pentair easytouch screenlogic for eisy now in PG3x
Here is what I have now. I used the same slot, fyi. Features look good and are updating, which is the most important thing to me. I see 2 pool thermostats. Should one be Spa?
To me, this is what your node arrangement should be replicating. You have a "Solar Thermostat" in your nodes. I don't even know what that means. It's like saying "Gas Thermostat" on my home. It doesn't make sense. A thermostat controls the temperature in an area... House/upstairs/downstairs/north wing/pool/spa. Within the thermostat controls you choose the source of heat. Gas (or "Heater")/Solar/Solar Preferred. Features seem fine, but I would prefer to see On and Off instead of True and False, but not a big deal. Features are now updating when controlled from outside IoX, so that's great.
I finally got around to installing and checked it out a bit yesterday. Thanks for putting this together. What I noticed: I don't understand the "Solar Heating" and "Solar Thermostat" naming and the repeating of temperatures in them. I have a pool and spa, gas heater and solar panels. My ScreenLogic desktop app presents this as 2 thermostats, one for pool and one for spa. Within each you select "off, heater, solar pref, solar only". I'm not getting updates into the plugin when changes are made outside the plugin. For example, if I turn on spa jets from the remote panel, the value for spa jets in the plugin never changes to True. Conversely, if I turn on the spa jets from the plugin, all works as it should. I don't see "Spa Setpoint" anywhere, just "Pool Setpoint". I can post any screenshots you might want.
Ecobee not communicating
Safe to assume that the ability to control the backlight is never going to come back?
I can't wait to try this!
Ah yes. UDI is in that list. Thank you.
I just checked my account on ecobee.com and checked the Developer page. I only see my Home Assistant application listed. Shouldn't Universal Devices (or whatever) be there too? It's been years since I set up the ecobee nodeserver and I don't remember how that all worked.
Line-in?
It was relatively easy to set up an NR to set the Line-in value to my Sonos devices. Is it possible (easily) to read the current value from the Sonos device too? I'm not terribly well versed in this stuff, but with enough Googling, and asking Gemini, I can usually copy and paste enough to get things to work. But I haven't been able to figure this out.
Ah HAH! Problems here too, but I've been having so many other network issues lately, I assumed the problem was mine alone.
- Line-in?
- Line-in?
- Line-in?
Line-in?
After much head scratching I finally figure out that Line-in can be made a Sonos Favorite. So I did that. Somehow persuaded the ST-Sonos plugin to update it's list of Favorites to show the newly added Line-in Favorite. I set up a Program so the Action portion would Set the Sonos Connect device to the Line-in Favorite... I even added Play command too... and... big fat nothing burger. To verify, I selected a different Favorite to test, and that worked. But it won't switch over to Line-in with the Favorite that is Line-in.
- Line-in?
