GDavis01
  • Posts
    369
Everything posted by GDavis01
  1. Thanks for the replies. I took the advice and didn't hook up my old ISY. It turn out that this was a false alarm! While I was away I started having issues with the system and eventually opened a support ticket to which Michel Kohanim replied. I had sent him my error log and he replied that my PLM was dead. When I returned on Saturday I just assumed it was dead and that I needed a new one. However, just before I clicked on the purchase of a new one I decided to go look at the existing PLM. I saw that the LED on the side of the PLM was not lit! The PLM wasn't dead after all, my problem was that the PLM was not properly plugged into the outlet!
  2. I bought the EISY and the 2413U PLM in October and it recently (March) died. Of course, this had to happen when I was away for a few months! I just returned today and I am thinking of pulling out the old ISY994i and 2413S PLM to get the system up and running again while I order and receive a new PLM. Hopefully there is some sort of warranty. Will simply plugging in the old ISY cause any issues to my system?
  3. Interesting... I had not considered that. By the way, I am running on an EISY. So, I tried to a few things: - simply pulled the power cord out of the EISY to simulate a power outage; and - rebooted the EISY from the Admin Console a few times. Each time when the system came back up, the 'Home' node and sub-nodes were still populated with True or False. So, for whatever reason, it appears that I still do not need to use the variables.
  4. Your method definitely works as does the method I explained. What I like about having the nodes set up on the Admin Console, the way I explained, is that I do not have to create and update a variable for each phone. Nor do I have to update the init value. The UD Mobile geofence, using the command changes the status of the specific phone node which in turn affects the status of the 'Home' node. My program simply tests the status of 'Home' to determine what to do. I also found interesting that changing the status of the 'Home' node acts like a state variable in that it triggers a program without having to query the node. So this program works as soon as the status of the 'Home' node changes. I also have another use where this approach makes programming simpler... we have a vacation home and we have a lot of family members coming and going; by having each member setting up their phone this way (as a separate sub-node) a simple program like this example runs when any member triggers the entry geofence. So either method works but with slightly different approaches. Thanks again for your detailed explanation in the earlier post. That explanation helped me realize that I needed to use the geofence command, from the UD Mobile app, to change the value of the Occupancy node (True / False) in the Admin Console. I had thought that the node would be updated somehow using the Occupancy tool in the Portal, but that does not appear to be the case.
  5. Thanks for the clear explanation. However, if I understand correctly, your explanation does not actually set up a node on the ISY / EISY, it only allows you to trigger actions when you enter or leave the geofence. What I like about having occupancy nodes on the Admin Console is that I can have a geofence called 'Home' and geofences nested under 'Home' for my phone and another for my wife's phone ('Home/myiPhone' and 'Home/heriPhone'). This way I can have programs testing if 'Home' is True (when one of us is home) or False (when we are both away from home). I don't believe that simply following your instructions I can do that. Using the Portal Occupancy tool only, I could not figure out how to do change the status of the nodes. So, I first set up the nodes on the Admin Console with the Portal Occupancy V2.0 tool; then, using UD Mobile (your steps above) I created a Geofence on each phone; then, using the Geofence Commands in the UD Mobile app I set the action to turn ON the myiPhone node when I enter the geofence or OFF when I leave and the same for my wife's phone. Perhaps this is what was contemplated when using UD Mobile to trigger the geofences but, if so, it wasn't very clear. Anyway, thanks for your help as I can now do what I want.
  6. I recently upgraded from the ISDY to the Eisy and I am trying to setup some Geofencing for our mobile devices. I am confused by which Geofence I should be using, Occupancy or Occupancy v2.0? I chose Occupancy v2.0 because it looks like it should be the latest! However, in the online help link when setting up the Geofence I see that it refers to 'UDI Mobile' app which no longer exists! Despite this I tried to follow the instructions and did the following: - Added geofence 'Home'; - Added Mobile Device - myiPhone; (the node shows as 'Home/myiPhone') - Assigned Mobile Device to 'Home' and then Synchronized so that the nodes ('Home' and 'myiPhone') now show up on the Admin Console. Here is the part that I am struggling with... the help section states: In the Portal when I look at 'myiPhone' in Mobile Devices, I see that the Linked section shows as "No". So I click on the small icon and I am asked if I want to Generate a new 6-digit pin. However, reading the help text suggests to me that the pin is only to link the app UD Mobile to the Portal. But since I have been using the app for some time now I would assume that it is already linked to my Portal account. Furthermore, after I generate a pin I cannot see where in the UD Mobile app I can actually enter it! So, I would think that the Linked parameter for 'myiPhone' should say "Yes" but it doesn't. In the UD Mobile app, I also set up a Geofence 'Home' and set the location. I then added a command that sends me an email whenever I enter or leave the geofence. This geofence works in that I receive the emails. However, there does not seem to be any synchronization with the app and the EISY for the nodes I created in the Portal! Can someone point me in the right direction, because clearly I am doing something wrong.
  7. What do you mean by 'state files'? Do you mean the temporary internet files? I could not find anything in the Wiki related to 'state files'!
  8. Yes, that is the link I used. My laptop is new so this wasn't an update from Win 10. However, I will try deleting Java completely and start the process over again.
  9. In anticipation of moving from my ISY to my new EISY, I fairly recently upgraded my ISY to 5.3.4 from 5.0.16. All seemed to go well. I have not yet done the migration because I have too many other things on the go. My access to the ISY has been my PC which was running Windows 10. Subsequent to upgrading the ISY, I am now moved to a Windows 11 laptop. Today, using the IoX Launcher, I tried to log into the Admin Console but clicking on the Launcher brought up the UD logo for a second and then did nothing. Looking at the Task Manager I can see that the process is running but nothing is happening! (I'm not sure, but I thought that I had accessed the Admin Console on this new laptop before today and it worked properly) After clicking on the IoX Launcher many times, I went into the Control Panel => Java and deleted the files (all 3 options). Then I downloaded the admin.jnlp file again and tried to run it. It properly sets up the icon on my desktop but still every time I click on it I only see the UD logo for a few seconds and then nothing! Any ideas on what is happening? I fired up my old PC and it still runs the Launcher properly.
  10. @Javi Thank you! I had incorrectly assumed that the 'very long key' was part of the Host, whereas it should be part of the Path! That simple change has the NR working properly!
  11. @Javi I am still struggling with this! I tried the code in a browser as follows: https://my.isy.io/isy/xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx/rest/vars/set/1/30/5 Because I didn't know how to add the Portal credentials directly into the code (if that is even possible) I was asked to enter them separately. After that, the code worked and this line changed the integer variable 1.30 to the fixed value of 5. However, when I tried to do the same thing through the Network Resource it failed. Here is a screenshot of the Network Resource where I tried to change the variable value to 11. I consistently get a "TCP client DNS error" and the variable does not change! I have tried changing the timeout with different values but each one failed. Any thoughts on what I am doing wrong?
  12. @larryllix Thanks for the reply. Both of my ISY's have the Portal Integration and I am trying to send the variable from ISY-1 to ISY-2, running the NR on ISY-1. I have tried using HTTP with port 80 but I am still getting the TCP client DNS error. Do you have any advice on the HOST question... what part of the string from the portal should I be using in the NR for the HOST? Similar question with respect to the AUTHORIZATION, should I use the Portal credentials or the Admin Console credentials? To provide a little context, ISY-1 is my home device, whereas ISY-2 is my vacation home device. Whenever there is a power outage at my vacation home (which happens too often!), my router resets several minutes before the Bell modem resets and as a result the router just sits there without internet access. What I am trying to do is send a variable (value of 9) daily from ISY-1 to ISY-2 at a specific time (at 5:00am), using a program; on ISY-2, I run one daily program (at 4:00am) to reset the variable to 0; then, also on ISY-2, I later run another program (at 5:30am) to check the value of the variable; If the variable = 0, it means that I do not have an internet connection because the value should have changed to 9, the THEN part of the program calls a program that turns off the Bell modem and the router and then restarts them in the proper order (note that I have Insteon On/Off switches attached to each); if the program finds that the variable = 9, ELSE does nothing. So, the programming is not complicated. As an aside, I already do this process with the Raspberry's using a script that I adapted from something you posted several years ago. It works well but I am trying to understand how I can accomplish the same thing without using the Raspberry's.
  13. I have been passing variables between my 2 ISY's (different locations) for several years using Raspberry pi's and python programs. I understand that it is possible to use the portal and eliminate the Raspberry but I'm having trouble finding the information to make this happen! Both of my ISY's are 994i/IP Pro versions running v.5.0.16C. I found one topic in the forum discussing this but the topic is now closed. I am trying to grab a variable from ISY-2, with a value in the integer variable location of 30 (1.30) and move that value to an integer variable on ISY-1 (1.63). Here is a description of how I have been filling in the Network Resource information in my attempts: - I understand that I need to be use https and GET, and to not check off either Encode URL or Use SNI. - Host box, I understand that I need to grab the value from the portal of ISY-2. However that value is "https://my.isy.io/isy/xxxxxxxxxxxxxxxxx" What part of that string am I supposed to put in the Host box? - port is 443, which is https port set up - path: based on what I saw in that closed thread, I tried "rest/vars/set/1/63/${var.1.30}" - Authorization: which User Name and Password should I be using... the credentials to log into the Admin Console or the credentials to log into the Portal? Here is one attempt I tried, using a variation of the host GET rest/vars/set/1/63/${var.1.30} HTTP/1.1 Host: /isy/xxxxxxxxxxxxxxxxxxxxxxxx User-Agent: Mozilla/4.0 Connection: Close Content-Type: application/x-www-form-urlencoded Authorization: Basic xxxxxxxxxxxxxxxxx I have tried various attempts with host values using different parts of the string from the portal but each time I get a response, after running the NR, of TCP client DNS error! Any suggestions on how to resolve this?
  14. On the ISY: - the DSC alarm the Partition 1 node is completely blank and the DSC Alarm node only has a few items showing. The heartbeat doesn't ever change - the Venstar nodes have data populated but do not update. The heartbeat doesn't change. The odd thing is that if I click on the button at the bottom of the node, on the ISY, 'Setpoint UP' or 'Setpoint Down' the setpoint value changes on in the NodeLink interface but not on the ISY! Any thoughts on where I go from here?
  15. Here is the log with the ISY also set to debug after a restart of NodeLink. Thanks 2022-04-18 12:15:44 - ISY resolved to 10.0.1.19 (5.0.16C) 2022-04-18 12:15:44 - ISY Send: Node Server request sent 2022-04-18 12:15:44 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><connections all="true" max="25"><connection profile="3" type="network" enabled="true"><name>ISY Portal</name><ssl>true</ssl><sni>false</sni><port>443</port><timeout>3000</timeout><isyusernum>0</isyusernum><ip>undefined</ip><baseurl>/api/ns/00:21:b9:01:f2:e5</baseurl><nsuser>gary.m.davis99@gmail.com</nsuser></connection><connection profile="1" type="network" enabled="true"><name>isylink</name><ssl>false</ssl><sni>false</sni><port>8090</port><timeout>10</timeout><isyusernum>0</isyusernum><ip>10.0.1.69</ip><baseurl>isylink</baseurl><nsuser></nsuser></connection></connections> (profiles/ns/0/connection) 2022-04-18 12:15:44 - ISY Node Server config detected (profile 1) 2022-04-18 12:15:44 - ISY Send: Node list request sent 2022-04-18 12:15:45 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><nodes><root></root><folder flag="0"><address>40102</address><name>Sprinklers</name></folder><folder flag="0"><address>20391</address><name>Unused Sprinklers</name><parent type="3">40102</parent></folder><folder flag="0"><address>10882</address><name>Alarm System</name></folder><folder flag="0"><address>21888</address><name>Unused Alarm Zones</name><parent type="3">10882</parent></folder><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>27 25 D7 1</address><name>Living Room Light</name><type>1.14.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>27 25 D7 1</pnode><ELK_ID>A01</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A 5A BC 1</address><name>Dining Room Light 1</name><type>1.25.64.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1A 5A BC 1</pnode><ELK_ID>A02</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A 4A 8 1</address><name>Dining Room Light 2</name><type>1.25.64.157</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1A 4A 8 1</pnode><ELK_ID>A03</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1B 2C C9 1</address><name>Great Room Light</name><type>1.32.64.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2C C9 1</pnode><ELK_ID>A05</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A 58 5F 1</address><name>Office Light</name><type>1.25.64.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1A 58 5F 1</pnode><ELK_ID>A06</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="BinaryControl"><address>19 E1 D1 1</address><name>Garage_Sensor</name><type>7.0.54.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>19 E1 D1 1</pnode><ELK_ID>A08</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="RelayLampOnly"><address>19 E1 D1 2</address><name>Garage_Relay</name><type>7.0.54.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>19 E1 D1 1</pnode><ELK_ID>A09</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch"><address>1B 85 C3 1</address><name>Outdoor Garage Lights</name><type>2.28.58.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 85 C3 1</pnode><ELK_ID>A10</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>37 E5 1B 1</address><name>Outdoor Timer 3</name><type>2.56.67.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>37 E5 1B 1</pnode><ELK_ID>A11</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="DSC" nls="102D"><address>n001_dsc1</address><name>DSC Alarm</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>A12</ELK_ID></node><node flag="0" nodeDefId="DSCPartition" nls="102DP"><address>n001_dsc1_part1</address><name>Partition 1</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>A13</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z01</address><name>Zone 01</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>A14</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z02</address><name>Zone 02</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>A15</ELK_ID></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A 2B 95 1</address><name>Walk-Out Lights</name><type>1.30.57.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1A 2B 95 1</pnode><ELK_ID>A16</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A 2B 86 1</address><name>Garage Walk-Out Light</name><type>1.30.57.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1A 2B 86 1</pnode><ELK_ID>B01</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="EZRAIN_Output"><address>1B 2 E 1</address><name>07 Hot Tub area</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 E 1</pnode><ELK_ID>B05</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 E 2</address><name>08 Cabana back, Spruces</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 E 1</pnode><ELK_ID>B06</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 E 3</address><name>03 Garden Top - Rob side</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 E 1</pnode><ELK_ID>B07</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 E 4</address><name>04 Garden Low - Rob side</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 E 1</pnode><ELK_ID>B08</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 E 5</address><name>09 Cabana right side</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 E 1</pnode><ELK_ID>B09</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 E 6</address><name>10 Back Grass</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 E 1</pnode><ELK_ID>B10</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 E 7</address><name>12 Dining area - Sue side</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 E 1</pnode><ELK_ID>B11</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 E 8</address><name>11 House, Birch, Firepit area</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 E 1</pnode><ELK_ID>B12</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="EZRAIN_Output"><address>1B 2 D4 1</address><name>02 Hangers</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 D4 1</pnode><ELK_ID>B13</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 D4 2</address><name>01 Veg Garden</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 D4 1</pnode><ELK_ID>B14</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 D4 3</address><name>06 Walkout area</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 D4 1</pnode><ELK_ID>B15</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 D4 4</address><name>05 AC to garage door</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 D4 1</pnode><ELK_ID>B16</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 D4 5</address><name>15 Front Lawn - Sue side</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 D4 1</pnode><ELK_ID>C01</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 D4 6</address><name>14 Front Garden - Sue side</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 D4 1</pnode><ELK_ID>C02</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 D4 7</address><name>13 Side Lawn - Sue side</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 D4 1</pnode><ELK_ID>C03</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 2 D4 8</address><name>Sprinkler Zone 16</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 2 D4 1</pnode><ELK_ID>C04</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="EZRAIN_Output"><address>1B 3 AC 1</address><name>17 Front Garden - Rob side</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 3 AC 1</pnode><ELK_ID>C05</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 3 AC 2</address><name>16 Front Lawn - Rob side</name><parent type="3">40102</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 3 AC 1</pnode><ELK_ID>C06</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 3 AC 3</address><name>Sprinkler Zone 19</name><parent type="3">20391</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 3 AC 1</pnode><ELK_ID>C07</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 3 AC 4</address><name>Sprinkler Zone 20</name><parent type="3">20391</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 3 AC 1</pnode><ELK_ID>C08</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 3 AC 5</address><name>Sprinkler Zone 21</name><parent type="3">20391</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 3 AC 1</pnode><ELK_ID>C09</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 3 AC 6</address><name>Sprinkler Zone 22</name><parent type="3">20391</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 3 AC 1</pnode><ELK_ID>C10</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 3 AC 7</address><name>Sprinkler Zone 23</name><parent type="3">20391</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 3 AC 1</pnode><ELK_ID>C11</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="EZRAIN_Output"><address>1B 3 AC 8</address><name>Sprinkler Zone 24</name><parent type="3">20391</parent><type>4.0.40.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 3 AC 1</pnode><ELK_ID>C12</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1B 31 77 1</address><name>Cabana - Front</name><type>1.32.64.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 31 77 1</pnode><ELK_ID>C13</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch"><address>1B 86 A1 1</address><name>Pool Light</name><type>2.28.58.9</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 86 A1 1</pnode><ELK_ID>C14</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A 4C 9D 1</address><name>Cabana - Back</name><type>1.25.64.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1A 4C 9D 1</pnode><ELK_ID>C15</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A 4C A5 1</address><name>Theatre_Pots</name><type>1.25.64.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1A 4C A5 1</pnode><ELK_ID>C16</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A 59 77 1</address><name>Theatre_Ceiling</name><type>1.25.64.