Everything posted by awysocki
Govee Outdoor Lights, Matter Stopped Working
I'm having the same issue with a Tapo TP-Link matter on/off switch. I added it to google, then added it to eISY by share code. It worked for a few weeks then stopped working. I deleted it everywhere and reset the switch. Added it back to google and tried to add it to eISY via share code and it just hangs and doesn't connect anymore. iox finder says I'm at 6.0.4 Don't know what else to try. I was able to share coded and add it to Alexa, Both Alexa and Google can control the on/off switch, but I can't get it to add to eISY.\ Same boat, just different switch.
Zigbee - Device Support Requests
I will second this request. My use is I have a hot water recirculation pump, it would be nice to have a button by the sinks that need it to run to bring hot water up. Today I use "Alexa turn on hot water". But guest don't always understand that, so having a button to press makes it even simpler. I haven't found any other buttons. I have 2 of these, they somewhat connect but the button pressed events don't show up.
UD Mobile loads on Android, then crashes
I called into support. they asked for access into my eISY and then things started working. Don't know what they did, but I'm good.
Matter for Dummies II ?
NEVERMIND, I was trying this on the other side of the house. I just factory reset the switch, added it to google home, got the share pin code, and added it to UD Mobile using the code was standing 5 fee away and after about 45 seconds it added it. I think I shot myself in the foot trying it from the office. I though it was all done via wifi where I think it uses Bluetooth for some of it. I have my switch added
I'm not having much luck, I think I have tried both ways 1) sharing the device by getting the pin code from Google Home, and 2) trying from a factory reset, then adding it in. All using UD Mobile app. I just get errors like Scan already started 500 (OK) or this error. I posted as the image.
Uninstall and reinstall does the same thing. AI says the cloud has a corrupted device listing. Causing the problem, I just didn't know how to clear the cloud
This morning trying to play around with Matter devices and seeing if I could get a device connected. Now when I run the UD MOBILE app. it loads up, I see my devices, then about 2 seconds later I'm looking back at the phone launch screen. What I have tried Uninstalled the UD MOBILE app and reinstalled it. Go thru all the steps and 2 seconds after the display of my devices, it crashes Did a complete interview of my Z-Wave devices from start.jnlp Rebooted my eISY - Pulled the plug Ran Upgrade Packages and did the reboot when it said to. I'm at a loss what else. AI says to do some weird stuff like deleting my profile and adding it back in. Setting up a second device via ip address, but the prompts AI says I should get don't match the UD prompts I see. Everything works from the Java admin screen, just not the UD MOBILE app I'm at 6.04 on eISY 1.5.2 on UD Mobile
Thanks this is clearer to me now. I was trying to do it from the Java Admin page, not the phone app. Sound like this will work when I get my app working again. Seems when I upgraded everything to 6.0.4 UD Mobile crashes. Don't answer here. I'll open a different post. Thanks
Can you or is this explained somewhere? How you would set this up. I just installed a TAPO MATTER switch, Connected it to google home I can connect it to Alexa/Amazon if that is easier. but I don't see how I connect that pipe to UD. From google home I see all the other HA systems but UD wasn't listed. So just trying to understand how to connect Tapo matter switch to UD Thanks
ran upgrade, left over night, next day reboot - DOA
I don't think its my Java cache because my.isy.io also says its down. since the reboot. Right now, Java start.jnlp can't connect, My UD Mobile can not see it. https://my.isy.io says its off line. I've rebooted the eISY a few times now, wait 20 minutes and still its off line. So trying to dig deeper to look at the unix logs to see what isn't running or what is crashing?
