johnnyt
Everything posted by johnnyt
  1. I was monitoring udx log during a Restart IoX and noticed that a restart of IoX does a restart of PG3 (twice, actually, in the test I monitored). See below. What's weird is that the uptime number for PG3 didn't/doesn't reflect this apparent PG3 restarts. It continues to show uptime since last system reboot (see my original post). Thu Jul 31 08:25:58 EDT 2025|/usr/local/etc/udx.d/static/udx_startup.sh: stopping isy service ... Thu Jul 31 08:26:05 EDT 2025|/usr/local/etc/udx.d/static/udx_startup.sh: starting isy service ... Thu Jul 31 08:26:05 EDT 2025|/usr/local/etc/udx.d/static/udx_startup.sh: starting pg3x service ... Thu Jul 31 08:26:05 EDT 2025|/usr/local/etc/udx.d/static/udx_startup.sh: starting ud_pkg_stat service ... Thu Jul 31 08:26:05 EDT 2025|/usr/local/etc/udx.d/static/udx_startup.sh: successfully started udx 3.9.0_9 Thu Jul 31 08:26:05 EDT 2025|/usr/local/etc/udx.d/static/udx_startup.sh: isy id = 349 Thu Jul 31 08:26:05 EDT 2025|/usr/local/etc/udx.d/static/udx_startup.sh: polyglot id = 349 Thu Jul 31 08:26:05 EDT 2025|/usr/local/etc/udx.d/static/udx_startup.sh: /etc/rc.conf has matter support Thu Jul 31 08:26:05 EDT 2025|/usr/local/etc/udx.d/static/ud_pkg_stat: wifi.ops is not being called as a comamnd Thu Jul 31 08:26:08 EDT 2025|/usr/local/etc/udx.d/static/udx_startup.sh: restarting pg3x because it didn't start 0 ... Thu Jul 31 08:26:11 EDT 2025|/usr/local/etc/udx.d/static/udx_startup.sh: pg3x started successfully ... I guess this means there's nothing you can do about the Airthings plug-in restarting when IoX restarts? So what about storing the short poll timing somewhere and recalling it at startup so the plug-in never exceeds the API limit? Similar to the INIT function in IoX. Thanks for considering it.
  2. johnnyt replied to pjjameso's topic in Airthings-C
    Would like to add my vote to this. With increasing occurrences of wildfires blowing smoke all over North America it would be good to know as PM2.5 and PM10 go up and down.
  3. Thanks for your reply. Does the plug-in actually need to restart just because one restarted IoX? Can't IoX just read/pull the values still there in the plug-in table (if it hadn't been restarted) to set the initial values in the IoX nodes? I was assuming a pull was possible because I see a "Query" and "Query All" buttons in AC as well as the option do it in programs for the Airthings nodes. If not / alternatively, can either a 'pull' function be added so a push is not needed (much cleaner), or something be added to stop/start the plug-in from a program in IoX? With the latter, one could write a program to stop the plug-in before doing an IoX restart (at least when it's a planned one), and another program that starts the plug-in 10 mins after IoX restarts. Or stop the plug-in when API Limit is exceeded, wait some period of time, then restart it. You're right that one should not have to Restart IoX regularly. Unfortunately, I have a number of issues that UDI either can't reproduce (so can't fix) or won't fix for a while because they have other higher priorities and very limited capacity. One of the unresolved problems is IoX spontaneously restarting, which can happen at highly inopportune time. These happen after IoX has been running for a while so I'm managing the issue by automating restarts to happen in middle of the night when no one notices. Right now weekly restarts at 2AM has avoided random restarts. It also means cleaner shutdowns instead of the hard crash of a random one. I might stretch that to 2 weeks but it's unfortunately become a necessary evil to avoid inopportune restarts, at least until either I and/or UDI can find/fix the root cause. I'm not hopeful that will happen soon, if at all.
