Home Page Widgets... Edit Title?
When adding some parameters to display values on the EISY Home Page, I cannot see a way to edit the title box in a specific widget. In this example, the title "Temp Sensor 1" is not descriptive and it would be good to be able to edit.
Click on the gear icon for Settings in the top right corner. Next click on the vertical ... menue in the right top corner of the widget. Followed by edit title. Make your changes and then save.
That was the first thing I tried. When you click on … vertical, you get an option to edit the tile, but there is no option to edit the title. No matter what choice I make the Tile Title Box is never presented as an editable feature.
I expect the UDI team will need to put this on a feature update list.
Looking at that screen, I'm guessing it is tied to the main node name and therefor, not currently modifiable.
@ISY4Me
From the eisy-ui wiki:
If you want to change the name shown at the top of the tile, please rename the node in the Nodes section. The name of the tile is the name of the node. If you have multiple nodes, the name of the first node listed is the name of the tile. You can reorder the nodes in the Nodes section if needed.
@DennisC Thank you... that is reasonable work around, but as @joeyISY states in the next post, the way you name the equipment is logical for hardware organization and the name that appears in the eisy-ui widget is more functionally descriptive.
Thank you @joeyISY for point that out... it would still be good if the eisy-ui team would consider user editing of the widget title.
Edited by ISY4Me
  • 3 weeks later...
ISY4Me might be happy with the solution, but I name my Nodes in a way that makes life easier for the programmer, but might be mysterious to a user of the Home page. The Home Page of the UD Mobile app inserts the Node name to tiles when you create them, but allows you to edit the name into anything you want.
