Everything posted by kstock
Gmail “tls error” message
Interesting. Guess Google just spending too much time, energy and money on their LLM claim to fame...
For what it's worth, long time ISY994 user here; still love it. Also long time user of gmail with ISY, app password, etc. Same recent gmail failure issues. Research for me identified likely issue is that Google/gmail finally/officially deprecated TLS 1.0, which I understand is what ISY uses. Needed new SMTP server. Now using SMTP2GO.com; SMTP2GO still supporting TLS 1.0 for legacy applications. I'm using free plan = 1000 emails/month; working without a hitch.
Flashing green light cant find isy
I see this power supply rated at 0.6A. Glad it's working, but the power supply recommendation for Polisy, from Michel, is for it to be rated up to 2.0A.
Neato Vacuum
I have the Botvac; bought 2 as gifts; really like it.
Support Thread: 5.0.16C (ISY994)
Updated to 5.0.16B. Can verify the wet and dry nodes seem to be appropriately updating in the admin console now for the leak sensors. Will see about the heartbeat node in the next x number of hours.
Was on 5.0.16. All was well. Upgraded to 5.0.16A. All 6 insteon leak sensors not working (2852-222, mostly 4.43). All 6 heartbeat programs notified me last night that no signal registered. In testing today, all links are intact. The admin console for all 3 nodes (wet, dry, heartbeat) remains blank for all sensors. Tapping the set button does register with ISY as seen in the event viewer, but admin console does not change. Shorting the electrodes (in water) does again register in ISY, but nodes do not change in console; remain blank. Programs written to act on the wet node activation are not firing. Downgraded back to 5.0.16, and all again working properly. Anyone else seeing this?
ISY & IOLINC Status Issue
From a previous thread, the IOLinc triggers at about 800 ohms. Adding a 1000 ohm resistor in parallel to the circuit would bring the circuit resistance down to about 687 ohm when active, and would likely trigger the IOLinc.
Controlling Foscam Camera Functions from ISY?
Is easy to do. Use setScheduleRecordConfig. isEnable=1. For schedul0 thru schedule6, set each of these =281474976710655. This will start the recording immediately. To stop recording, network resource using setScheduleRecordConfig, only use isEnable=0. I use these 2 resources on multiple Foscam cameras/models without a problem.
Unable to link Insteon On/Off module to ISY
LeeG, Direct from the Smarthome website, all of the Micro Modules (On|Off, Dimmer, Open/Close) are Dual Band. KS
Foscam Recording
zerop Latest CGI I have is Ver 1.0.10. Is a PDF file. Happy to send to you. PM me with your email address
Foscam Recording
Here is the full command syntax Function: Set schedule recordconfig Privilege: admin Usage: /cgi-bin/CGIProxy.fcgi?cmd=setScheduleRecordConfig Param: isEnable: Schedule-Record enable status, 0-disable,1-enable recordLevel: Level for drop frame,0-30/30,1-24/30,2-15/30,3-8/30, 4-4/30,5-1/30; spaceFullMode: The process method when SD card is full,0-cover the oldest video and continue record,1-stop record isEnableAudio: Is recording include audio? 0-no,1-yes scheduleN: The motion alaram schedule of one week, N = 0(Monday) ~6(Sunday) For detail, see *1 bellow /cgi-bin/CGIProxy.fcgi?cmd=setScheduleRecordConfig&isEnable=1&recordLev el=0&spaceFullMode=0&isEnableAudio=0&schedule0=1023&schedule1=1023& schedule2=1023&schedule3=1023&schedule4=1023&schedule5=1023&sched ule6=1023&usr=admin&pwd=
- Foscam Recording
Why isn't this program running?
Assuming variable $iCal.Holiday is in fact being set = 1, perhaps the "Holiday Changed to 1" program is running before the program "New Years Day" completes. Try putting a Wait of 5-10 seconds code line before the Run Program 'Holiday Changed to 1' (If) line in the "Holiday reset" program
how to get dusk & logs to work on new ISY-994i
It absolutely will. I have several programs with this exact syntax that trigger appropriately.
New Elk water sensor not showing up in ISY
Did you 'Refresh Topology' in ISY?
Insteon Camera and ISY
I have my timeout set to 2000ms. I came across the syntax when surfing the net over a year ago. It puzzled me also, but as I recall it's necessary--testing the resource without this specific syntax I think errors out. As an FYI, the Foscam HD cameras DO use the syntax as specified in the CGI User Guide for the HD cameras.
Was just noticing, when using the above syntax, you don't need/perhaps shouldn't have the authorization header. I don't. Also for what it's worth, I have the Encode URL box checked to the right of the path.
You need to put your user id and password in the path with this syntax: /set_alarm.cgi?motion_armed=1&user=xxxxxx&pwd=yyyyyy Where xxxxxx = camera username yyyyyy = camera password I am using network resources to control several Foscam mpeg cameras without problems.
Can't connect to ISY
If you still have it available, the easiest thing to do would be to put your old router back into the system and fire up your network. When you again have access to ISY, change the network setting to automatic (DHCP). When your new router is subsequently installed, you will be able to access ISY and edit its IP address back to a static one recognized by the new router.
I/O Linc control question
luckyp62--I just scanned down and saw your post/question today. Did you get your Floodstop devices communicating with Insteon? If not and if still interested, I can go through how I have my system set up and wired.
Thanks for the info. I have need to use the insteon wireless water sensors to control the Floodstop automated water valve closing products. Output from the I/o linc does in fact activate the Floodstop controller and close the valves. Programming the control of the I/O Linc through the ISY was simple. Thus a simple Insteon wireless water sensing solution for the the Floodstop product.
Can the sensor and/or relay side of an I/O Linc be controlled using an ISY program? Can I send an 'On' or 'Fast On' command to the i/o linc sensor through the program to simulate the sensor being activated as if through a wired sensor input? In a similar light, can I send on 'On', 'Off', etc. command through a program to the i/o linc relay address in ISY to activate any low voltage device I have wired to the output side of the i/o linc?