  4. Just to provide a visual, I have a program that notifies me by email when Airthings API Limit has been exceeded. Here's an example of what I get in my inbox when I restart IoX:
  5. Hi @Jimbo.Automates, Whenever I restart IoX both my active Airthings-C plug-ins restart. For one of them it causes the plug-in to exceed the API limit for multiple update cycles that can last up to 45 mins when I look back to previous restarts. The plug-in that violates the API contract supports 9 devices with short poll of 330 (5 1/2 mins), which is sufficient in terms of not exceeding API limit (anything over 270 is enough) unless a plug-in restart occurs. The other active plug-in doesn't hit the API limit but it only has 4 devices and a 200 sec short poll. Unfortunately, for several reasons I need to restart IoX with some regularity, meaning a regular violation of the API contract with Airthings. Ideally could you put in a delay of short poll duration at plug-in restart to ensure there is no API limit violation? Desirable would also be no automatic restart when one is just calling for an IoX restart. That seems like a bug to me but I see other plug-ins restart too so maybe there's a reason for it that I'm not seeing? I guess it's not a big deal if one doesn't have an API call limitation but is more problematic when there is one. I will PM you my log (set to Info) for today. There was an automated restart just before 2AM and a manual one around 8:12 AM. Let me know if you need a lower level of debug logs. It's easy to change and replicate the issue. Here's a screenshot showing how PG3 has been running for a couple of weeks now while the plug-in has only been running for less than an hour (when I took the screenshot). Note that this has been happening for a while. i just haven't taken the time to report it until now. Thanks
  6. Thanks @larryllix. You raise a good point of discussion about doing this. I did post not long ago looking for recent feedback/experience on having 2 insteon and 2 zwave networks co-existing together. While there hasn't been any confirmation there that it works (or doesn't) as of the time I write this, it did get a comment from a long time user that supported my own understanding that it should work. I also recall a long time ago (pre zwave 994i days) asking if having 2 insteon networks works, and the answers I got from several people, including UD Support, were basically "yes but you have to know what you're doing". You'll see in that other thread I do ask if someone can confirm whether both insteon networks are helping each other by passing all messages on, what I assume you mean by "echoing", which is how I think it would work. No one has answered that yet so if you know from experience whether/how it works, can you elaborate on that in the other thread? Thanks again
  7. I'm considering splitting up my eISY workload into 2 separate (smaller) IoX instances - one that will continue to run on the same eISY, and one that will run on a currently unused Polisy. I'm hoping to get some help understanding what might be missing in the migration steps I list below, as well as if something simply won't work the way I'm expecting it to work (most notably on the Insteon side). For those curious about my motivations, I've attached more info with context and some of the reasons for wanting to do this (which is not the focus for this thread) Before getting into the migration steps, here are a few important notes about the plan: - A key element of my plan is to use a remote eISY (connected through a VPN but completely disconnected from my Insteon and Zwave devices) to pare down my 'prod' IoX into its two distinct (smaller) "images" that I would then restore onto my existing main eISY and a 'blank' Polisy respectively as an initial load that would take me 90% of the way there. - On the zwave side, I know I would need to exclude/include any/all zwave devices (and fix a bunch of programs) that I now want to control using the IoX instance on the blank Polisy, a.k.a IoP (with a separate Zwave dongle). That's fine as there are only a handful of them. The Polisy will be controlling mostly Insteon stuff. - What isn't clear to me is whether I can avoid having to unlink/relink all the Insteon devices and recreate all the scenes that I now want to control using IoP. One veteran opinion I got was that I may not have to but it hasn't been proven so to be safe I should plan to start over. If I did have to unlink/relink everything, the cost would be high and it would pour a lot of cold water on this idea pretty quickly. My own assumption - and it's a critical one - is that, because Insteon linking uses the hardware's address directly (xx.xx.xx), unlike zwave which creates an arbitrary logical address (e.g. ZY001), I would just be able to do a "Restore PLM" on IoP (with new/blank PLM) and everything will simply work on IoP as they did on the eISY's IoX instance. Stated more explicitly, a Restore PLM on IoP would simply go to every device it knows about using the xx.xx.xx address it has for it and tell those devices that it is now the PLM in charge. Any Insteon devices that I would have deleted when creating the IoP "image" (half a dozen or so) will simply not be queried/updated by IoP since it doesn't have those devices in the PLM table it maintains. The latter devices would therefore still continue to respond to the main eISY/PLM combo. If this assumption is wrong I'd like to know why it doesn't work this way. What am I not understanding about how insteon and "Restore PLM" works? Assuming that my assumption is correct, below are the steps I put together for splitting an IoX instance into two. Note that the image creation prep work (Phase 1) has been tested/refined using my remote eISY. Everything worked as described below and the fixing/cleanup involved was very manageable. Also, all my devices and programs have been organized by folders according to their intended destination, i.e. "eISY" vs "Polisy", to make the deletion process really easy. Phase 1 - Prep work using a remote eISY with its own PLM/zwave Create Polisy 2.0 starter image 1. load current