Everything posted by hart2hart
Please help me with this simple programming
If sensor is off/on (whichever means not full) Wait 10 minutes Set micro relay on that turns on pump Else Set micro relay off that controls pump
EISY 6.0.5
I didn’t read all of the background but I’d guess he meant restore the backup that you made prior to the upgrade.
fanlinc
The scenes per button were a little daunting to setup but they’ve been flawless for me. The plus for me is it’s there and doesn’t need a controller to work so if eISY happens to be offline or you get line noise etc it still functions.
Odd pop up keeps popping up
Reboot and it will go away. It’s a bug from one of later releases.
New Device Notification
Glad I could help.
Reboot and it will clear.
Version Question
As I recall, the number on switch likely refers to the hardware version. It might uptick if for example a larger capacitor was specified. eISY is reporting the onboard firmware version.
- ghost nodes
Program Details Screen
By name they appear time for a a portion of the If. Is your time zone set correctly?
Green means the last time executed it was True and Red means it was False. The ones in Yellow are the ones you should look at.
- EISY 6.0.5
EISY 6.0.5
I too updated both an eISY r1 and r2 (in burn in mode). The only quick item I noticed was when opening PG3x dashboard it says IoX Version: 6.0.4 Connected instead of 6.0.5
EISY 6.0.5
@Techman Great! Are there release notes posted? Nevermind. Found it.
ALEXA found more then one
The name is likely in Alexa from the ISY if you had one.
Alexa echo help new to Eisy
The automations as I recall are tied to the device. Sounds like you upgraded from an ISY or Polisy. Not sure if there is a way to move them over or you have to recreate them.
Verify I have an Eisy R2
Not from console that I’m aware. If it has a USB-C port on the back it’s R2. R1 had a regular USB port on the back.
Gave up and put an Insteon plug in front of MH dev
It’s been a few years since I started used these devices in scenes What I found was they became non-responsive over time but would work in scenes again if power was removed from them. Non I’ve got very inexpensive zwave devices that a program cycles power off and on each night. They work consistently in eISY scenes. Not elegant and not better than what you did but an FYI.
Mini Remote Flashes Red When Charging
I found a replacement battery for my first one. It’s really small and don’t recall details.
Report switch on/off time
The log as I recall (but no sure)is recorded by device and not scene so on or off for a scene translates to devices going on off. I’d likely write a program to parse rather than do it in excel. As to writing programs, it would be a task but if you triggered on device change that still happens if a scene caused the change.
Maybe look at the logging as I believe it records off / on and time of event.
Download list of installed insteon devices
Not exactly what you asked but I use create topology which is html representation of all devices a scenes.
Thermostat Won't Discover
Not much I can do to help. You said you’d installed latest FW. FWIW mine are at 6.93.
Can you ping the thermostats from the Polisy?
I wasn’t suggesting your WiFi was not password protected. I was suggesting they might be connected to different SSIDs and one of the ssid was setup on its access point without choosing encryption in its setup. None of mine say http.
Did you just turn them to enabled now and they still don’t discover in plugin? If so I’d find the option in thermostat menu to restart them. Are all three joined to a secure WiFi access name? If the one saying http is not it sounds like it’s saying secured access is required.
