n_sievers
Everything posted by n_sievers
  1. I was happy to see that after rolling over to the next day, the issue has corrected as you stated and I have experienced in the past. I was just thinkig that initial time-change inconsistency may have been resolved with all of the new/recent firmware developments so was surprised to see it still occurs as it previously had but glad to see it corrected.
  2. In confirming all of my clocks are adjusted for the end of DST, I have also checked both of my eisy's and both were reflecting the correct time but the sunrise and sunset times are indicating 1 hour earlier than actual. I have confirmed this is consistent on both of my eisy's and also indicating incorrectly in both eisy-ui and AC. Both units are fully up-to-date, correct location and timezones are selected in configuration, and I even initiated a reboot on both, without success. Maybe this will update to reflect the correct times once the day rolls over again at midnight? I have a few programs that rely on sunrise/sunset so hopefully can get resolved fairly quickly.
  3. n_sievers replied to Techman's topic in eisy
    Since I have updated to 6.0.5 on my eisy, I have had 2 separate occurrences where z-wave just stops responding and requires a power cycle where it comes back up and all functionality is restored. I also have a Polisy Pro that have updated and do not have the same issue occurring so seems isolated to my eisy.
  4. Thank you! I will try this approach 1st.
  5. Thank you for your response. I have been considering this as I have something similar to this set up with a notification upon condition that only want to execute once and not continually trigger. With regard to the "status" that I mentioned, the deabolt access alarm condition is only available as "status" that can be referenced and stays static at that until the state changes and not "control" type of notification/command that can be referenced once when that condition/state charges. Thank you for the response, I will try this approach out.
  6. I have a program that is set to trigger a lighting scene when the deadbolt is unlocked via the keypad between Sunset - to Sunrise +. I am using the deadbolt access alarm status "keypad unlock" and the parameters to initiate this and trigger the "then" path of a separate program to set the lighting scene. This generally works as intended but the issue comes about when the deadbolt status hasn't changed from "keypad unlock" and the trigger time of day comes around again, thus triggering the program to run since status is still "keypad unlock". I am looking for a solution that only triggers the program once when the deadbolt is unlocked and not again if the deadbolt remains unlocked and the trigger time comes around again. Unfortunately the access alarm parameters are only "status" and not "control" for the "keypad unlock" condition. For clarification there is another deactivation program for the trigger lighting based on time of day or by manual deactivation. Any thought/insight on resolving this is greatly appreciated.
  7. Thanks to all that responded. Since I deleted the program, the issue has not resurfaced.
  8. So following my deletion of the program it was included in, it hasn't occurred again; fingers crossed!
  9. Thank you for your response. It, along with one other device, is associated with 1 program so will just completely delete that program, reset the local ON level to 100% and see if it occurs again...
  10. I have the most bizarre issue occurring with a single device in my system and am looking for any possible insight. I have a single SwitchLinc 2477D that has continued to have random OFF events occurring and in conjunction with that, the local ON level setting chages from 100% to 40%. This is an entirely new system in a 2nd residence that I have set up up from scratch on a new eisy that is currently running 5.9.1. I have another very extensive system that is currently running on a Polisy, upgraded through several iterations starting with ISY 99i many years ago so am very versed in this and have never encountered anything like this previously. The initially installed switch that this was occurring with was a brand new device and after a couple months of this issue randomly occurring and me completely factory resetting the device and restoring with the issue continuin to return, I replaced with a completely different switch and the issue still was randomly occurring. I have completely deleted the device, added as a new device instsead of restoring and this issue still returns! I have checked all of my programs and associations and there is nothing I am seeing that could be the possible cause of this issue. I have reviewed the logs and all is see is a status change to "off" when this occurs and no other events happening in the immediate timeframe leading up to it. Any insight as to what I could look at would be greatly appreciated.
  11. Just tried logging into portal and get "HTTP error 429" message and remote access to UD Mobile is not functioning either.
  12. Just did this and resolved my issue as well, thank you for posting!
  13. Just checked and mine just reconnected a few minutes ago too.
  14. Unfortunately mine still remains disconnected.
  15. Thank you, I appreciate the quick response and will continue to wait.
  16. I have received the notice that the portal maintenance was completed but unfortunately my system's connectivity has not resumed. When logging into the portal, it is still showing as disconnected with no remote access to UD Mobile and Alexa connectivity. I am running a Polisy Pro on v5.8.4.
  17. I just got home from a trip and found my routines that announce sensor change of state are no longer working. I can’t be sure when they stopped for sure but was sometime between last Wednesday and today. I have tried disabling and rebuilding with no success. I am running Polisy Pro on v 5.8.4
  18. I am on a Polisy Pro running v5.8.4
  19. Just got home from a trip and found my routines are no longer working to announce state of change on a contact sensor. I have tried disable/re-enable and rebuild the routine but nothing was successful.
  20. I just completed the UD Mobile update and all of my lock/deadbolt devices using the default icon that was previously a lock keypad, have now changed to lightbulbs.
  21. Michel got back to me very quickly and just had to complete the upgrade to PG3x and now all is back up and running.
  22. I just tried upgrading from 5.8.3 to 5.8.4 and all seemed to go well with getting 4 finalization beeps. I cleared Java and downloaded new launcher. I went to connect to admin console and was indicating still on 5.8.3 so I initiated a reboot and have now lost connectivity. I never got the 4 beeps and when opening the launcher, my local address is no longer showing and only the "polisy.local" address shows up with a UUID of all "0" except for the final digit which is "1" but is showing it is on 5.8.4. I have tried power cycling the Polisy and the same issue occurs. When I try going to the portal address in the launcher and log in, all devices are showing no status or functionality. My whole system is now down and I have submitted a ticket so am just awaiting a response.
  23. It is very different from any others I have seen and even has a small hole on the opposite side of the case from the "set" and LED that has a small pushbutton on the PCB. The PCB has "Insteon" printed on it but think you may be right in that is was something specially manufactured for Smartenit. With that being said, it may or may not be a capacitor issue plaguing it and with no info out there on it, I may just go ahead and replace all caps with the hope in resurrecting it.
  24. The PLM that was originally on the EZFlora (about 10ish years old) is not dual band, is also not marked as to the model and is a different PCB layout than I have previously seen or recapped; pic attached. The EZIO4O that I was able to successfully use the PLM to replace the faulty one on the EZFlora was a USB 2412U but also want to clarify that the PLM from the EZIO2X4’s that I first attempted to use are the same USB 2412U and do not work with the EZFlora. There is also a small pen marking “9B” on the upper right hand corner of the label on the EZIO2X4’s so I am just making am assumption that is some indicator of the deference in the base PLM’s used?
