-12-05 11:26:56,625 Thread-2 udi_interface INFO phue:connect: Attempting to connect to the bridge... 2023-12-05 11:26:56,626 Thread-2 udi_interface INFO phue:connect: Error opening config file, will attempt bridge registration 2023-12-05 11:26:56,688 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-12-05 11:26:56,730 Thread-5 udi_interface.interface INFO interface:updateProfile: Sending Install Profile command to Polyglot. 2023-12-05 11:26:56,731 Thread-5 udi_interface.custom INFO custom:_save: Sending data notices to Polyglot. 2023-12-05 11:26:56,770 Thread-2 udi_interface INFO phue:get_ip_address: Connecting to discovery.meethue.com/ 2023-12-05 11:26:56,850 MQTT udi_interface.interface INFO interface:_message: Successfully set key = notices 2023-12-05 11:26:56,876 Thread-2 udi_interface ERROR hue:connect: Cannot find Hue Bridge 2023-12-05 11:26:56,917 MQTT udi_interface.interface INFO interface:_message: Profile installation finished
  23. Thank God there's a thread for this cause I'm getting the exact same error
  24. Hello, I am using an Apple with Sonoma 14.1.1 (23B81)
  • Create New...