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1A 59 77 1</pnode><ELK_ID>D01</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A 4B 41 1</address><name>Theatre Sconces_Front</name><type>1.25.64.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1A 4B 41 1</pnode><ELK_ID>D02</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A 4C D1 1</address><name>Basement_Accent</name><type>1.25.64.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1A 4C D1 1</pnode><ELK_ID>D03</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A 59 D 1</address><name>Theatre Sconces_Back</name><type>1.25.64.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1A 59 D 1</pnode><ELK_ID>D04</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch"><address>1A 5A 9B 1</address><name>Basement_Pots</name><type>1.25.64.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1A 5A 9B 1</pnode><ELK_ID>D05</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>1D B4 63 1</address><name>Soffit Lights - Front</name><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1D B4 63 1</pnode><ELK_ID>D06</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>1D BE 22 1</address><name>Soffit Lights - Garage</name><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1D BE 22 1</pnode><ELK_ID>D07</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>1D B4 92 1</address><name>Soffit Lights - Sides</name><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1D B4 92 1</pnode><ELK_ID>D08</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>1D C0 29 1</address><name>Soffit Lights - Back</name><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1D C0 29 1</pnode><ELK_ID>D09</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>1D B9 82 1</address><name>Back Stairs_Bar - Bottom</name><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1D B9 82 1</pnode><ELK_ID>D10</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>1D AD F1 1</address><name>Bar Light - Accent Wall</name><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1D AD F1 1</pnode><ELK_ID>D11</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>1D B3 5 1</address><name>Bar Light - Main</name><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1D B3 5 1</pnode><ELK_ID>D12</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>1F AB F3 1</address><name>Back Stairs_Bar - Top</name><type>2.42.66.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1F AB F3 1</pnode><ELK_ID>D13</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>1F AD 4 1</address><name>Portico Light</name><type>2.42.66.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1F AD 4 1</pnode><ELK_ID>D15</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="KeypadDimmer_ADV"><address>3D 7B 62 1</address><name>Keypad.Main</name><type>1.65.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>3D 7B 62 1</pnode><ELK_ID>D16</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>27 BC 69 1</address><name>Outdoor Timer (Back)</name><type>2.56.66.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>27 BC 69 1</pnode><ELK_ID>E04</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="RelayLampSwitch"><address>1B 91 8 1</address><name>Cabana Fan</name><type>2.28.58.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1B 91 8 1</pnode><ELK_ID>E05</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>1D AD 51 1</address><name>Deck Middle Light</name><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1D AD 51 1</pnode><ELK_ID>E06</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>1D B9 D1 1</address><name>Deck Outside Lights</name><type>1.32.65.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>1D B9 D1 1</pnode><ELK_ID>E07</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="BinaryAlarm_ADV"><address>36 B8 D4 1</address><name>FurnaceLeak-Dry</name><type>16.8.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>36 B8 D4 1</pnode><ELK_ID>E08</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="BinaryAlarm_ADV"><address>36 B8 D4 2</address><name>FurnaceLeak-Wet</name><parent type="1">36 B8 D4 1</parent><type>16.8.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>36 B8 D4 1</pnode><ELK_ID>E09</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="BinaryAlarm_ADV"><address>36 B8 D4 4</address><name>FurnaceLeak-Heartbeat</name><parent type="1">36 B8 D4 1</parent><type>16.8.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>36 B8 D4 1</pnode><ELK_ID>E10</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>3D 7B 62 2</address><name>Keypad.B</name><parent type="1">3D 7B 62 1</parent><type>1.65.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>3D 7B 62 1</pnode><ELK_ID>E12</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>3D 7B 62 3</address><name>Keypad.C</name><parent type="1">3D 7B 62 1</parent><type>1.65.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>3D 7B 62 1</pnode><ELK_ID>E13</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>3D 7B 62 4</address><name>Keypad.D</name><parent type="1">3D 7B 62 1</parent><type>1.65.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>3D 7B 62 1</pnode><ELK_ID>E14</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>3D 7B 62 5</address><name>Keypad.E</name><parent type="1">3D 7B 62 1</parent><type>1.65.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>3D 7B 62 1</pnode><ELK_ID>E15</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>3D 7B 62 6</address><name>Keypad.F</name><parent type="1">3D 7B 62 1</parent><type>1.65.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>3D 7B 62 1</pnode><ELK_ID>E16</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>3D 7B 62 7</address><name>Keypad.G</name><parent type="1">3D 7B 62 1</parent><type>1.65.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>3D 7B 62 1</pnode><ELK_ID>F01</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="0" nodeDefId="KeypadButton_ADV"><address>3D 7B 62 8</address><name>Keypad.H</name><parent type="1">3D 7B 62 1</parent><type>1.65.69.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>3D 7B 62 1</pnode><ELK_ID>F02</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>38 7F CB 1</address><name>Great Room Wall Unit</name><type>1.32.68.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>38 7F CB 1</pnode><ELK_ID>G02</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>35 A3 B6 1</address><name>Master Lamp</name><type>1.14.67.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>35 A3 B6 1</pnode><ELK_ID>G03</ELK_ID><property id="ST" value="0" formatted="Off" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>35 A3 C6 1</address><name>Xmas Stars Lamplinc</name><type>1.14.67.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>35 A3 C6 1</pnode><ELK_ID>G04</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z03</address><name>(Z03) Door to Upper Deck</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>G05</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z04</address><name>Zone 04</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>G06</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z05</address><name>Zone 05</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>G07</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z06</address><name>Zone 06</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>G08</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z07</address><name>Zone 07</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>G09</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z08</address><name>Zone 08</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>G10</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z09</address><name>Zone 09</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>G11</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z10</address><name>Zone 10</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>G12</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z11</address><name>Zone 11</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>G13</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z12</address><name>Zone 12</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>G14</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z13</address><name>Zone 13</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>G15</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z14</address><name>Zone 14</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>G16</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z15</address><name>Zone 15</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H01</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z16</address><name>Zone 16</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H02</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z17</address><name>Zone 17</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H03</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z18</address><name>Zone 18</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H04</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z19</address><name>Zone 19</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H05</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z20</address><name>Zone 20</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H06</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z21</address><name>Zone 21</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H07</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z22</address><name>Zone 22</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H08</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z23</address><name>Zone 23</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H09</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z24</address><name>Zone 24</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H10</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z25</address><name>Zone 25</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H11</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z26</address><name>Zone 26</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H12</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z27</address><name>Zone 27</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H13</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z28</address><name>Zone 28</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H14</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z29</address><name>Zone 29</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H15</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z30</address><name>Zone 30</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>H16</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z31</address><name>Zone 31</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I01</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z32</address><name>Zone 32</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I02</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z33</address><name>Zone 33</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I03</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z34</address><name>Zone 34</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I04</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z35</address><name>Zone 35</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I05</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z36</address><name>Zone 36</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I06</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z37</address><name>Zone 37</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I07</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z38</address><name>Zone 38</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I08</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z39</address><name>Zone 39</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I09</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z40</address><name>Zone 40</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I10</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z41</address><name>Zone 41</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I11</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z42</address><name>Zone 42</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I12</ELK_ID></node><node flag="0" nodeDefId="DSCZone" nls="102Z"><address>n001_dsc1_z43</address><name>Zone 43</name><family instance="1">10</family><parent type="3">10882</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_dsc1</pnode><ELK_ID>I13</ELK_ID></node><node flag="128" nodeDefId="Venstar" nls="140V"><address>n001_ven2</address><name>Venstar-Glen_02</name><family instance="1">10</family><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_ven2</pnode><ELK_ID>I14</ELK_ID></node><node flag="0" nodeDefId="VenstarSensor" nls="140VS"><address>n001_ven2_s00</address><name>Space Temp</name><family instance="1">10</family><parent type="1">n001_ven2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_ven2</pnode><ELK_ID>I15</ELK_ID></node><node flag="128" nodeDefId="Venstar" nls="140V"><address>n001_ven1</address><name>Venstar-Glen_01</name><family instance="1">10</family><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_ven1</pnode><ELK_ID>I16</ELK_ID></node><node flag="0" nodeDefId="VenstarRuntimes" nls="140VR"><address>n001_ven1_run</address><name>Runtime</name><family instance="1">10</family><parent type="1">n001_ven1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_ven1</pnode><ELK_ID>J01</ELK_ID></node><node flag="0" nodeDefId="VenstarSensor" nls="140VS"><address>n001_ven1_s00</address><name>Space Temp</name><family instance="1">10</family><parent type="1">n001_ven1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_ven1</pnode><ELK_ID>J02</ELK_ID></node><node flag="0" nodeDefId="VenstarSensor" nls="140VS"><address>n001_ven1_s01</address><name>Glen Sensor</name><family instance="1">10</family><parent type="1">n001_ven1</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_ven1</pnode><ELK_ID>J04</ELK_ID></node><node flag="128" nodeDefId="occupancy"><address>n003_occdev001</address><name>Home</name><family instance="3">10</family><parent type="1">n003_occloc01</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n003_occdev001</pnode><ELK_ID>J07</ELK_ID></node><node flag="128" nodeDefId="occupancy"><address>n003_occloc01</address><name>Home</name><family instance="3">10</family><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n003_occloc01</pnode><ELK_ID>J08</ELK_ID></node><node flag="0" nodeDefId="VenstarRuntimes" nls="140VR"><address>n001_ven2_run</address><name>Runtime</name><family instance="1">10</family><parent type="1">n001_ven2</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n001_ven2</pnode><ELK_ID>J11</ELK_ID></node><node flag="0" nodeDefId="occupancy"><address>n003_occdev002</address><name>Home1</name><family instance="3">10</family><parent type="1">n003_occloc01</parent><type>1.1.0.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>n003_occloc01</pnode><ELK_ID>K03</ELK_ID></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>3F DE 90 1</address><name>Outdoor Timer 2</name><type>2.56.67.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>3F DE 90 1</pnode><ELK_ID>K04</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="RelayLampSwitch_ADV"><address>49 40 E3 1</address><name>Coffee Machine</name><type>2.55.72.0</type><enabled>true</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>49 40 E3 1</pnode><ELK_ID>K05</ELK_ID><property id="ST" value="255" formatted="On" uom="100" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>47 16 A 1</address><name>Xmas Tree (Main Floor)</name><type>1.14.67.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>47 16 A 1</pnode><ELK_ID>K06</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>47 17 E 1</address><name>Xmas Tree Basement</name><type>1.14.67.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>47 17 E 1</pnode><ELK_ID>K07</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><node flag="128" nodeDefId="DimmerLampSwitch_ADV"><address>47 16 D3 1</address><name>Extra 3</name><type>1.14.67.0</type><enabled>false</enabled><deviceClass>0</deviceClass><wattage>0</wattage><dcPeriod>0</dcPeriod><startDelay>0</startDelay><endDelay>0</endDelay><pnode>47 16 D3 1</pnode><ELK_ID>K08</ELK_ID><property id="ST" value="" formatted=" " uom="0" /></node><group flag="12" nodeDefId="InsteonDimmer"><address>00:21:b9:01:f2:e5</address><name>The Glen ISY</name><family>6</family><members><link type="0">27 25 D7 1</link><link type="0">1A 5A BC 1</link><link type="0">1A 4A 8 1</link><link type="0">1B 2C C9 1</link><link type="0">1A 58 5F 1</link><link type="0">19 E1 D1 1</link><link type="0">19 E1 D1 2</link><link type="0">1B 85 C3 1</link><link type="0">37 E5 1B 1</link><link type="0">n001_dsc1</link><link type="0">n001_dsc1_part1</link><link type="0">n001_dsc1_z01</link><link type="0">n001_dsc1_z02</link><link type="0">1A 2B 95 1</link><link type="0">1A 2B 86 1</link><link type="0">1B 2 E 1</link><link type="0">1B 2 E 2</link><link type="0">1B 2 E 3</link><link type="0">1B 2 E 4</link><link type="0">1B 2 E 5</link><link type="0">1B 2 E 6</link><link type="0">1B 2 E 7</link><link type="0">1B 2 E 8</link><link type="0">1B 2 D4 1</link><link type="0">1B 2 D4 2</link><link type="0">1B 2 D4 3</link><link type="0">1B 2 D4 4</link><link type="0">1B 2 D4 5</link><link type="0">1B 2 D4 6</link><link type="0">1B 2 D4 7</link><link type="0">1B 2 D4 8</link><link type="0">1B 3 AC 1</link><link type="0">1B 3 AC 2</link><link type="0">1B 3 AC 3</link><link type="0">1B 3 AC 4</link><link type="0">1B 3 AC 5</link><link type="0">1B 3 AC 6</link><link type="0">1B 3 AC 7</link><link type="0">1B 3 AC 8</link><link type="0">1B 31 77 1</link><link type="0">1B 86 A1 1</link><link type="0">1A 4C 9D 1</link><link type="0">1A 4C A5 1</link><link type="0">1A 59 77 1</link><link type="0">1A 4B 41 1</link><link type="0">1A 4C D1 1</link><link type="0">1A 59 D 1</link><link type="0">1A 5A 9B 1</link><link type="0">1D B4 63 1</link><link type="0">1D BE 22 1</link><link type="0">1D B4 92 1</link><link type="0">1D C0 29 1</link><link type="0">1D B9 82 1</link><link type="0">1D AD F1 1</link><link type="0">1D B3 5 1</link><link type="0">1F AB F3 1</link><link type="0">1F AD 4 1</link><link type="0">3D 7B 62 1</link><link type="0">27 BC 69 1</link><link type="0">1B 91 8 1</link><link type="0">1D AD 51 1</link><link type="0">1D B9 D1 1</link><link type="0">36 B8 D4 1</link><link type="0">36 B8 D4 2</link><link type="0">36 B8 D4 4</link><link type="0">3D 7B 62 2</link><link type="0">3D 7B 62 3</link><link type="0">3D 7B 62 4</link><link type="0">3D 7B 62 5</link><link type="0">3D 7B 62 6</link><link type="0">3D 7B 62 7</link><link type="0">3D 7B 62 8</link><link type="0">38 7F CB 1</link><link type="0">35 A3 B6 1</link><link type="0">35 A3 C6 1</link><link type="0">n001_dsc1_z03</link><link type="0">n001_dsc1_z04</link><link type="0">n001_dsc1_z05</link><link type="0">n001_dsc1_z06</link><link type="0">n001_dsc1_z07</link><link type="0">n001_dsc1_z08</link><link type="0">n001_dsc1_z09</link><link type="0">n001_dsc1_z10</link><link type="0">n001_dsc1_z11</link><link type="0">n001_dsc1_z12</link><link type="0">n001_dsc1_z13</link><link type="0">n001_dsc1_z14</link><link type="0">n001_dsc1_z15</link><link type="0">n001_dsc1_z16</link><link type="0">n001_dsc1_z17</link><link type="0">n001_dsc1_z18</link><link type="0">n001_dsc1_z19</link><link type="0">n001_dsc1_z20</link><link type="0">n001_dsc1_z21</link><link type="0">n001_dsc1_z22</link><link type="0">n001_dsc1_z23</link><link type="0">n001_dsc1_z24</link><link type="0">n001_dsc1_z25</link><link type="0">n001_dsc1_z26</link><link type="0">n001_dsc1_z27</link><link type="0">n001_dsc1_z28</link><link type="0">n001_dsc1_z29</link><link type="0">n001_dsc1_z30</link><link type="0">n001_dsc1_z31</link><link type="0">n001_dsc1_z32</link><link type="0">n001_dsc1_z33</link><link type="0">n001_dsc1_z34</link><link type="0">n001_dsc1_z35</link><link type="0">n001_dsc1_z36</link><link type="0">n001_dsc1_z37</link><link type="0">n001_dsc1_z38</link><link type="0">n001_dsc1_z39</link><link type="0">n001_dsc1_z40</link><link type="0">n001_dsc1_z41</link><link type="0">n001_dsc1_z42</link><link type="0">n001_dsc1_z43</link><link type="0">n001_ven2</link><link type="0">n001_ven2_s00</link><link type="0">n001_ven1</link><link type="0">n001_ven1_run</link><link type="0">n001_ven1_s00</link><link type="0">n001_ven1_s01</link><link type="0">n003_occdev001</link><link type="0">n003_occloc01</link><link type="0">n001_ven2_run</link><link type="0">n003_occdev002</link><link type="0">3F DE 90 1</link><link type="0">49 40 E3 1</link><link type="0">47 16 A 1</link><link type="0">47 17 E 1</link><link type="0">47 16 D3 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>50271</address><name>Dining Room Light</name><family>6</family><deviceGroup>16</deviceGroup><pnode>50271</pnode><ELK_ID>A04</ELK_ID><members><link type="16">1A 5A BC 1</link><link type="16">1A 4A 8 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>ADR0001</address><name>Auto DR</name><family>6</family><deviceGroup>19</deviceGroup><pnode>ADR0001</pnode><ELK_ID>A07</ELK_ID><members></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>16591</address><name>A_Test_Lights</name><family>6</family><deviceGroup>35</deviceGroup><pnode>16591</pnode><ELK_ID>B03</ELK_ID><members><link type="0">1A 58 5F 1</link><link type="0">35 A3 B6 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>16544</address><name>All Soffits</name><family>6</family><deviceGroup>36</deviceGroup><pnode>16544</pnode><ELK_ID>B04</ELK_ID><members><link type="0">1D B4 63 1</link><link type="0">1D BE 22 1</link><link type="0">1D B4 92 1</link><link type="0">1D C0 29 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>60174</address><name>Back Stairs_Bar</name><family>6</family><deviceGroup>18</deviceGroup><pnode>60174</pnode><ELK_ID>D14</ELK_ID><members><link type="16">1D B9 82 1</link><link type="16">1F AB F3 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>45150</address><name>Basement Lights</name><family>6</family><deviceGroup>37</deviceGroup><pnode>45150</pnode><ELK_ID>E11</ELK_ID><members><link type="0">1A 4C A5 1</link><link type="0">1A 59 77 1</link><link type="0">1A 4B 41 1</link><link type="0">1A 4C D1 1</link><link type="0">1A 59 D 1</link><link type="0">1A 5A 9B 1</link><link type="0">1D B9 82 1</link><link type="0">1D AD F1 1</link><link type="0">1D B3 5 1</link><link