Everything posted by baabm
getting an error when trying to backup using EISY-UI
Thanks - I looked at that page and all the services are running. I then tried another backup and got the same error. I am attaching the log file (the backup is in the last 20 or so lines). ui-current.log
Thanks for the suggestions. Here is my configuration: And we had several power outages today which caused the EISY to reboot a few times - after which the same error occurred when I tried to backup the system.
I get the following error when I try to back up using EISY-UI. I am on the latest versions of all the software.
EISY-UI not ready for prime time
Thank you all for the comments....I was in a hurry to post and didn't include all the pertinent information. 1) When I entered EISY-UI, I was looking for the resource manager, so I went through the hamburger menu and selected each item in it. When I got to "system", I saw that I didn't have the latest software for several modules, so I hit 'update packages", waited for it to complete, and assumed that was all I need to do to get the latest. After reading your comments, I decided to reboot the EISY and TADA, the missing pieces were there. I am now able to modify programs, and I can re-sort them but I do have a question or 2.... 1) I wanted to re-name an existing program and couldn't figure out how to do that. Right clicking on the program brings up a menu but "rename" isn't on it. Is that "missing" or is there another way that I am not aware of? 2) Does EISY-UI only run on a computer (ie, no access from an iPhone of iPad?) 3) If I go to the "settings" menu item, it shows 3 things PG3, portal and display. If I select PG3, it gives me an error "Error: Internal server error", what does this mean? 4) If I go to the "EISY PLUGINS" menu item, there are 3 buttons - ADD, MIGRATE from PG3, REINSTALL ALL and a message saying no plugins are installed. What are we supposed to do with this page? Clicking on MIGRATE gives an "Internal server error". That's it for now...Thanks for the help.
I saw today's announcement saying that the EISY-UI is some 90+ % ready. So I called it up and wanted to edit a program.... 1st problem - the programs come up in some random order that you have to carefully look through to find the one that you want to modify - there is no way to re-sort them by name or any other criteria. I found the one I wanted to edit, clicked on the line I wanted to edit, found the field I wanted to change - it was a fixed number (not in an integer or state variable. I couldn't type directly into the box to change the number, instead a pulldown comes down that allows you to select a new number. The problem was I wanted to change a number from 60000 to 90000. Which took a long time to page down the dropdown list. Then when I went to save the program, it said I had an invalid character in the program name (although it was valid under the ADMIN Console.) So I changed the name and went save the file, and the screen went blank. I re-opened EISY-UI - found the program again - the program name had gone back to the original name. re-did the edit and changed the file name again, and this time it worked. Lastly, I couldn't find how to create or edit a network resource - I see where i can edit a network resource in a program, but not how to create one or edit one outside of a program. When you put out release notes, you should say what new is working, what still is in development, what needs more testing, NOT it's 98% there.
Is Network Resources still supported ?
Thank you both for your suggestions. I tried backing up and reloading the resources but that didn’t fix the issue. I’ll probably write a ticket and also try to use the LIFX plug in which means rewriting every function I use.
I upgraded to v6.1.1 which is supposed to have full implementation of the Admin Console in EISY-UI. After upgrading, I noticed that my LIFX lights don't respond to the program controls that I have set up. I tried to take a look at this today using EISY-UI and I cannot see where there is any way to access the network resources in EISY-UI. So then I started AC and tried to execute some LIFX resource that used to work and now they don't work and some throw errors. So is something broken or is this the new world and I have to rewrite/troubleshoot my network resources. Note that I have loaded the LIFX plugin through PG3 but I decided to stick with network resources because the plugin is limited in its capabilities. TIA for any help. Bob
How do I update to OS 14.4 ????/
Eisy iOX v 6.0.5 FreeBSD eisy 14.3-RELEASE-p9 Sorry all. My bad. I mis-read it. It only pertains to “if your FreeBSD is old.
So I got the email stating that OS14.4 is available and I started going through the checklist...backing up IOX and PG3, ensuring the correct FREEBSD is there, etc. Then I get to the line that says "REFLASH YOUR EISY USING OUR USB STICK". So I click on the link and it takes me to the page where I see that it will cost me $18 (that's not a big deal- except it will probably take at least a week to get to me) but it's 1) out of stock and 2) i also need a terminal and a keyboard and I have neither. So at this point, I am unsure how to proceed. While I am looking forward to the new capabilities of this new release, perhaps it wan't well thought out (like - let's make sure we have enough USB sticks in stock before we announce the release and how can people who have been using EISY headless perform the update). Any help would be appreciated.
application won't be supported on future MACOS
I haven't upgraded to the latest MACOS yet, but today when I went into Admin Console, I got a message on the mac saying that this application won't be supported on future MACOS releases. ( i think it means the JAVA application.) Does anyone have any information on this?
