Everything posted by maxnorth
Spontaneous garage remote lockout
In my case, I already had a single wire into the Liftmaster, from the Ratdgo. the 880LM was wired into the Ratdgo in pass through mode. My problem was false, spontaneous "lock" signals. This was confirmed because the 800LM would display "locked." The question is whether the spurious lock signal came from the 880LM, which is 12 years old, or the ratdgo itself. I disconnected the 880LM completely. At this point, I only have the ratdgo and wireless remotes communicating with my Liftmaster. It's been four days and I have not had a recurrence of the problem. My plan for now is to live with only wireless remotes plus the ratdgo. It that proves to be a problem, I'll install a new wired controller in pass through mode to the ratdgo. I am tossing the old 880LM. I am also trying to add the ratdgo "lock" control to my Home Assistant instance, but am having some difficulty. I can see the control in the ratdgo ESPHome instance and control it from my HA dashboard, but when I add it to HomeKit, it does not appear in HomeKit.
I seem to be experiencing this same symptom now. As a test, I have disconnected my 880LM completely and will see what happens. Did you ever track down a diagnosis or solution @SHM ?
Not Seeing elk-m1 zone status
My recollection is that the IP for the M1xep is set in the Elk settings. I use ElkRP software for that. It is located in the Account Details tab.
.yaml file location
# Store in /usr/home/admin/ # No SSH required, Command to copy file FROM cd current directory (e.g., Mac desktop) to eisy # Replace with your own IP and user name and dev file name scp 2025-10-10-devfile.yaml admin@10.20.30.xxx:/usr/home/admin/
Programming help please
I believe the best approach is to create a scene including your relay. Then use programs to have the scene turned on and off (including by the KPL). For the light on the KPL button, that is another story. Create another scene including the KPL button. In the program controlling the relay, add an entry to turn off the KPL button scene when the relay is turned off.
Elk node issues recently
I, too, would like to know if there is anything in process to fix the Elk problems related to the upgrade. I am holding off on the upgrade to 6/7 until this is more stable. I am unclear if this is a node server issue or something else. Clarification on that would be helpful.
Protection Against Device Failures
I don't live in an area affected by lightening, but we do have periodic power outages during the winter months. I had several Insteon devices fried during outages like this. After installing a single whole house suppressor, I have not had any.
Time server for Elk M1XEP
I have used darwin.kenyonralph.com successfully.
Sonoff S31POW polling interval
Ah, yes, "TelePeriod 20" does in fact set this to 20 seconds. Nice to be able to set this on a per-device basis! Thank you!
I am wanting to work with the power readings thrown off by the S31POW. I notice that polyglot seems to retrieve these readings using some sort of polling. They only update every three minutes (per the log). Not very helpful when you have an application needing more frequent readings. The Sonoff itself updates immediately, it's just that Polyglot does not get the updates promptly. Is there a setting somewhere that this can be changed?
MQTT message payloads
You don't really send commands to sensors. Here is a screenshot from a Tasmota device console for a switch. If you have a more specific question, let us know. In this case my "status topic" configured in Polyglot is "stat/sSlamphC/POWER"
Room Off button
I always use a program to control the LED status, and I have the button set to non-toggle off. Pressing the button turns everything off.
Sonoff TH Origin (16A) with THS01 (SI7021) sensor
To answer my own question, the correct type to use is "TempHumid." This is working now. It might be helpful to update the configuration help to list the SI7201 sensor as an acceptable sensor for TempHumid.
Find the MQTT Broker
I believe that if you then want to set up the S31 as a switch, you would create a second device for that, using "switch" type.