type="0">1F AB F3 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>34523</address><name>Keypad.B LED</name><family>6</family><deviceGroup>17</deviceGroup><pnode>34523</pnode><ELK_ID>F03</ELK_ID><members><link type="0">3D 7B 62 2</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>29523</address><name>Front Lights to Update</name><family>6</family><deviceGroup>20</deviceGroup><pnode>29523</pnode><ELK_ID>F04</ELK_ID><members><link type="0">1B 85 C3 1</link><link type="0">1D B4 63 1</link><link type="0">1D BE 22 1</link><link type="0">1F AD 4 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>13585</address><name>Keypad.C LED</name><family>6</family><deviceGroup>21</deviceGroup><pnode>13585</pnode><ELK_ID>F05</ELK_ID><members><link type="0">3D 7B 62 3</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>7026</address><name>Keypad.G LED</name><family>6</family><deviceGroup>22</deviceGroup><pnode>7026</pnode><ELK_ID>F06</ELK_ID><members><link type="0">3D 7B 62 7</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>53433</address><name>Keypad.D LED</name><family>6</family><deviceGroup>23</deviceGroup><pnode>53433</pnode><ELK_ID>F07</ELK_ID><members><link type="0">3D 7B 62 4</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>30724</address><name>Keypad.E LED</name><family>6</family><deviceGroup>24</deviceGroup><pnode>30724</pnode><ELK_ID>F08</ELK_ID><members><link type="0">3D 7B 62 5</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>3408</address><name>Keypad.F LED</name><family>6</family><deviceGroup>25</deviceGroup><pnode>3408</pnode><ELK_ID>F09</ELK_ID><members><link type="0">3D 7B 62 6</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>12393</address><name>Keypad.H LED</name><family>6</family><deviceGroup>26</deviceGroup><pnode>12393</pnode><ELK_ID>F10</ELK_ID><members><link type="0">3D 7B 62 8</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>30979</address><name>Back Lights</name><family>6</family><deviceGroup>27</deviceGroup><pnode>30979</pnode><ELK_ID>F11</ELK_ID><members><link type="0">1A 2B 95 1</link><link type="0">1A 2B 86 1</link><link type="0">1B 31 77 1</link><link type="0">1A 4C 9D 1</link><link type="0">27 BC 69 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>36476</address><name>Front Lights</name><family>6</family><deviceGroup>28</deviceGroup><pnode>36476</pnode><ELK_ID>F12</ELK_ID><members><link type="0">1B 85 C3 1</link><link type="0">1F AD 4 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>8754</address><name>Back Lights ON Brighter</name><family>6</family><deviceGroup>29</deviceGroup><pnode>8754</pnode><ELK_ID>F13</ELK_ID><members><link type="0">1A 2B 95 1</link><link type="0">1B 31 77 1</link><link type="0">1A 4C 9D 1</link><link type="0">27 BC 69 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>42</address><name>Party Lights</name><family>6</family><deviceGroup>30</deviceGroup><pnode>42</pnode><ELK_ID>F14</ELK_ID><members><link type="0">1A 58 5F 1</link><link type="0">1A 2B 86 1</link><link type="0">1A 4C A5 1</link><link type="0">1A 59 77 1</link><link type="0">1A 4B 41 1</link><link type="0">1A 4C D1 1</link><link type="0">1A 59 D 1</link><link type="0">1A 5A 9B 1</link><link type="0">1D B4 92 1</link><link type="0">1D C0 29 1</link><link type="0">1D AD F1 1</link><link type="0">1D B3 5 1</link><link type="0">1D AD 51 1</link><link type="0">1D B9 D1 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>23567</address><name>Front-Garage Soffits - Bright</name><family>6</family><deviceGroup>31</deviceGroup><pnode>23567</pnode><ELK_ID>F15</ELK_ID><members><link type="0">1D B4 63 1</link><link type="0">1D BE 22 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>43972</address><name>Front- Garage Soffits</name><family>6</family><deviceGroup>32</deviceGroup><pnode>43972</pnode><ELK_ID>F16</ELK_ID><members><link type="0">1D B4 63 1</link><link type="0">1D BE 22 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>40990</address><name>Keypad.C Lights OFF</name><family>6</family><deviceGroup>33</deviceGroup><pnode>40990</pnode><ELK_ID>G01</ELK_ID><members><link type="0">1A 2B 86 1</link><link type="0">1D B4 92 1</link><link type="0">1D C0 29 1</link><link type="0">1B 91 8 1</link><link type="0">1D AD 51 1</link><link type="0">1D B9 D1 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>29297</address><name>OutDoor Xmas Timers</name><family>6</family><deviceGroup>34</deviceGroup><pnode>29297</pnode><ELK_ID>J03</ELK_ID><members><link type="0">37 E5 1B 1</link><link type="0">3F DE 90 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>21078</address><name>Deck Lights</name><family>6</family><deviceGroup>38</deviceGroup><pnode>21078</pnode><ELK_ID>J06</ELK_ID><members><link type="0">1D AD 51 1</link><link type="0">1D B9 D1 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>23645</address><name>Theatre Ceiling ON</name><family>6</family><deviceGroup>39</deviceGroup><pnode>23645</pnode><ELK_ID>K09</ELK_ID><members><link type="0">1A 59 77 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>54692</address><name>Theatre Ceiling OFF</name><family>6</family><deviceGroup>40</deviceGroup><pnode>54692</pnode><ELK_ID>K10</ELK_ID><members><link type="0">1A 59 77 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>51355</address><name>Theatre Pots ON</name><family>6</family><deviceGroup>41</deviceGroup><pnode>51355</pnode><ELK_ID>K11</ELK_ID><members><link type="0">1A 4C A5 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>26563</address><name>Theatre Pots OFF</name><family>6</family><deviceGroup>42</deviceGroup><pnode>26563</pnode><ELK_ID>K12</ELK_ID><members><link type="0">1A 4C A5 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>31761</address><name>Theatre Sconces ON</name><family>6</family><deviceGroup>43</deviceGroup><pnode>31761</pnode><ELK_ID>K13</ELK_ID><members><link type="0">1A 4B 41 1</link><link type="0">1A 59 D 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>52606</address><name>Theatre Sconces OFF</name><family>6</family><deviceGroup>44</deviceGroup><pnode>52606</pnode><ELK_ID>K14</ELK_ID><members><link type="0">1A 4B 41 1</link><link type="0">1A 59 D 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>24905</address><name>Theatre ALL Lights ON</name><family>6</family><deviceGroup>45</deviceGroup><pnode>24905</pnode><ELK_ID>K15</ELK_ID><members><link type="0">1A 4C A5 1</link><link type="0">1A 59 77 1</link><link type="0">1A 4B 41 1</link><link type="0">1A 59 D 1</link></members></group><group flag="132" nodeDefId="InsteonDimmer"><address>45206</address><name>Theatre ALL Lights OFF</name><family>6</family><deviceGroup>46</deviceGroup><pnode>45206</pnode><ELK_ID>K16</ELK_ID><members><link type="0">1A 4C A5 1</link><link type="0">1A 59 77 1</link><link type="0">1A 4B 41 1</link><link type="0">1A 59 D 1</link></members></group></nodes> (nodes) 2022-04-18 12:15:45 - ISY Warning: Duplicate node names exist on the ISY (Runtime) 2022-04-18 12:15:45 - ISY Warning: Duplicate node names exist on the ISY (Home) 2022-04-18 12:15:45 - ISY Warning: Duplicate node names exist on the ISY (Space Temp) 2022-04-18 12:15:45 - ISY Receive: <editors> <editor id="I_10DAYS"> <range uom="25" min="0" max="10" prec="0" /> </editor> <editor id="I_ALARM_ZONE"> <range uom="25" min="0" max="1" prec="0" nls="EN_ALARM_ZONE" /> </editor> <editor id="I_ALARMCODE"> <range uom="25" min="0" max="999999" prec="0" /> </editor> <editor id="I_BATTERY"> <range uom="51" min="0" max="100" prec="0" /> </editor> <editor id="I_BINARY"> <range uom="25" subset="0-1" /> </editor> <editor id="I_CLISPC"> <range uom="4" min="5" max="35" step="0.5" prec="1" /> <range uom="17" min="32" max="90" step="1" prec="0"/> </editor> <editor id="I_CLISPH"> <range uom="4" min="5" max="35" step="0.5" prec="1" /> <range uom="17" min="32" max="90" step="1" prec="0"/> </editor> <editor id="I_COLOR"> <range uom="25" subset="0-255" nls="EN_COLOR" /> </editor> <editor id="I_COLORSET"> <range uom="25" subset="0-15" nls="EN_COLORSET" /> </editor> <editor id="I_DAYOFWEEK"> <range uom="25" subset="0-6" nls="EN_DAY" /> </editor> <editor id="I_DEGREE"> <range uom="14" min="-360" max="360" prec="0" /> </editor> <editor id="I_DEGREES"> <range uom="14" min="0" max="360" prec="0" /> </editor> <editor id="I_DIMMER"> <range uom="51" subset="0-100" /> </editor> <editor id="I_DISTANCE_LARGE"> <range uom="116" min="0" max="50000000" prec="2" /> <range uom="83" min="0" max="50000000" prec="2" /> </editor> <editor id="I_DOOR"> <range uom="25" subset="0,254,255" nls="EN_DOOR" /> </editor> <editor id="I_DOOR_INFO"> <range uom="25" subset="0,1,2,3,4,5,8,10,11,15,17,254,500" nls="EN_DOOR_INFO" /> </editor> <editor id="I_DSC_STANDARD"> <range uom="25" subset="0-1" nls="EN_STATUS" /> </editor> <editor id="I_DSC_STATUS"> <range uom="25" subset="0-4" nls="EN_DSCSTAT" /> </editor> <editor id="I_DSC_USER"> <range uom="70" min="1" max="42" prec="0" /> </editor> <editor id="I_ENABLED"> <range uom="25" subset="0-1" nls="EN_ENABLED" /> </editor> <editor id="I_ERROR_STATUS"> <range uom="25" subset="0-1" nls="EN_ERROR_STATUS" /> </editor> <editor id="I_FREQUENCY"> <range uom="90" min="0" max="65535" prec="0" /> </editor> <editor id="I_FLOAT2"> <range uom="25" min="0" max="50000000" prec="2" /> </editor> <editor id="I_GEN_MAINV"> <range uom="72" min="0" max="300" prec="1" /> </editor> <editor id="I_GEN_BATTV"> <range uom="72" min="0" max="300" /> </editor> <editor id="I_GEN_FREQ"> <range uom="90" min="0" max="100" /> </editor> <editor id="I_GEN_SWITCHSTATE"> <range uom="25" min="0" max="5" nls="EN_GEN_SWITCHSTATE" /> </editor> <editor id="I_GEN_ENGINESTATE"> <range uom="25" min="0" max="11" nls="EN_GEN_ENGINESTATE" /> </editor> <editor id="I_GEN_TRANSFERSWITCHSTATE"> <range uom="25" min="0" max="2" nls="EN_GEN_TRANSFERSWITCHSTATE" /> </editor> <editor id="I_GEN_MONITORHEALTH"> <range uom="25" min="0" max="2" nls="EN_GEN_MONITORHEALTH" /> </editor> <editor id="I_GEM_A"> <range uom="1" min="0" max="200" prec="1" /> </editor> <editor id="I_GEM_CO"> <range uom="55" min="0" max="32768" prec="0" /> </editor> <editor id="I_GEM_T"> <range uom="14" min="0" max="500" prec="2" /> </editor> <editor id="I_GEM_V"> <range uom="72" min="0" max="300" prec="1" /> </editor> <editor id="I_GEM_W"> <range uom="73" min="0" max="50000" prec="0" /> </editor> <editor id="I_GEM_WH"> <range uom="33" min="0" max="500" prec="2" /> </editor> <editor id="I_GEM_RUNTIME"> <range uom="10" min="0" max="5000000000" prec="2" /> </editor> <editor id="I_HEARTBEAT"> <range uom="25" min="-1" max="1" step="1" prec="0" /> </editor> <editor id="I_HONALARM_STATUS"> <range uom="25" subset="0-3" nls="EN_HONALARM_STATUS" /> </editor> <editor id="I_HONTSTAT_FAN_MODE"> <range uom="68" subset="0,1,6" /> </editor> <editor id="I_HONTSTAT_STATUS"> <range uom="25" subset="0-4" nls="EN_HONTSTAT_STATUS" /> </editor> <editor id="I_HUMIDITY"> <range uom="51" min="0" max="100" prec="0" /> </editor> <editor id="I_ILLUMINANCE"> <range uom="36" min="0" max="1000000" prec="0" /> </editor> <editor id="I_INTEGER"> <range uom="25" min="0" max="50000000" prec="0" /> </editor> <editor id="I_INTEGER16"> <range uom="25" min="0" max="65535" prec="0" /> </editor> <editor id="I_LEAK_SENSOR"> <range uom="25" subset="0,2,254" nls="EN_LEAK_SENSOR" /> </editor> <editor id="I_LOC_STATUS"> <range uom="25" subset="0-1" nls="EN_LOC_STATUS" /> </editor> <editor id="I_MIDIMMER"> <range uom="51" subset="10-100" /> </editor> <editor id="I_MONTH"> <range uom="47" subset="1-12" /> </editor> <editor id="I_ODDEVEN"> <range uom="25" subset="0,1" nls="EN_ODD" /> </editor> <editor id="I_PHONE_RINGING"> <range uom="25" subset="0-1" nls="EN_PHONE_RINGING" /> </editor> <editor id="I_PING"> <range uom="25" subset="0-1" nls="EN_PING" /> </editor> <editor id="I_PRECIP_ACCUMULATED"> <range uom="105" min="0" max="150" prec="2" /> <range uom="82" min="0" max="150" prec="2" /> </editor> <editor id="I_PRECIP_RATE"> <range uom="24" min="0" max="150" prec="2" /> <range uom="46" min="0" max="150" prec="2" /> </editor> <editor id="I_PRECIP_TYPE"> <range uom="25" subset="0-3" nls="EN_PRECIP_TYPE" /> </editor> <editor id="I_PRESSURE_VENT"> <range uom="25" min="0" max="150" prec="2" /> </editor> <editor id="I_PRESSURE_WEATHER"> <range uom="23" min="0" max="150" prec="1" /> <range uom="31" min="0" max="150" prec="2" /> </editor> <editor id="I_RAIN_INTENSITY"> <range uom="25" subset="0-4" nls="EN_RAIN_INTENSITY" /> </editor> <editor id="I_RAIN_NEXTRUN"> <range uom="25" subset="0-3" nls="EN_RAIN_NEXTRUN" /> </editor> <editor id="I_RAIN_PROGFREQ"> <range uom="25" subset="0-4" nls="EN_RAIN_PROGFREQ" /> </editor> <editor id="I_RAIN_PROGFREQPARAM"> <range uom="25" subset="0-14" nls="EN_RAIN_PROGFREQPARAM" /> </editor> <editor id="I_RAIN_ZONE"> <range uom="25" subset="0-2" nls="EN_RAIN_ZONE" /> </editor> <editor id="I_RAIN_ZONE_DURATION"> <range uom="25" subset="5-120" /> </editor> <editor id="I_RAINMACHINEPROGRAM"> <range uom="25" subset="0-2" nls="EN_RAINMACHINEPROGRAM" /> </editor> <editor id="I_SEASON"> <range uom="25" subset="1-4" nls="EN_SEASON" /> </editor> <editor id="I_SETTEMP"> <range uom="4" min="0" max="30" step="0.5" prec="1" /> <range uom="17" min="0" max="100" step="1" prec="0" /> </editor> <editor id="I_SKY"> <range uom="25" subset="0-34" nls="EN_SKY" /> </editor> <editor id="I_SOLAR_RADIATION"> <range uom="74" min="0" max="10000" prec="0" /> </editor> <editor id="I_STATUS"> <range uom="25" subset="0-1" nls="EN_STATUS" /> </editor> <editor id="I_SWITCH"> <range uom="25" subset="0,255" nls="EN_SWITCH" /> </editor> <editor id="I_TEMP"> <range uom="14" min="-50" max="200" prec="2" /> </editor> <editor id="I_TEMP_1"> <range uom="14" min="-50" max="200" step="0.5" prec="1" /> </editor> <editor id="I_TEMPERATURE"> <range uom="17" min="-50" max="150" prec="1" /> <range uom="4" min="-50" max="150" prec="1" /> </editor> <editor id="I_TEL"> <range uom="25" subset="0,1" nls="EN_PHONE_RINGING" /> </editor> <editor id="I_TEL_AREACODE"> <range uom="25" min="0" max="999" prec="0" /> </editor> <editor id="I_TEL_NUMBER"> <range uom="25" min="0" max="9999999" prec="0" /> </editor> <editor id="I_TIMEOFUSE"> <range uom="25" subset="0-2" nls="EN_TOU" /> </editor> <editor id="I_TRUE_BOOL"> <range uom="25" subset="0-1" nls="EN_TRUE_BOOL" /> </editor> <editor id="I_TSTAT_ALERT"> <range uom="25" subset="0,1" nls="EN_ALERT" /> </editor> <editor id="I_TSTAT_ECO_SCHED_TYPE"> <range uom="25" subset="0-10" nls="EN_ECOSCH" /> </editor> <editor id="I_TSTAT_ECO_SCHED_OPT"> <range uom="25" subset="0-1" nls="EN_ECOSCH_OPT" /> </editor> <editor id="I_TSTAT_FAN_MODE"> <range uom="68" subset="0,1" /> </editor> <editor id="I_TSTAT_FAN_STATE"> <range uom="80" subset="0,1" /> </editor> <editor id="I_TSTAT_FANONTIME"> <range uom="25" min="0" max="55" step="1" prec="0" /> </editor> <editor id="I_TSTAT_ECOHCS"> <range uom="25" subset="0-8" nls="EN_ECOHCS" /> </editor> <editor id="I_TSTAT_VEN_ACTSTAGE"> <range uom="25" subset="0-4" /> </editor> <editor id="I_TSTAT_HCS"> <range uom="66" subset="0-2" /> </editor> <editor id="I_TSTAT_HUM_SET"> <range uom="51" min="10" max="100" step="1" prec="0" /> </editor> <editor id="I_TSTAT_LOC"> <range uom="25" subset="0,1" nls="EN_LOC" /> </editor> <editor id="I_TSTAT_MODE"> <range uom="67" subset="0-3" /> </editor> <editor id="I_TSTAT_OCC"> <range uom="25" subset="0,1" nls="EN_BOOL" /> </editor> <editor id="I_TSTAT_PROG_MODE"> <range uom="25" subset="0,1" nls="EN_PM" /> </editor> <editor id="I_TSTAT_PROG_MODE2"> <range uom="25" subset="0-2" nls="EN_PM2" /> </editor> <editor id="I_TSTAT_PROG_MODE3"> <range uom="25" subset="0-3" nls="EN_PM3" /> </editor> <editor id="I_TSTAT_RUNTIME"> <range uom="25" min="0" max="5000000000" prec="0" /> </editor> <editor id="I_TSTAT_RUNTIME2"> <range uom="10" min="0" max="5000000000" prec="2" /> </editor> <editor id="I_UV"> <range uom="25" min="0" max="50" prec="2" /> </editor> <editor id="I_VIRTUAL"> <range uom="25" subset="0,255" nls="EN_VIRTUAL" /> </editor> <editor id="I_VOLTS"> <range uom="72" min="0" max="50000000" prec="2" /> </editor> <editor id="I_VSTAR_HCS"> <range uom="25" subset="0-4" nls="EN_VENSTATE" /> </editor> <editor id="I_WEATHER_SYMBOL"> <range uom="25" subset="0-21" /> </editor> <editor id="I_WIND"> <range uom="32" subset="0-500" /> <range uom="48" subset="0-500" /> </editor> <editor id="I_WIND_DIRECTION"> <range uom="25" subset="0-8" nls="EN_WIND_DIRECTION" /> </editor> <editor id="I_WINDSPEED"> <range uom="48" min="0" max="200" prec="0" /> <range uom="40" min="0" max="200" prec="2" /> </editor> </editors> (profiles/family/10/profile/1/download/editor/i_edit.xml) 2022-04-18 12:15:46 - ISY Receive: <nodeDefs> <!-- === Ecobee Thermostat ============================================================ --> <nodeDef id="Ecobee" nls="140E" > <sts> <st id="ST" editor="I_TEMPERATURE" /> <st id="CLISPH" editor="I_CLISPH" /> <st id="CLISPC" editor="I_CLISPC" /> <st id="CLIMD" editor="I_TSTAT_MODE" /> <st id="CLIHUM" editor="I_HUMIDITY" /> <st id="CLIHCS" editor="I_TSTAT_ECOHCS" /> <st id="CLIFRS" editor="I_TSTAT_FAN_STATE" /> <st id="GV1" editor="I_TSTAT_HUM_SET" /> <st id="CLISMD" editor="I_TSTAT_PROG_MODE3" /> <st id="GV2" editor="I_HEARTBEAT" /> <st id="GV4" editor="I_TSTAT_FANONTIME" /> <st id="GV3" editor="I_TSTAT_ECO_SCHED_TYPE" /> <st id="GV5" editor="I_HUMIDITY" /> <st id="GV6" editor="I_ENABLED" /> <st id="GV7" editor="I_ENABLED" /> </sts> <cmds> <accepts> <cmd id="CLISPH"> <p id="" editor="I_CLISPH" init="CLISPH" /> </cmd> <cmd id="CLISPC"> <p id="" editor="I_CLISPC" init="CLISPC" /> </cmd> <cmd id="CLIMD"> <p id="" editor="I_TSTAT_MODE" init="CLIMD" /> </cmd> <cmd id="CLISMD"> <p id="" editor="I_TSTAT_PROG_MODE2" init="CLISMD" /> </cmd> <cmd id="GV3"> <p id="" editor="I_TSTAT_ECO_SCHED_TYPE" init="GV3" /> <p id="HoldType" editor="I_TSTAT_ECO_SCHED_OPT" init="0" optional="T" /> </cmd> <cmd id="GV4"> <p id="" editor="I_TSTAT_FANONTIME" init="GV4" /> </cmd> <cmd id="GV6"> <p id="" editor="I_ENABLED" init="GV6" /> </cmd> <cmd id="GV7"> <p id="" editor="I_ENABLED" init="GV7" /> </cmd> <cmd id="BRT"> <p id="" editor="I_SETTEMP" optional="T" /> </cmd> <cmd id="DIM"> <p id="" editor="I_SETTEMP" optional="T" /> </cmd> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="EcobeeSensor" nls="140ES" > <sts> <st id="ST" editor="I_TEMPERATURE" /> <st id="GV1" editor="I_TSTAT_OCC" /> </sts> </nodeDef> <nodeDef id="EcobeeWeather" nls="140EW" > <sts> <st id="ST" editor="I_TEMPERATURE" /> <st id="GV1" editor="I_HUMIDITY" /> <st id="GV2" editor="I_HUMIDITY" /> <st id="GV3" editor="I_TEMPERATURE" /> <st id="GV4" editor="I_TEMPERATURE" /> <st id="GV5" editor="I_WIND" /> <st id="GV6" editor="I_WIND_DIRECTION" /> <st id="GV7" editor="I_SKY" /> <st id="GV8" editor="I_WEATHER_SYMBOL" /> </sts> </nodeDef> <!-- === Honeywell Thermostat ============================================================ --> <nodeDef id="HonTCC" nls="140H" > <sts> <st id="ST" editor="I_TEMPERATURE" /> <st id="CLISPH" editor="I_CLISPH" /> <st id="CLISPC" editor="I_CLISPC" /> <st id="CLIMD" editor="I_TSTAT_MODE" /> <st id="CLIFS" editor="I_HONTSTAT_FAN_MODE" /> <st id="CLIHUM" editor="I_HUMIDITY" /> <st id="GV1" editor="I_HONTSTAT_STATUS" /> <st id="GV2" editor="I_HEARTBEAT" /> <st id="GV3" editor="I_TEMPERATURE" /> <st id="GV4" editor="I_HUMIDITY" /> </sts> <cmds> <accepts> <cmd id="CLISPH"> <p id="" editor="I_CLISPH" init="CLISPH" /> </cmd> <cmd id="CLISPC"> <p id="" editor="I_CLISPC" init="CLISPC" /> </cmd> <cmd id="CLIMD"> <p id="" editor="I_TSTAT_MODE" init="CLIMD" /> </cmd> <cmd id="GV1"> <p id="" editor="I_HONTSTAT_STATUS" init="GV1" /> </cmd> <cmd id="CLIFS"> <p id="" editor="I_HONTSTAT_FAN_MODE" init="CLIFS" /> </cmd> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <!-- === Venstar Thermostat ============================================================ --> <nodeDef id="Venstar" nls="140V" > <sts> <st id="ST" editor="I_TEMPERATURE" /> <st id="CLISPH" editor="I_CLISPH" /> <st id="CLISPC" editor="I_CLISPC" /> <st id="CLIMD" editor="I_TSTAT_MODE" /> <st id="CLIFS" editor="I_TSTAT_FAN_MODE" /> <st id="CLIHUM" editor="I_HUMIDITY" /> <st id="CLIHCS" editor="I_VSTAR_HCS" /> <st id="GV4" editor="I_TSTAT_VEN_ACTSTAGE" /> <st id="CLIFRS" editor="I_TSTAT_FAN_STATE" /> <st id="GV1" editor="I_TSTAT_HUM_SET" /> <st id="CLISMD" editor="I_TSTAT_PROG_MODE" /> <st id="GV2" editor="I_HEARTBEAT" /> <st id="GV3" editor="I_TSTAT_LOC" /> <st id="GV6" editor="I_TSTAT_ALERT" /> <st id="GV5" editor="I_HUMIDITY" /> <st id="GV7" editor="I_TRUE_BOOL" /> </sts> <cmds> <accepts> <cmd id="CLISPH"> <p id="" editor="I_CLISPH" init="CLISPH" /> </cmd> <cmd id="CLISPC"> <p id="" editor="I_CLISPC" init="CLISPC" /> </cmd> <cmd id="CLIMD"> <p id="" editor="I_TSTAT_MODE" init="CLIMD" /> </cmd> <cmd id="CLIFS"> <p id="" editor="I_TSTAT_FAN_MODE" init="CLIFS" /> </cmd> <cmd id="CLISMD"> <p id="" editor="I_TSTAT_PROG_MODE" init="CLISMD" /> </cmd> <cmd id="GV1"> <p id="" editor="I_TSTAT_HUM_SET" init="GV1" /> </cmd> <cmd id="GV3"> <p id="" editor="I_TSTAT_LOC" init="GV3" /> </cmd> <cmd id="GV5"> <p id="" editor="I_TSTAT_HUM_SET" init="GV5" /> </cmd> <cmd id="BRT" /> <cmd id="DIM" /> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="VenstarRuntimes" nls="140VR" > <sts> <st id="GV1" editor="I_TSTAT_RUNTIME" /> <st id="GV2" editor="I_TSTAT_RUNTIME" /> <st id="GV3" editor="I_TSTAT_RUNTIME" /> <st id="GV4" editor="I_TSTAT_RUNTIME" /> <st id="GV5" editor="I_TSTAT_RUNTIME" /> <st id="GV6" editor="I_TSTAT_RUNTIME" /> <st id="GV7" editor="I_TSTAT_RUNTIME" /> <st id="GV8" editor="I_TSTAT_RUNTIME" /> <st id="GV9" editor="I_TSTAT_RUNTIME2" /> </sts> <cmds> <accepts> <cmd id="GV9" /> </accepts> </cmds> </nodeDef> <nodeDef id="VenstarSensor" nls="140VS" > <sts> <st id="ST" editor="I_TEMPERATURE" /> <st id="GV1" editor="I_BATTERY" /> </sts> </nodeDef> <!-- === Honeywell Alarm ============================================================ --> <nodeDef id="HonAlarm" nls="102H" > <sts> <st id="ST" editor="I_HEARTBEAT" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="HonAlarmZone" nls="102Z" > <sts> <st id="ST" editor="I_ALARM_ZONE" /> </sts> </nodeDef> <nodeDef id="HonAlarmPartition" nls="102HP" > <sts> <st id="ST" editor="I_HONALARM_STATUS" /> <st id="GV1" editor="I_TRUE_BOOL" /> <st id="GV2" editor="I_TRUE_BOOL" /> <st id="GV3" editor="I_TRUE_BOOL" /> <st id="GV4" editor="I_TRUE_BOOL" /> <st id="GV5" editor="I_BINARY" /> <st id="GV6" editor="I_BINARY" /> <st id="GV7" editor="I_BINARY" /> </sts> <cmds> <accepts> <cmd id="DISARM" /> <cmd id="ARMAWAY" /> <cmd id="ARMSTAY" /> <cmd id="ARMNOENTRY" /> </accepts> </cmds> </nodeDef> <!