IndyUDIuser
  1. I upgraded from an ISY994i to Eisy about a year ago. Didn't notice any difference in performance. Several weeks ago my Eisy stopped running programs and responding to Alexa commands. I went to check it and the box was very hot. I spent a few hours rebooting and trying to debug. It did notice an update was available, which restored its functionality (and now requires me to log on to Admin Console with my portal ID and passwords, which takes twice as long). I don't really know what "locked up" in the Eisy but it was very hot, and I fear it may have shortened its lifespan. In the last 2 weeks I've had wierd problems occur with an IOLinc that has been working for years suddenly getting communication errors. I moved it closer to the PLM (on the same power strip actually) and then it worked fine. I moved it back to its original location (15 feet away) and it failed again. Like I said, it has been working for years without an issue. Nothing else has been changed in that room. My PLM is over 10 years old and everything else in the house is working fine.
  2. Sorry, forgot to post the previous version: DEHUM Toggle - [ID 0062][Parent 0057] If From Last Run Time for 'DEHUM Toggle' + 30 minutes For 30 minutes Then $sDehumidifierOn = 1 $sDehumidifierOn Init To $sDehumidifierOn Else $sDehumidifierOn = 0 $sDehumidifierOn Init To $sDehumidifierOn A separate program turns the dehumidifier on or off based on the value of $sDehumidifierOn.
  3. I'm a long-time ISY Admin Console user struggling with the "From Last Run Time" statement. This is the first time I've tried using it. I'm trying to create a simple program that sets a variable to 1 for half an hour and then 0 for the next half hour. Repeat every hour all day. I've tried different variations of the following code but it doesn't behave I think it would. Or I don't know how this works in plain English. The current version (below) turns on for 30 minutes and then off for 60 minutes. DEHUM Toggle - [ID 0062][Parent 0057] If From Last Run Time for 'DEHUM Toggle' + 1 hour For 30 minutes Then $sDehumidifierOn = 1 $sDehumidifierOn Init To $sDehumidifierOn Else $sDehumidifierOn = 0 $sDehumidifierOn Init To $sDehumidifierOn A previous version, shown below, sets the variable to 1 and just leaves it that way forever. I can see from the status log that the program runs every hour, but never sets the variable to 0. Can anybody please explain the thinking on how this "From Last Run TIme" is supposed to work? In the past I had just hard coded all the half hour intervals, but I thought I could come up with something shorter and more succinct. Alas it is fighting me. No combination of times in the command seems to work. (For those that are curious, I like to run my dehumidifier for just half of every hour so that it has time to defrost between runs.) Thanks in advance!
  4. That PDF shows the module I was wishing for, but I don't seem to find that for sale anywhere on Google. I wonder if/when they plan to release it? Knock on wood my current PLM keeps working until then.
  5. I wonder if they ever plan to redesign the PLM. The case design reminds me of the early Insteon products that I got rid of years ago. A smaller size would be nice.
  6. My PLM is at least 10-15 years old. I don't suppose there's a way to check the device electronically to see what is manufacture date is. Does the device label show the date? I haven't unplugged mine in many years and am afraid to touch it. Should I go ahead and buy one just to get the latest improvements in the technology (if any)? Have they changed much in recent years?
  7. I found the setting for "Catch up schedules at restart" and it IS checked. This is the first time I've seen that setting, so it must have been a default. I would think this is OK so that any programs scheduled AFTER the reboot will happen on their appropriately scheduled times. What other ramifications do I need to consider? I left it checked for now. I also see a "Query at restart" which probably explains why the EISY queried every device. I guess this should be harmless. I left it checked. I'm not quite understanding Geddy's comments about the wait. The program seems very simple. Twice a day it turns on the blower, waits 5 minutes, and turns it off again. It has been working fine for months. It has never left the blower turned on for more than 5 minutes. The Onvacation variable simply allows me to prevent the blower from running unnecessarily when I am on vacation. I set that variable to 1 before I leave, and then set it to 0 when I return. I don't have any other programs that affect the BSMT Blower. Perhaps you are saying "what if the reboot occurred during that 5 minute wait?" I guess I don't know to be honest. Is the software smart enough to know that it has to catch up to the middle of that 5 minute wait and continue on where it left off, finishing out the wait and turning the blower off? Or if the power is out for, say, 10 minutes, will it recognize the current time is now past when the blower should have been shut off, and go ahead and shut it off immediately? The X10 Universal Modules I mentioned are used to turn ceiling fans on or off. Two of them are programmed to turn on at noon every day (they turn on my kitchen and living room ceiling fans). A third one turns on again in the evening (to turn off the kitchen fan). None of those programs has "run at startup" set to true, yet they did run. I could hear the modules clacking on and off during the reboot. Not a big deal, just odd. I kind of understand what you are saying about using 2 programs, but I'm hesitant to make this more complicated that it needs to be, given how rare the problem comes up. Thank you nonetheless. Oh well, I'll just chalk this up to "live and learn". P.S. I did move the EISY to a UPS so it shouldn't be affected by power outages (at least relatively short ones). I'm a retired batch programmer and have used Insteon and UDI for many years, but still learning a new trick here and there. Thank you for your assistance and have a good day! Jon
  8. Saturday night 8/16/2025 I had a thunderstorm and my house lost power for a second or two and came back on. This happened twice several minutes apart. Each time, my EISY rebooted and started running a few programs unexpectedly. It was bizarre sitting in my living room as EISY turned on modules unnecessarily after the power restored. Just now I was able to replicate the issue by simply unplugging the EISY and plugging it back in. In the log file there are 134 entries in the few seconds after each power blip. Like it is maybe polling information from modules, getting Status, On Level, Ramp Rate, etc. from just about every device in my house. Is that normal? Here is one example program. It turned on an appliance module for my basement blower for 5 minutes and turned it off again, even though it wasn't 6AM or 5PM. In the Summary tab, this program is not set to Run At Startup. (I have very few programs set to Run At Startup.) Yet this one did. Despite the conditions not being met. Any idea why this would happen? 7D Bsmt blower - [ID 005A][Parent 0023] If ( Time is 6:00:00AM Or Time is 5:00:00PM ) And $sOnVacation is 0 Then Set 'Basement / BSMT Blower' On Wait 5 minutes Set 'Basement / BSMT Blower' Off Else - No Actions - (To add one, press 'Action') I've attached an excerpt from my log. The outages were at 9:43:45PM and again at 9:53:22PM. I inserted a couple blank lines to break them apart. The X10 Universal Modules at lines 20-25 all triggered on even though their programs are not set to Run At Startup. THANKS! Partial EISY Log.xlsx
  9. My Alexa and phone app weren't working but they're back up now. Thanks!