Socket Timeout & UDM Sync issues
I restarted my modem and my router, then I rebooted my EISY and am still getting the same issue with synchronization. It gets a little past "programs", then bombs out with a message that disappears so quickly, I cannot read it. Then I noticed that my caseta devices weren't working using UDM, so I opened the PG3 server and Admin Console on my mac. I got at least one instance of the socket error on AC while trying to figure out what was happening. I then reloaded the caseta plugin and it started working. I retried the sync and it still didn't work. Any ideas?
- Fixed warning for upgrade to 14.x <br/> ************ IoX ************ isy-6.0.3_3 Name : isy Version : 6.0.3_3 Installed on : Sat Dec 13 08:30:25 2025 EST Origin : misc/isy Architecture : FreeBSD:14:amd64 Prefix : /usr/local Categories : misc Licenses : Maintainer : michel@universal-devices.com WWW : UNKNOWN Comment : ISY Port to X (IoX) Sh
I just finishing upgrading and am also receiving the socket timeout error. The upgrade seemed to complete correctly, but after the reboot, I had trouble restarting PG3, but eventually got it to start. In addition, when I use the UDM interface on my iphone, when I try to synchronize to the EISY, it starts, gets to the programs step, starts the next phase and stops. It never gets to the end where it displays the number of unused items, where it asks if you want to backup and then delete them. So I am not sure if that functionality has changed or if its not working.
Questions after update to IoX v.6.0.0
I think my issue resolved itself...I found that I had stored 2 different instances of my.isy.io in my password manager - each with a different password. I was able to log in to the Admin console using one of them... My question now is ' Should I still be using Admin Console or is there something else that I should be using?" thanks
After what I think was a successful update to 6.0 (I am able to see the status and control devices via the mobile app on my phone.) But I was only able to log into the admin console using my portal ID and password one time (but it didn't show me any of my devices or programs). So I rebooted the EISY, am still able to see and control devices on my phone, but still can't log in to the admin console - I get the same error as AKAPADIA and polo2883 above.
Need help with LIFX plugin
I finally figured out how to add my LIFX Z-strips nd bulbs to the plugin, but now am having trouble controlling them with a program. As a simple example, the LIFX API says that brightness is a (decimal) number from 0.0 to 0.9, and color (hue) is an integer between 0 and 360. but the program allows entries of 0-32767 for brightness and 0-32767 for color. Michel says that the interface is designed to only show acceptable values, but I don't understand how 0-32767 maps too either 0.0-0.9 or 0 to 360. Any help would be appreciated. thanks
I cannot find any information on how to use the LIFX plugin. I am currently controlling my LIFX lights using the old networking resources, but would like to use the plugin. I only have a few LIFX lights but can't see how to add them to the plug in. Any help would be appreciated. Thanks
red exclamation point next to the telegram service device in Admin console
I’m using about a half dozen notifications through the notification node server and they seem to work fine with my iphone. At this point, I’m not sure if there is any value in trying to implement telegram (or even pushover).
Thanks for the response, but if you read further in the post, I managed to remove the telegram service- but I’m not sure how I did it. thanks
Need help getting LIFX node server to run
I have installed the LIFX node server from the PG3x plugin store. I have it in slot 3. I have tried to follow the instructions in https://lifx-nodeserver.readthedocs.io/en/latest/usage.html#how-to-use but this seems to be focused on downloading from GITHUB and not loading it from the plugin store. I have also read through anything I could find in the forum and I couldn't find anything in the wiki. to Anyway, when I go into POLYGLOT, and look at the LIFX node, it says that it is DISCONNECTED. I can't seem to find any way get it connected. Any help would be appreciated.
UD mobile synchronization doesn't complete
Thanks for the explanation re: the multi function button. I never actually use that to cycle the power, I essentially disconnect it from power and reconnect it. This “seemed” to have less impact on the system as using the admin console to reboot. After the power cycle, the EISY simply restarted. But after the reboot, I got a message saying the system has been updated- which seems like more activity to me.
More info: I had cycled power before my initial writeup. I didn't realize that a reboot (from the admin console) is a different animal, so I did that today. It still hangs up in network resources. I don't know when this issue started but I had switched over to EISY a few months ago and set up UDMobile at that time and had done several synchronizations while setting up UDM. I have made a few recent changes to my network resources in order to utilize the notification node server, but I think I saved everything I changed. I'll try to save them all again.
I have an ISY portal account, but cannot find where to open a ticket.
I have been trying to run the synchronization of my UD mobile to the EISY and it starts off OK, syncing a bunch of stuff including programs and "optional", but when it gets to "Getting Network Resource files from ISY", it hangs up and never completes. I tried letting it run overnight last night and it never completed. I'd like to make sure that UDM and the EISY are synchronized before I go on a trip. Thanks, Bob M
After I wrote the note above, I decided to look around at the PG3 page. there I found that I had 3 nodes, so I clicked on it to discover 1 of them was the Telegram node and there was an x icon next to it. I clicked on the x and it started to delete the telegram node. I restarted Admin console and it was gone...
