ccclapp
Everything posted by ccclapp
  1. Hi I have done testing on this as suggested by @Geddy and @gdntx ... for the advanced settings shown on the "FLAG" tab of the i3 dial dimmer, one must press/click the label in on the left eg Mode, Program Lock etc. and each must be pressed individually after changing the desired value in the right column. Dont know if it matters but I then also pressed write changes after all settings were set. I then did a reboot of eisy and then after doing Query on the device, all values stick and correctly show. Also, it has been hard to find info on what each value does/means. With some AI research I find the following... It was especially hard to find info on the Relay at Full On setting...interesting Hope others find this useful. Thanks for the help.
  2. Fair point. since I am doing configurations for a whole house now it's very helpful to see the actual specifications so I will put in a ticket on this just for final clarification. Thanks
  3. Hi geddy or others I'm just trying to clarify the question above of of whether whether the insteon device properties actual settings will be visible in the eisy admin panel because if not I don't know how anyone is able to do meaningfully use insteon devices. is anyone able to clarify this? Thanks very much
  4. Ok, this is crazy! If I understand correctly we have no way of seeing what settings we have applied to the devices. If so, this might be enough to abandon ISY/EISY. How can this be, that is a base level requirement (to know what settings you have on your devices.
  5. Hi thanks for your help. I will look at this more carefully when I return to that location next week. I appreciate it thanks
  6. ...Update,,, Interestingly, using the UD App on my phone, I have changed Mode from Dimmer to Relay. However does not work on the Admin Console. I am connected locally with both.
  7. HI I just setup a new EISY Home in a new location. I updated to firmware and UI version IoX v.6.0.3. After adding multiple i3 Dials, when I try to make any changes, eg, ramp rate , on level, or mode from dimmer to relay, nothing gets updated on the device. I have tries multiple times and rebooted EISY. Each time I click Write Changes button and/or right click to Write Updates to Device. WHen I do this, event viewer shows no communication. When I querry device, the settings revert back to default. How do I resolve this? Have others had issues with the i3 devices? Do I need to revert to manual device programming or use the Insteon controller outside of ISY? Note, before adding to EISY, I factory reset the devices via air gap etc. Any wisdom on this? Thanks
  8. Hi I am testing zooz Zen72 smart dimmer. This is designed to control scenes/devices via 2, 3, 4, 5, up/down presses. I have set zwave parameter #13 to 1 per... https://www.support.getzooz.com/kb/article/538-zen72-dimmer-switch-700-advanced-settings/#:~:text=Parameter 13%3A Enable or disable,for quick double tap triggers. However in eisy I do not see these are triggers in programs, not as possible controllers in scenes. eisy simply brings in the dimmer as a single device/node/entity Does isy not support this functionality? Thanks
  9. Thanks. This is working for some programs but not for others. There is no apparent reason, all are simple working programs.
  10. Ok, this is strange, some programs do copy via r-click->copy. But some dont???
  11. Hi Sorry for my basic question but I have searched wiki and forum and can not remember how to copy/duplicate a program. I just want to duplicate an existing program so I can make some edits for testing. I see right-click -> copy but no paste and nothing happens when I just do copy. I am on latest firmware on an eisy after migrating from 994 Thanks
  12. HI Thanks Darn,I was hoping to avoid this, as many scenes x many brightness levels = too many I regularly dim/brighten a given scene from a KP button and its not really time or event specific to automate. Thanks for the clarification
  13. Hi Quick question: Are scenes dimmable or can you specify the brightness level of scenes on the Amazon or Google assistant integrations Thanks
  14. I just connected my 1st zigbee test device. Its a "Third Reality" "Smart Plug GEN2" www.3reality.com, bought on aamazon for about $10 (4pack for $38) https://www.amazon.com/gp/product/B0BPY5D1KC/ref=ppx_yo_dt_b_asin_title_o04_s04?ie=UTF8&psc=1 THIRDREALITY ZigBee Smart Plug 4 Pack with Real-time Energy Monitoring,15A Outlet, Zigbee Repeater,ETL Certified,ZigBee Hub Required,Work with Home Assistant,Compatible Echo Devices and SmartThings It was very quickly found/added to eisy. It has a single device field listed and functioning as an on/off switch. It is supposed to report poser/energy use, but does not on eisy. I have not tried it elsewhere. Thanks
  15. Hi , apologize in advance if this is an obvious question I should know the answer to... but I don't I just received my eisy and the z matter stick (I was previously on an ISY). I had assumed they're already was zigbee broad support as I thought that's what that stick was for. am I mistaken and only just now we starting to get zigby support? a simple clarification would be helpful Thanks
  16. Guys: It shouldn't be this difficult! Why cant we simply enter the ISY IP address in our browsers and log into the device interface, as we can with EVERY other network device. The comment was made above that these problems are rare. I don't think that's correct. More likely people are accustomed to a certain amount of head-banging to get set up or re-set up as this is a DYI device and users. We could start a poll on that question
  17. HI All of this is the point I was trying to make in this thread (which has now been closed by UD)... Eventually we all solve the problems, but often after hours of knocking our heads against the wall. I really don't understand why UD hasn't provided a non-Java and otherwise standard and less problem-prone application for ISY. Thanks to those who replies with assistance on that thread. I cant reply there as it is been closed.