-- === DSC Alarm ============================================================ --> <nodeDef id="DSC" nls="102D" > <sts> <st id="GV1" editor="I_DSC_USER" /> <st id="GV2" editor="I_BINARY" /> <st id="GV3" editor="I_BINARY" /> <st id="GV4" editor="I_BINARY" /> <st id="GV5" editor="I_BINARY" /> <st id="GV6" editor="I_BINARY" /> <st id="GV7" editor="I_DSC_STANDARD" /> <st id="GV8" editor="I_DSC_STANDARD" /> <st id="GV9" editor="I_DSC_STANDARD" /> <st id="GV10" editor="I_DSC_STANDARD" /> <st id="GV11" editor="I_HEARTBEAT" /> <st id="GV12" editor="I_BINARY" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> <cmd id="FIRE" /> <cmd id="AMB" /> <cmd id="PANIC" /> <cmd id="PGM_OUT1" /> <cmd id="PGM_OUT2" /> <cmd id="PGM_OUT3" /> <cmd id="PGM_OUT4" /> </accepts> </cmds> </nodeDef> <nodeDef id="DSCZone" nls="102Z" > <sts> <st id="ST" editor="I_ALARM_ZONE" /> </sts> </nodeDef> <nodeDef id="DSCPartition" nls="102DP" > <sts> <st id="ST" editor="I_DSC_STATUS" /> <st id="GV1" editor="I_TRUE_BOOL" /> <st id="GV2" editor="I_TRUE_BOOL" /> <st id="GV3" editor="I_TRUE_BOOL" /> </sts> <cmds> <accepts> <cmd id="DISARM"> <p id="CODE" editor="I_ALARMCODE" optional="T" /> </cmd> <cmd id="ARMAWAY" /> <cmd id="ARMSTAY" /> <cmd id="ARMNOENTRY" /> </accepts> </cmds> </nodeDef> <!-- === GreenEye ============================================================ --> <nodeDef id="GreenEye" nls="143" > <sts> <st id="ST" editor="I_GEM_V" /> <st id="GV1" editor="I_HEARTBEAT" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> <cmd id="RESET" /> </accepts> </cmds> </nodeDef> <nodeDef id="GreenEyeMain" nls="143M" > <sts> <st id="ST" editor="I_GEM_V" /> <st id="GV1" editor="I_GEM_A" /> <st id="GV2" editor="I_GEM_W" /> <st id="GV3" editor="I_GEM_WH" /> <st id="GV4" editor="I_GEM_A" /> <st id="GV5" editor="I_GEM_W" /> <st id="GV6" editor="I_HEARTBEAT" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> <cmd id="RESET" /> <cmd id="RUNRES" /> </accepts> </cmds> </nodeDef> <nodeDef id="GreenEyeChannel" nls="143C" > <sts> <st id="ST" editor="I_GEM_A" /> <st id="GV1" editor="I_GEM_W" /> <st id="GV2" editor="I_GEM_WH" /> <st id="GV3" editor="I_GEM_RUNTIME" /> </sts> <cmds> <accepts> <cmd id="RESET" /> <cmd id="RUNRES" /> </accepts> </cmds> </nodeDef> <nodeDef id="GreenEyeCounter" nls="143CO" > <sts> <st id="ST" editor="I_GEM_CO" /> </sts> </nodeDef> <nodeDef id="GreenEyeTemperature" nls="143T" > <sts> <st id="ST" editor="I_GEM_T" /> </sts> </nodeDef> <!-- === 1-Wire ============================================================ --> <nodeDef id="OneWire" nls="139OW" > <sts> <st id="ST" editor="I_HEARTBEAT" /> <st id="GV1" editor="I_INTEGER" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="OneWireTemp" nls="139OWT" > <sts> <st id="ST" editor="I_TEMP" /> </sts> </nodeDef> <nodeDef id="OneWireTempHum" nls="139OWTH" > <sts> <st id="ST" editor="I_TEMP" /> <st id="GV1" editor="I_HUMIDITY" /> </sts> </nodeDef> <nodeDef id="OneWireCounter" nls="139OWC" > <sts> <st id="ST" editor="I_INTEGER" /> <st id="GV1" editor="I_INTEGER" /> </sts> </nodeDef> <!-- === Flair ============================================================ --> <nodeDef id="FlairCloud" nls="139FC" > <sts> <st id="ST" editor="I_HEARTBEAT" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="FlairPuck" nls="139FP" > <sts> <st id="GV1" editor="I_TEMP_1" /> <st id="GV2" editor="I_HUMIDITY" /> <st id="GV3" editor="I_PRESSURE_VENT" /> <st id="GV4" editor="I_INTEGER" /> <st id="GV5" editor="I_HUMIDITY" /> </sts> </nodeDef> <nodeDef id="FlairVent" nls="139FV" > <sts> <st id="GV1" editor="I_HUMIDITY" /> <st id="GV2" editor="I_TEMP_1" /> <st id="GV3" editor="I_PRESSURE_VENT" /> <st id="GV4" editor="I_HUMIDITY" /> </sts> <cmds> <accepts> <cmd id="GV1"> <p id="" editor="I_HUMIDITY" init="GV1" /> </cmd> </accepts> </cmds> </nodeDef> <!-- === ISY Data ============================================================ --> <nodeDef id="ISYData" nls="139D" > <sts> <st id="GV1" editor="I_INTEGER" /> <st id="GV2" editor="I_INTEGER" /> <st id="GV3" editor="I_INTEGER" /> <st id="GV4" editor="I_ODDEVEN" /> <st id="GV5" editor="I_INTEGER" /> <st id="GV6" editor="I_DAYOFWEEK" /> <st id="GV7" editor="I_MONTH" /> <st id="GV8" editor="I_INTEGER" /> <st id="GV9" editor="I_INTEGER" /> <st id="GV10" editor="I_INTEGER" /> <st id="GV11" editor="I_SEASON" /> <st id="GV12" editor="I_TRUE_BOOL" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="ISYDataSun" nls="139DS" > <sts> <st id="GV1" editor="I_DEGREE" /> <st id="GV2" editor="I_DEGREE" /> <st id="GV3" editor="I_DEGREE" /> </sts> </nodeDef> <nodeDef id="ISYDataElec" nls="139DE" > <sts> <st id="ST" editor="I_TIMEOFUSE" /> </sts> </nodeDef> <!-- === Location ============================================================ --> <nodeDef id="Location" nls="113L" > <sts> <st id="ST" editor="I_HEARTBEAT" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="LocationDevice" nls="113LD" > <sts> <st id="ST" editor="I_LOC_STATUS" /> </sts> </nodeDef> <!-- === RainMachine ============================================================ --> <nodeDef id="RainMachine" nls="123R" > <sts> <st id="ST" editor="I_RAIN_ZONE" /> <st id="GV1" editor="I_HEARTBEAT" /> <st id="GV2" editor="I_FLOAT2" /> <st id="GV3" editor="I_TRUE_BOOL" /> <st id="GV4" editor="I_RAIN_NEXTRUN" /> </sts> <cmds> <accepts> <cmd id="DELAY"> <p id="" editor="I_10DAYS" /> </cmd> <cmd id="QUERY" /> <cmd id="ALLOFF" /> </accepts> </cmds> </nodeDef> <nodeDef id="RainMachineProgram" nls="123RP" > <sts> <st id="ST" editor="I_RAINMACHINEPROGRAM" /> <st id="GV1" editor="I_RAIN_NEXTRUN" /> <st id="GV2" editor="I_RAIN_PROGFREQ" /> <st id="GV3" editor="I_RAIN_PROGFREQPARAM" /> </sts> <cmds> <accepts> <cmd id="START" /> <cmd id="STOP" /> <cmd id="GV2"> <p id="" editor="I_RAIN_PROGFREQ" init="GV2" /> <p id="DAYS" editor="I_RAIN_PROGFREQPARAM" init="GV3" optional="T" /> </cmd> <cmd id="GV3"> <p id="" editor="I_RAIN_PROGFREQPARAM" init="GV3" /> </cmd> </accepts> </cmds> </nodeDef> <nodeDef id="RainMachineZone" nls="123RZ" > <sts> <st id="ST" editor="I_RAIN_ZONE" /> </sts> <cmds> <accepts> <cmd id="ON"> <p id="" editor="I_RAIN_ZONE_DURATION" optional="T" /> </cmd> <cmd id="OFF" /> </accepts> </cmds> </nodeDef> <nodeDef id="RainMachineMixer" nls="123MX" > <sts> <st id="ST" editor="I_FLOAT2" /> <st id="GV1" editor="I_FLOAT2" /> <st id="GV2" editor="I_FLOAT2" /> </sts> </nodeDef> <!-- === MiLight ============================================================ --> <nodeDef id="MiLi" nls="109ML" > <sts> </sts> <cmds> <accepts> <cmd id="ALLON"> <p id="" editor="I_MIDIMMER" optional="T" /> <p id="COLOR" editor="I_COLOR" optional="T" /> </cmd> <cmd id="COLORCODE"> <p id="" editor="I_COLORSET" nls="EN_COLORSET" /> </cmd> <cmd id="COLOR"> <p id="" editor="I_COLOR" /> </cmd> <cmd id="ALLWHITE"> <p id="" editor="I_MIDIMMER" optional="T" /> </cmd> <cmd id="ALLOFF" /> <cmd id="ALLFADEOFF" /> </accepts> </cmds> </nodeDef> <nodeDef id="MiLiGroup" nls="109MLG" > <sts> <st id="ST" editor="I_MIDIMMER" /> <st id="GV1" editor="I_COLOR" /> </sts> <cmds> <accepts> <cmd id="DON"> <p id="" editor="I_MIDIMMER" optional="T" /> <p id="COLOR" editor="I_COLOR" init="GV1" optional="T" /> </cmd> <cmd id="COLORCODE"> <p id="" editor="I_COLORSET" nls="EN_COLORSET" /> </cmd> <cmd id="COLOR"> <p id="" editor="I_COLOR" init="GV1" /> </cmd> <cmd id="WHITE"> <p id="" editor="I_MIDIMMER" optional="T" /> </cmd> <cmd id="DOF" /> <cmd id="FADEOFF" /> </accepts> </cmds> </nodeDef> <!-- === Modbus TCP ============================================================ --> <nodeDef id="MBTCP" nls="108MB" > <sts> <st id="ST" editor="I_HEARTBEAT" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="MBTCPDI" nls="108MBDI" > <sts> <st id="ST" editor="I_SWITCH" /> </sts> </nodeDef> <nodeDef id="MBTCPAI" nls="108MBAI" > <sts> <st id="ST" editor="I_INTEGER" /> </sts> </nodeDef> <nodeDef id="MBTCPDO" nls="108MBDO" > <sts> <st id="ST" editor="I_SWITCH" /> </sts> <cmds> <accepts> <cmd id="ON" /> <cmd id="OFF" /> </accepts> </cmds> </nodeDef> <nodeDef id="MBTCPAO" nls="108MBAO" > <sts> <st id="ST" editor="I_INTEGER16" /> </sts> <cmds> <accepts> <cmd id="VAL"> <p id="" editor="I_INTEGER" init="ST" /> </cmd> </accepts> </cmds> </nodeDef> <!-- === Webcontrol 8/32 ============================================================ --> <nodeDef id="WC8" nls="108W" > <sts> <st id="ST" editor="I_HEARTBEAT" /> <st id="GV1" editor="I_ERROR_STATUS" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="WC8T" nls="108WT" > <sts> <st id="ST" editor="I_FLOAT2" /> </sts> </nodeDef> <nodeDef id="WC8H" nls="108WH" > <sts> <st id="ST" editor="I_HUMIDITY" /> </sts> </nodeDef> <nodeDef id="WC8V" nls="108WV" > <sts> <st id="ST" editor="I_INTEGER" /> </sts> </nodeDef> <nodeDef id="WC8P" nls="108WP" > <sts> <st id="ST" editor="I_DIMMER" /> <st id="GV1" editor="I_FREQUENCY" /> </sts> <cmds> <accepts> <cmd id="ON"> <p id="" editor="I_DIMMER" init="ST" /> <p id="Frequency" editor="I_FREQUENCY" init="GV1" optional="T" /> </cmd> <cmd id="OFF" /> <cmd id="FREQ"> <p id="" editor="I_FREQUENCY" init="GV1" /> </cmd> </accepts> </cmds> </nodeDef> <nodeDef id="WC8C" nls="108WC" > <sts> <st id="ST" editor="I_GEM_CO" /> </sts> </nodeDef> <nodeDef id="WC8AI" nls="108WA" > <sts> <st id="ST" editor="I_FLOAT2" /> <st id="GV1" editor="I_INTEGER" /> </sts> </nodeDef> <nodeDef id="WC8DI" nls="108WI" > <sts> <st id="ST" editor="I_BINARY" /> </sts> </nodeDef> <nodeDef id="WC8DO" nls="108WO" > <sts> <st id="ST" editor="I_BINARY" /> </sts> <cmds> <accepts> <cmd id="ON" /> <cmd id="OFF" /> </accepts> </cmds> </nodeDef> <!-- === Tank Utility ============================================================ --> <nodeDef id="TankUtility" nls="146T" > <sts> <st id="ST" editor="I_BATTERY" /> <st id="GV1" editor="I_INTEGER16" /> <st id="GV2" editor="I_TEMP_F" /> <st id="GV3" editor="I_HEARTBEAT" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <!-- === GenMon ============================================================ --> <nodeDef id="GenMon" nls="181G" > <sts> <st id="ST" editor="I_GEN_SWITCHSTATE" /> <st id="GV1" editor="I_GEN_ENGINESTATE" /> <st id="GV2" editor="I_GEN_TRANSFERSWITCHSTATE" /> <st id="GV3" editor="I_GEN_MAINV" /> <st id="GV4" editor="I_GEN_MAINV" /> <st id="GV5" editor="I_GEN_FREQ" /> <st id="GV6" editor="I_GEN_BATTV" /> <st id="GV7" editor="I_GEN_MONITORHEALTH" /> <st id="GV8" editor="I_HEARTBEAT" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> <cmd id="START" /> <cmd id="STOP" /> <cmd id="EXERCISE" /> <cmd id="TRANSFER" /> </accepts> </cmds> </nodeDef> <!-- === Caller ID ============================================================ --> <nodeDef id="CallerID" nls="185CID" > <sts> <st id="ST" editor="I_TEL" /> <st id="GV1" editor="I_TEL_AREACODE" /> <st id="GV2" editor="I_TEL_NUMBER" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <!-- === Harmony Hub ============================================================ --> <nodeDef id="HarmonyHub" nls="127HH" > <sts> <st id="ST" editor="I_HEARTBEAT" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> <cmd id="OFF" /> </accepts> </cmds> </nodeDef> <!-- === Network Monitor ============================================================ --> <nodeDef id="NetMon" nls="165NM" > <sts> <st id="ST" editor="I_HEARTBEAT" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="NetMonDevice" nls="165NMD" > <sts> <st id="ST" editor="I_PING" /> </sts> </nodeDef> <!-- === WeatherFlow ============================================================ --> <nodeDef id="WFAir" nls="140WFA" > <sts> <st id="ST" editor="I_HEARTBEAT" /> <st id="GV1" editor="I_PRESSURE_WEATHER" /> <st id="GV2" editor="I_TEMPERATURE" /> <st id="GV3" editor="I_HUMIDITY" /> <st id="GV4" editor="I_INTEGER" /> <st id="GV5" editor="I_DISTANCE_LARGE" /> <st id="GV6" editor="I_VOLTS" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="WFSky" nls="140WFS" > <sts> <st id="ST" editor="I_HEARTBEAT" /> <st id="GV1" editor="I_ILLUMINANCE" /> <st id="GV2" editor="I_UV" /> <st id="GV3" editor="I_PRECIP_ACCUMULATED" /> <st id="GV4" editor="I_WINDSPEED" /> <st id="GV5" editor="I_WINDSPEED" /> <st id="GV6" editor="I_WINDSPEED" /> <st id="GV7" editor="I_DEGREES" /> <st id="GV8" editor="I_VOLTS" /> <st id="GV9" editor="I_SOLAR_RADIATION" /> <st id="GV10" editor="I_PRECIP_ACCUMULATED" /> <st id="GV11" editor="I_PRECIP_TYPE" /> <st id="GV12" editor="I_RAIN_INTENSITY" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <!-- === Homeseer ============================================================ --> <nodeDef id="Homeseer" nls="108HS" > <sts> <st id="ST" editor="I_HEARTBEAT" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="hsDoorLock" nls="111DL" > <sts> <st id="ST" editor="I_DOOR" /> <st id="GV1" editor="I_BATTERY" /> <st id="GV2" editor="I_DSC_USER" /> <st id="GV3" editor="I_DOOR_INFO" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> <cmd id="LOCK" /> <cmd id="UNLOCK" /> </accepts> </cmds> </nodeDef> <nodeDef id="hsLeakSensor" nls="169LS" > <sts> <st id="ST" editor="I_LEAK_SENSOR" /> <st id="GV1" editor="I_BATTERY" /> <st id="GV2" editor="I_TEMP_1" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> </accepts> </cmds> </nodeDef> <nodeDef id="hsSwitch" nls="121SW" > <sts> <st id="ST" editor="I_SWITCH" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> <cmd id="ON" /> <cmd id="OFF" /> </accepts> </cmds> </nodeDef> <nodeDef id="hsDimmer" nls="121D" > <sts> <st id="ST" editor="I_DIMMER" /> </sts> <cmds> <accepts> <cmd id="VAL"> <p id="" editor="I_DIMMER" init="ST" /> </cmd> <cmd id="QUERY" /> <cmd id="ON" /> <cmd id="OFF" /> </accepts> </cmds> </nodeDef> <nodeDef id="hsVirtual" nls="121V" > <sts> <st id="ST" editor="I_VIRTUAL" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> <cmd id="ON" /> <cmd id="OFF" /> </accepts> </cmds> </nodeDef> <nodeDef id="hsPlug" nls="121PG" > <sts> <st id="ST" editor="I_SWITCH" /> <st id="GV1" editor="I_GEM_V" /> <st id="GV2" editor="I_GEM_A" /> <st id="GV3" editor="I_GEM_W" /> <st id="GV4" editor="I_GEM_WH" /> </sts> <cmds> <accepts> <cmd id="QUERY" /> <cmd id="ON" /> <cmd id="OFF" /> </accepts> </cmds> </nodeDef> <!-- === Internet Weather ============================================================ --> <nodeDef id="InternetWeather" nls="1IWC" > <sts> <st id="CLITEMP" editor="I_TEMPERATURE" /> <st id="CLIHUM" editor="I_HUMIDITY" /> <st id="BARPRES" editor="I_PRESSURE_WEATHER" /> <st id="DEWPT" editor="I_TEMPERATURE" /> <st id="UV" editor="I_UV" /> <st id="RAINRT" editor="I_PRECIP_ACCUMULATED" /> </sts> </nodeDef> <nodeDef id="InternetWeatherForecast" nls="1IWF" > <sts> <st id="CLITEMP" editor="I_TEMPERATURE" /> <st id="CLIHUM" editor="I_HUMIDITY" /> <st id="BARPRES" editor="I_PRESSURE_WEATHER" /> <st id="DEWPT" editor="I_TEMPERATURE" /> <st id="UV" editor="I_UV" /> <st id="RAINRT" editor="I_PRECIP_ACCUMULATED" /> </sts> </nodeDef> </nodeDefs> (profiles/family/10/profile/1/download/nodedef/i_ndefs.xml) 2022-04-18 12:15:46 - ISY Receive: ND-Venstar-NAME = Venstar ColorTouch Thermostat ND-Venstar-ICON = Thermostat ND-VenstarRuntimes-NAME = Venstar Runtime Data ND-VenstarRuntimes-ICON = Thermostat ND-VenstarSensor-NAME = Venstar Sensor ND-VenstarSensor-ICON = TempSensor ND-Ecobee-NAME = Ecobee Thermostat ND-Ecobee-ICON = Thermostat ND-EcobeeSensor-NAME = Ecobee Sensor ND-EcobeeSensor-ICON = TempSensor ND-EcobeeWeather-NAME = Ecobee Weather ND-EcobeeWeather-ICON = Weather ND-HonTCC-NAME = Honeywell Thermostat ND-HonTCC-ICON = Thermostat ND-NetMon-NAME = Network Monitor ND-NetMon-ICON = GenericCtl ST-165NM-ST-NAME = Heartbeat ND-NetMonDevice-NAME = Network Device ND-NetMonDevice-ICON = GenericCtl ST-165NMD-ST-NAME = Status ND-HarmonyHub-NAME = Harmony Hub ND-Harmony Hub-ICON = GenericCtl ST-127HH-ST-NAME = Status CMD-127HH-OFF-NAME = Off ND-FlairCloud-NAME = Flair Smart Vent Cloud ND-FlairCloud-ICON = Thermostat ND-FlairPuck-NAME = Flair Puck ND-FlairPuck-ICON = TempSensor ND-FlairVent-NAME = Flair Vent ND-FlairVent-ICON = Switch ST-139FC-ST-NAME = Heartbeat ST-139FP-GV1-NAME = Temperature ST-139FP-GV2-NAME = Humidity ST-139FP-GV3-NAME = Pressure ST-139FP-GV4-NAME = Light ST-139FP-GV5-NAME = Battery ST-139FV-GV1-NAME = Duct Position ST-139FV-GV2-NAME = Duct Temperature ST-139FV-GV3-NAME = Duct Pressure ST-139FV-GV4-NAME = Battery CMD-139FV-GV1-NAME = Duct Position ND-RainMachine-NAME = RainMachine Irrigation Controller ND-RainMachine-ICON = Irrigation ND-RainMachineProgram-NAME = RainMachine Program ND-RainMachineProgram-ICON = GenericCtl ND-RainMachineZone-NAME = RainMachine Zone ND-RainMachineZone-ICON = Output ND-RainMachineMixer-NAME = RainMachine Mixer ND-RainMachineMixer-ICON = Weather ST-123R-GV1-NAME = Heartbeat ST-123R-GV2-NAME = Rain Delay ST-123R-GV3-NAME = Rain Sensor ST-123R-GV4-NAME = Next Program Run ST-123RP-GV1-NAME = Next Run ST-123RP-GV2-NAME = Frequency Type ST-123RP-GV3-NAME = Frequency Days ST-123MX-ST-NAME = QPF (Today) ST-123MX-GV1-NAME = QPF (Yesterday) ST-123MX-GV2-NAME = QPF (2 Days Ago) CMD-123R-ALLOFF-NAME = All Off CMD-123R-DELAY-NAME = Rain Delay CMD-123RP-START-NAME = Start CMD-123RP-STOP-NAME = Stop CMD-123RP-GV2-NAME = Frequency Type CMD-123RP-GV3-NAME = Frequency Days PGM-CMD-123RP-GV2-FMT = //${c}/to ${v}/ /Days//, days ${v}/ CMDP-I_RAIN_PROGFREQPARAM-DAYS-NAME = Days CMD-123RZ-ON-NAME = On CMD-123RZ-OFF-NAME = Off ND-ISYData-NAME = Additional ISY Data ND-ISYData-ICON = Input ND-ISYDataSun-NAME = Sun Position ND-ISYDataSun-ICON = Weather ND-ISYDataElec-NAME = Electricity Time-of-Use ND-ISYDataElec-ICON = Electricity ND-MiLi-NAME = MiLight WiFi Bridge ND-MiLi-ICON = LampAndSwitch ND-MiLiGroup-NAME = MiLight WiFi Bridge Group ND-MiLiGroup-ICON = Lamp ST-109MLG-GV1-NAME = Color CMD-109ML-ALLON-NAME = All On CMD-109ML-ALLWHITE-NAME = All On White CMD-109ML-ALLOFF-NAME = All Off CMD-109ML-ALLFADEOFF-NAME = All Fade Off CMD-109MLG-FADEOFF-NAME = Fade Off CMD-109ML-COLOR-NAME = Color CMD-109ML-COLORCODE-NAME = Color Code CMD-109MLG-WHITE-NAME = On White CMD-109MLG-COLOR-NAME = Color CMD-109MLG-COLORCODE-NAME = Color Code PGM-CMD-109ML-ALLON-FMT = //${c}/to ${v}/ /COLOR//, color ${v}/ PGM-CMD-109MLG-DON-FMT = //${c}/to ${v}/ /COLOR//, color ${v}/ CMDP-I_COLOR-COLOR-NAME = Color ND-OneWire-NAME = 1-Wire Controller ND-OneWire-ICON = GenericCtl ND-OneWireTemp-NAME = 1-Wire Temperature Sensor ND-OneWireTemp-ICON = TempSensor ND-OneWireTempHum-NAME = 1-Wire Climate Sensor ND-OneWireTempHum-ICON = TempSensor ND-OneWireCounter-NAME = 1-Wire 2-Channel Counter ND-OneWire-ICON = Input ST-139OW-ST-NAME = Heartbeat ST-139OW-GV1-NAME = Sensor Count ST-139OW-GV2-NAME = Read Errors ST-139OWT-ST-NAME = Temperature ST-139OWTH-ST-NAME = Temperature ST-139OWTH-GV1-NAME = Humidity ST-139OWC-ST-NAME = Counter 1 ST-139OWC-GV1-NAME = Counter 2 ND-Location-NAME = Geofence ND-Location-ICON = DoorLock ND-LocationDevice-NAME = Geo Device ND-LocationDevice-ICON = GenericRsp ST-108MB-ST-NAME = Heartbeat ND-TankUtility-NAME = Tank Utility ND-TankUtility-ICON = Switch ST-146T-GV1-NAME = Capacity ST-146T-GV2-NAME = Temperature ST-146T-GV3-NAME = Heartbeat ND-CallerID-NAME = Caller ID ND-CallerID-ICON = MotionSensor ST-185CID-GV1-NAME = Area Code ST-185CID-GV2-NAME = Phone Number ND-MBTCP-NAME = Modbus TCP ND-MBTCP-ICON = GenericCtl ND-MBTCPDI-NAME = Digital Input ND-MBTCPDI-ICON = Input ND-MBTCPAI-NAME = Analog Input ND-MBTCPAI-ICON = Input ND-MBTCPDO-NAME = Digital Output ND-MBTCPDO-ICON = Output ND-MBTCPAO-NAME = Analog Output ND-MBTCPAO-ICON = Output ST-113L-ST-NAME = Heartbeat CMD-108MBDO-ON-NAME = On CMD-108MBDO-OFF-NAME = Off CMD-108MBAO-VAL-NAME = Value ND-WC8-NAME = CAI WebControl ND-WC8-ICON = GenericCtl ND-WC8T-NAME = Climate Sensor ND-WC8T-ICON = TempSensor ND-WC8DI-NAME = Digital Input ND-WC8DI-ICON = Input ND-WC8DO-NAME = Digital Output ND-WC8DO-ICON = Output ND-WC8AI-NAME = Analog Input ND-WC8AI-ICON = Input ND-WC8H-NAME = Humidity ND-WC8H-ICON = Irrigation ND-WC8V-NAME = Variable ND-WC8V-ICON = GenericCtl ND-WC8C-NAME = Counter ND-WC8C-ICON = Input ND-WC8P-NAME = PWM ND-WC8P-ICON = Output ST-108WP-ST-NAME = Duty Cycle ST-108WP-GV1-NAME = Frequency CMD-108WP-ON-NAME = On CMD-108WP-OFF-NAME = Off CMD-108WP-FREQ-NAME = Frequency PGM-CMD-108WP-ON-FMT = //${c}/to ${v}/ /Frequency//, Frequency ${v}/ CMDP-I_FREQUENCY-Frequency-NAME = Frequency CMD-108WO-ON-NAME = On CMD-108WO-OFF-NAME = Off ST-108W-ST-NAME = Heartbeat ST-108W-GV1-NAME = Temp Sensor Status ST-108WA-ST-NAME = Scaled Value ST-108WA-GV1-NAME = Raw Value ST-139D-GV1-NAME = Hour ST-139D-GV2-NAME = Minutes ST-139D-GV3-NAME = Minutes This Year ST-139D-GV4-NAME = Odd/Even Day ST-139D-GV5-NAME = Week ST-139D-GV6-NAME = Day of Week ST-139D-GV7-NAME = Month ST-139D-GV8-NAME = Day of Month ST-139D-GV9-NAME = Year ST-139D-GV10-NAME = Day of Year ST-139D-GV11-NAME = Season ST-139D-GV12-NAME = Daylight Savings ST-139DS-GV1-NAME = Azimuth ST-139DS-GV2-NAME = Elevation ST-139DS-GV3-NAME = Zenith ST-139DE-ST-NAME = Time-of-Use EN_PM-0 = Manual EN_PM-1 = Running EN_ODD-0 = Even EN_ODD-1 = Odd EN_SWITCH-0 = Off EN_SWITCH-255 = On EN_VIRTUAL-0 = Off EN_VIRTUAL-255 = On EN_DOOR-0 = Unlocked EN_DOOR-254 = Unknown EN_DOOR-255 = Locked EN_DOOR_INFO-0 = None EN_DOOR_INFO-1 = Manually Locked EN_DOOR_INFO-2 = Manually Unlocked EN_DOOR_INFO-3 = RF Locked EN_DOOR_INFO-4 = RF Unlocked EN_DOOR_INFO-5 = Keypad Locked EN_DOOR_INFO-8 = RF Not Fully Unlocked EN_DOOR_INFO-10 = Auto Lock Not Fully Locked EN_DOOR_INFO-11 = Jammed EN_DOOR_INFO-15 = New User Code Error EN_DOOR_INFO-17 = Keypad Busy EN_DOOR_INFO-254 = Unknown EN_DOOR_INFO-500 = User Unlocked EN_LEAK_SENSOR-0 = OK EN_LEAK_SENSOR-2 = Leak EN_LEAK_SENSOR-254 = Unknown EN_COLOR-256 = White EN_COLORSET-0 = Violet EN_COLORSET-1 = Royal Blue EN_COLORSET-2 = Baby Blue EN_COLORSET-3 = Aqua EN_COLORSET-4 = Mint EN_COLORSET-5 = Seafoam Green EN_COLORSET-6 = Green EN_COLORSET-7 = Lime Green EN_COLORSET-8 = Yellow EN_COLORSET-9 = Yellow Orange EN_COLORSET-10 = Orange EN_COLORSET-11 = Red EN_COLORSET-12 = Pink EN_COLORSET-13 = Fuschia EN_COLORSET-14 = Lilac EN_COLORSET-15 = Lavendar EN_RAINMACHINEPROGRAM-0 = Not Running EN_RAINMACHINEPROGRAM-1 = Running EN_RAINMACHINEPROGRAM-2 = Queued EN_RAIN_NEXTRUN-0 = Today EN_RAIN_NEXTRUN-1 = Tomorrow EN_RAIN_NEXTRUN-2 = Several Days EN_RAIN_NEXTRUN-3 = Not Scheduled EN_RAIN_PROGFREQ-0 = Daily EN_RAIN_PROGFREQ-1 = Every N Days EN_RAIN_PROGFREQ-2 = Selected EN_RAIN_PROGFREQ-3 = Odd Days EN_RAIN_PROGFREQ-4 = Even Days EN_RAIN_PROGFREQPARAM-0 = N/A EN_PM2-0 = Running EN_PM2-1 = Hold