joeyISY
Everything posted by joeyISY
  1. ISY4Me might be happy with the solution, but I name my Nodes in a way that makes life easier for the programmer, but might be mysterious to a user of the Home page. The Home Page of the UD Mobile app inserts the Node name to tiles when you create them, but allows you to edit the name into anything you want.
  2. Well I guess that I won't be able to enjoy the Insteon, "Configuration options that were improved/fixed," as described by Javi.... Not good if the Java Admin Console is going to be abandoned in three weeks.
  3. In eisy-ui 1.4.8, when I click 'System' and get to the System Upgrade/Upgrade page, the version in the Upgrade To column for eisy-ui is listed as 1.4.8 for 'Production repo' and 'Beta repo'. I clicked 'Staging repo' and a scary window popped-up saying: Staging RepositoryPlease do not use the Staging repo unless requested by UDI Support. Despite the warning, I clicked the 'Use staging repo' button. The number1.4.13 then appeared in the Upgrade To column. I didn't click the 'Upgrade Packages' button because of the warning Should I go ahead and upgrade to the packages from the Staging repo?
  4. I am in-process of weaning myself from the Admin Console, but I notice that the eisy-ui program has different ways of reading/writing some Insteon configurations. For example, I have an Insteon 2844-222 Motion Sensor. In Admin Console which is working fine to control a scene that turns my kitchen light on and off. If I click on the motion sensor node on the Main screen, and then click the 'Options' button. A window pops up which shows a bunch of parameters that I don't understand. I have left all of them in their factory set-up except one called Motion Timeout. I used the Admin Console to set the Motion Timeout to 3000-seconds . This makes the scene turn the kitchen light off 5-minutes after the last time the sensor sees motion. With the eisy-ui, I right click on the motion sensor node and one of the selections is 'Configuration'. Left clicking 'Configuration' opens a new page that includes a gear icon called "Options'. Clicking the Options selection gets me a pop-up window with seven Options: Timeout (0–127) LED Brightness (0–255) Dark Sense (0–255) Sensing No LED On Only Night Mode The 'No LED' has a blue checkmarks next to it, but all of the other Option values are blank. I set the Motion Sensor into communicating mode and clicked the 'Query' button hoping that the parameters in the Motion Sensor would upload, but no luck. The system did seem to communicate, but no data filled in. So, how do I set the Timeout if I want to change it from 3000-seconds? I also have an older 2842-222 Motion Sensor. The Configuration Options has the same window pop-up, but it has Timeout, LED Brightness and Dark Sense values filled in. The Timeout value is 8. Do you know what the Unit-of-Measure is? Before you ask, below are the versions I have on my system. Thanks, -Joe Package Current Version Upgrade To eisy-ui 1.4.8 1.4.8 IoX 6.1.2_10 6.1.2_10 UDX 5.1.0 5.1.0 PG3x 3.4.28 3.4.28 iox-matter service 1.3.24 1.3.24 mosquitto 2.0.18 2.0.18 mDNSResponder 2881.100.56.0.1 2881.100.56.0.1 libwebsockets 4.3.3 4.3.3
  5. My EISY has lost contact with all of my Insteon Devices. I have been operating normally with eisy/insteon for a year or two, but now, the eisy cannot effectively communicate with any of my insteon devices. I am using a 2413S PLM (Address 2B.93.EB) The PLM is attached to the eisy via a Serial-USB cable. The PLM Info/Status comes back with , "3B.93.EB /Connected." When I do the PLM diagnostic for PLM, the system goes through and extensive set of pop-ups where it seems to be doing a "Restore Modem (PLM) procedure. After completing the pop-up sequence I can send commands from the Admin Console t turn things On and Off, but the device does not actually respond. Some devices show the device turning on and off (without actually responding). Other devices get a pop-up saying "Cannot Communicate with [deviuce name]. Please check connections." The device then gets a red exclamation point on the Admin Console Main list. I have another 2413S PLM (Address 3D.95.E3). What is the procedure for swapping it in while doing the least damage to may rather extensive system?