I noticed that eISY was updated for a new interface. So I java admin into my machine and clicked on update/upgrade Left the system overnight to do it thing. I know sometimes it can take a few minutes. The next day there was a message on the java admin page that a reboot was needed. To go to system and click on reboot. I did and now its dead. Nothing loads up and I can't get any of my ISY screens to show up. The only good news is that the system does connect to the network and I can ssh in. But I'm lost as to where to look or what to check as to why the system isn't loading. Any logs I should start in on? Thanks
/usr/local/etc/udx.d/static/common/ide (NOT FOUND)
I'm Following along on this page => https://developer.isy.io/docs/getstarted/dev_env going to use VS Code on my windows machine. I'm going to be remote because I can't put a monitor and keyboard on my device -- its in a closet. When I get to step #2 its not finding the IDE script. I've update the eISY to 14.3 and installed the dev packages from the admin screen but when I connect its not finding this script. Thanks Andy
is ZMATTER the same as MATTER
Had to pick up some on/off switches for work. We were using KASA so I picked up some new ones (Kasa KP125M ) They now support MATTER. From my quick read of the forums, ZMATTER is for the support of Zigbee devices that support matter, I'm guessing over the zigbee network. Will my EISY support MATTER over ethernet/WiFi? Will it support the Kasa devices that support matter? Just learning so trying to understand this all.
Does the NVMe post have lots of errors...
👍All is good, Just converted mine. eisy-peisy
At the final prompt Should we answer Y or N?
I was looking at Increase Performance or Add Redundancy? | UD Developer Docs (isy.io) post. I'm not a unix/FreeBSD expert but script doesn't work. It has 2 functions but the starting function is never called It calls the shell script But at the very bottom of the post it says to run the script but uses '.' instead of '_' And LAST.... You can only run this script ONCE if you choose the Performance option but run it many time if you select the Redundancy option??? I don't want to brick my machine.... Thanks
Bond Node Server Assistance
FYI I have a hardwire network where my eISY sits, but my BOND controller is on the wifi side of my network. My network is behind a firewall/router which connects to the WAN. eISY 192.168.1.106 (hardwire) Wifi Router 192.168.1.6 (hardwire) BOND 192.168.86.85 (wireless) I punched a hole though the wifi router so I can access my BOND from the hardwired side setting up port 192.168.1.6 -> 8085 to map to port 192.168.86.85 -> 80 on the wireless side https://192.168.1.6:8085 For anybody else you can put a PORT number on the host name to get thru your wifi router :-)
Power Requirements eISY - Can I use a plugged in Power Bank
Yes, a small UPS is less expensive, but its a space issue I'm trying to solve. So the UPS's I have found are too big for where I want my unit to go. Thanks
My eISY has a USB C connector that supplies power. I don't remember if there is a 12V connector, on it
eISY move from Zooz-700 to ZMATTER
After all said and done, it was pretty easy. I did the migration of Polisy to eISY first, using the same zooz-700 let that run for a couple of weeks. Then this week I did the migration from the zooz-700 to the MATTER usb stick, It was as simple as clicking the Migrate button and READING THE PROMPTS. One is a negative question, where you have to select NO but, I went slow read each page to understand it and it just worked. It seems to have a better radio and switches that use to have issues connecting now connect and work perfectly. Thanks Michael and UD! I'm hoping to forget about my eISY and just live with my connected home, because it just works.
My units at home so I couldn't look and I didn't find the power requirements on the UD web site tech notes. I've had couple of brown outs lately. Looking at some Plugged in Power banks. (eg: https://www.anker.com/products/a1621?variant=37437690052758 ) They both charge and provide battery power. Not knowing the power requirements of the eISY I don't want to underpower the power bank. I think this would be a smaller option than a full blow Uninterruptable power supply. A 10 minute option is all I'm looking for. What wattage on the USB C power cord does eISY require? Thanks Andy
My power went out during the conversion from zooz to ZMATTER
If this doesn't work, I will try to restore method. Thanks
What I found I and what I am doing is I have to now manually on each device, Z-WAVE -> SYNCRONIZE -> UPDATE WITH INTERVIEW and they come back
I was in the middle of the conversion from zooz-700 to a ZMATTER . I was watching the tail -f /var/isy/FILES/LOG/ZWAY.LOG do it stuff when the power went out. It wasn't complete. Now when log into my eISY many of the devices are marked disabled. Is there a way I can restart the conversion from where it left off. This is the first time in ages the power went out. So lesson learned, put the eISY on a U-Power Supply. Any pointers? Thanks
Most of the topics talked about converting from ISY994 to Polisy or eISY which confused me. I wasn't doing a conversion I was just upgrading my Zooz700 to the Matter. It is as simple as just clicking the Migrate button and waiting and waiting till its done. Thanks for the help