Next EN_PM2-2 = Hold EN_PM3-0 = Running EN_PM3-1 = Hold Next EN_PM3-2 = Hold EN_PM3-3 = Vacation EN_NA-0 = N/A EN_DAY-0 = Sunday EN_DAY-1 = Monday EN_DAY-2 = Tuesday EN_DAY-3 = Wednesday EN_DAY-4 = Thursday EN_DAY-5 = Friday EN_DAY-6 = Saturday EN_WIND_DIRECTION-0 = N/A EN_WIND_DIRECTION-1 = N EN_WIND_DIRECTION-2 = NE EN_WIND_DIRECTION-3 = E EN_WIND_DIRECTION-4 = SE EN_WIND_DIRECTION-5 = S EN_WIND_DIRECTION-6 = SW EN_WIND_DIRECTION-7 = W EN_WIND_DIRECTION-8 = NW EN_PRECIP_TYPE-0 = None EN_PRECIP_TYPE-1 = Rain EN_PRECIP_TYPE-2 = Hail EN_PRECIP_TYPE-3 = Rain & Hail EN_SKY-0 = N/A EN_SKY-1 = Sunny EN_SKY-2 = Clear EN_SKY-3 = Mostly Sunny EN_SKY-4 = Mostly Clear EN_SKY-5 = Hazy Sunshine EN_SKY-6 = Haze EN_SKY-7 = Passing Clouds EN_SKY-8 = More Sun than Clouds EN_SKY-9 = Scattered Clouds EN_SKY-10 = Partly Cloudy EN_SKY-11 = A Mixture of Sun and CLouds EN_SKY-12 = High Level Clouds EN_SKY-13 = More Clouds than Sun EN_SKY-14 = Partly Sunny EN_SKY-15 = Broken Clouds EN_SKY-16 = Mostly Cloudy EN_SKY-17 = Cloudy EN_SKY-18 = Overcast EN_SKY-19 = Low Clouds EN_SKY-20 = Light Fog EN_SKY-21 = Fog EN_SKY-22 = Dense Fog EN_SKY-23 = Ice Fog EN_SKY-24 = Sandstorm EN_SKY-25 = Duststorm EN_SKY-26 = Increasing Cloudiness EN_SKY-27 = Decreasing Cloudiness EN_SKY-28 = Clearing Skies EN_SKY-29 = Breaks of Sun Late EN_SKY-30 = Early Fog Followed by Sunny Skies EN_SKY-31 = Afternoon Clouds EN_SKY-32 = Morning Couds EN_SKY-33 = Smoke EN_SKY-34 = Low Level Haze EN_RAIN_INTENSITY-0 = None EN_RAIN_INTENSITY-1 = Light EN_RAIN_INTENSITY-2 = Moderate EN_RAIN_INTENSITY-3 = Heavy EN_RAIN_INTENSITY-4 = Violent EN_HONALARM_STATUS-0 = Disarmed EN_HONALARM_STATUS-1 = Armed Stay EN_HONALARM_STATUS-2 = Armed Night Stay EN_HONALARM_STATUS-3 = Armed Away EN_DSCSTAT-0 = Disarmed EN_DSCSTAT-1 = Armed Stay EN_DSCSTAT-2 = Armed Away EN_DSCSTAT-3 = Entry Delay EN_DSCSTAT-4 = Exit Delay CMDP-I_ALARMCODE-CODE-NAME = Code EN_DSC_PANIC-0 = None EN_DSC_PANIC-1 = Fire EN_DSC_PANIC-2 = Ambulance EN_DSC_PANIC-3 = Panic EN_RAIN_ZONE-0 = Off EN_RAIN_ZONE-1 = On EN_RAIN_ZONE-2 = Queued EN_HONTSTAT_STATUS-0 = Schedule EN_HONTSTAT_STATUS-1 = Temp Hold EN_HONTSTAT_STATUS-2 = Perm Hold EN_HONTSTAT_STATUS-3 = Vacation Hold EN_HONTSTAT_STATUS-4 = N/A EN_SEASON-1 = Spring EN_SEASON-2 = Summer EN_SEASON-3 = Fall EN_SEASON-4 = Winter EN_ECOSCH-0 = Away EN_ECOSCH-1 = Home EN_ECOSCH-2 = Sleep EN_ECOSCH-3 = Smart1 EN_ECOSCH-4 = Smart2 EN_ECOSCH-5 = Smart3 EN_ECOSCH-6 = Smart4 EN_ECOSCH-7 = Smart5 EN_ECOSCH-8 = Smart6 EN_ECOSCH-9 = Smart7 EN_ECOSCH-10 = N/A EN_ECOSCH_OPT-0 = Permanent EN_ECOSCH_OPT-1 = Transition EN_ECOHCS-0 = Idle EN_ECOHCS-1 = Heat EN_ECOHCS-2 = Cool EN_ECOHCS-3 = Heat2 EN_ECOHCS-4 = Heat3 EN_ECOHCS-5 = Cool2 EN_ECOHCS-6 = AuxHeat EN_ECOHCS-7 = AuxHeat2 EN_ECOHCS-8 = AuxHeat3 EN_VENSTATE-0 = Idle EN_VENSTATE-1 = Heating EN_VENSTATE-2 = Cooling EN_VENSTATE-3 = Lockout EN_VENSTATE-4 = Error EN_TOU-0 = On-Peak EN_TOU-1 = Mid-Peak EN_TOU-2 = Off-Peak EN_BOOL-0 = No EN_BOOL-1 = Yes EN_PHONE_RINGING-0 = Idle EN_PHONE_RINGING-1 = Ringing EN_LOC_STATUS-0 = Away EN_LOC_STATUS-1 = Home EN_ERROR_STATUS-0 = OK EN_ERROR_STATUS-1 = Error EN_STATUS-0 = Off EN_STATUS-1 = On EN_ENABLED-0 = Disabled EN_ENABLED-1 = Enabled EN_TRUE_BOOL-0 = False EN_TRUE_BOOL-1 = True EN_ALERT-0 = OK EN_ALERT-1 = Alert EN_PING-0 = Offline EN_PING-1 = OK EN_LOC-0 = Home EN_LOC-1 = Away EN_ALARM_ZONE-0 = Closed EN_ALARM_ZONE-1 = Open EN_GEN_SWITCHSTATE-0 = N/A EN_GEN_SWITCHSTATE-1 = Auto EN_GEN_SWITCHSTATE-2 = Off EN_GEN_SWITCHSTATE-3 = Manual EN_GEN_SWITCHSTATE-4 = Two Wire Stop EN_GEN_SWITCHSTATE-5 = System in Alarm EN_GEN_ENGINESTATE-0 = N/A EN_GEN_ENGINESTATE-1 = Exercising EN_GEN_ENGINESTATE-2 = Stopped EN_GEN_ENGINESTATE-3 = Startup Delay Timer Activated EN_GEN_ENGINESTATE-4 = Cranking in Alarm EN_GEN_ENGINESTATE-5 = Cranking EN_GEN_ENGINESTATE-6 = Cooling Down EN_GEN_ENGINESTATE-7 = Running in Alarm EN_GEN_ENGINESTATE-8 = Running EN_GEN_ENGINESTATE-9 = Running in Warning EN_GEN_ENGINESTATE-10 = Stopped in Alarm EN_GEN_ENGINESTATE-11 = Off EN_GEN_TRANSFERSWITCHSTATE-0 = N/A EN_GEN_TRANSFERSWITCHSTATE-1 = Generator EN_GEN_TRANSFERSWITCHSTATE-2 = Utility EN_GEN_MONITORHEALTH-0 = N/A EN_GEN_MONITORHEALTH-1 = OK EN_GEN_MONITORHEALTH-2 = Not OK CMD-ST-NAME = Query ST-140H-ST-NAME = Temperature ST-140H-GV1-NAME = Schedule Status ST-140H-GV2-NAME = Heartbeat ST-140H-GV3-NAME = Outdoor Temperature ST-140H-GV4-NAME = Outdoor Humidity CMD-140H-GV1-NAME = Schedule Status ST-140V-ST-NAME = Temperature ST-140V-GV1-NAME = Humidification Setpoint ST-140V-GV2-NAME = Heartbeat ST-140V-GV3-NAME = Home / Away ST-140V-GV4-NAME = Active Stage ST-140V-GV5-NAME = Dehumidification Setpoint ST-140V-GV6-NAME = Filter ST-140V-GV7-NAME = Humidity Active CMD-140V-GV1-NAME = Humidification Setpoint CMD-140V-GV3-NAME = Home / Away CMD-140V-GV5-NAME = Dehumidification Setpoint CMD-140V-BRT-NAME = Setpoint Up CMD-140V-DIM-NAME = Setpoint Down ST-140VR-GV1-NAME = Timestamp ST-140VR-GV2-NAME = Heat Stage 1 ST-140VR-GV3-NAME = Heat Stage 2 ST-140VR-GV4-NAME = Cool Stage 1 ST-140VR-GV5-NAME = Cool Stage 2 ST-140VR-GV6-NAME = Aux Stage 1 ST-140VR-GV7-NAME = Aux Stage 2 ST-140VR-GV8-NAME = Free Cooling ST-140VR-GV9-NAME = Filter Runtime CMD-140VR-GV9-NAME = Reset Filter Runtime ST-140E-ST-NAME = Temperature ST-140E-GV1-NAME = Humidification Setpoint ST-140E-GV2-NAME = Heartbeat ST-140E-GV3-NAME = Climate Type ST-140E-GV4-NAME = Fan On Time ST-140E-GV5-NAME = Dehumidification Setpoint ST-140E-GV6-NAME = Smart Home-Away ST-140E-GV7-NAME = Follow Me ST-140E-GV8-NAME = Vacation Mode CMD-140E-GV3-NAME = Climate Type CMD-140E-GV4-NAME = Fan On Time CMD-140E-GV6-NAME = Smart Home-Away CMD-140E-GV7-NAME = Follow Me CMD-140E-BRT-NAME = Setpoint Up CMD-140E-DIM-NAME = Setpoint Down PGM-CMD-140E-GV3-FMT = //${c}/to ${v}/ /HoldType//, Hold Type ${v}/ CMDP-I_TSTAT_ECO_SCHED_OPT-HoldType-NAME = Hold Type ST-140ES-ST-NAME = Temperature ST-140ES-GV1-NAME = Occupancy ST-140EW-ST-NAME = Temperature ST-140EW-GV1-NAME = Humidity ST-140EW-GV2-NAME = POP ST-140EW-GV3-NAME = High Temp ST-140EW-GV4-NAME = Low Temp ST-140EW-GV5-NAME = Wind Speed ST-140EW-GV6-NAME = Wind Direction ST-140EW-GV7-NAME = Sky ST-140EW-GV8-NAME = Symbol ST-140VS-ST-NAME = Temperature ST-140VS-GV1-NAME = Battery ND-GenMon-NAME = GenMon Generator ND-GenMon-ICON = EnergyMonitor ST-181G-ST-NAME = Switch State ST-181G-GV1-NAME = Engine State ST-181G-GV2-NAME = Transfer Switch State ST-181G-GV3-NAME = Output Voltage ST-181G-GV4-NAME = Utility Voltage ST-181G-GV5-NAME = Frequency ST-181G-GV6-NAME = Battery Voltage ST-181G-GV7-NAME = Monitor Health ST-181G-GV8-NAME = Heartbeat CMD-181G-START-NAME = Start CMD-181G-STOP-NAME = Stop CMD-181G-EXERCISE-NAME = Start Exercise CMD-181G-TRANSFER-NAME = Start Transfer ND-GreenEye-NAME = GreenEye Energy Monitor ND-GreenEye-ICON = EnergyMonitor ND-GreenEyeMain-NAME = GreenEye Energy Monitor (Main) ND-GreenEyeMain-ICON = EnergyMonitor ND-GreenEyeChannel-NAME = GreenEye Energy Channel ND-GreenEyeChannel-ICON = Electricity ND-GreenEyeCounter-NAME = GreenEye Counter Input ND-GreenEyeCounter-ICON = PulseCounter ND-GreenEyeTemperature-NAME = GreenEye Temperature Sensor ND-GreenEyeTemperature-ICON = TempSensor ST-143-ST-NAME = Voltage ST-143-GV1-NAME = Heartbeat CMD-143-RESET-NAME = Reset All kWh Counters CMD-143-RUNRES-NAME = Reset All Runtime Counters ST-143M-ST-NAME = Voltage ST-143M-GV1-NAME = Current ST-143M-GV2-NAME = Power ST-143M-GV3-NAME = Total Energy ST-143M-GV4-NAME = Phase Imbalance ST-143M-GV5-NAME = Not Monitored ST-143M-GV6-NAME = Heartbeat CMD-143M-RESET-NAME = Reset All kWh Counters CMD-143M-RUNRES-NAME = Reset All Runtime Counters CMD-143C-RESET-NAME = Reset kWh Counter CMD-143C-RUNRES-NAME = Reset Runtime Counter ST-143C-ST-NAME = Current ST-143C-GV1-NAME = Power ST-143C-GV2-NAME = Total Energy ST-143C-GV3-NAME = Runtime ND-HonAlarm-NAME = Honeywell Alarm Panel ND-HonAlarm-ICON = GenericCtl ND-HonAlarmZone-NAME = Honeywell Zone ND-HonAlarmZone-ICON = MotionSensor ND-HonAlarmPartition-NAME = Honeywell Partition ND-HonAlarmPartition-ICON = Input ST-102H-ST-NAME = Heartbeat ST-102HP-ST-NAME = Status ST-102HP-GV1-NAME = Alarm ST-102HP-GV2-NAME = Ready ST-102HP-GV3-NAME = Entry Delay ST-102HP-GV4-NAME = Zones Bypassed ST-102HP-GV5-NAME = Panel Trouble ST-102HP-GV6-NAME = Fire Alarm ST-102HP-GV7-NAME = CO Alarm CMD-102H-QUERY-NAME = Query CMD-102HP-DISARM-NAME = Disarm CMD-102HP-ARMAWAY-NAME = Arm Away CMD-102HP-ARMSTAY-NAME = Arm Stay CMD-102HP-ARMNOENTRY-NAME = Arm No Entry ND-DSC-NAME = DSC Alarm Panel ND-DSC-ICON = GenericCtl ND-DSCZone-NAME = DSC Zone ND-DSCZone-ICON = MotionSensor ND-DSCPartition-NAME = DSC Partition ND-DSCPartition-ICON = Input ST-102Z-ST-NAME = Status ST-102D-GV1-NAME = Disarming User ST-102D-GV2-NAME = Panel Trouble ST-102D-GV3-NAME = Fire Alarm ST-102D-GV4-NAME = Aux Alarm ST-102D-GV5-NAME = Panic Alarm ST-102D-GV6-NAME = Aux Input Alarm ST-102D-GV7-NAME = PGM Out 1 Pressed ST-102D-GV8-NAME = PGM Out 2 Pressed ST-102D-GV9-NAME = PGM Out 3 Pressed ST-102D-GV10-NAME = PGM Out 4 Pressed ST-102D-GV11-NAME = Heartbeat ST-102D-GV12-NAME = AC Trouble ST-102DP-ST-NAME = Status ST-102DP-GV1-NAME = Alarm ST-102DP-GV2-NAME = Ready ST-102DP-GV3-NAME = No Delay Enabled CMD-102D-QUERY-NAME = Query CMD-102D-FIRE-NAME = Trigger Fire Alarm CMD-102D-AMB-NAME = Trigger Ambulance CMD-102D-PANIC-NAME = Trigger Panic Alarm CMD-102D-PGM_OUT1-NAME = PGM Out 1 On CMD-102D-PGM_OUT2-NAME = PGM Out 2 On CMD-102D-PGM_OUT3-NAME = PGM Out 3 On CMD-102D-PGM_OUT4-NAME = PGM Out 4 On CMD-102DP-DISARM-NAME = Disarm CMD-102DP-ARMAWAY-NAME = Arm Away CMD-102DP-ARMSTAY-NAME = Arm Stay CMD-102DP-ARMNOENTRY-NAME = Arm No Entry ND-WFAir-NAME = WeatherFlow Air ND-WFAir-ICON = Weather ST-140WFA-ST-NAME = Heartbeat ST-140WFA-GV1-NAME = Pressure ST-140WFA-GV2-NAME = Temperature ST-140WFA-GV3-NAME = Humidity ST-140WFA-GV4-NAME = Lightning Strike Count (Last Hour) ST-140WFA-GV5-NAME = Lightning Strike Avg Distance ST-140WFA-GV6-NAME = Battery ND-WFSky-NAME = WeatherFlow Sky ND-WFSky-ICON = Irrigation ST-140WFS-ST-NAME = Heartbeat ST-140WFS-GV1-NAME = Illuminance ST-140WFS-GV2-NAME = UV ST-140WFS-GV3-NAME = Rain Accumulated (Last Hour) ST-140WFS-GV4-NAME = Wind Lull ST-140WFS-GV5-NAME = Wind Average ST-140WFS-GV6-NAME = Wind Gust ST-140WFS-GV7-NAME = Wind Direction ST-140WFS-GV8-NAME = Battery ST-140WFS-GV9-NAME = Solar Radiation ST-140WFS-GV10-NAME = Rain Accumulation (Today) ST-140WFS-GV11-NAME = Precipitation Type ST-140WFS-GV12-NAME = Rain Intensity ND-Homeseer-NAME = Homeseer Controller ND-Homeseer-ICON = GenericCtl ND-hsDoorLock-NAME = Door Lock ND-hsDoorLock-ICON = DoorLock ST-111DL-GV1-NAME = Battery ST-111DL-GV2-NAME = User ST-111DL-GV3-NAME = Action CMD-111DL-LOCK-NAME = Lock CMD-111DL-UNLOCK-NAME = Unlock ND-hsSwitch-NAME = Switch ND-hsSwitch-ICON = LampAndSwitch CMD-121SW-ON-NAME = On CMD-121SW-OFF-NAME = Off ND-hsDimmer-NAME = Dimmer ND-hsDimmer-ICON = LampAndSwitch CMD-121D-VAL-NAME = Value CMD-121D-ON-NAME = On CMD-121D-OFF-NAME = Off ND-hsVirtual-NAME = Virtual ND-hsVirtual-ICON = Input CMD-121V-ON-NAME = On CMD-121V-OFF-NAME = Off ND-hsLeakSensor-NAME = Leak Sensor ND-hsLeakSensor-ICON = Irrigation ST-169LS-GV1-NAME = Battery ST-169LS-GV2-NAME = Temperature ND-hsPlug-NAME = Wall Plug Switch ND-hsPlug-ICON = LampAndSwitch ST-121PG-GV1-NAME = Volts ST-121PG-GV2-NAME = Amps ST-121PG-GV3-NAME = Watts ST-121PG-GV4-NAME = kWH CMD-121PG-ON-NAME = On CMD-121PG-OFF-NAME = Off ND-InternetWeather-NAME = Internet Current Weather ND-InternetWeather-ICON = Weather ND-InternetWeatherForecast-NAME = Internet Weather Forecast ND-InternetWeatherForecast-ICON = Weather (profiles/family/10/profile/1/download/nls/en_us.txt) 2022-04-18 12:15:46 - DSC: 5053CD[C][L] [dsc1] 2022-04-18 12:15:46 - Venstar: Get Data - {"runtimes":[{"ts":1649808000,"heat1":0,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649894400,"heat1":0,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649980800,"heat1":0,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1650067200,"heat1":28,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1650153600,"heat1":86,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1650240000,"heat1":143,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1650284146,"heat1":93,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0}]} [ven1] 2022-04-18 12:15:46 - DSC: 505 - Login Interaction (Password Requested) [dsc1] 2022-04-18 12:15:46 - DSC: EVL User Login - Password Sent [dsc1] 2022-04-18 12:15:46 - DSC: 5000052A[C][L]5051CB[C][L] [dsc1] 2022-04-18 12:15:46 - DSC: 500 - Command Acknowledge (005) [dsc1] 2022-04-18 12:15:46 - DSC: 505 - Login Interaction (Password Correct, Session Established) [dsc1] 2022-04-18 12:15:46 - DSC: Status Request Sent [dsc1] 2022-04-18 12:15:46 - DSC: Data Sent - 00191 [dsc1] 2022-04-18 12:15:46 - DSC TCP: Polling DSC [dsc1] 2022-04-18 12:15:46 - DSC: Connected to 10.0.1.18 [dsc1] 2022-04-18 12:15:46 - DSC: 50000126[C][L]61000128[C][L]61000229[C][L]6100032A[C][L]6100042B[C][L]6100052C[C][L]6100062D[C][L]6100072E[C][L]6100082F[C][L]61000930[C][L]61001028[C][L]61001129[C][L]6100122A[C][L]6100132B[C][L]6100142C[C][L]6100152D[C][L]6100162E[C][L]6100172F[C][L]61001830[C][L]61001931[C][L]61002029[C][L]6100212A[C][L]6100222B[C][L]6100232C[C][L] [dsc1] 2022-04-18 12:15:46 - DSC: 500 - Command Acknowledge (001) [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 001) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 1 (Zone 01) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 002) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 2 (Zone 02) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 003) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 3 ((Z03) Door to Upper Deck) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 004) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 4 (Zone 04) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 005) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 5 (Zone 05) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 006) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 6 (Zone 06) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 007) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 7 (Zone 07) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 008) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 8 (Zone 08) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 009) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 9 (Zone 09) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 010) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 10 (Zone 10) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 011) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 11 (Zone 11) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 012) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 12 (Zone 12) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 013) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 13 (Zone 13) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 014) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 14 (Zone 14) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 015) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 15 (Zone 15) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 016) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 16 (Zone 16) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 017) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 17 (Zone 17) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 018) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 18 (Zone 18) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 019) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 19 (Zone 19) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 020) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 20 (Zone 20) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 021) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 21 (Zone 21) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 022) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 22 (Zone 22) Closed [dsc1] 2022-04-18 12:15:46 - DSC: 610 - Zone Restored (Zone 023) [dsc1] 2022-04-18 12:15:46 - DSC: Zone 23 (Zone 23) Closed [dsc1] 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z01-ST added to queue (Val: 0, QS: 1) 2022-04-18 12:15:46 - DSC: 50000025[C][L] [dsc1] 2022-04-18 12:15:46 - DSC: 500 - Command Acknowledge (000) [dsc1] 2022-04-18 12:15:46 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z01/report/status/ST/0/25) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z02-ST added to queue (Val: 0, QS: 1) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z03-ST added to queue (Val: 0, QS: 2) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z04-ST added to queue (Val: 0, QS: 3) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z05-ST added to queue (Val: 0, QS: 4) 2022-04-18 12:15:46 - Venstar: Get Data - {"runtimes":[{"ts":1649808000,"heat1":323,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649894400,"heat1":106,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649980800,"heat1":0,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1650067200,"heat1":102,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1650153600,"heat1":414,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1650240000,"heat1":320,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1650284146,"heat1":326,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0}]} [ven2] 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z06-ST added to queue (Val: 0, QS: 5) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z07-ST added to queue (Val: 0, QS: 6) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z08-ST added to queue (Val: 0, QS: 7) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z09-ST added to queue (Val: 0, QS: 8) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z10-ST added to queue (Val: 0, QS: 9) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z11-ST added to queue (Val: 0, QS: 10) 2022-04-18 12:15:46 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z02/report/status/ST/0/25) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z12-ST added to queue (Val: 0, QS: 10) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z13-ST added to queue (Val: 0, QS: 11) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z14-ST added to queue (Val: 0, QS: 12) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z15-ST added to queue (Val: 0, QS: 13) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z16-ST added to queue (Val: 0, QS: 14) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z17-ST added to queue (Val: 0, QS: 15) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z18-ST added to queue (Val: 0, QS: 16) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z19-ST added to queue (Val: 0, QS: 17) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z20-ST added to queue (Val: 0, QS: 18) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z21-ST added to queue (Val: 0, QS: 19) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z22-ST added to queue (Val: 0, QS: 20) 2022-04-18 12:15:46 - ISY Send: Variable dsc1_z23-ST added to queue (Val: 0, QS: 21) 2022-04-18 12:15:46 - ISY Send: Variable dsc1-GV11 added to queue (Val: 1, QS: 22) 2022-04-18 12:15:47 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z03/report/status/ST/0/25) 2022-04-18 12:15:47 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z04/report/status/ST/0/25) 2022-04-18 12:15:47 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z05/report/status/ST/0/25) 2022-04-18 12:15:47 - DSC: 6100242D[C][L]6100252E[C][L]6100262F[C][L]61002730[C][L]61002831[C][L]61002932[C][L]6100302A[C][L]6100312B[C][L]6100322C[C][L]6100332D[C][L]60903436[C][L]6100352F[C][L]61003630[C][L]61003731[C][L]61003832[C][L]61003933[C][L]6100402B[C][L]6100412C[C][L]6100422D[C][L]6100432E[C][L]6100442F[C][L]61004530[C][L]61004631[C][L]61004732[C][L] [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 024) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 24 (Zone 24) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 025) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 25 (Zone 25) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 026) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 26 (Zone 26) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 027) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 27 (Zone 27) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 028) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 28 (Zone 28) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 029) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 29 (Zone 29) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 030) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 30 (Zone 30) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 031) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 31 (Zone 31) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 032) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 32 (Zone 32) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 033) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 33 (Zone 33) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 609 - Zone Open (Zone 034) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 34 (Zone 34) Opened [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 035) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 35 (Zone 35) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 036) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 36 (Zone 36) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 037) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 37 (Zone 37) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 038) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 38 (Zone 38) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 039) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 39 (Zone 39) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 040) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 40 (Zone 40) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 041) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 41 (Zone 41) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 042) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 42 (Zone 42) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 043) [dsc1] 2022-04-18 12:15:47 - DSC: Zone 43 (Zone 43) Closed [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 