Everything posted by maxnorth
Preparing for AI: Data Dictionary
It occurred to me that to make AI work on top of the eisy ecosystem, there really needs to be a data dictionary that is fully legible to the LLM. It needs to be able to determine what each device does, what sensor readings mean, etc. While most of us have friendly folder and device naming structures, that will not be enough for semantic systems to shine. I spent some time with AI interrogating a full backup, and the AI could certainly parse that to create a low level dictionary. But it can't tell how the parts all relate. It needs more. The last thing we want is to be forced to create a separate semantic overlay to provide this information, but there is a gap currently. In other words, there is no way I know of to add the needed semantic context within the existing UDI interfaces. I asked the AI whether the low level parsing was enough, and here's what it said: "You've hit on the most critical challenge in home automation AI integration: the Semantic Gap. Raw backup files give the LLM syntax and structure, but not semantic meaning or intent. While iGarDoorState hints at its purpose, the LLM won't reliably know: Value Mapping (Enums): Is 0 = Closed, 1 = Open, 2 = Opening, or 3 = Fault? Physical Context: Which bay of the garage does this track? Is it a tilt sensor, contact sensor, or smart door opener? Behavioral Intent: Why does iKitchenStairsOffReset exist? (e.g., "Latches to prevent stair motion sensors from turning off lights while someone is cooking"). Cryptic Names: What do abbreviations like 1.KitchCookingKPL.H.All Off or G.GarZWkRmMotion.Tamper Alarm mean? How to Bridge the Semantic GapTo make your eisy system fully legible to an LLM, you need a Two-Tier Data Dictionary: [ Tier 1: Auto-Extracted Telemetry ] [ Tier 2: Human Semantic Overlay ]- Variable & Node IDs - Value Enums (0=Closed, 1=Open) - Current & Initial Values - Physical Location & Area - Program Cross-References (If/Then) - Plain-English Purpose & Intent \ / v v [ LLM-Optimized Data Dictionary (JSON/YAML) ] _____________ It goes on to suggest the creation of a YAML/JSON overlay containing richer descriptions. And suggests a python tool that would build the file and pre-populate it for easy editing. Here is an example of the json for a couple of variables. variables: integer: iGarDoorState: id: 7 current_val: 0 type: "integer" description: "Tracks the physical open/closed state of the main garage overhead door." values: 0: "Closed" 1: "Open" 2: "Opening / In Motion" used_by_programs: - "Garage Door Opening Alert" - "Auto Close Garage At Night" associated_nodes: - "G.GarageMainSensorZSE70" state: sDark: id: 1 current_val: 1 type: "state" description: "Global environmental state flag indicating ambient darkness (between sunset and sunrise or heavy cloud cover)." values: 0: "Daylight" 1: "Dark / Night" triggers_automation: true In my view, it makes a lot more sense for UDI to build this semantic capability into the native tool. Thoughts anyone?
EISY not running program after upgrade
if you haven't already, I'd suggest editing the program, selecting "sunset" again, clicking update and then saving the program. Some of my triggers stopped working after the upgrade, but this seemed to fix them.
Sunset of Java Admin Console is Premature
For eisy-ui, it appears that the user-selected sort order for devices and programs is "sticky," meaning that it is saved between sessions. But this is not the case for variables. It would be nice to have that. Also, there needs to be some ability to sort notification templates, or at least have them sorted by default by name.
Ubiquity UniFi and EISY
Not sure I understand the issue. There is no functionality to worry about with network equipment or access points. Cameras? They have IP addresses and can be integrated just like anything else. (I also use Unify Controller). I have not attempted to get cameras into eisy because I do not use it as an interface. I have, however, used the scrypted plugin to add my cameras to HomeKit, which is where I view them. Meantime, they are also recording to my Synology NAS. I'm sure they could be added to HA, but I don't need that. So, what, exactly is the problem you are trying to solve.
portal not working after upgrade to v.6.0.5
For starters, I would at least restart it and make sure it is performing normally. Mine is working fine now with Pi-Hole running.
Hopefully final update: Safari now has a portal tab after logging out and back in. According to Benoit, certain features are disabled in eisy-ui when there is no internet access. I guess that means they disappear completely from the UI, which is a bit confusing. So, now that my portal access is restored, the feature is back, but it required a logout.
Update: The portal page shows in Chrome, but not Safari.
Here is how this resolved for me. At first, they wanted me to disable IPv6 on my router (it was never enabled, so not the issue). Did a long remote session with Benoit, who was very helpful. Noticed slowness from the eisy in web calls. Calls to the portal continued to fail even after extending the retry to 20 seconds. Did a bunch of diagnosis via SSH. Thought there might be DNS issues. I decided to take a look at my Pi-Hole instance on my NAS. It was hung. I stopped the docker container for that and the portal instantly started working. Restarted Pi-Hole and it still works. So, that being hung was the issue. No, I still do not have a portal tab in eisy-ui. I will have to focus on that another day. Thanks for the input, everyone.
