ronbo
Everything posted by ronbo
  1. AlarmSet - [ID 0049][Parent 0009] If 'Alarm / INTERIOR / LIVING ROOM MOTION' is switched Open And ( 'Alarm / DMP' System Alarm State is Armed Stay Or 'Alarm / DMP' System Alarm State is Armed Sleep ) And From 3:00:00AM To 2:00:00PM (same day) Then $sSpeakAlarmArmed = 1 Wait 3 seconds $sSpeakAlarmArmed = 0 Else - No Actions - (To add one, press 'Action')
  2. How do you copy the program to paste it?
  3. In the example below the routine does not always evaluate TRUE when switchB is on and switchA opens. This usually happens at 8:00 AM. If I eliminate the time constraint them it works flawlessly. I even created two routine on with and one without the time and I can monitor them and see that the one with the time does not work. Ideas ? If switchA 1 is switched open And ( switchB is on or switchC is on ) And From 3:00:00 AM To 1:00:00 PM (same day) Then ... Else
  4. @brians I got mine to work. In my case the issue was that I changed my IOX password a few days ago. I had to update by ISY info in PG3 and I am back up and running
  5. @Chris Jahn PG3 starts but does see IOX. Tried a reboot of Polisy... same problem PG3 Version 3.1.17 Status: Connected Frontend Version: 3.1.17 ISY Version: 5.5.5 Disconnected Uptime: 15 Minute(s) 59 Second(s) 2/2/2023, 24:01:50 [pg3] error: No code in error response 2/2/2023, 24:01:50 [pg3] warn: ISY Response: [Try: 1] [00:0d:b9:5e:df:dc] :: [401 - OK] :: 6.113249ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection 2/2/2023, 24:01:50 [pg3] error: No code in error response 2/2/2023, 24:01:50 [pg3] warn: ISY Response: [Try: 2] [00:0d:b9:5e:df:dc] :: [401 - OK] :: 10.221074ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection 2/2/2023, 24:01:50 [pg3] error: No code in error response 2/2/2023, 24:01:50 [pg3] warn: ISY Response: [Try: 3] [00:0d:b9:5e:df:dc] :: [401 - OK] :: 4.950628ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection 2/2/2023, 24:01:50 [pg3] error: No code in error response 2/2/2023, 24:01:50 [pg3] error: ISY Response: [MAX TRIES EXCEEDED] [00:0d:b9:5e:df:dc] :: [401 - OK] :: 4.781022ms - http://127.0.0.1:8080/rest/profiles/ns/0/connection 2/2/2023, 24:01:50 [pg3] error: Error: GET http://127.0.0.1:8080/rest/profiles/ns/0/connection Failed :: 401 - OK 2/2/2023, 24:01:50 [pg3] error: getExistingNodeServers :: Error: Received no response from the ISY. Check your ISY IP Address at Object.getExistingNodeServers (/var/polyglot/node_modules/@universaldevices/pg3/lib/modules/isy/system.js:93:13) at async /var/polyglot/node_modules/@universaldevices/pg3/lib/services/isy.js:80:21 at async Promise.allSettled (index 0)
  6. @Chris Jahn Same issue here... How do we fix it?
  7. I was told the that the zmatter must be primary. I too had a setup like you. When I migrated I had to make the polisy the primary in order for things to work. Sent from my iPhone using Tapatalk
  8. @Chris Jahn All of my zwave devices work after the interview process except my garage door opener. It still shows as a single node. Is this functionality coming down the road? Or is this a problem I should open a ticket for Thanks
  9. ronbo replied to ronbo's topic in ZMatter
    Yes, I don't know how I missed that... 😀 Thank You
  10. ronbo posted a topic in ZMatter
    I have my lock functioning on 5.5.3 on my Polisy. My Door lock has 3 nodes. ZY 008 Door Lock ZY 008 Access Control Alarm ZY 008 Assoc Only on the ISY I was able to access the user number that unlocked the door my accessing the USRNUM from the main node. On Zmatter the usrnum is not on the main node, but on the Access Control Alarm and I really don't see how to access that info in a program. Any help is appreciated
  11. On my ISY994 there was a learn option to add the ISY to an existing ZWave network. This does not seem to exist with ZMatter on 5.5.3?? Help!
  12. So my devices did not come online after the inrerview process so I decided to rebuild by network. Thats when I realized there is no "Learn" option available on 5.5.3 with the zmatter board. This option existed with the ISY994. I want to add my polisy to my existing Network. Any thoughts?
  13. With the ISY994, I was able to link the isy into an existing Zwave network. Zwave does allow for Primary & Seconday controller. On the ISY994 the other device showed up as "PCcontroller" From the link below, it appears the the ISY994 had a learn mode. That is what I do not have with the Zmatter. https://wiki.universal-devices.com/index.php?title=ISY_Users:V5:ZWave:User_Guide
  14. My security system is currently my zwave controller. I want to add my Polisy into the existing network. How Do I do that?
  15. Step 2 did it for me
  16. Not sure if I am missing something, but I think the "update packages" from the configuration page is what I should be doing. I click that button confirm upgrade. The AC closes and nothing happens. No light blinking no beeps. I waited 30 minutes ?? Ron
  17. Where are you finding > ‘Automatically upgrade ISY Nodes to 5.5.2’ ?
  18. @bpwwer Can you confirm this? Also does the EVT take into account the RainToday? I am trying to use these to calculate watering requirements. Thank You Ron
  19. It Looks to me like it is updated and should reflect total rain today, assuming that precip from API is what feeds RainToday.
  20. Is the forecast0->rain today adjusted/updated through-out the day? If I capture it just before midnight will I get the rain fall for today? Or do i need to capture the rain rate thorough-out the day and calculate total precipitation?
  21. I wasn’t sure where to best post it. I did manage to resolve it by restarting the polisy
  22. I had been running my isy994 with polyglot cloud until it went away. I just received my polisy pro and am trying to instal weatherbit node server. I deleted the existing node servers from my isy. All except the portal Node server. I then logged into PG3 on my polisy. I added in my isy994, purchased and installed the weatherbit node server. I get a message that it was successfully installed in slot x. Nothing shows up in ISY994 even after rebooting. Should I have deleted the portal Node server in the 994?
  23. @Bumbershootlike I said I’ve got the Wi-Fi interface turned on, But as soon as I unplug the hardwired cable the Polisy is no longer accessible on either IP. Can you share how you were able to unplug it and move it to a different location. My intent is to do exactly what you did but to leave it hardwired most of the time
  24. I just fires up my Polisy Pro. I went into the config and enabled the WiFi, connected it to my Network and assigned it a static iP. My WiFI is x.x.x.12 and the Ethernet is x.x.x.13. I am able to ping both addresses and access the IOP and polisyconf on both IP's. Until I unplug the hardwired connection. Then I looses all connectivity and ISY finder can not find it.
  25. ronbo replied to ronbo's topic in Polisy
    So what am I missing, why is it cheaper to buy them separately Than already installed?
