douyon
  1. Same error, different version. "This Version of the Admin Console is not compatible with the installed version of the ISY firmware" v. 5.3.0." I deleted Java Trace and Log Files, Cached Applications and Applet, and installed Application and Applets. Still get the same issue. Any help will be appreciated.
  2. Hello, When I go to programs>Details, I get error "Not Implemented" None of my programs are there. Just the names. Any help is greatly appreciated. See screen shots
  3. Running into a problem after upgrade to 5.0.1.6b with one of my garage door modules. When I close the door, it closes all the way, then opens, then stops almost immediatly. (If this is not the correct forum for this post, please let me know and I will move it accordingly.) If I unplug the garage door module, the door works fine. Functionality was working fine prior to upgrade. My programming for door is as follows Garage Door Open (Auto) If 'Garage/Bay1/Garage Door 1 Status' Status is On Then 'Set Garage/Bay1/Garage Door 1 Control' On If Garage Door 1 is Closed If 'Garage/Bay1/Garage Door 1 Status' Status is On Then Else 'Set Garage/Bay1/Garage Door 1 Control' Fast On Garage Door Open When I Arrive If $Homebass_1_New Geofence is 1 Then Run Program 'Garage Door Open (Auto)' (if) Garage Door already open when I arrive If $Homebass_1_New Geofence is 1 And 'Garage/Bay1/Garage Door 1 Status' Status is Off Then Else
  4. Thank You
  5. After upgrade, I am unable to log in using user id and password. (Was not using default) Is there a default user ID and password? Failed. Retry Authenticating My Lighting and Universal Devices Administrative Console.pdf
  6. Thank you for the info and quick response. Does anyone know if this is compatible with ISY994? https://www.smarthome.com/dome-dmof1-z-wave-smart-outlet-with-range-boost.html
  7. Hello, I am a ISY994/IR Pro user with all insteon products. Is there a way to monitor usage on a per switch or plug basis?
  8. I would like to know if I place an iBeacon in my car, can I then tell ISY to open garage door 2 when that beacon comes into range. I currently have ISY programmed to recognize my iPhone and open garage door 1. I would like to be able to let ISY know what Car I am driving and therefore what garage door to open. Can this be done with an iBeacon, and which one is recommended that works well with ISY994i. Thanks
  9. Thank you for the confirmation. My programming was similar. The issue I am seeing is as follows. I originally had a bathroom MS in the master bat scene. This worked but the light would shut off after 30 seconds. I tried selecting options and changing the timeout in minutes variable to 10.0. I hit the set button on the MS, clicked ok to start the upload and done on the configuration screen. This seems to do nothing. I also noticed that the light was coming on during daylight hours as well, so again I selected options on the MS and selected night only. I did some reading and decided that since I had a program running this event, I would also select On commands only. My understanding with this switch is that it would only sense motion and send an on command but never send off command which would allow for ISY to issue off command within the program. I saved this and again nothing. Light still came on day or night and turned off after 30 seconds. I then removed the MS from the scene. I am still using the aforementioned formatted If Then program listed earlier. When not in a scene, when motion is detected, nothing is happening, regardless of program variables. What am I missing here
  10. Just purchased 3 of the new Insteon Motion sensors 2844-222. What would be tht correct way to program them to do the follwoing. When motion is sensed, after dusk, turn lights on for 5 minutes then turn lights off. I triesd the simple if then, but I think I am missing something.
  11. Thank you for your candor Teken, I am a ISY99ir user for many years now and am completely happy with it. I think my real questions is and should have been . Will UD be adding a apple watch support in the near future. I support some highness customers who I have installed ISY and other home automation products for, and they are already asking for this functionality. Thanks again
  12. 1) What is the difference between Insteon Hub and ISY99i 2) Can ISY support Apple Watch functionality like Insteon Hub? or will I need to switch to instead HUB. 3) How difficult would it be to go from icy to instead hub and what functionality would I loose or gain.
  13. douyon posted a topic in ISY994
    Anyone have any experianc integrating Insteon with Universal Remote Total Control? Have customer with Insteon lighting setup, and Universal Controls Total control. He would like to control lights from remotes as well. Thanks
  14. Thank you. That did the trick. Much appreciated. It would be nice to have a guide for us non programmers so that we could see what and how to apply such commands.
