drprm1
  1. Looks like Ring received actual motion webhooks but Rachio failed Rachio-log-2026-11-07T02-45-27.034Z.zip
  2. Sorry I don’t see a “test”button.
  3. No incoming event seen when recording was confirmed via Ring app
  4. I made sure PG3 remote access was available, configured, and active in portal. I reconfigured PG3 remote access and rebooted Eisy. Restarted Rachio with same error. In logs webhook test still failed despite general portal connectivity.
  5. Having kind of same issue but mine returns 503 error than 408
  6. Believe you’re looking at “system” rather than “setting” which is right above system
  7. Any dry or project box that will hold it.
  8. Used a couple of these mounted in a small dry box. Worked well for long time. Replaced with YoLink outdoor contact sensors after they failed. YoLink devices are great.
  9. drprm1 replied to Panda88's topic in YoLink
    That’s it. Thanks
  10. drprm1 replied to Panda88's topic in YoLink
    Here's the log. Also just curious as to why the number of nodes showing on dashboard went up, in my case, by nearly ten? YoLink_5-14-2026_24829_PM.zip
  11. drprm1 replied to Panda88's topic in YoLink
    Tried changing the programs to status yesterday and programs still didn’t respond so changed back to control. This morning I changed all my motion sensors command to ON/OFF and everything is working for the time being. Let me know if/when you need to test Again appreciate the help
  12. drprm1 replied to Panda88's topic in YoLink
    Appreciate all your help. I have over 60 Yolink devices and they work great. Last year replaced all my Insteon motion sensors with Yolink in an effort to quell the occasional ALL ON episode which still affects my older Insteon switches.Hope this gets resolved as one of my new motion sensors controls lights on some steps I frequent in the night….before I break my neck. 😂
  13. drprm1 replied to Panda88's topic in YoLink
    I’ve tried to see what is different and why these aren’t working. All these devices look like they have their command settings set to ON ONLY. All the programs they are in look for “if control X is switched on” then the programs are ran….These are also all motion sensors Problem is I have one motion sensor whose program works correctly. 🤷🏻 Edit: I changed a couple of the motion sensors command settings to ON/OFF and they appear to be working correctly….I’ll send a new log later if it will help you pick up any differences. Thanks again!
  14. drprm1 replied to Panda88's topic in YoLink
    Did all that you suggested unfortunately no change (Don’t know why none of my Zwave devices were functional after the update but after a few hours they have all come back on line and are functional now.)
  15. drprm1 replied to Panda88's topic in YoLink
    I updated everything and reinstalled Yolink plugin with no change. I mentioned that my programs using Yolink sensors weren’t firing. I appears that it is only programs using Yolink motion sensors which are evaluated using “control”. If I change this to “status” the program runs. In scenes where the Yolink device is the controller nothing happens either. (Door sensors work fine in this capacity) I can see in the AC that the status is changing just not responding correctly to “control” in the if statement….(Way over my head as to why) Appreciate the help!
