jpoje
  1. Okay, thank you for your help. I've deleted windows temp files, still have error message, but slightly different. I will open a ticket.
  2. I just cleared cache and downloaded Launcher. Admin Console could not load nodes, do you want to close, so I closed Admin Console, then Launcher was not able to find. I power cycled PLM and eIsy and was able to bring up AC again. Tried to create scene called "house" and below is a slightly different error message regarding a config file?
  3. No, no scene is created in the Admin Console.
  4. Just updated Firmware and UI to 5.8.4. and replaced my PLM (it was 5 years old and I have several replacements on stand-by). I am still receiving the ERROR "Add scene incomplete"?
  5. 5.8.0 on both Firmware and UI
  6. Yesterday, I started receiving the following error when trying to create a new scene in eIsy IoX (admin console): Error: Add Scene Incomplete (name of scene) [-2000000/-14] This error reminded me of a similar error I received (a long time ago) on ISY994i (unable to add new scene). It was recommended I upgrade to "PRO" version of ISY994i, which I did, and solved that issue. So what does this error mean on eIsy and how do I correct it? Thanks!
  7. THANK YOU!!!! Hubs have been discovered. I appreciate your time and explaining in detail how to add parameters. Have a great day!
  8. Thank you, but not sure if I am formatting correctly. Is this correct formatting?
  9. In router I found "diagnostic tool" and I selected "ping" and put in ip address to one of the harmonys and this is what I received: (looks like harmony is receiving packets?) PING 192.168.58.16 (192.168.58.16): 56 data bytes 64 bytes from 192.168.58.16: seq=0 ttl=64 time=18.297 ms 64 bytes from 192.168.58.16: seq=1 ttl=64 time=3.274 ms 64 bytes from 192.168.58.16: seq=2 ttl=64 time=3.962 ms 64 bytes from 192.168.58.16: seq=3 ttl=64 time=2.029 ms 64 bytes from 192.168.58.16: seq=4 ttl=64 time=20.555 ms --- 192.168.58.16 ping statistics --- 5 packets transmitted, 5 packets received, 0% packet loss round-trip min/avg/max = 2.029/9.623/20.555 ms ping completed
  10. Thank you so much for responding. Unfortunately, I haven't a clue on how to perform that task. I will go in the router's advanced settings and see if I see anything that says "allow discover packets". If it helps, I do have my "ethernet" device room set up in the router to "share" to the "wifi" device room that the harmonys are located in and visa versa. My Bond hub which is wifi and located in the same "room" in the router as the harmonys, was able to connect through PG3 Bond node server to eIsy. I also have a wifi govee light connected through PG3 govee node server to eIsy.
  11. Hello, I'm looking for some advice regarding getting the PG3 Harmony Hub node server back up and running. I replaced my TPLink Archer 11000 wifi router last week with the new RIO ROUTER. I am not a tech person, so bear with me on terminology. I have managed to get my nearly 50 network devices back up and working including eIsy, Blue Iris, Alexas, Firesticks, Shields, Roombas, Harmonys, Bonds etc. I started to count up all my Insteon/Zwave/Zigbee devices that I have installed over the past 13 years, and currently installed on eIsy, and came up with 154. 😲 I also have several PG3 node servers setup, eIsyIR, Bond and Harmony. So here's my issue, I have not been able to get PG3 HarmonyHub to discover my 4 hubs now that they've been moved over to the new Rio Router. I have deleted the node server, reinstalled, discovered, started, restarted, rebooted eIsy, etc, etc. It just won't discover the 4 hubs. It runs discovery but comes back with 0 hubs. I have enabled "share" to every device/room in the new Router. I just can't think of anything else to do. I tried to configure one of the harmony's ip address into the node server, which I wasn't sure of exact format, I just typed hostname in the key and the ip address in the value, and clicked save, still would not discover the harmony hub. I have eIsy connected via ethernet (not wifi) and all the harmony hubs have XMPP enabled. I'm suspecting it must be some setting in the router, but have been able to get everything else up and running just fine. Any advice or suggestions on getting the node server to discover my 4 harmony hubs, would greatly be appreciated.
  12. Sengled A19 Zigbee Color Bulbs Ability to tune bulbs 2000K-6500K https://www.amazon.com/dp/B07HL5GPPF?ref=emc_s_m_5_i_atc&th=1
  13. Thank you @Mike M. So I just changed out ALL of my Bluetooth ceiling bulbs and BT/WIFI led strip controllers (that worked just fine in Alexa app controlling colors and whites), to Zigbee bulbs and Zigbee led controllers in hopes of all local control of bulbs and led strips in Eisy (and not rely on Alexa integration). I don't care too much about my LED strip lighting, RGB is fine as they are mostly for fun, but the Bulbs and LED strips for under cabinet lighting really do need some warm/bright white options. I suppose I may have to switch back to my Bluetooth bulbs and Alexa for now. â˜šī¸
  14. Did you ever get this issue resolved, as I've also been struggling trying to get my Sengled Zigbee BR30 bulbs to tune to different whites in Eisy? (bulbs are changeable white 2700K - 6500K). Before connecting them to Eisy, the bulbs first came on with a very calming warm white, but since integrating them into the Eisy, I am unable to duplicate any whites except a harsh bright white. Not sure if I am also missing something?
  15. Sengled Zigbee BR30/E26 Bulbs Model: E12-N1E 2700K - 6500K While I can control RGB colors, I haven't been able to figure out how to control the white 2700K - 6500K? Bulbs first turned on with a nice warm white, but since adding into eisy, I haven't been able to duplicate that warm white color? The description indicates temperature of light bulb is changeable 2700K - 6500K. Is there something I'm missing or is the feature not available? Thanks!!! https://www.amazon.com/gp/product/B08R5FWMCW/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&th=1 https://us.sengled.com/products/zigbee-color-br30-e26-2-packs-hub-required?_pos=3&_psq=br30&_ss=e&_v=1.0
