Eisy-ui control of Insteon Configurations
I am in-process of weaning myself from the Admin Console, but I notice that the eisy-ui program has different ways of reading/writing some Insteon configurations.
For example, I have an Insteon 2844-222 Motion Sensor. In Admin Console which is working fine to control a scene that turns my kitchen light on and off. If I click on the motion sensor node on the Main screen, and then click the 'Options' button. A window pops up which shows a bunch of parameters that I don't understand. I have left all of them in their factory set-up except one called Motion Timeout. I used the Admin Console to set the Motion Timeout to 3000-seconds . This makes the scene turn the kitchen light off 5-minutes after the last time the sensor sees motion.
With the eisy-ui, I right click on the motion sensor node and one of the selections is 'Configuration'. Left clicking 'Configuration' opens a new page that includes a gear icon called "Options'. Clicking the Options selection gets me a pop-up window with seven Options:
Timeout (0–127)
LED Brightness (0–255)
Dark Sense (0–255)
Sensing
No LED
On Only
Night Mode
The 'No LED' has a blue checkmarks next to it, but all of the other Option values are blank. I set the Motion Sensor into communicating mode and clicked the 'Query' button hoping that the parameters in the Motion Sensor would upload, but no luck. The system did seem to communicate, but no data filled in. So, how do I set the Timeout if I want to change it from 3000-seconds?
I also have an older 2842-222 Motion Sensor. The Configuration Options has the same window pop-up, but it has Timeout, LED Brightness and Dark Sense values filled in. The Timeout value is 8. Do you know what the Unit-of-Measure is?
Before you ask, below are the versions I have on my system.
-Joe
Package Current Version Upgrade To
eisy-ui 1.4.8 1.4.8
IoX 6.1.2_10 6.1.2_10
UDX 5.1.0 5.1.0
PG3x 3.4.28 3.4.28
iox-matter service 1.3.24 1.3.24
mosquitto 2.0.18 2.0.18
mDNSResponder 2881.100.56.0.1 2881.100.56.0.1
libwebsockets 4.3.3 4.3.3
