noobmuch
Everything posted by noobmuch
  1. I am not sure why, but after using Brave instead of safari, I was able to see all of my nodes. Then trying again in safari and the nodes populated. Strange As far as the admin console goes, nothing has populated anything when logging into the LAN. Even on the config tag system settings, all entries are blank. I did log into the cloud option and was able to see my system. I am thinking this is due to the RAM limitations of the polisy, so my options i guess are use the cloud to get admin console or buy an EISY. I was waiting for some of the more tech savvy among us to share their insights before i decide what to do.
  2. Logging in with Brave fixed my nodes 404 error that I was having with Safari.
  3. My experience: nodes 404 error - reinstalling plugins no joy Integer Variables 500 error programs populate Admin console sees Polisy and shows version 6.0 Login via admin console nothing populates. System busy/open folder icon in bottom left corner power cycle Polisy no changes
  4. Were you about to log into admin console? If so was your system visible ?
  5. Hi, From the home page I used the menu button in top left corner then settings then plug ins
  6. I have this same issue, however reinstalling all plugins did not resolve the problem
  7. After logging into admin console, everything would just freeze as in pic related. I just did the update and that has since resolved the issue. Thanks for getting back to me.
  8. I can log into admin console but have no remote access. "ISY Offline"
  9. I am not sure if I selected that option, but when I look at network resources, they are all still there.
  10. I was able to get my Sonos going and it sees all zones now. I can not yet get the itch to load the parameters. Can someone clue me in on Node address vs primary node address?
  11. Hi, Looking for video tutorials for how to get the parameters of the nodes to populate in the admin console. Since the initial upgrade to Polisy, I have lost all of the functionality of my network resources that controlled my Sonos and itach. I am able to get the nodes via polyglot 3x and see them on the admin console screen, but am struggling to get the fields to populate when I click on the nodes. Any help is appreciated.
  12. Hi, It occurred tome that for all of us having Insteon devices that fail with time that are linked to other devices, there could be a "replace existing product" option that took a non responsive ID from one product and gave all of its attributes to the same product so you dont have to rewire all of the programs, links etc, I know there used to be a copy attributes option. I thought that went away with an update, but I am not the most prolific user or follower or programmer type If there is an easy button for this, someone please spare me the long way. Thanks for any input in advance.
  13. I would think they could do a preorder/deposit to see what their demand is on certain products right out of the gate. I am sure others also have a few things then would like to add or replace. This could allow them to let the market decide what to make so the have more accurate forecasts. There would need to be a refund mechanism if the decide there is not enough demand to do a production run to avoid us from providing interest free loans. This could also provide some quick capitol upfront to offset their burn rate until they have money coming and products going out.
  14. ok. I may be using the wrong nomenclature. Micheal, rather patiently, walked me through my setup not too long ago. I have not eliminated my Isy yet and still use it and the polisy and they communicate as I have some of the plugins that I installed on poliSy that show up on my admin controls of the ISY. If that makes sense. So my question then is should I migrate the ISY to the polisy and disconnect the ISY, if I understand you.
  15. My Isy is connected to the PLM and the polisy is just plugged into a switch.
  16. I started doing as Javi has done an apply a static IP on the router end and device end. Aside from Sonos everything lets my assign static Ip on the device also so it saves some frustration downstream after you get everything in place.
  17. itach is who I was thinking of. I was really hoping to be able to do this through the polisy or the Pi as I own them already but have been considering an Itach previously for a long time to solve this issue. The argument in my mind has always been why not dump that 100+ into a new receiver without a need for a work around. Knowing full well I would repurpose the old receiver again and start the cycle over. Thanks everyone.
  18. I have a 2134s that is linked to my ISY but not physically connected to my Polisy if that answers your question. Thanks for responding also. I don't know if harmony bought the company that had inline Ethernet, wired and wireless with either IR blaster out or serial out. I can't find them online line now they were yellow for wireless and red for wired I believe
  19. I have an old Denon 3805 I would like to be able to turn on and off and maybe use volume controls if possible. I also have a Pi with home bridge I could use but was looking for the path of least resistance. Any help is appreciated.
  20. noobmuch replied to KenUD2's topic in UD Mobile
    Hi, Thanks for getting back so quick. I stepped out and now it seems to work. I did an an access point that I think may be not quite as integrated as it should for full functionality but I haven't got to it yet as I am adding another AP today and will address both at once. cheers, Rick
  21. noobmuch replied to KenUD2's topic in UD Mobile
    Hi, My app sees the Isy portal, everything appears to load. then when I go to use the home button to sync I get error could not get system id
  22. No, sorry I told you wrong. I didn't remember correctly. There are traveler lines but no neutral at least in one box. I pulled that switch to see. The other had a traveler but was wired incorrectly so it is dependent on the upstream switch. I would have to find the light where the power comes in and repurpose a line to make a functional neutral then just use the standard 2477D switch. Prior to your response I realized what youre saying about the downstream switch not getting power to function correctly. Thank you Brian for helping me sort this out. I was going off memory and now I have 2@2474 switches I need to return. And still need to find the light where the power comes in.
  23. One of my outlets doesn't have a traveler so it's not a true three way. Its been a couple years since I messed with them and I struggled for a few days trying to get standard 3 way switches to work. I think the second switch location is an ad hoc afterthought.
  24. 2474DWH is the model. I know I can make them controllers for each other. I guess I need to find the upstream hot and put the load on that and cap the red wire in the downstream is my thinking, but I can see having the downstream switch with the load wired also. I guess the scene will be doing the work in either configuration if I understand this correctly
  25. I was going to install Insteon 2 wire switches
