CopyRon
Everything posted by CopyRon
  1. Thank you upgrade was to 5.8.4
  2. Power supply
  3. UD Mobil suggested updating my workplace Polisy from 5.80 to 5.84. Polisy will no longer connect. Have rebooted - changed power supply When rebooting all 3 lights light for a second or so then only left light stays light and later a single beep. Portal stills says 5.8.0 disconnected. Any thoughts??
  4. Thank you!!
  5. om my polisy 3rd light flashing won't connect power cycled multiple time no avail any help Thank you!!
  6. trying to set up Kwickset Zwave lock with mini remote so on activates lock and off activates unlock. I got to on to lock but can't figure out how to make off unlock Thank you!
  7. CopyRon replied to CopyRon's topic in ZMatter
    But we can use 800 devices with the 700 controller?
  8. CopyRon posted a topic in ZMatter
    Will the Zmatter support ZOOZ 800 or can we add the https://www.thesmartesthouse.com/collections/zooz/products/zooz-800-series-z-wave-long-range-usb-stick-zst39.
  9. Light is not lit, ordered a new one
  10. Could my PLM have failed?
  11. Updated to 5.7 and lost communication to keypadlinc and miniremote. All efforts to restore have failed. Deleted keypad (8 button) and can not add back - insteon engine not found Some help please, this is at work where I depend on these lights. Also lost all communication with Google and can't get z-wave to work in a scene.
  12. CopyRon replied to CopyRon's topic in Polisy
    Deleted Morninglinc and rediscovered saving old links working fine
  13. CopyRon replied to CopyRon's topic in Polisy
    no joy power cycle sorry but don't know the protocol
  14. CopyRon posted a topic in Polisy
    This morning I updated to 5.6.4 from 5.62 and noticed my morninglinc door lock wouldn't respond from admin console, yet it works fine from mini remotes and even reports correct status. Probably time to upgrade door lock,but this has worked well for me from I beta tested the original units. Any thoughts???
  15. apparently it's bricked
  16. submitted ticket around 3pm, heard back from Michel, but so far still dead. Unfortunately I can't access the polisy, even says inactive in my router.
  17. meanwhile none of my zwave devices can be controlled, at lest most of my insteon still works
  18. I have not installed the the Z matter, was updating to 5.4.5 before the install
  19. have tried but will try again, thank you Tried again several times doesn't even turn the left light off
  20. Attempted to upgrade to 5.4.5 to install Z matter board rebooted got 5 beeps said i was still on 5.4.4 atempted upgrade again nothing happened can't find polisy. Unplugged several times left most light come on quickly and then all tree flash once and just left left light stays on tried repeatedly. Help???!!!
  21. I wasn't tapping quick enough at the switch. Thank you!!
  22. Thank you! Tried doing at the switch, I will try with polisy
  23. Has anyone gotten the Enbrighten Z-Wave Smart Toggle Light Switch LED to illuminate? (Optional toggle guide light – The white, toggle-style switch illuminates to show switch location and status. A blue LED backlight provides a soft glow and can be reversed, turned off or always on based on your indicator preferences) LED status can be inverted manually changed to invert, always OFF and always ON I have read the instructions over and over - no light
  24. Thanks I'll give that atry in the morning!