prod eISY backup onto remote eISY 2. restore zwave & disable automatic writing for Insteon 3. delete eISY related programs folder 4. delete eISY related devices folder (mostly zwave with a few Insteon) 5. Zwave | Synchronize | New & Deleted 6. Remove Failed Nodes for all the deleted devices now appearing in root folder 7. take zwave and IoX backup for use in phase 2 Create eISY 2.0 starter image (with only a handful of Insteon devices) 8. load current prod eISY backup onto remote eISY 9. restore zwave & disable automatic writing for Insteon 10. delete Polisy related programs folder 11. delete Polisy related devices folder (mostly Insteon with a few zwave) 12. Zwave | Synchronize | New & Deleted 13. Remove Failed Nodes for all the deleted devices now appearing in root folder 14. take zwave and IoX backup for use in phase 2 Phase 2 - Deployment (starting with Polisy) 15. shutdown prod eISY and unplug its PLM 16. power ON Polisy (with its own PLM/zwave) 17. load Polisy 2.0 starter image 18. restore zwave & disable automatic writing for Insteon 19. exclude zwave devices that are needed on Polisy (and still exist in the image) 20. factory reset zwave dongle (to start clean) 22. re-include zwave devices that are needed on Polisy 23. fix programs 24. Restore PLM 25. shutdown Polisy while eISY is being updated 26. plug in PLM and power ON prod eISY 27. load eISY 2.0 starter image 28. restore zwave backup 29. restore PLM 30. Zwave | Network | Heal Network Anyone ever do something like this? Any thoughts/comments on whether this should work? Any missing or out-of-order steps? whysplit.txt
  8. Updated my Polisy today, which was at latest I could get before this update, i.e. 13.2 and 5.8.4, and it worked fine. I was an early buyer of the Polisy but I went through the pain of getting updated BIOS, etc. some time ago. I made some popcorn and watched it happening in real time by opening a Putty session and typing in: sudo tail -f /var/udx/logs/log It did appear to skip some things (like OS upgrade) the first time around to do some other things first then go back to do the things it skipped, with long pauses along the way so that's why I guess it takes a while. Guessing 15 mins in my case. I saw a lot of messages about things not needed or up to date, so that helped timewise in this case.
  9. Thanks for that bit of info. Can anyone confirm my understand that all insteon signals from both insteon networks will be repeated for all to hear? Also, do zwave repeaters (built solely for that) repeat signals from both zwave networks or just the ones they see when initially powered on? Finally, anyone actually have experience with this?
  10. I'd like to push the content of a variable from one eISY/IoX to a second one. I know how to push a static value, such as '1', to a variable on the second IoX using Network Resources and REST but can't find how to send the dynamic content of a variable. Is there a way to, in effect, have the contents of a variable end up where the '1' is at the end of the "Path" in the screenshot below? I didn't see a way here https://wiki.universal-devices.com/ISY_Developers:API:REST_Interface#Networking I also browsed the documentation on SOAP API, which has a Get Variable option, but I can't find info/examples of if/how I can use Network Resources to achieve my objective using SOAP API instead of REST.
  11. I want to separate my workload (~1400 programs, 751 total nodes, 328 Zwave, 179 Insteon) from one eISY to two eISY's, one for lighting, one for HVAC. Lighting is mostly Insteon with some zwave, while HVAC is mostly Zwave with some Insteon. I don't have any ZMatter or Zigbee at this point but may want to add some in the future. While I've seen Insteon and Zwave co-exist with a couple of test devices using a separate Polisy I have for testing and as a backup in case my eISY fails, I'm wondering if it will scale, particularly for Zwave and Zmatter/Zigbee when devices are spread out further away from their respective controllers, and particularly if there are only a few devices on the 2nd controller For Insteon, I believe all devices repeat all insteon signals no matter which controller/PLM is sending/receiving, meaning both Insteon networks will help each other. (Please correct me if I'm wrong) - Can the same be said about Zwave? As I understand it, I would end up with two separate Zwave networks that will NOT help each other. - What about with Zigbee/ZMatter? Also, worse than not helping each other if that's the case, could/will devices from separate networks actually interfere with each other? Any info would be appreciated.
  12. johnnyt replied to johnnyt's topic in eisy
    the CL command to change the log size does not work using SSH lowercase either
  13. johnnyt replied to johnnyt's topic in eisy
    Not surprised. So how do I increase the log size in eISY? My log file rotates after about a day and a half and getting at and reading the old files for days past is a PIA.
  14. johnnyt posted a topic in eisy
    Am trying to increase my log file file size using the CL command outlined here https://wiki.universal-devices.com/ISY-99i/ISY-26_INSTEON:Advanced_Configuration_Guide by telnet'ing into eISY following the instructions here https://wiki.universal-devices.com/ISY-99i/ISY-26_INSTEON:Quick_Start_Guide#Connecting_to_the_ISY_Shell but I get a message "Could not open connection..." Is this an outdated way of doing it? Is there a way to do this using Putty/SSH (which is working fine)?
  15. I make *extensive* use of this capability. I don't know how people troubleshoot anything more than simple problems with just the log and error log. (Full disclosure: I have over 1300 programs) I just wish I didn't have to click every small '+' sign to get to the folder where the files are each time I go to the web server tab. I also wish there was a better folder view with last changed date/time, file size, and files sortable by those various columns. Be aware that the data is NOT backed up as part of the backup function. You need to go pull the files manually and it's a bit of a process because they are in a folder with restricted access.
