AT&T to end email-to-text ×
raydoc
  • Posts
    70
Everything posted by raydoc
  1. I am trying get my Yale assure z-wave lock to work through eisy to the google home portal. It used to work with my ISG. Now I can see and control the lock through the eisy portal but I cut get it to show up as available to the google portal. Any ideas? I am not terribly z-wave centric, I have lots of Insteon stuff.
  2. I have installed a Yale Z-wave lock and have successfully added it through my eisy. I can’t figure out how to make it available through the portal for google voice and home integration. thanks
  3. I have done the migration and the Eisy shows my Insteon network and controls it. I am trying to migrate my Google Home stuff over. When I go in to Google Home, I still see the devices but they are "offline". When I try to relink Universal Devices, it tries to hand me to the ISY portal which does not open. How to I reconnect? I think I have to delete all my old devices in Google Home and reinstall them but I cannot figure out how to delete them and relink UDI.
  4. raydoc
    Lost connections
    I put a filter on the nearby chest freezer and will try another outlet in the vicinity. I'd really like it to be downstairs with everything else. An odd note, when the PLM was offline, my Insteon lights all flashed at random times. As soon as I got the PLM and ISY up and running , the flashing went away.
  5. raydoc
    Lost connections
    THANK YOU! I moved the PLM and ISY to an entirely different part of the house and it all works. I had tried two different outlets downstairs adjacent to my new shelves for my NAS drives and switches, etc. That was the problem. Now that I have it back, and know the problem, I will try one additional outlet that was recently installed downstairs. An electrician changed an old dryer outlet into two duplex outlets. If these work it would be more convenient. If they don't, I'll neaten up my test setup and keep it there. Again, thank you. I am moving into a new house and all my network testing gear is an hour and a half away.
  6. raydoc
    Lost connections
    Techman, Here is the diagnostic log I just ran at startup. All I did to provoke this is to move the ISY and PLM from one side of my basement to another (different outlets). ISY Error Log.v4.9.0__Mon 2024.04.01 10.08.47 AM.txt
  7. raydoc
    Lost connections
    Individual restores did not work. I will do a PLM reset.
  8. raydoc
    Lost connections
    Yes and will do another. All my devices are red exclamation points. When I log into the administration console I get a barrage of "cannot communicate with xyz device" errors. I'll try the right click and restore thing. If it does not work I will do a PLM reset. Again, thanks for advice.
  9. raydoc
    Lost connections
    PLM is alive and the ISY can see it. PLM can't seem to see all my devices.
  10. raydoc
    Lost connections
    Did this. PLM has solid green light. ISY has one blue light, no flashing rx/tx like before. When I log into UD Admin Console I get a "failed communication" error for every Insteon device. It is like it does not see anything, my Google integration is gone. Seems like PLM is locked up. Is there a way to reset it? I tried a PLM restore from the admin console but got nothing.
  11. raydoc
    Lost connections
    More info. It is a 2413S that is relatively new. The TX and RX LEDS are not flashing on the back. The network connect and activity lights on the back are lit.
  12. raydoc
    Lost connections
    I recently reconfigured my home network and physically moved my ISY994i. When I hooked it up, the ISY has had a small freakout and I've lost most of my dimmer connections. The admin console says it can see the PLM and it is working but on the "Main" column, all Insteon devices are not found (exclamation points). I tried a PLM restore that didn't seem to do anything. Not sure what I did but need to dig back out. Any ideas are appreciated. Thanks.
  13. raydoc
    ISY problems
    Update: Got the outdoor module to work. I had to replace a module with a same-type, different version one. I've successfully added it to the ISY but when I go to the old module listing and go to "replace", the new one is not there as an option.
  14. raydoc
    ISY problems
    I am having multiple ISY problems that are driving me insane. 1. I have a Insteon 2477D dimmer that works manually fine. It used to work in my ISY. Now the ISY shows an exclamation point and doesn't talk to it. I've put it in linking mode to see if that is a possible fix but it doen't "find it". Not sure what to do. 2. I replaced a 5 button dimmer module with a new one since the old one died. I've linked it in but the ISY would not replace it. When I look at it in the ISY Admin Console I see the main module (on/off) buttons (which work) but don't see the sub buttons except D. 3. I have a brand new on/off outdoor module which I was using to replace a dead minimodule. I cannot get the ISY to see it. It is a 2634-222. I've tried moving it around to different outlets. I've put noise filters on everything I could think is or would be noisy (don't have any other noise problems). When I put it into linking mode the ISY responds that it cannot see it. Any help or suggestions would be great. Thanks. Oh, ISY 994i PRO running v.4.0.0 both firmware and UI.
  15. Are there examples of this in the wiki?
  16. If I have virtual multiway circuits, how do I keep the KPL lights synced so that any 'on' activation puts the light on for all KPLs involved and when any 'off' activations occur, that all the KPLs indicate the off status? I can't figure out what to search under on the site.
  17. I put my Remotelinc into programming mode (blinking light) and attempt to update it. I continue to get error messages from my ISY (red !) and a message saying it could not communicate. I tried to manually force device update but no success as well. Ideas? THanks. ISY-Backup.v4.2.18__Sun 2015.10.25 06.58.05 PM.zip
  18. I am one of those people who hates to read online. Is there a printed programming guide for the ISY?
  19. So, I think I have my 2842 open/close module enrolled with the ISY. It seems to get latched to whatever state it goes to not being momentary like I thought it would be. Also, I've read through this thread but I am not sure I that I follow all of your changes. Is there a new "roll up" program that incorporates what you think is the current state of the art?
  20. I use an Insteon current sensor to see if the pump is running. I have the Insteon "water sensors" (wireless open/close sensor with a wire and some contacts that trigger the event when they get wet and short).
  21. Would I be able to use this program with the water sensors and the current sensors to work out a way to notify me not only if there is high water in my sumps but if the sump pumps are not actually running? The current sensors know if the pump is running and what I need to have is a notification that the pumps are running AND losing ground.
  22. raydoc
    Java error
    Java console report: Missing Application-Name manifest attribute for: http://isy.universal-devices.com/994i/4.2.17/insteon.jar When I logged in from this link (successfully) I got a whole list of errors related to basically every module in the house. I am going to restart the ISY and see what happens. I can get in when I use the http://www.universal-devices.com/99i/3.1.2/admin.jnlp address. Now I am getting a PLM error message. I've restarted the ISY. Going to research the dead PLM. Still don't know why the other link does not work.
  23. raydoc
    Java error
    I had to rebuild my computer (Win 7) and I loaded the newest Java release. When I go to startup my web interface (www.universal-devices.com/00i) I get a java error: ClassNotFoundException com.universaldevices.client.ui.UDClientApplet.class I've uninstalled Java and reinstalled it. I have added the address to the Java trusted list in the Java console. What am I missing??
  24. I brought them downstairs to within 10 feet of my ISY and its PLM (which I thought was dual band) and put them in linking mode. Then I set the ISY to linking mode. It did not find them. I then entered their addresses, etc. manually but still the linking failed.
  • Create New...