044) [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 045) [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 046) [dsc1] 2022-04-18 12:15:47 - DSC: 610 - Zone Restored (Zone 047) [dsc1] 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z24-ST added to queue (Val: 0, QS: 20) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z25-ST added to queue (Val: 0, QS: 21) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z26-ST added to queue (Val: 0, QS: 22) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z27-ST added to queue (Val: 0, QS: 23) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z28-ST added to queue (Val: 0, QS: 24) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z29-ST added to queue (Val: 0, QS: 25) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z30-ST added to queue (Val: 0, QS: 26) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z31-ST added to queue (Val: 0, QS: 27) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z32-ST added to queue (Val: 0, QS: 28) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z33-ST added to queue (Val: 0, QS: 29) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z34-ST added to queue (Val: 1, QS: 30) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z35-ST added to queue (Val: 0, QS: 31) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z36-ST added to queue (Val: 0, QS: 32) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z37-ST added to queue (Val: 0, QS: 33) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z38-ST added to queue (Val: 0, QS: 34) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z39-ST added to queue (Val: 0, QS: 35) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z40-ST added to queue (Val: 0, QS: 36) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z41-ST added to queue (Val: 0, QS: 37) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z42-ST added to queue (Val: 0, QS: 38) 2022-04-18 12:15:47 - ISY Send: Variable dsc1_z43-ST added to queue (Val: 0, QS: 39) 2022-04-18 12:15:47 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z06/report/status/ST/0/25) 2022-04-18 12:15:47 - Venstar: Get Data - {"api_ver":7,"type":"residential","model":"COLORTOUCH","firmware":"5.10"} [ven2] 2022-04-18 12:15:47 - Venstar: Get Data - {"api_ver":7,"type":"residential","model":"COLORTOUCH","firmware":"5.10"} [ven1] 2022-04-18 12:15:47 - Venstar: Get Data - {"name":"GLEN_02","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":24.0,"heattemp":24.0,"cooltemp":28.0,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":29,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven2] 2022-04-18 12:15:47 - Venstar: Get Data - {"name":"GLEN_01","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":22.0,"heattemp":22.5,"cooltemp":28.5,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":25,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven1] 2022-04-18 12:15:47 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z07/report/status/ST/0/25) 2022-04-18 12:15:48 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":24.0,"hum":29},{"name":"Space Temp","temp":24.0}]} [ven2] 2022-04-18 12:15:48 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":22.0,"hum":25},{"name":"Space Temp","temp":22.0},{"id":1,"name":"Glen Sensor","temp":22.0,"battery":27,"type":"Remote"}]} [ven1] 2022-04-18 12:15:48 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z08/report/status/ST/0/25) 2022-04-18 12:15:48 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven2] 2022-04-18 12:15:48 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven1] 2022-04-18 12:15:48 - DSC: 61004833[C][L]61004934[C][L]6100502C[C][L]6100512D[C][L]6100522E[C][L]6100532F[C][L]61005430[C][L]61005531[C][L]61005632[C][L]61005733[C][L]61005834[C][L]61005935[C][L]6100602D[C][L]6100612E[C][L]6100622F[C][L]61006330[C][L]61006431[C][L]6531CF[C][L]6732D2[C][L]6733D3[C][L]6734D4[C][L]8411CE[C][L]8412CF[C][L]8413D0[C][L]8414D1[C][L]8415D2[C][L] [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 048) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 049) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 050) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 051) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 052) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 053) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 054) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 055) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 056) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 057) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 058) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 059) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 060) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 061) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 062) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 063) [dsc1] 2022-04-18 12:15:48 - DSC: 610 - Zone Restored (Zone 064) [dsc1] 2022-04-18 12:15:48 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1] 2022-04-18 12:15:48 - DSC: 673 - Partition Busy (Partition 2) [dsc1] 2022-04-18 12:15:48 - DSC: 673 - Partition Busy (Partition 3) [dsc1] 2022-04-18 12:15:48 - DSC: 673 - Partition Busy (Partition 4) [dsc1] 2022-04-18 12:15:48 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 1) [dsc1] 2022-04-18 12:15:48 - DSC: Panel OK [dsc1] 2022-04-18 12:15:48 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 2) [dsc1] 2022-04-18 12:15:48 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 3) [dsc1] 2022-04-18 12:15:48 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 4) [dsc1] 2022-04-18 12:15:48 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 5) [dsc1] 2022-04-18 12:15:48 - ISY Send: Variable dsc1-GV2 added to queue (Val: 0, QS: 37) 2022-04-18 12:15:48 - ISY Send: Variable dsc1-GV12 added to queue (Val: 0, QS: 38) 2022-04-18 12:15:48 - ISY Send: Variable ven2-ST added to queue (Val: 24.0, QS: 39) 2022-04-18 12:15:48 - ISY Send: Variable ven1-ST added to queue (Val: 22.0, QS: 40) 2022-04-18 12:15:48 - ISY Send: Variable ven2-CLISPC added to queue (Val: 28.0, QS: 41) 2022-04-18 12:15:48 - ISY Send: Variable ven1-CLISPC added to queue (Val: 28.5, QS: 42) 2022-04-18 12:15:48 - ISY Send: Variable ven2-CLISPH added to queue (Val: 24.0, QS: 43) 2022-04-18 12:15:48 - ISY Send: Variable ven1-CLISPH added to queue (Val: 22.5, QS: 44) 2022-04-18 12:15:48 - ISY Send: Variable ven2-CLIHUM added to queue (Val: 29, QS: 45) 2022-04-18 12:15:48 - ISY Send: Variable ven1-CLIHUM added to queue (Val: 25, QS: 46) 2022-04-18 12:15:48 - ISY Send: Variable ven2-CLIFS added to queue (Val: 0, QS: 47) 2022-04-18 12:15:48 - ISY Send: Variable ven1-CLIFS added to queue (Val: 0, QS: 48) 2022-04-18 12:15:48 - ISY Send: Variable ven2-CLIFRS added to queue (Val: 0, QS: 49) 2022-04-18 12:15:48 - ISY Send: Variable ven1-CLIFRS added to queue (Val: 0, QS: 50) 2022-04-18 12:15:48 - ISY Send: Variable ven2-CLIMD added to queue (Val: 1, QS: 51) 2022-04-18 12:15:48 - ISY Send: Variable ven1-CLIMD added to queue (Val: 1, QS: 52) 2022-04-18 12:15:48 - ISY Send: Variable ven2-CLISMD added to queue (Val: 0, QS: 53) 2022-04-18 12:15:48 - ISY Send: Variable ven1-CLISMD added to queue (Val: 0, QS: 54) 2022-04-18 12:15:48 - ISY Send: Variable ven2-CLIHCS added to queue (Val: 0, QS: 55) 2022-04-18 12:15:48 - ISY Send: Variable ven1-CLIHCS added to queue (Val: 0, QS: 56) 2022-04-18 12:15:48 - ISY Send: Variable ven2-GV1 added to queue (Val: 0, QS: 57) 2022-04-18 12:15:48 - ISY Send: Variable ven1-GV1 added to queue (Val: 0, QS: 58) 2022-04-18 12:15:48 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z09/report/status/ST/0/25) 2022-04-18 12:15:48 - ISY Send: Variable ven1-GV2 added to queue (Val: -1, QS: 58) 2022-04-18 12:15:48 - ISY Send: Variable ven2-GV2 added to queue (Val: -1, QS: 59) 2022-04-18 12:15:48 - ISY Send: Variable ven2-GV3 added to queue (Val: 0, QS: 60) 2022-04-18 12:15:48 - ISY Send: Variable ven1-GV3 added to queue (Val: 0, QS: 61) 2022-04-18 12:15:48 - ISY Send: Variable ven2-GV4 added to queue (Val: 0, QS: 62) 2022-04-18 12:15:48 - ISY Send: Variable ven1-GV4 added to queue (Val: 0, QS: 63) 2022-04-18 12:15:48 - ISY Send: Variable ven2-GV5 added to queue (Val: 99, QS: 64) 2022-04-18 12:15:48 - ISY Send: Variable ven1-GV5 added to queue (Val: 99, QS: 65) 2022-04-18 12:15:48 - ISY Send: Variable ven2-GV6 added to queue (Val: 0, QS: 66) 2022-04-18 12:15:48 - ISY Send: Variable ven1-GV6 added to queue (Val: 0, QS: 67) 2022-04-18 12:15:48 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z10/report/status/ST/0/25) 2022-04-18 12:15:48 - ISY Send: Variable ven2-GV7 added to queue (Val: 0, QS: 67) 2022-04-18 12:15:48 - ISY Send: Variable ven1-GV7 added to queue (Val: 0, QS: 68) 2022-04-18 12:15:48 - ISY Send: Variable ven2_run-GV1 added to queue (Val: 1650284146, QS: 69) 2022-04-18 12:15:48 - ISY Send: Variable ven1_run-GV1 added to queue (Val: 1650284146, QS: 70) 2022-04-18 12:15:48 - ISY Send: Variable ven1_run-GV2 added to queue (Val: 93, QS: 71) 2022-04-18 12:15:48 - ISY Send: Variable ven2_run-GV2 added to queue (Val: 326, QS: 72) 2022-04-18 12:15:48 - ISY Send: Variable ven1_run-GV3 added to queue (Val: 0, QS: 73) 2022-04-18 12:15:48 - ISY Send: Variable ven2_run-GV3 added to queue (Val: 0, QS: 74) 2022-04-18 12:15:48 - ISY Send: Variable ven1_run-GV4 added to queue (Val: 0, QS: 75) 2022-04-18 12:15:48 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z11/report/status/ST/0/25) 2022-04-18 12:15:48 - ISY Send: Variable ven2_run-GV4 added to queue (Val: 0, QS: 75) 2022-04-18 12:15:48 - ISY Send: Variable ven1_run-GV5 added to queue (Val: 0, QS: 76) 2022-04-18 12:15:48 - ISY Send: Variable ven2_run-GV5 added to queue (Val: 0, QS: 77) 2022-04-18 12:15:48 - ISY Send: Variable ven1_run-GV6 added to queue (Val: 0, QS: 78) 2022-04-18 12:15:48 - ISY Send: Variable ven2_run-GV6 added to queue (Val: 0, QS: 79) 2022-04-18 12:15:48 - ISY Send: Variable ven1_run-GV7 added to queue (Val: 0, QS: 80) 2022-04-18 12:15:48 - ISY Send: Variable ven2_run-GV7 added to queue (Val: 0, QS: 81) 2022-04-18 12:15:48 - ISY Send: Variable ven1_run-GV8 added to queue (Val: 0, QS: 82) 2022-04-18 12:15:48 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z12/report/status/ST/0/25) 2022-04-18 12:15:48 - ISY Send: Variable ven2_run-GV8 added to queue (Val: 0, QS: 82) 2022-04-18 12:15:48 - ISY Send: Variable ven1_run-GV9 added to queue (Val: 0.72, QS: 83) 2022-04-18 12:15:48 - ISY Send: Variable ven2_run-GV9 added to queue (Val: 6.07, QS: 84) 2022-04-18 12:15:48 - ISY Send: Variable ven1_s00-ST added to queue (Val: 22.0, QS: 85) 2022-04-18 12:15:48 - ISY Send: Variable ven2_s00-ST added to queue (Val: 24.0, QS: 86) 2022-04-18 12:15:48 - ISY Send: Variable ven1_s00-GV1 added to queue (Val: , QS: 87) 2022-04-18 12:15:48 - ISY Send: Variable ven2_s00-GV1 added to queue (Val: , QS: 88) 2022-04-18 12:15:48 - ISY Send: Variable ven1_s01-ST added to queue (Val: 22.0, QS: 89) 2022-04-18 12:15:48 - ISY Send: Variable ven1_s01-GV1 added to queue (Val: 27, QS: 90) 2022-04-18 12:15:48 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z13/report/status/ST/0/25) 2022-04-18 12:15:48 - DSC: 8416D3[C][L]8417D4[C][L]8418D5[C][L]51081FF[C][L] [dsc1] 2022-04-18 12:15:48 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 6) [dsc1] 2022-04-18 12:15:48 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 7) [dsc1] 2022-04-18 12:15:48 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 8) [dsc1] 2022-04-18 12:15:48 - DSC: 510 - Full LED Status Update [dsc1] 2022-04-18 12:15:49 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z14/report/status/ST/0/25) 2022-04-18 12:15:49 - Auto-Update: Checking for program update... 2022-04-18 12:15:49 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z15/report/status/ST/0/25) 2022-04-18 12:15:49 - Auto-Update: No web update available 2022-04-18 12:15:49 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z16/report/status/ST/0/25) 2022-04-18 12:15:49 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z17/report/status/ST/0/25) 2022-04-18 12:15:49 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z18/report/status/ST/0/25) 2022-04-18 12:15:49 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z19/report/status/ST/0/25) 2022-04-18 12:15:50 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z20/report/status/ST/0/25) 2022-04-18 12:15:50 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z21/report/status/ST/0/25) 2022-04-18 12:15:51 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z22/report/status/ST/0/25) 2022-04-18 12:15:51 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z23/report/status/ST/0/25) 2022-04-18 12:15:51 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1/report/status/GV11/1/25) 2022-04-18 12:15:51 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z24/report/status/ST/0/25) 2022-04-18 12:15:51 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z25/report/status/ST/0/25) 2022-04-18 12:15:51 - Web Request: / 2022-04-18 12:15:51 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z26/report/status/ST/0/25) 2022-04-18 12:15:51 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z27/report/status/ST/0/25) 2022-04-18 12:15:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z28/report/status/ST/0/25) 2022-04-18 12:15:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z29/report/status/ST/0/25) 2022-04-18 12:15:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z30/report/status/ST/0/25) 2022-04-18 12:15:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z31/report/status/ST/0/25) 2022-04-18 12:15:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z32/report/status/ST/0/25) 2022-04-18 12:15:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z33/report/status/ST/0/25) 2022-04-18 12:15:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z34/report/status/ST/1/25) 2022-04-18 12:15:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z35/report/status/ST/0/25) 2022-04-18 12:15:52 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z36/report/status/ST/0/25) 2022-04-18 12:15:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z37/report/status/ST/0/25) 2022-04-18 12:15:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z38/report/status/ST/0/25) 2022-04-18 12:15:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z39/report/status/ST/0/25) 2022-04-18 12:15:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z40/report/status/ST/0/25) 2022-04-18 12:15:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z41/report/status/ST/0/25) 2022-04-18 12:15:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z42/report/status/ST/0/25) 2022-04-18 12:15:53 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1_z43/report/status/ST/0/25) 2022-04-18 12:15:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1/report/status/GV2/0/25) 2022-04-18 12:15:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1/report/status/GV12/0/25) 2022-04-18 12:15:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/ST/24.0/4) 2022-04-18 12:15:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/ST/22.0/4) 2022-04-18 12:15:54 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/CLISPC/28.0/4) 2022-04-18 12:15:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/CLISPC/28.5/4) 2022-04-18 12:15:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/CLISPH/24.0/4) 2022-04-18 12:15:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/CLISPH/22.5/4) 2022-04-18 12:15:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/CLIHUM/29/51) 2022-04-18 12:15:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/CLIHUM/25/51) 2022-04-18 12:15:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/CLIFS/0/68) 2022-04-18 12:15:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/CLIFS/0/68) 2022-04-18 12:15:55 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/CLIFRS/0/80) 2022-04-18 12:15:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/CLIFRS/0/80) 2022-04-18 12:15:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/CLIMD/1/67) 2022-04-18 12:15:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/CLIMD/1/67) 2022-04-18 12:15:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/CLISMD/0/25) 2022-04-18 12:15:56 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/CLISMD/0/25) 2022-04-18 12:15:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/CLIHCS/0/25) 2022-04-18 12:15:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/CLIHCS/0/25) 2022-04-18 12:15:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/GV1/0/51) 2022-04-18 12:15:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/GV1/0/51) 2022-04-18 12:15:57 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/GV2/-1/25) 2022-04-18 12:15:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/GV2/-1/25) 2022-04-18 12:15:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/GV3/0/25) 2022-04-18 12:15:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/GV3/0/25) 2022-04-18 12:15:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/GV4/0/25) 2022-04-18 12:15:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/GV4/0/25) 2022-04-18 12:15:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/GV5/99/51) 2022-04-18 12:15:58 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/GV5/99/51) 2022-04-18 12:15:59 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/GV6/0/25) 2022-04-18 12:15:59 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/GV6/0/25) 2022-04-18 12:15:59 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/GV7/0/25) 2022-04-18 12:15:59 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1/report/status/GV7/0/25) 2022-04-18 12:15:59 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2_run/report/status/GV1/1650284146/25) 2022-04-18 12:16:00 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_run/report/status/GV1/1650284146/25) 2022-04-18 12:16:00 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_run/report/status/GV2/93/25) 2022-04-18 12:16:00 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2_run/report/status/GV2/326/25) 2022-04-18 12:16:00 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_run/report/status/GV3/0/25) 2022-04-18 12:16:00 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2_run/report/status/GV3/0/25) 2022-04-18 12:16:01 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_run/report/status/GV4/0/25) 2022-04-18 12:16:01 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2_run/report/status/GV4/0/25) 2022-04-18 12:16:01 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_run/report/status/GV5/0/25) 2022-04-18 12:16:01 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2_run/report/status/GV5/0/25) 2022-04-18 12:16:01 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_run/report/status/GV6/0/25) 2022-04-18 12:16:02 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2_run/report/status/GV6/0/25) 2022-04-18 12:16:02 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_run/report/status/GV7/0/25) 2022-04-18 12:16:02 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2_run/report/status/GV7/0/25) 2022-04-18 12:16:02 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_run/report/status/GV8/0/25) 2022-04-18 12:16:02 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2_run/report/status/GV8/0/25) 2022-04-18 12:16:02 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_run/report/status/GV9/0.72/10) 2022-04-18 12:16:02 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2_run/report/status/GV9/6.07/10) 2022-04-18 12:16:02 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_s00/report/status/ST/22.0/4) 2022-04-18 12:16:03 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2_s00/report/status/ST/24.0/4) 2022-04-18 12:16:03 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_s00/report/status/GV1//25) 2022-04-18 12:16:03 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2_s00/report/status/GV1//25) 2022-04-18 12:16:03 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_s01/report/status/ST/22.0/4) 2022-04-18 12:16:03 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven1_s01/report/status/GV1/27/25) 2022-04-18 12:16:16 - ISY Send: Variable dsc1-GV11 added to queue (Val: -1, QS: 1) 2022-04-18 12:16:16 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_dsc1/report/status/GV11/-1/25) 2022-04-18 12:16:18 - Venstar: Get Data - {"name":"GLEN_02","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":24.0,"heattemp":24.0,"cooltemp":28.0,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":29,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven2] 2022-04-18 12:16:18 - Venstar: Get Data - {"name":"GLEN_01","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":22.0,"heattemp":22.5,"cooltemp":28.5,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":25,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven1] 2022-04-18 12:16:18 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":24.0,"hum":29},{"name":"Space Temp","temp":24.0}]} [ven2] 2022-04-18 12:16:18 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":22.0,"hum":25},{"name":"Space Temp","temp":22.0},{"id":1,"name":"Glen Sensor","temp":22.0,"battery":27,"type":"Remote"}]} [ven1] 2022-04-18 12:16:18 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven2] 2022-04-18 12:16:18 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven1] 2022-04-18 12:16:18 - ISY Send: Variable ven2-ST added to queue (Val: 24.0, QS: 1) 2022-04-18 12:16:18 - ISY Send: Variable ven2-CLISPH added to queue (Val: 24.0, QS: 2) 2022-04-18 12:16:18 - ISY Send: Variable ven2-GV2 added to queue (Val: 1, QS: 3) 2022-04-18 12:16:18 - ISY Send: Variable ven1-ST added to queue (Val: 22.0, QS: 4) 2022-04-18 12:16:18 - ISY Send: Variable ven1-CLISPH added to queue (Val: 22.5, QS: 5) 2022-04-18 12:16:18 - ISY Receive: <?xml version="1.0" encoding="UTF-8"?><RestResponse succeeded="true"><status>200</status><reason code="0" /></RestResponse> (ns/1/nodes/n001_ven2/report/status/ST/24.0/4)