Interesting. I'm not sure what to make of the IPv6 comment. I have never had IPv6 addresses on my network. My portal connection broke spontaneously on 5/2 when I was doing nothing on the system. I find it very odd that neither us has a "portal" page in eisy UI Settings. To me, that seems like a failed upgrade. I did just notice that the Configuration->Network Settings are grayed out on my Admin Console. DHCP is checked, but it is grayed out and nothing can be changed. I don't recall if that is normal after initial setup, but it does not seem right. I've got a ticket in and will report back.
I have the exact same problem (on an eisy). What was the resolution @someguy ?
Spontaneous garage remote lockout
In my case, I already had a single wire into the Liftmaster, from the Ratdgo. the 880LM was wired into the Ratdgo in pass through mode. My problem was false, spontaneous "lock" signals. This was confirmed because the 800LM would display "locked." The question is whether the spurious lock signal came from the 880LM, which is 12 years old, or the ratdgo itself. I disconnected the 880LM completely. At this point, I only have the ratdgo and wireless remotes communicating with my Liftmaster. It's been four days and I have not had a recurrence of the problem. My plan for now is to live with only wireless remotes plus the ratdgo. It that proves to be a problem, I'll install a new wired controller in pass through mode to the ratdgo. I am tossing the old 880LM. I am also trying to add the ratdgo "lock" control to my Home Assistant instance, but am having some difficulty. I can see the control in the ratdgo ESPHome instance and control it from my HA dashboard, but when I add it to HomeKit, it does not appear in HomeKit.
I seem to be experiencing this same symptom now. As a test, I have disconnected my 880LM completely and will see what happens. Did you ever track down a diagnosis or solution @SHM ?
Not Seeing elk-m1 zone status
My recollection is that the IP for the M1xep is set in the Elk settings. I use ElkRP software for that. It is located in the Account Details tab.
.yaml file location
# Store in /usr/home/admin/ # No SSH required, Command to copy file FROM cd current directory (e.g., Mac desktop) to eisy # Replace with your own IP and user name and dev file name scp 2025-10-10-devfile.yaml admin@10.20.30.xxx:/usr/home/admin/
Programming help please
I believe the best approach is to create a scene including your relay. Then use programs to have the scene turned on and off (including by the KPL). For the light on the KPL button, that is another story. Create another scene including the KPL button. In the program controlling the relay, add an entry to turn off the KPL button scene when the relay is turned off.
Elk node issues recently
I, too, would like to know if there is anything in process to fix the Elk problems related to the upgrade. I am holding off on the upgrade to 6/7 until this is more stable. I am unclear if this is a node server issue or something else. Clarification on that would be helpful.
Protection Against Device Failures
I don't live in an area affected by lightening, but we do have periodic power outages during the winter months. I had several Insteon devices fried during outages like this. After installing a single whole house suppressor, I have not had any.
Time server for Elk M1XEP
I have used darwin.kenyonralph.com successfully.
Sonoff S31POW polling interval
Ah, yes, "TelePeriod 20" does in fact set this to 20 seconds. Nice to be able to set this on a per-device basis! Thank you!
I am wanting to work with the power readings thrown off by the S31POW. I notice that polyglot seems to retrieve these readings using some sort of polling. They only update every three minutes (per the log). Not very helpful when you have an application needing more frequent readings. The Sonoff itself updates immediately, it's just that Polyglot does not get the updates promptly. Is there a setting somewhere that this can be changed?
MQTT message payloads
You don't really send commands to sensors. Here is a screenshot from a Tasmota device console for a switch. If you have a more specific question, let us know. In this case my "status topic" configured in Polyglot is "stat/sSlamphC/POWER"
Room Off button
I always use a program to control the LED status, and I have the button set to non-toggle off. Pressing the button turns everything off.
Sonoff TH Origin (16A) with THS01 (SI7021) sensor
To answer my own question, the correct type to use is "TempHumid." This is working now. It might be helpful to update the configuration help to list the SI7201 sensor as an acceptable sensor for TempHumid.
Find the MQTT Broker
I believe that if you then want to set up the S31 as a switch, you would create a second device for that, using "switch" type.
I can't figure out what node server yaml entry to use for this setup. I tried the types "analog" and "Temp", but the resulting node device does not show any temps. My tasmota config identifies the Sonoff THS01 temp/humid sensor as a SI7021, and that config is working fine in the Tasmota web setup. It show readings. I am using "SI7021" in the node server as the sensor ID. From the Tasmota web console: "18:08:48.992 MQT: tele/sSonoff_THR316/SENSOR = {"Time":"2025-05-18T18:08:48","SI7021":{"Temperature":68.7,"Humidity":51.3,"DewPoint":50.0},"TempUnit":"F"} I also have a "switch" device for the TH Origin. It is working fine in the node server and the switch device appears in order after the sensor device. Below is an example: - id: "sSonoff_THR316Sens" type: "Temp" name: "AtticSwTemp_145" sensor_id: "SI7021" status_topic: "tele/sSonoff_THR316/SENSOR" cmd_topic: "cmnd/sSonoff_THR316/power" - id: "sSonoff_THR316" type: "switch" name: "AtticSw_145" status_topic: "stat/sSonoff_THR316/POWER" cmd_topic: "cmnd/sSonoff_THR316/power"