I can't figure out what node server yaml entry to use for this setup. I tried the types "analog" and "Temp", but the resulting node device does not show any temps. My tasmota config identifies the Sonoff THS01 temp/humid sensor as a SI7021, and that config is working fine in the Tasmota web setup. It show readings. I am using "SI7021" in the node server as the sensor ID. From the Tasmota web console: "18:08:48.992 MQT: tele/sSonoff_THR316/SENSOR = {"Time":"2025-05-18T18:08:48","SI7021":{"Temperature":68.7,"Humidity":51.3,"DewPoint":50.0},"TempUnit":"F"} I also have a "switch" device for the TH Origin. It is working fine in the node server and the switch device appears in order after the sensor device. Below is an example: - id: "sSonoff_THR316Sens" type: "Temp" name: "AtticSwTemp_145" sensor_id: "SI7021" status_topic: "tele/sSonoff_THR316/SENSOR" cmd_topic: "cmnd/sSonoff_THR316/power" - id: "sSonoff_THR316" type: "switch" name: "AtticSw_145" status_topic: "stat/sSonoff_THR316/POWER" cmd_topic: "cmnd/sSonoff_THR316/power"
I seem to recall there was a problem in not being able to see the config help screen for the plugin unless you enter some data first. Not sure if that was fixed. In any case: https://github.com/Trilife/udi-mqtt-pg3x/blob/0.40/POLYGLOT_CONFIG.md
Install the MQTT nodeserver from the plugins store on the PG3 home page, by trilife. Note that they do not necessarily appear in alphabetical order in the store.
Help with RatGDO as scene controller / responder?
I finally installed my RatGDO and faced a similar problem. Here is my experience. If you just want your KPL light to come on when the door is open and off when closed, simply create a scene with the RatGDO and the KPLs involved, and it should just work. If your KPL is set to "toggle" mode, when the toggle sends an "on" the door will open and the KPL light will come on. When it sends an "off" the door will close and the light will go off. In this scenario, you should not use a separate scene to control the LED, because your door will no longer work properly if the off/on status of the KPL gets out of sync with the actual door status. In my case (previous IO Linc user), I have always had my LED set to be on when the door is closed. That provides me positive confirmation that the door is actually closed, whereas no light does not. I have three KPLs with garage door buttons. So, how to do this? I do not put the RatGDO and KPLs in a scene together. The method I used was to set my KPL buttons to non-toggle (on). So, every press sends an "on". I created a program that says anytime a button "on" is received, "toggle" the RatGDO. This program is dumb -- it does not care about door status. Then, to control the LEDs I created a scene containing only my KPL buttons. I created two programs. When RatGDO door status is closed, turn the scene on (the LEDs turn on but no command is sent to the RatGDO). When door status is open, turn the scene off. This seems to work perfectly fine. This is not needed if you are content with having the LED on when the door is open.
Plugin (Node) Not Available for a Program
This happened to me with the Tasmota node server at one point, and the developer fixed the node server.
ratgdo Reliability
I currently have a contact sensor to detect the garage door position, with the IO Linc. Is it true that with Security + 2.0, I no longer need that? The door position is signaled by the control board on the opener?
ratgdo Reliability
I am considering switching to the ratdgo from Insteon IO Linc for reliability reasons. I am tired of having my garage door open by itself, due to "all on" events or other reasons. I currently have a lock out on my IO Linc that I activate when out of town, but that is not enough. My question is whether users have been satisfied with the reliability of the ratdgo from a security perspective. I have an eisy, Home Assistant/ESPHome, and HomeKit integration. I could just use HA with the ratdgo if introducing the node server would increase security concerns. But using the node server in addition would make program development easier. Are people using electronic lockouts with the ratdgo? Thoughts?
Human Presence Sensors
If you can use the Home Assistant to ISY integration and ESP Home, Apollo MSR-2 presence sensor. Uses a LD2410B mmWave board. Radar. Very sensitive and very configurable. It completely solves all of my presence issues. Also has an issue with false positives, so it is best used for "off" programs only, not "on." You can also build your own using a C3Mini ESP-32 board.
Strange upgrade "Warning" prompt in Admin
Same behavior here, although I am on 5.8.4.
Control eisy with Siri using Synology server hosting Home Assistant or Homebridge
You have a choice on Synology (depending on your model) of using Docker or the Synology Virtual Machine Manager (VMM). The former is quicker and easier to install, but more laborious to update over time. The latter is harder to install but will give you access to all the features of the Home Assistant Operating System over time. (HA is improving its own voice control capability, by the way).
I believe the basic approach for controlling KPL LEDs is to create another scene with only the LED in it. Then create a program that will turn that scene on or off. When the garage door is open, run the program to turn the LED on. When closed, off. (fwiw, I have mine set to turn the light on when the door is closed. It's sort of a failsafe so I know it is working properly.)