  16. Back in February I started a new thread after updating NodeLink from V0.10.6 to v0.11.3 on my Raspberry. My Pi was running Buster OS at the time. I never resolved my issues so I decided to take the plunge and make a clean install of Bullseye. I then ran the NodeLink script. I have 3 devices on Nodelink: 2 Venstar stats (both ColorTouch) and 1 DSC alarm using EnvisaLink 4. For the Venstar stats, I ran the command to update the Venstar nodes http://ISY/rest/ns/1/nodes/n001_ven1/change/Venstar?nls=140V (also for n001_ven2). Most of the time the heartbeat for all 3 devices does not change. I say 'most of the time' because occasionally it does change! I set the File Logging to Debug and the Log Level for all 3 devices to Debug... I restarted NodeLink and below is the log for only a few minutes after. I checked and none of the heartbeats were being updated on the ISY. Any help with this would be appreciated. 2022-04-13 13:50:30 - ISY resolved to 10.0.1.19 (5.0.16C) 2022-04-13 13:50:30 - ISY Node Server config detected (profile 1) 2022-04-13 13:50:31 - ISY Warning: Duplicate node names exist on the ISY (Home) 2022-04-13 13:50:31 - ISY Warning: Duplicate node names exist on the ISY (Space Temp) 2022-04-13 13:50:31 - ISY Warning: Duplicate node names exist on the ISY (Runtime) 2022-04-13 13:50:32 - DSC: 5053CD[C][L] [dsc1] 2022-04-13 13:50:33 - Venstar: Get Data - {"runtimes":[{"ts":1649376000,"heat1":67,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649462400,"heat1":59,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649548800,"heat1":83,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649635200,"heat1":0,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649721600,"heat1":0,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649808000,"heat1":0,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649857832,"heat1":0,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0}]} [ven1] 2022-04-13 13:50:33 - DSC: 505 - Login Interaction (Password Requested) [dsc1] 2022-04-13 13:50:33 - DSC: EVL User Login - Password Sent [dsc1] 2022-04-13 13:50:33 - DSC: Connected to 10.0.1.18 [dsc1] 2022-04-13 13:50:33 - DSC: 5000052A[C][L]5051CB[C][L] [dsc1] 2022-04-13 13:50:33 - DSC: 500 - Command Acknowledge (005) [dsc1] 2022-04-13 13:50:33 - DSC: 505 - Login Interaction (Password Correct, Session Established) [dsc1] 2022-04-13 13:50:33 - DSC: Status Request Sent [dsc1] 2022-04-13 13:50:33 - DSC: Data Sent - 00191 [dsc1] 2022-04-13 13:50:33 - DSC TCP: Polling DSC [dsc1] 2022-04-13 13:50:33 - DSC: 50000126[C][L]61000128[C][L]61000229[C][L]6100032A[C][L]6100042B[C][L]6100052C[C][L]6100062D[C][L]6100072E[C][L]6100082F[C][L]61000930[C][L]61001028[C][L]61001129[C][L]6100122A[C][L]6100132B[C][L]6100142C[C][L]6100152D[C][L]6100162E[C][L]6100172F[C][L]61001830[C][L]61001931[C][L]61002029[C][L]6100212A[C][L]6100222B[C][L]6100232C[C][L] [dsc1] 2022-04-13 13:50:33 - DSC: 500 - Command Acknowledge (001) [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 001) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 1 (Zone 01) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 002) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 2 (Zone 02) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 003) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 3 ((Z03) Door to Upper Deck) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 004) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 4 (Zone 04) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 005) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 5 (Zone 05) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 006) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 6 (Zone 06) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 007) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 7 (Zone 07) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 008) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 8 (Zone 08) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 009) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 9 (Zone 09) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 010) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 10 (Zone 10) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 011) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 11 (Zone 11) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 012) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 12 (Zone 12) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 013) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 13 (Zone 13) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 014) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 14 (Zone 14) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 015) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 15 (Zone 15) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 016) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 16 (Zone 16) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 017) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 17 (Zone 17) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 018) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 18 (Zone 18) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 019) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 19 (Zone 19) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 020) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 20 (Zone 20) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 021) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 21 (Zone 21) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 022) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 22 (Zone 22) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 023) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 23 (Zone 23) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 50000025[C][L] [dsc1] 2022-04-13 13:50:33 - DSC: 500 - Command Acknowledge (000) [dsc1] 2022-04-13 13:50:33 - Venstar: Get Data - {"runtimes":[{"ts":1649376000,"heat1":159,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649462400,"heat1":332,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649548800,"heat1":506,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649635200,"heat1":534,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649721600,"heat1":575,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649808000,"heat1":323,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0},{"ts":1649857832,"heat1":106,"heat2":0,"cool1":0,"cool2":0,"aux1":0,"aux2":0,"fc":0}]} [ven2] 2022-04-13 13:50:33 - DSC: 6100242D[C][L]6100252E[C][L]6100262F[C][L]61002730[C][L]61002831[C][L]61002932[C][L]6100302A[C][L]6100312B[C][L]6100322C[C][L]6100332D[C][L]60903436[C][L]6100352F[C][L]61003630[C][L]61003731[C][L]61003832[C][L]61003933[C][L]6100402B[C][L]6100412C[C][L]6100422D[C][L]6100432E[C][L]6100442F[C][L]61004530[C][L]61004631[C][L]61004732[C][L] [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 024) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 24 (Zone 24) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 025) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 25 (Zone 25) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 026) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 26 (Zone 26) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 027) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 27 (Zone 27) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 028) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 28 (Zone 28) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 029) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 29 (Zone 29) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 030) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 30 (Zone 30) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 031) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 31 (Zone 31) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 032) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 32 (Zone 32) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 033) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 33 (Zone 33) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 609 - Zone Open (Zone 034) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 34 (Zone 34) Opened [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 035) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 35 (Zone 35) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 036) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 36 (Zone 36) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 037) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 37 (Zone 37) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 038) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 38 (Zone 38) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 039) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 39 (Zone 39) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 040) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 40 (Zone 40) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 041) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 41 (Zone 41) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 042) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 42 (Zone 42) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 043) [dsc1] 2022-04-13 13:50:33 - DSC: Zone 43 (Zone 43) Closed [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 044) [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 045) [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 046) [dsc1] 2022-04-13 13:50:33 - DSC: 610 - Zone Restored (Zone 047) [dsc1] 2022-04-13 13:50:34 - Venstar: Get Data - {"api_ver":7,"type":"residential","model":"COLORTOUCH","firmware":"5.10"} [ven2] 2022-04-13 13:50:34 - Venstar: Get Data - {"api_ver":7,"type":"residential","model":"COLORTOUCH","firmware":"5.10"} [ven1] 2022-04-13 13:50:34 - Venstar: Get Data - {"name":"GLEN_02","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":25.0,"heattemp":24.0,"cooltemp":28.0,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":30,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven2] 2022-04-13 13:50:34 - Venstar: Get Data - {"name":"GLEN_01","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":23.5,"heattemp":22.5,"cooltemp":28.5,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":25,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven1] 2022-04-13 13:50:34 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":23.5,"hum":25},{"name":"Space Temp","temp":23.5},{"id":1,"name":"Glen Sensor","temp":23.5,"battery":29,"type":"Remote"}]} [ven1] 2022-04-13 13:50:34 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":25.0,"hum":30},{"name":"Space Temp","temp":25.0}]} [ven2] 2022-04-13 13:50:34 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven2] 2022-04-13 13:50:34 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven1] 2022-04-13 13:50:34 - DSC: 61004833[C][L]61004934[C][L]6100502C[C][L]6100512D[C][L]6100522E[C][L]6100532F[C][L]61005430[C][L]61005531[C][L]61005632[C][L]61005733[C][L]61005834[C][L]61005935[C][L]6100602D[C][L]6100612E[C][L]6100622F[C][L]61006330[C][L]61006431[C][L]6531CF[C][L]6732D2[C][L]6733D3[C][L]6734D4[C][L]8411CE[C][L]8412CF[C][L]8413D0[C][L]8414D1[C][L]8415D2[C][L] [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 048) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 049) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 050) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 051) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 052) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 053) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 054) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 055) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 056) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 057) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 058) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 059) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 060) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 061) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 062) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 063) [dsc1] 2022-04-13 13:50:34 - DSC: 610 - Zone Restored (Zone 064) [dsc1] 2022-04-13 13:50:34 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1] 2022-04-13 13:50:34 - DSC: 673 - Partition Busy (Partition 2) [dsc1] 2022-04-13 13:50:34 - DSC: 673 - Partition Busy (Partition 3) [dsc1] 2022-04-13 13:50:34 - DSC: 673 - Partition Busy (Partition 4) [dsc1] 2022-04-13 13:50:34 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 1) [dsc1] 2022-04-13 13:50:34 - DSC: Panel OK [dsc1] 2022-04-13 13:50:34 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 2) [dsc1] 2022-04-13 13:50:34 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 3) [dsc1] 2022-04-13 13:50:34 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 4) [dsc1] 2022-04-13 13:50:34 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 5) [dsc1] 2022-04-13 13:50:34 - ISY Error: Error setting node value - Destination array was not long enough. Check the destination index, length, and the array's lower bounds. (Parameter 'destinationArray') 2022-04-13 13:50:35 - DSC: 8416D3[C][L]8417D4[C][L]8418D5[C][L]51081FF[C][L] [dsc1] 2022-04-13 13:50:35 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 6) [dsc1] 2022-04-13 13:50:35 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 7) [dsc1] 2022-04-13 13:50:35 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 8) [dsc1] 2022-04-13 13:50:35 - DSC: 510 - Full LED Status Update [dsc1] 2022-04-13 13:51:04 - Venstar: Get Data - {"name":"GLEN_02","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":25.0,"heattemp":24.0,"cooltemp":28.0,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":29,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven2] 2022-04-13 13:51:04 - Venstar: Get Data - {"name":"GLEN_01","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":23.5,"heattemp":22.5,"cooltemp":28.5,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":25,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven1] 2022-04-13 13:51:04 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":23.5,"hum":25},{"name":"Space Temp","temp":23.5},{"id":1,"name":"Glen Sensor","temp":23.5,"battery":29,"type":"Remote"}]} [ven1] 2022-04-13 13:51:04 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":25.0,"hum":29},{"name":"Space Temp","temp":25.0}]} [ven2] 2022-04-13 13:51:04 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven2] 2022-04-13 13:51:04 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven1] 2022-04-13 13:51:04 - ISY Error: Error setting node value - The given key 'ven2-CLISMD' was not present in the dictionary. 2022-04-13 13:51:32 - DSC TCP: Polling DSC [dsc1] 2022-04-13 13:51:32 - DSC: 50000025[C][L] [dsc1] 2022-04-13 13:51:32 - DSC: 500 - Command Acknowledge (000) [dsc1] 2022-04-13 13:51:34 - Venstar: Get Data - {"name":"GLEN_01","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":23.5,"heattemp":22.5,"cooltemp":28.5,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":25,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven1] 2022-04-13 13:51:34 - Venstar: Get Data - {"name":"GLEN_02","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":25.0,"heattemp":24.0,"cooltemp":28.0,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":29,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven2] 2022-04-13 13:51:34 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":23.5,"hum":25},{"name":"Space Temp","temp":23.5},{"id":1,"name":"Glen Sensor","temp":23.5,"battery":29,"type":"Remote"}]} [ven1] 2022-04-13 13:51:34 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven1] 2022-04-13 13:51:34 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":25.0,"hum":29},{"name":"Space Temp","temp":25.0}]} [ven2] 2022-04-13 13:51:34 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven2] 2022-04-13 13:52:04 - Venstar: Get Data - {"name":"GLEN_01","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":23.5,"heattemp":22.5,"cooltemp":28.5,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":25,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven1] 2022-04-13 13:52:04 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":23.5,"hum":25},{"name":"Space Temp","temp":23.5},{"id":1,"name":"Glen Sensor","temp":23.5,"battery":29,"type":"Remote"}]} [ven1] 2022-04-13 13:52:04 - Venstar: Get Data - {"name":"GLEN_02","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":25.0,"heattemp":24.0,"cooltemp":28.0,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":29,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven2] 2022-04-13 13:52:04 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven1] 2022-04-13 13:52:04 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":25.0,"hum":29},{"name":"Space Temp","temp":25.0}]} [ven2] 2022-04-13 13:52:04 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven2] 2022-04-13 13:52:32 - DSC TCP: Polling DSC [dsc1] 2022-04-13 13:52:32 - DSC: 50000025[C][L] [dsc1] 2022-04-13 13:52:32 - DSC: 500 - Command Acknowledge (000) [dsc1] 2022-04-13 13:52:34 - Venstar: Get Data - {"name":"GLEN_01","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":23.5,"heattemp":22.5,"cooltemp":28.5,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":25,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven1] 2022-04-13 13:52:34 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":23.5,"hum":25},{"name":"Space Temp","temp":23.5},{"id":1,"name":"Glen Sensor","temp":23.5,"battery":29,"type":"Remote"}]} [ven1] 2022-04-13 13:52:34 - Venstar: Get Data - {"name":"GLEN_02","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":25.0,"heattemp":24.0,"cooltemp":28.0,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":29,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven2] 2022-04-13 13:52:34 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven1] 2022-04-13 13:52:34 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":25.0,"hum":29},{"name":"Space Temp","temp":25.0}]} [ven2] 2022-04-13 13:52:34 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven2] 2022-04-13 13:53:04 - Venstar: Get Data - {"name":"GLEN_01","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":23.5,"heattemp":22.5,"cooltemp":28.5,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":25,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven1] 2022-04-13 13:53:04 - Venstar: Get Data - {"name":"GLEN_02","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":25.0,"heattemp":24.0,"cooltemp":28.0,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":29,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven2] 2022-04-13 13:53:04 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":23.5,"hum":25},{"name":"Space Temp","temp":23.5},{"id":1,"name":"Glen Sensor","temp":23.5,"battery":29,"type":"Remote"}]} [ven1] 2022-04-13 13:53:04 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":25.0,"hum":29},{"name":"Space Temp","temp":25.0}]} [ven2] 2022-04-13 13:53:04 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven2] 2022-04-13 13:53:04 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven1] 2022-04-13 13:53:32 - DSC TCP: Polling DSC [dsc1] 2022-04-13 13:53:32 - DSC: 50000025[C][L] [dsc1] 2022-04-13 13:53:32 - DSC: 500 - Command Acknowledge (000) [dsc1] 2022-04-13 13:53:34 - Venstar: Get Data - {"name":"GLEN_02","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":25.0,"heattemp":24.0,"cooltemp":28.0,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":29,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven2] 2022-04-13 13:53:34 - Venstar: Get Data - {"name":"GLEN_01","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":23.5,"heattemp":22.5,"cooltemp":28.5,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":25,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven1] 2022-04-13 13:53:34 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":25.0,"hum":29},{"name":"Space Temp","temp":25.0}]} [ven2] 2022-04-13 13:53:34 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":23.5,"hum":25},{"name":"Space Temp","temp":23.5},{"id":1,"name":"Glen Sensor","temp":23.5,"battery":29,"type":"Remote"}]} [ven1] 2022-04-13 13:53:34 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven2] 2022-04-13 13:53:34 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven1] 2022-04-13 13:54:04 - Venstar: Get Data - {"name":"GLEN_02","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":25.0,"heattemp":24.0,"cooltemp":28.0,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":29,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven2] 2022-04-13 13:54:04 - Venstar: Get Data - {"name":"GLEN_01","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":23.5,"heattemp":22.5,"cooltemp":28.5,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":25,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven1] 2022-04-13 13:54:04 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":25.0,"hum":29},{"name":"Space Temp","temp":25.0}]} [ven2] 2022-04-13 13:54:04 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":23.5,"hum":25},{"name":"Space Temp","temp":23.5},{"id":1,"name":"Glen Sensor","temp":23.5,"battery":29,"type":"Remote"}]} [ven1] 2022-04-13 13:54:04 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven2] 2022-04-13 13:54:05 - Venstar: Get Data - {"alerts":[{"name":"Air Filter","active":false},{"name":"UV Lamp","active":false},{"name":"Service","active":false}]} [ven1] 2022-04-13 13:54:32 - DSC TCP: Polling DSC [dsc1] 2022-04-13 13:54:32 - DSC: 50000025[C][L] [dsc1] 2022-04-13 13:54:32 - DSC: 500 - Command Acknowledge (000) [dsc1] 2022-04-13 13:54:35 - Venstar: Get Data - {"name":"GLEN_02","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":25.0,"heattemp":24.0,"cooltemp":28.0,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":29,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven2] 2022-04-13 13:54:35 - Venstar: Get Data - {"name":"GLEN_01","mode":1,"state":0,"fan":0,"fanstate":0,"tempunits":1,"schedule":0,"schedulepart":255,"away":0,"spacetemp":23.5,"heattemp":22.5,"cooltemp":28.5,"cooltempmin":1.5,"cooltempmax":37.0,"heattempmin":1.50,"heattempmax":37.0,"activestage":0,"hum_active":0,"hum":25,"hum_setpoint":0,"dehum_setpoint":99,"setpointdelta":2.0,"availablemodes":0} [ven1] 2022-04-13 13:54:35 - Venstar: Get Data - {"sensors":[{"name":"Thermostat","temp":25.0,"hum":29},{"name":"Space Temp","temp":25.0}]} [ven2]
  17. Thanks for the reply... I did run the install script which presumably moved me to .net 5. I should have explained that, in fact, I had executed the rest command for each Venstar stat. I did notice that when I ran the script on the Raspberry that it did have an error... attached is a screenshot I took of the error. Perhaps this is causing issues.
