Everything posted by flsenior
Help with timer execution
Thank you. You had the right solution.
I want to use the Insteon open/close sensor to monitor my garage doors. In the evening/early morning hours I want to have interior lights alert me if either garage door has been left open for 20 minutes. I I would like the interior light cycle to repeat 4 times. As written, the interior lights only run the cycle 1X. How do I correct the program to run 4X? Garage Timer - [ID 0006][Parent 0001] If From 6:00:00PM To 6:00:00AM (next day) And ( 'Garage - Golf' Status is On Or 'Garage - Main' Status is On ) Then Wait 20 minutes Run Program 'Garage Open' (Then Path) Else - No Actions - (To add one, press 'Action') Garage Open - [ID 0005][Parent 0001] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set 'Kitchen Ceiling - Dining Room' On Wait 3 seconds Set 'Kitchen Ceiling - Dining Room' Off Wait 3 seconds Set 'Kitchen Ceiling - Dining Room' On Set 'Kitchen Pendant' On Wait 3 seconds Set 'Kitchen Pendant' Off Wait 3 seconds Set 'Kitchen Pendant' On Set 'Living Room' On Wait 3 seconds Set 'Living Room' Off Wait 3 seconds Set 'Living Room' On Set 'MBR Ceiling Main' On Wait 3 seconds Set 'MBR Ceiling Main' Off Wait 3 seconds Set 'MBR Ceiling Main' On Repeat 4 times Else - No Actions - (To add one, press 'Action') TIA
IoX Launcher can't find eisy
Guy & DennisC - I just got it to work. No idea what change was made/what mistake I corrected. Thanks to both of you for your responses. I greatly appreciate the help.
Guy - I do see the eisy in the router device table. The IoX Launcher was working and I can access it with no issues on the UD Mobil. Having said that, I recently installed a new computer with Windows 11. This is my first attempt to access the eisy from the new computer. DennisC - I followed your directions. I could not discover the eisy. I then followed the directions above from Guy and attempted to discover the eisy with the IP address. I still can not use the IoX Launcer. Other ideas?
Guy, I have followed your suggestion, however, the eisy can't be found. Any other suggestions?
I can access eisy from the UD Mobile. The IoX Launcher can't find the eisy. My router indicates that the device is connected and shows it in the network device list. I have not done any updates in the past 9 months. All suggestions on how to get the Launcher to find the eisy are appreciated. TIA
Eisy wifi connection
My Eisy is currently connected to the wifi without a wired connection. Is there any issue if I use a Ethernet cable to connect directly to my router via the port to the right side of the power connection? Any changes needed on the Eisy?
Frequent eisy offline/online notificatio
I too have been seeing the same problem over the past couple of weeks. It is always in short duration. My ISP is showing no outages. I do not see the same problem on other devices. For example, I was accessing the Eisy via the UD portal on my desktop. The app indicated that the Eisy was offline, however, I was able to access other web sites during the "outage". Also I stream tv and there was no interruption.
Program does not run
Paul - thank you. As you state, I turned the scene on/off and the lights perform as programmed. I did the same for the other bathrooms and all is ok. I have deleted the programs and now operate only with a scene. Thanks to you and everyone who contributed.
Guy - I deleted the scene, enabled the program and performed "Run Then" as suggested. The lights came on per the program instructions. Next step? Thanks Just another comment regarding the change in my Eisy yesterday. I had linked Google and Alexa to switches in three different rooms. Both Google and Alexa lost their links to the Eisy.
I will respond to the above with the oldest message first. Guy - the admin console accurately reflects the status of the devices. I performed an on/off at the switch and the console indicated the correct status. Paul - I disabled the program, save the change, then wrote a scene with the 3 devices as a controller. When I selected the ceiling light "on" from the console, no other light turned on. Apostolakisl - the program does not indicate any run time. Geddy - thanks for the instruction on how to properly post a program. I appreciate the advice and will remember it. The current situation has everything to do with my post yesterday. Something happened with my Eisy. The above program was working yesterday in 3 bathrooms. I have the same program for all 3 rooms. During the day all of these programs lost their function in the same exact manner. In addition, the on level on the dimmer switches (ceiling and mirror) all defaulted to 100%. Beyond the above program I have a program for outside lights and it lost part of its function. I attempted to recover the issue by manually doing a restore on each device, resetting the on levels, etc. I could not resolve the program issues so I then tried to restore the IoX. I kept making the same mistake of not selecting the most recent IoX backup until you trigger some sense into me. I then properly selected the latest IoX backup, which is what I am working from. At the time I made the backup all of my devices and programs were operating as designed. ALL - So the current status is - - the "bathroom" light program is not functional. - the scene created with all 3 switches as controllers was created and tested for 1 bathroom. The scene operates (faulty) similar to the program. - other programs such as an outdoor light program lost some function yesterday when the light program became faulty. - I have tried to restore devices and still can't operate the program - The IoX was restored with a known good program. All help is greatly appreciated. Your comments for improvements are also appreciated.
I have this program and it does not run. It is enabled. When I turned "on" any one of the lights, the other lights do not respond. The program summary page indicates that the program has not run. I also have a companion program for turning "off" the lights and it also will not run. Suggestions appreciated. Eisy, Insteon.
