Eisy System lost contact with Insteon Devices
@TStephens @joeyISY Did you follow the attached replace PLM procedure Replace PLM Procedure (EISY or POLISY).pdf
Techman started following Audio Player 1.4.0 , Eisy System lost contact with Insteon Devices , eisy-ui Network Resources Tab is blank and 7 others
The network resources is working with the packages you're running. Try doing a power cycle on the eisy
eisy-ui 1.4.18?
Audio player plug-in is crashing, on an almost daily basis, with the current upgrades. The plug-in requires a restart to get it back online
Need to convert to a new set up from ISY994i and PLM
If you want to stay with UD your options are either the eisy-r2 or the eisy lite. UD Store - Universal Devices The 2413S PLM you're currently using is no longer offered by Insteon. The eisy uses the 2413U which is available from Insteon PLM USB Modem Interface | Insteon If you want something real simple check out the Insteon Hub which has a built-in PLM. It requires a annual subscription Insteon Hub 2 Central Controller: App, Alexa and Google Home
Audio Player plug-in fails
@Javi The Audio Player plug-in is crashing every few days. An audio plyer restart brings it back online. The audio player was idle when it stopped. My eisy is running the latest Staging firmware
Looking to upgrade from an ISY99i to the new eisy r2
UD no longer offers the Zwave dongle. You have to use a recommended 3rd party device. The Zooz Zwave works with the eisy. Zooz 800 Series Z-Wave Long Range USB Stick ZST39 LR - The Smartest House
eisy lock ups, failed storage (eMMC) (updated)
I also had a spontaneous reboot a few days ago. I'm on the latest staging firmware
The migration to the eisy requires that your existing firmware must be 4.x or 5.x. If your running 3.x firmware then the migraion isn't possible due to the incompatibility. You'll probably have to build the new system from scratch You should also use a USB PLM with the eisy as it doesn't require a conversion cable
eisy upgrade experience today
Take a look at this link: PG3 continues to run - eisy-ui - Universal Devices Forum
How to add old X10 devices to EISY-UI?
From AI Steps to Add an X10 Device in eisy-ui Log in to eisy-ui. Open a web browser and navigate to http://eisy.local (or access it through your ISY Portal account) and sign in with your portal credentials. Open the Devices / Link Management Menu. Navigate to the Devices management section in the web interface where new Insteon, Z-Wave, and Zigbee devices are added. Select Manual Device Addition. Choose the option to Add an Inste / X10 Device manually (rather than scanning a QR code or starting auto-linking). Enter the Device Name and Type. Give your X10 device a descriptive name and select the X10 device category/type from the device type dropdown list. Input the X10 Address. Enter the combined House Code and Unit Code without spaces or punctuation (for example, enter I9 for House Code I, Unit 9). Save and Test. Confirm to create the node in your device tree, then test turning the device On and Off directly from its tile or device page in eisy-ui. Important Limitations to Keep in Mind Admin Console Fallback. While Universal Devices announced full device-management parity in eisy-ui ahead of retiring the Java Admin Console in December 2026, if an older legacy A10/X10 module type does not appear in your browser dropdown, you can still add it via Link Management > New INSTEON/A10/X10 Device in the IoX Launcher Admin Console.
Verizon email to text is being shutdown.
All the carriers have dropped email to text. There's no text option that I know of. Your choices are email only and push notifications plugins
Take a look at this link for a migration overview Eisy:User Guide - Universal Devices, Inc. Wiki
Audio Player 1.4.0
@Javi With the latest version of the Audio Player I have a few questions What is the procedure to upload MP3 files. Does the upload still have to be in a Zip format Is it possible to view/download and/or modify existing MP3 files that were previously uploaded Can the existing MP3 files be moved to a different directory
Z-Wave nodes ids changed in migration
In the admin console run the topology report which contains the previous data
Insteon motion sensors where are options
Probably best to open a support ticket as there may be a bug in the eisy-ui firmware
