jeffl012
  • Posts
    18
Everything posted by jeffl012
  1. smokegrub, how often do you need to 'reset' (power down/up) the TStats?
  2. There should be no need to run any special programs (ie: set the mode OFF, then ON), to get it to work. Hopefully, SH will continue to work on these issues as to improve an otherwise unique and promising product.
  3. This seems to be a persistent problem with the 2441ZTH. I'm having the same issues with all 3 of my thermostats (firmware v.0E). This is unfortunate as I've invested a lot of time and money into these thermostats with the assumption it would work as well as other Insteon products. Hopefully it will be fixed soon. Using a different product like the Venstar 1800 is not an acceptable workaround.
  4. Yeah, that's what I was thinking too.
  5. Okay. Can anyone recommend a wired motion sensor with a dry contact? I appreciate all of the help.
  6. The sensor is an old Ademco N7941V1 passive infrared motion sensor. (4 wire - 2 for 12v pwr).
  7. The hardwired motion sensor is connected directly to the IOLinc.
  8. I'm looking at the sensor status (not the relay status) in the admin console which isn't corresponding to the what the IOLinc Green LED shows. Only 1.5v comes across the Sense input when the motion detector triggers (indicating motion) otherwise there is no voltage.
  9. No luck with the reset. I have two of these set up and they're exhibiting the same behavior, so I must be doing something wrong.
  10. Yes, it is communicating because when I press the Set button on the IOLinc, the values (on/off) instantly change within the ISY. I have not set up a program yet because I can see that the motion sensor value in the ISY doesn't change when the sensor LED on the IOLinc changes, thus the program would never be triggered. FYI, I have the Motion Relay options set to the "Momentary C" setting
  11. I have a hardwired motion sensor wired to an Insteon I/O Linc GND and Sense inputs. The power for the motion sensor is provided via a separate 12v source. When the motion sensor trips, the I/O Linc sense LED turns off. When there is no motion, the sense LED stays on. This is the desired/expected result. However, I don't see this reflected in the ISY 994i I/O Linc Motion Sensor state. In other words, there is no reaction to the sense input on/off state in the ISY. I'm trying capture that state to trigger lights to turn on/off. What am I doing wrong, or is what I'm trying to do possible with a wired motion sensor and the I/O Linc module.
  12. I recently replaced my Venstar thermostat 2441V adapter. The replacement was sent to me by SmartHome due to the recall that caused the thermostat to sporatically set itself at a random temperature. Now the replacement adapter (v.95) does not work properly with the isy99. The isy seems to only be able to get the status of the tstat and cannot change its settings. Anyone else have this issue? I've updated the isy99 firmware to the latest beta, but it doesnt help. I solved this problem by deleting the thermostats from the ISY99, then added them back in after updating to ISY 3.3.2.
  13. I recently replaced my Venstar thermostat 2441V adapter. The replacement was sent to me by SmartHome due to the recall that caused the thermostat to sporatically set itself at a random temperature. Now the replacement adapter (v.95) does not work properly with the isy99. The isy seems to only be able to get the status of the tstat and cannot change its settings. Anyone else have this issue? I've updated the isy99 firmware to the latest beta, but it doesnt help.
  14. I cannot change the setpoint Heat or Cool on the Venstar Thermostat 2441V - with adapter v.95 (latest). When attempting to change the Thermostat Mode to Auto, the Admin Console reports that it cannot connect to the device. Has anyone else experienced this issue since upgrading to the replacement adapter that SmartHome issued? I solved this problem by deleting the thermostats from the ISY99, then added them back in after updating to ISY 3.3.2.
  • Create New...