  18. Today I decided to update NodeLink from v0.10.6 to v0.11.3. I am running v5.0.16C on my ISY. I have NodeLink running on my Raspberry pi. I have 2 Venstar stats and therefore 2 nodes; a DSC alarm node; Network Monitor; and ISY Data nodes. The nodes that seem to be giving me issues are the 2 Venstar and the DSC nodes. The issue is that the ISY is not updating and the heartbeat is not changing. Note that after installing the new version on the pi, I ran the command to update the Venstar nodes (http://ISY/rest/ns/1/nodes/n001_ven1/change/Venstar?nls=140V) I am attaching the log file after I set both of the Venstars and the DSC to debug. Any thoughts on what is wrong? logfile_2022-02-27.txt
  19. Are you seeing that Aartech seems to have less and less Insteon products available recently? For example, they currently aren't showing any LampLinc devices on their site! It may be that their revamped website only shows items that are actually in stock and perhaps due to Covid their supply is really low! Just before Christmas, based on their lack of Insteon product, I was wondering I should switch away from Insteon! However, I do see that one product that wasn't showing on their site (before Christmas) is now back in stock! So, I'm hoping it is just a production issue!
  20. I have been using Insteon only devices for numerous years with my 2 ISY's (home and vacation home). The recent release of v.5.2.0 (RC3) seems to be primarily driven by Z Wave devices. I am currently on release v.5.0.16C and it appears that the new release does little or nothing for me. However, it did make me wonder if I should be considering adding Z Wave devices to my network. After a little research on the devices, Z Wave products look to be cheaper and there are more manufacturers than Insteon! My questions: - for those that have chosen to add Z Wave devices to their network, was it Price? Availability? or Features? Or put another way... Why did you choose Z Wave over Insteon? - I have 2 ISY 994i/IR PRO controllers... do I need to change controllers (to ISY9941 ZW+/IR PRO) or can my controllers be upgraded to handle Z Wave Plus by buying the External Z-Wave PLUS Module (although the description for this module states "Use this module in case you have Zigbee module installed inside your ISY994" which I don't believe I have!) - As I understand it, Z Wave communications do not use RF or power line signals, that Insteon devices use, so if I add Z Wave devices, to my network, their communications would have to stand on their own... roughly, how many Z Wave devices are required in a home (say 3,000 to 4,000 sq ft) to make a reliable network? As an example, if I only install one Z Wave Plus lock on a back door at the other end of the house from where the controller sits will the communications work? - Are there any other key factors I should consider with respect to adding Z Wave Plus devices?
  21. Thanks... that was easy!
  22. Another question related to the Venstar thermostats... I have 2 of them in my home and 1 at the cottage. I noticed that the 2 at my home, on the ISY, have the Fahrenheit node whereas I want the Celsius node! The 1 at the cottage is correct. I don't remember seeing the option to select F or C when setting up the nodes! Can I simply delete the F nodes on the ISY and manually install C nodes? If so, what do I enter for the Node Address and Primary Node Address values in the Add Node dialog box? If not, how do I correct this?
  23. Thanks... that fixed it! I wondered what that option was for! I did not need to enable that option on my cottage DSC alarm system! I have increased the Venstar timeout and I will watch to see if I need to increase it more.
  24. @io_guy... You would think that I should have figured that out by now!! Do you prefer the log as an attachment or right into the body of the reply? I'm going to put it in the body now... Before copying the log, I rebooted NodeLink and then briefly opened our front door. The ISY is now showing the Ready status as 'False'. I also see in the log that I am getting a number of Venstar: Get Error - Timeouts! Is this normal? Here is the log: 2020-07-10 09:52:09 - ISY resolved to 10.0.1.19 (5.0.16C) 2020-07-10 09:52:09 - ISY Node Server config detected (profile 1) 2020-07-10 09:52:10 - ISY Warning: Duplicate node names exist on the ISY (Space Temp) 2020-07-10 09:52:10 - ISY Warning: Duplicate node names exist on the ISY (Runtime) 2020-07-10 09:52:10 - ISY Warning: Duplicate node names exist on the ISY (Home) 2020-07-10 09:52:11 - DSC: 5053CD[C][L] [dsc1] 2020-07-10 09:52:12 - DSC: 505 - Login Interaction (Password Requested) [dsc1] 2020-07-10 09:52:12 - DSC: EVL User Login - Password Sent [dsc1] 2020-07-10 09:52:12 - DSC: Connected to 10.0.1.18 [dsc1] 2020-07-10 09:52:12 - DSC: 5000052A[C][L]5051CB[C][L] [dsc1] 2020-07-10 09:52:12 - DSC: 500 - Command Acknowledge (005) [dsc1] 2020-07-10 09:52:12 - DSC: 505 - Login Interaction (Password Correct, Session Established) [dsc1] 2020-07-10 09:52:12 - DSC: Status Request Sent [dsc1] 2020-07-10 09:52:12 - DSC: Data Sent - 00191 [dsc1] 2020-07-10 09:52:12 - DSC TCP: Polling DSC [dsc1] 2020-07-10 09:52:12 - DSC: 50000126[C][L]61000128[C][L]61000229[C][L]6100032A[C][L]6100042B[C][L]6100052C[C][L]6100062D[C][L]6100072E[C][L]6100082F[C][L]61000930[C][L]61001028[C][L]61001129[C][L]6100122A[C][L]6100132B[C][L]6100142C[C][L]6100152D[C][L]6100162E[C][L]6100172F[C][L]61001830[C][L]61001931[C][L]61002029[C][L]6100212A[C][L]6100222B[C][L]6100232C[C][L] [dsc1] 2020-07-10 09:52:12 - DSC: 500 - Command Acknowledge (001) [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 001) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 1 ((Z01) Front Door) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 002) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 2 ((Z02) Door to Garage) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 003) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 3 ((Z03) Door to Upper Deck) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 004) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 4 ((Z04) Basement Door) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 005) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 5 ((Z05) Garage Door #3) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 006) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 6 ((Z06) Garage Door #2) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 007) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 7 ((Z07) Garage Door #1) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 008) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 8 ((Z08) Garage Exit Door) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 009) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 9 ((Z09) Laundry Glass Break) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 010) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 10 ((Z10) Office Glass Break) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 011) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 11 ((Z11) Kitchen Glass Break) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 012) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 12 ((Z12) Great Rm Glass Break) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 013) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 13 ((Z13) Powder Rm Glass Break) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 014) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 14 ((Z14) Basement L Glass Break) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 015) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 15 ((Z15) Basement C Glass Break) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 016) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 16 ((Z16) Basement R Glass Break) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 017) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 17 ((Z17) Motion Front Door) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 018) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 18 ((Z18) Motion Kitchen) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 019) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 19 ((Z19) Motion Great Rm) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 020) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 20 ((Z20) Motion Basement) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 021) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 21 ((Z21) Smoke D Basement L) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 022) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 22 ((Z22)Smoke D Basement R) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 023) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 23 ((Z23) Unused) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 50000025[C][L] [dsc1] 2020-07-10 09:52:12 - DSC: 500 - Command Acknowledge (000) [dsc1] 2020-07-10 09:52:12 - DSC: 6100242D[C][L]6100252E[C][L]6100262F[C][L]61002730[C][L]61002831[C][L]61002932[C][L]6100302A[C][L]6100312B[C][L]6100322C[C][L]6100332D[C][L]60903436[C][L]6100352F[C][L]61003630[C][L]61003731[C][L]61003832[C][L]61003933[C][L]6100402B[C][L]6100412C[C][L]6100422D[C][L]6100432E[C][L]6100442F[C][L]61004530[C][L]61004631[C][L]61004732[C][L] [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 024) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 24 ((Z24) Unused) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 025) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 25 ((Z25) Office Windows) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 026) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 26 ((Z26) Dining Rm Windows) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 027) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 27 ((Z27) Kitchen Window) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 028) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 28 ((Z28) Laundry Rm Window) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 029) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 29 ((Z29) Powder Rm Window) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 030) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 30 ((Z30) Great Rm Windows) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 031) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 31 ((Z31) Living Rm Windows) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 032) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 32 ((Z32) Unused) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 033) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 33 ((Z33) Master Bedrm Windows) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 609 - Zone Open (Zone 034) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 34 ((Z34) Julia's Bedrm Windows) Opened [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 035) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 35 ((Z35) Chrissy's Bedrm Windows) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 036) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 36 ((Z36) Maddy's Bedrm Window) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 037) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 37 ((Z37) Guest Rm Window) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 038) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 38 ((Z38) Shared Washrm Window) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 039) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 39 ((Z39) Master Washrm Window) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 040) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 40 ((Z40) Gym Window) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 041) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 41 ((Z41) Unused) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 042) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 42 ((Z42) Bsmnt Bar Windows) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 043) [dsc1] 2020-07-10 09:52:12 - DSC: Zone 43 ((Z43) Bsmnt Fireplace Windows) Closed [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 044) [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 045) [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 046) [dsc1] 2020-07-10 09:52:12 - DSC: 610 - Zone Restored (Zone 047) [dsc1] 2020-07-10 09:52:13 - DSC: 61004833[C][L]61004934[C][L]6100502C[C][L]6100512D[C][L]6100522E[C][L]6100532F[C][L]61005430[C][L]61005531[C][L]61005632[C][L]61005733[C][L]61005834[C][L]61005935[C][L]6100602D[C][L]6100612E[C][L]6100622F[C][L]61006330[C][L]61006431[C][L]6531CF[C][L]6732D2[C][L]6733D3[C][L]6734D4[C][L]8411CE[C][L]8412CF[C][L]8413D0[C][L]8414D1[C][L]8415D2[C][L] [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 048) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 049) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 050) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 051) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 052) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 053) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 054) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 055) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 056) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 057) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 058) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 059) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 060) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 061) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 062) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 063) [dsc1] 2020-07-10 09:52:13 - DSC: 610 - Zone Restored (Zone 064) [dsc1] 2020-07-10 09:52:13 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1] 2020-07-10 09:52:13 - DSC: 673 - Partition Busy (Partition 2) [dsc1] 2020-07-10 09:52:13 - DSC: 673 - Partition Busy (Partition 3) [dsc1] 2020-07-10 09:52:13 - DSC: 673 - Partition Busy (Partition 4) [dsc1] 2020-07-10 09:52:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 1) [dsc1] 2020-07-10 09:52:13 - DSC: Panel OK [dsc1] 2020-07-10 09:52:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 2) [dsc1] 2020-07-10 09:52:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 3) [dsc1] 2020-07-10 09:52:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 4) [dsc1] 2020-07-10 09:52:13 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 5) [dsc1] 2020-07-10 09:52:14 - DSC: 8416D3[C][L]8417D4[C][L]8418D5[C][L]51081FF[C][L] [dsc1] 2020-07-10 09:52:14 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 6) [dsc1] 2020-07-10 09:52:14 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 7) [dsc1] 2020-07-10 09:52:14 - DSC: 841 - Trouble Status Restore (LED OFF) (Partition 8) [dsc1] 2020-07-10 09:52:14 - DSC: 510 - Full LED Status Update [dsc1] 2020-07-10 09:52:15 - Relay Server: Started on port 2405 2020-07-10 09:52:21 - Venstar: Get Error - Timeout [ven1] 2020-07-10 09:52:21 - Venstar: Get Error - Timeout [ven1] 2020-07-10 09:52:21 - Venstar: Get Error - Timeout [ven2] 2020-07-10 09:52:41 - DSC: 60901838[C][L] [dsc1] 2020-07-10 09:52:41 - DSC: 609 - Zone Open (Zone 018) [dsc1] 2020-07-10 09:52:41 - DSC: Zone 18 ((Z18) Motion Kitchen) Opened [dsc1] 2020-07-10 09:52:46 - DSC: 61001830[C][L] [dsc1] 2020-07-10 09:52:46 - DSC: 610 - Zone Restored (Zone 018) [dsc1] 2020-07-10 09:52:46 - DSC: Zone 18 ((Z18) Motion Kitchen) Closed [dsc1] 2020-07-10 09:52:50 - DSC: 60901838[C][L] [dsc1] 2020-07-10 09:52:50 - DSC: 609 - Zone Open (Zone 018) [dsc1] 2020-07-10 09:52:50 - DSC: Zone 18 ((Z18) Motion Kitchen) Opened [dsc1] 2020-07-10 09:52:52 - DSC: 61001830[C][L] [dsc1] 2020-07-10 09:52:52 - DSC: 610 - Zone Restored (Zone 018) [dsc1] 2020-07-10 09:52:52 - DSC: Zone 18 ((Z18) Motion Kitchen) Closed [dsc1] 2020-07-10 09:52:52 - DSC: 60901838[C][L] [dsc1] 2020-07-10 09:52:52 - DSC: 609 - Zone Open (Zone 018) [dsc1] 2020-07-10 09:52:52 - DSC: Zone 18 ((Z18) Motion Kitchen) Opened [dsc1] 2020-07-10 09:52:53 - DSC: 61001830[C][L] [dsc1] 2020-07-10 09:52:53 - DSC: 610 - Zone Restored (Zone 018) [dsc1] 2020-07-10 09:52:53 - DSC: Zone 18 ((Z18) Motion Kitchen) Closed [dsc1] 2020-07-10 09:52:54 - DSC: 60901737[C][L] [dsc1] 2020-07-10 09:52:54 - DSC: 609 - Zone Open (Zone 017) [dsc1] 2020-07-10 09:52:54 - DSC: Zone 17 ((Z17) Motion Front Door) Opened [dsc1] 2020-07-10 09:52:58 - DSC: 60900130[C][L] [dsc1] 2020-07-10 09:52:58 - DSC: 609 - Zone Open (Zone 001) [dsc1] 2020-07-10 09:52:58 - DSC: Zone 1 ((Z01) Front Door) Opened [dsc1] 2020-07-10 09:52:58 - DSC: 51080FE[C][L] [dsc1] 2020-07-10 09:52:58 - DSC: 510 - Full LED Status Update [dsc1] 2020-07-10 09:52:58 - DSC: 6511CD[C][L] [dsc1] 2020-07-10 09:52:58 - DSC: 651 - Partition Not Ready (Partition 1) [dsc1] 2020-07-10 09:52:58 - DSC: System Status - Not Ready (Partition 1) [dsc1] 2020-07-10 09:52:58 - DSC: System Status - Disarmed (Set By Status Request - Partition 1) [dsc1] 2020-07-10 09:53:00 - DSC: 6100172F[C][L] [dsc1] 2020-07-10 09:53:00 - DSC: 610 - Zone Restored (Zone 017) [dsc1] 2020-07-10 09:53:00 - DSC: Zone 17 ((Z17) Motion Front Door) Closed [dsc1] 2020-07-10 09:53:11 - DSC TCP: Polling DSC [dsc1] 2020-07-10 09:53:11 - DSC: 50000025[C][L] [dsc1] 2020-07-10 09:53:11 - DSC: 500 - Command Acknowledge (000) [dsc1] 2020-07-10 09:53:16 - DSC: 61000128[C][L] [dsc1] 2020-07-10 09:53:16 - DSC: 610 - Zone Restored (Zone 001) [dsc1] 2020-07-10 09:53:16 - DSC: Zone 1 ((Z01) Front Door) Closed [dsc1] 2020-07-10 09:53:16 - DSC: 51081FF[C][L] [dsc1] 2020-07-10 09:53:16 - DSC: 510 - Full LED Status Update [dsc1] 2020-07-10 09:53:16 - DSC: 6531CF[C][L] [dsc1] 2020-07-10 09:53:16 - DSC: 653 - Partition in Ready to Force Arm (Partition 1) [dsc1] 2020-07-10 09:53:19 - DSC: 60901737[C][L] [dsc1] 2020-07-10 09:53:19 - DSC: 609 - Zone Open (Zone 017) [dsc1] 2020-07-10 09:53:19 - DSC: Zone 17 ((Z17) Motion Front Door) Opened [dsc1] 2020-07-10 09:53:20 - DSC: 6100172F[C][L] [dsc1] 2020-07-10 09:53:20 - DSC: 610 - Zone Restored (Zone 017) [dsc1] 2020-07-10 09:53:20 - DSC: Zone 17 ((Z17) Motion Front Door) Closed [dsc1] 2020-07-10 09:53:21 - DSC: 60901737[C][L] [dsc1] 2020-07-10 09:53:21 - DSC: 609 - Zone Open (Zone 017) [dsc1] 2020-07-10 09:53:21 - DSC: Zone 17 ((Z17) Motion Front Door) Opened [dsc1] 2020-07-10 09:53:24 - DSC: 6100172F[C][L] [dsc1] 2020-07-10 09:53:24 - DSC: 610 - Zone Restored (Zone 017) [dsc1] 2020-07-10 09:53:24 - DSC: Zone 17 ((Z17) Motion Front Door) Closed [dsc1] 2020-07-10 09:53:26 - DSC: 60901737[C][L] [dsc1] 2020-07-10 09:53:26 - DSC: 609 - Zone Open (Zone 017) [dsc1] 2020-07-10 09:53:26 - DSC: Zone 17 ((Z17) Motion Front Door) Opened [dsc1] 2020-07-10 09:53:28 - DSC: 6100172F[C][L] [dsc1] 2020-07-10 09:53:28 - DSC: 610 - Zone Restored (Zone 017) [dsc1] 2020-07-10 09:53:28 - DSC: Zone 17 ((Z17) Motion Front Door) Closed [dsc1] 2020-07-10 09:53:41 - DSC: 60901737[C][L] [dsc1] 2020-07-10 09:53:41 - DSC: 609 - Zone Open (Zone 017) [dsc1] 2020-07-10 09:53:41 - DSC: Zone 17 ((Z17) Motion Front Door) Opened [dsc1] 2020-07-10 09:53:45 - DSC: 60901838[C][L] [dsc1] 2020-07-10 09:53:45 - DSC: 609 - Zone Open (Zone 018) [dsc1] 2020-07-10 09:53:45 - DSC: Zone 18 ((Z18) Motion Kitchen) Opened [dsc1] 2020-07-10 09:53:46 - DSC: 6100172F[C][L] [dsc1] 2020-07-10 09:53:46 - DSC: 610 - Zone Restored (Zone 017) [dsc1] 2020-07-10 09:53:46 - DSC: Zone 17 ((Z17) Motion Front Door) Closed [dsc1] 2020-07-10 09:53:52 - DSC: 61001830[C][L] [dsc1] 2020-07-10 09:53:52 - DSC: 610 - Zone Restored (Zone 018) [dsc1] 2020-07-10 09:53:52 - DSC: Zone 18 ((Z18) Motion Kitchen) Closed [dsc1] 2020-07-10 09:53:57 - Venstar: Get Error - Timeout [ven1] 2020-07-10 09:53:57 - Venstar: Get Error - Timeout [ven2] 2020-07-10 09:54:11 - DSC TCP: Polling DSC [dsc1] 2020-07-10 09:54:11 - DSC: 50000025[C][L] [dsc1] 2020-07-10 09:54:11 - DSC: 500 - Command Acknowledge (000) [dsc1]
  25. I'm back at my home for a few days so I upgraded my ISY to v 5.0.16C and I did a fresh Buster install on my Raspberry (I actually used the image from my cottage Raspberry). Then I installed NodeLink. Now the nodes all look correct with one exception... My Partition 1 node was showing the Ready field as False when it is in fact green and ready... and now it's showing the Ready field as a blank value! My cottage system shows the Ready Field as True! On my home alarm system I have one zone always by-passed which allows the Ready to go green on the keypad... could this be causing the issue? My 2 Venstar ColorTouch Thermostats are now reporting fine, once I enabled the Local API setting. Edit: I should have mentioned that despite the Ready state in the Partition 1 node showing as either False or just blank, I was still able to Arm the alarm from an ISY program
  • Create New...
