Toasted_IoT
  • Posts
    117
Profile Information
  • Location
    Minnesota
Recent Profile Visitors
1564 profile views
Toasted_IoT's Achievements
Experienced
Experienced (4/6)
17
Reputation
2
Community Answers
  1. Hi @Mr B, I will have to hook up the extender again and try overriding the port. Thanks for the tip!
  2. Interesting that you bring this up. I purchased the same extender early February 2024 and it had been working without any issues. Then mid-day on New Year's Day, the eISY stopped communicating with Z-Wave devices. It started working again after a reboot, but only for a couple of hours. I had to plug the ZMatter dongle directly into the eISY for it to be stable again. Looking forward to hearing if others have any ideas.
  3. I opened a ticket over the weekend about the script and Michel's response stated to wait for the next udx release (mid this week). It includes fully tested scripts so that all you have to do is to run couple of commands.
  4. My ISY is back online, but not my eISY. I wonder if the portal stopped taking inbound connections last night and it is slowly resolving itself. Update: The eISY is online now. I did not have to reboot anything.
  5. My ISY and eISY went offline with the portal at 3:29 AM CST today. My USW-Pro-24 switch did an update at 3:28 AM, but not my UDM-SE router. The UDM-SE router updated a couple of days ago with no issues. I have no problem logging into my.isy.io.
  6. Hi @mbking - How is the USB over Cat 5/6 extender working for you? I have a similar situation and thinking about using extenders as well.
  7. Hi @Javi - I used UD Mobile (on iOS) to add Insteon to my new eISY. The PLM was successfully added, but the UD Mobile UI had a couple of issues. Appears to be a minor code copy-and-paste error. While the screen is "Insteon Hardware" screen, it references Z-Wave in the message body. (First screenshot.) While the app was waiting for the reboot to complete, the exception shown in the second screenshot was thrown.
  8. Thanks for the responses. I was going to submit a ticket with the question and decided to bite the bullet and order an eISY instead. I figured it was time to get to the latest hardware platform.
  9. Found an old post stating that PG2 should not be deleted due to UDX and Mongo dependancies. Is it now possible to remove PG2 and use ports 80 & 443 for IoX instead of ports 8080 & 8443?
  10. Thanks the response @Michel Kohanim. Any ETA as to when the enclosures will be back in stock?
  11. I purchased the ZMatter module to install into my Polisy. Now I am thinking I would be better served to install the module inside of the ZMatter USB Enclosure and hang off the end of a USB extension cable to get it away from some duct work as well a prepare for a future migration to eISY. Will an USB enabled ZMatter board work with Polisy, or only with the eISY?
  12. As of last fall, there was not a migration path for node servers. Tagging @bpwwer to see if there are any updates. Here is a related post.
  13. Hi @Javi - I think I found a similar issue with a Z-Wave dimmer. I cannot figure out how to set the INIT value, however. Screenshots below. I tapped on the three dots next to "On"...
  14. I read the instructions to migrate from the 994 to Polisy. What I am not see is how to "repoint" the existing PG3 node servers from the 994 ISY to the Polisy IoP. I currently have both my 994 ISY and Polisy IoP configured as ISYs in PG3. I only have node servers installed for the 994 ISY, however. When the time comes to migrate, do I just delete the Polisy IoP from PG3 and then update entry for the 994 ISY with the local host IP and port 8080, so it points to the Polisy IoP? (After I restore the 994 ISY backup to the Polisy IoP.) Will the UUID shown in PG3 automatically update?
  • Create New...