  16. I removed an airthings device by deleting it using the plug-in config page and after that the following error kept happening every short poll: 2024-09-22 13:24:04.648 Thread-107 (handler_poll) udi_interface ERROR pgSession:response: Not Found: https://ext-api.airthings.com/v1//devices/3220001054/latest-samples: text: {"error":"NOT_FOUND","error_description":"segment for user <myapikey> does not exist"} 2024-09-22 13:24:04.648 Thread-107 (handler_poll) udi_interface ERROR Controller:api_get: failed to parse res={'code': 404, 'data': {'error': 'NOT_FOUND', 'error_description': 'segment for user <myapikey> does not exist'}} Traceback (most recent call last): File "/var/polyglot/pg3/ns/<myeisy>_8/nodes/Controller.py", line 251, in api_get LOGGER.warning(f"Service returned code {code} {res['data']['message']}") ~~~~~~~~~~~^^^^^^^^^^^ This caused the "server status" in IoX to become false and it triggered a program to notify me of that every short poll. I didn't notice until I checked my email later to see an inbox full of notifications. It's like the polling temporarily changes the status to something other than false but then back to false, causing the program to trigger each time. IMO, I should have only received one notification when it went false the first time. The problem stopped after I restarted the plug-in but I'd suggest that, if possible, some cleaning up could be done within the plug-in when one deletes a node so one does not have to restart to avoid this error. Alternatively the plug-in could restart itself (if that's possible) or a message to restart the plug-in could be provided, although these are less elegant solutions. The problem with restarts is that they reset the polling timer to zero, which causes the API limit to be reached. Of course this is not critical. Just something to maybe consider the next time the plug-in is opened up for changes. Thanks for all the good work you've done on this plug-in to make using these devices in my automation possible.
  17. The other error has not re-occurred. Maybe I just needed to reboot/restart PG3. (I did a reboot)
  18. It happened again the night after I installed 1.2.2 so I went in and turned on debug log level (because the reinstall returned log level to warning only) but it hasn't happened since. Maybe I needed to restart PG3, which I think I did later the next day. Anyway, all is good now. Thanks
  19. Hold on publishing that change. I got a ton of these errors last night again, which you suggested was fixed in 1.2.2: Have turned on debug level for logs - hopefully it happens again soon. Could be tonight because it's been happening almost daily since I reported it. It requires a restart, which then causes API limit to be reached not long after the restart. I wish there was a way to stop/start plug-in from IoX so I could heal things programmatically instead of manually.
  20. Well the long poll does matter because if user picks a short poll that's longer than the long poll using the GUI, it won't stick. I'm not sure what the heartbeat is all about for this, anyway. Is the number important for something, i.e. could I set it to 10000 or something ridiculous? Is it something one can use for anything? Thanks.
  21. I did notice today that if I change short poll using the GUI and the long poll is the same or shorter than the number I set, it changes it back (or changes it to long poll - not sure. It was the same in my case). So I had to go into plug-in config to first change long poll to something longer. There was no message about this in the GUI. I just knew the issue from having gotten the message doing that in plug-in config. You may need to add long poll to GUI and have a message pop-up there if the numbers don't work if you want to keep things this way.
  22. ok, i now see the option to set auto short poll in Admin Console. Did not notice that before. A good place for that would be on config page for plug-in right below the poll config info. When I reinstalled plug-in to get 1.2.2, it set the values too low for all three of my instances. Correct me if I'm wrong but I'm now having to choose between always having to change polling every update vs. having the plug-in change it for me to the minimum it calculates and overwriting any change I make the next time it reads data. Could the plug-in not just leave any existing short poll setting alone at restart and during data updates? Or at least during data updates? The latter is the bigger flaw in this. I understand if a timestamp solution is too complicated. Yes, there are more beneficial things to work on if it's not an easy thing. As long as Airthings continues to only temporarily block things when over the limit, it's not major issue. Thanks
  23. I upgraded to 1.2.1 and it sets short poll to the minimum for devices, which is good, but it keeps resetting it to that minimum over again after I change it to something longer. I suspect it's during the next polling cycle because It doesn't happen right away. Part of my reason for setting it longer is that it helps prevent hitting API rate limit for those times when I have to restart the plug-in or reboot. (I have 8 devices.) While this isn't a daily thing, of course, it often comes in clumps with more than one restart, which ends up blowing the limit. With this in mind, in addition to letting people be able to set their own short poll, could the plug-in save a timestamp of the last time it did a poll such that it lives through restarts?
  24. No problem. I noticed the messages started before midnight so I went to grab yesterday's log file from the archive and PM'ed that file too. There appears to have been some successful updates before 2AM but then things got stuck repeating the error. Thanks.