Restore IoX
I have a program that turns on a group of lights. If "A" is on or "B' is on or "C" is on Then turn A on turn B on turn C on The program was working without issues until today when a switch would not trigger any other switch. I did a restore on each switch and could not resolve the issue. I disabled, then enabled the program with a "save changes" with each change. Nothing was resolved. I then did a restore IoX. Ugh. The IoX backup that was restored is not my latest backup. In addition, I have an on/off outlet and a on/off dimmer outlet. I can't establish communication with either. I have tried to manually set the devices into linking mode but can't communicate with them. (green light blinks rapidly) Questions: 1. How can I select which backup is used for the restore? 2. Any idea what may have caused the loss of links in the program? 3. Any suggestions on establishing communication with the outlets? Thanks
Insteon Education
Thanks to everyone who responded. I bought my first ISY in 2011 and I have performed no programming in 8-10 years as the system worked just fine. Even the exchange to a new ISY was a no brainer. Now I am in a new house with a new Eisy and all new devices, rooms, etc. so I am trying to navigate the setup from my ancient memory and as it appears, from ancient documentation. My primary challenge has been scenes. As noted above, the process has changed and there appears to be no updated documentation that is kept in one location. I don't know where to point the finger as Insteon doesn't sell the Eisy and UD does not sell Insteon. Insteon is willing to answer support questions, however, that process doesn't facilitate timely responses and follow up questions. My conclusion is to again say "Thank you", to all of you on the forum who spend the time to provide help.
Insteon Education
Does anyone have a resource that I could reference which provides education on programming Insteon on the Eisy? Specifically, I am trying to understand scenes, controllers, responders. Some of my questions include the following; - Do I use a scene to simultaneously operate a number of switches and dimmers that are in an area or do I write a program to operate the devices? - I am replacing a 3-way circuit. Can I use a dimmer & an 0n/off or must both devices match? IE dimmer/dimmer, on/off & on/off. - In the two examples above, can I operate these two devices in a scene or should I write a program? - Again, in this type of 3 way circuit, is one device a controller, responder or are both controllers? - If one is a controller and the other a responder, does it matter which device has the controller label (dimmer or switch)? In the main Eisy scene screen do I set the on level for each device or does my on level from the device list carry over to the scene? Thanks for help on these questions and pointing me to documentation which may help with these and other Insteon questions.
IoX Finder
Thanks to paulbates and Geddy. Changing the memory has resolved the issue. The help is really appreciated.
IoX Finder
I have 12 GB of RAM I got the launched from the UDI web page. I clicked on the "My ISY" icon. I have taken your link and added it to my desktop. Thx
IoX Finder
I have a new Eisy on version 5.8.4 When I use the IoX launcher, the IoX finder will responder "not found" then will display the Eisy. I can then select the Lan launch. The response to the sign in is slow. Sometimes the sign in window will lock up. I am on Windows 10. I have cleared the Java cache (3 selections), deleted the IoX launcher and obtained a new launcher from UDI. Any suggestions?
IoX screen status not matching device status
The Eisy IoX screen which shows all devices on my network has some devices where the status on the IoX screen does not match the actual status of the device as shown on the individual device. What is the cause of the mismatch?
Seeking support for a new homeowner
Thank you. Your advice is good. The Hub would be better for them. Right now I have to use another app, MobiLinc to get the iPhone feature. The decision to replace the ISY is now with the new owner, which is another reason I hope local support can be found to get them through the transition. This situation is a classic example of how Smarthome technology can affect a home sale.
I just sold my home which has 40+ Insteon devices and an ISY 994i. The new buyer has no knowledge of the technology and needs help to set up the system into their wifi and computer. They also need a general introduction and education about the operation of the equipment. Is there a resource in the Tampa Bay area who would contract with the buyer to provide assistance?
ISY Not Showing Correct Status
My ISY 994I Pro is operating and I have no issues communicating via my desktop or MoblLinc Connect. The Administrative Console does not show the correct status of a light. IE, it will show OFF when the light is ON or vice versa. I have rebooted the ISY but the problem persists. The problem is not consistent and does not affect all devices. I have made no changes to my devices, lighting system, home electrical system or added new appliances, etc. Suggestions?
Leak Sensor Communication
Update to the above posting; I placed the leak sensor in water and the device communicated to the ISY without any issue. I still would like suggestions about why the activation of the leak sensor button does not cause a change in the wet/dry settings on the ISY. Depression of the leak sensor button will cause a change of the ISY wet/dry settings.
I have successfully run a leak sensor program for several years. Recently, there was an unknown event that caused my ISY to lose communications with all of my leak sensors (14 units). I did a restore on all of the leak sensors and successfully reconnected all but 1 leak sensor. After attempting to restore the 1 non-communicating leak sensor several times, I deleted the leak sensor and then reinstalled the device. I could write to the device, however the ISY would not recognize when I activated the leak sensor wet/dry button. I removed the battery from the leak sensor. After installation of the battery, the ISY registered the wet/dry settings. However, when I depressed the device activation button, the ISY wet/dry settings would remain static. I deleted the device plus all programming and state variables for the device and then reinstalled the device and the program items. Once again the ISY recognized the wet/dry settings. The wet/dry settings would not change when I activated the leak sensor switch. I then purchased a new leak sensor from Insteon. I deleted the original sensor, the state variable and all program references. The new leak sensor was installed and the program references were rewritten. Once again, the ISY will recognize the wet/dry settings but will remain static when I depress the leak sensor button. All of my other leak sensors respond appropriately for daily heartbeat and activation of the leak sensor button for wet/dry. I have no issues in writing a restore to the leak sensor, yet the ISY will not record the wet/dry communication from the activated leak sensor. Any suggestions on the problem are appreciated.
ISY 994i Communications
How do you troubleshoot the PLM?