  18. Thahkns, but as described I used that and it doesnt find the ISY. I enter the IP and it says invalid address. I have no doubt its some simple issue, but after 2 hours of following the wiki, the cookbook, the forums etc still not in the admin UI. Just saying, the tools dont work as described and/or the documentation is lacking.
  19. I am returning to my ISY 994 after not using it for a while and the ISY Finder / admin.jnlp etc continue to drive me CRAZY!!! I installed 32 snf 64 bit versions of java Cleared the cache Launched ISY finder, which as always does not find my local isy which is on my current/correct subnet Launch admin.jnlp and get an error message as usual "Cannot launch Application" Use http://isy which yields site cannot be reached I browse to the ISY url and enter via HTTP and sign in. Then click admin and het the stupid "Keep this window Open" All of this is in conjunction with following the wiki and searching the forums for current solutions. WHY AFTER SO MANY YEARS CANT UD USE A STRAIGHT FORWARD PC APP TO ACCESS THE ISY, OR USE A NOTMAL DEFAULT HTTP / HTTPS INTERFSCE TO ACCESS THE ADMIN UI? I REMEMBER DOING THIS MANY MANY TIMES OVER THE YEARS AND FINALLY DOING SOME CONVOLUTED THING TO SOLVE THE ISSUE AFTER A FEW HOURS OF EFFOFT AND AM NOT FINALLY COMPLAINING LOUDLY. UD Please reply and PLEASE fix this for all other users.
  20. Hi guys thanks for the posts . I'm traveling this week on business and can be in touch next week . The project is going through a systems redesign for the larger scope which will then inform what and how should integrate with ISY or other monitoring/control systems.
  21. I dont mind shifting to client-roll with a project leader (in many ways a welcome thought), but maybe that's not quite what you meant. Just looking for the right fit, narrow or broad. Enjoy the weekend, Thanks
  22. I added to my description above as you were typing, crossed in forum air PS: Not a bad suggestion as a possible component
  23. HI Sure, in a perfect world, nearby (Boston) would be a plus, but I'm not expecting that. I'm moderately competent ISY user and this is not mission-critical stuff (in the context that I am introducing some systems and monitoring that don't currently exist). If it all fails, I where I'm where I'be been for 25 years, which means fine. I'd just be better with the enhancement. Having said that, the real answer is, if it breaks I will fix/replace or seek assistance here or elsewhere. I realize my description is sparse as I was looking for interest and then would get into more details depending on the interested person. The point being, truly the assignment will be limited by the ability (and time) of the interest person and not by limitations of the project, including budget. We can keep it fairly simple and limited, or not. Here's a bit more context, without turning this post into a novel... I am changing/adding some systems to a few buildings including IP cameras, access monitoring, monitoring of some physical conditions e.g. moisture temp etc. I may add more (with the right person). Some of this is basic ISY stuff. Some would be enhanced from deeper integration of systems: sensors-to-cameras / timing of multiple-system events to each other / event data collection into useful usable info / communication between systems / which handles what notifications / UI / cross monitoring for failures in system(s). Some questions will include: Wired/wireless, what and when Elk, relay expansion boards, or http Polyglot and RPI, or not Which system leads/follows Which system interface site team uses for monitoring and how is non-system data incorporated. Note: I have installers, consultants for traditional components, i.e. cameras, network, etc. I am missing the more open-thinking ISY-type of brain/skill The above does not add much specificity, because the direction we take will change based on the contribution of the person I find. As stated it can just be adding some ISY stuff into the mix, or it could be a broader blank-paper conceptualization. Likely somewhere between. Hope this helps a little Thanks
  24. Sure, I completely understand where you're coming from and certainly not everyone with the skills wants to "commercialize" them with ISY. I'm just surprised No One does. It will be an interesting assignment for the right person. Have a great Labor Day weekend!!
  25. It is interesting there has been no replies to this inquiry. I wonder if that means few are using it for more than DYI home use AND other than demand response, no one sees it as having commercial application. I had expected some of the experienced users might be looking for a way to be paid for their ISY-time. I, for one, believe ISY DOES have real-world use outside one's own home. Just an observation.
