kowaj
Everything posted by kowaj
  1. They work very spotty for me as well and normally revert to just using Alexa to control these devices. I have started to move away from Hue. I have had to many failures from Hue lights and started putting in Govee bulbs instead. They overall have a good color spectrum and are extremely more affordable. Basically it appears you can only send a limited ammount of commands thru the ISY and they the Govee api no longer will take commands. This may be more of a Govee issue than ISY but I would also love to know if there is another option to control these lights better.
  2. I went into configuration tab and did update packages. It seems to be bricked now. Looking at the Polisy the light the first light on the left is light. When started it goes from all 3 to quickly just the far left showing on.
  3. My Polisy is not responding after doing the update. I waited over an hour after doing the update and now I can not see it on my network anymore.
  4. I have not had much time to troubleshoot it yet but bond stopped working with both PG3 and Alexa for me. I will look into more this weekend.
  5. Done. Back when I used my Raspberry PI for Polyglot I would have to do this as well.
  6. Does anyone else experience this? When I reboot my Polisy PG3 does not come up right with HUE and I have to restart PG3 to get HUE to work with my keypad links.
  7. I finally got it to load not sure what I did but now I have new problems now. I am at work now so can't get to far into it but this is what I am seeing now. Both on pg2 and pg3. They can't find the Polisy anymore. I opened a ticket in support.
  8. .51 is my Polisy. I also looked at the console and it showed using port 8443 for some reason. Tried that and still not communicating.
  9. I see the below in my Polyglot v3 log 29/2022, 11:03:41 [polyglot] info: Successful login by admin 4/29/2022, 11:03:41 [polyglot] info: MQTTS: polyglot_frontend-7b8FH authenticated successfully. 4/29/2022, 11:03:41 [polyglot] info: MQTTS: Client Connected: 4/29/2022, 11:03:41 [polyglot] info: MQTTP: Frontend Websockets interface Connected. 4/29/2022, 11:04:39 [polyglot] error: MQTTS: clientError: polyglot_frontend-7b8FH write after end 4/29/2022, 11:04:39 [polyglot] info: MQTTS: Client Disconnected: 4/29/2022, 11:04:39 [polyglot] info: Successfully updated profile for User: admin 4/29/2022, 11:04:39 [polyglot] info: MQTTP: Frontend Websockets interface Disconnected. 4/29/2022, 11:04:45 [polyglot] info: Successful login by admin 4/29/2022, 11:04:45 [polyglot] info: MQTTS: polyglot_frontend-7b8FH authenticated successfully. 4/29/2022, 11:04:45 [polyglot] info: MQTTS: Client Connected: 4/29/2022, 11:04:45 [polyglot] info: MQTTP: Frontend Websockets interface Connected. 4/29/2022, 11:05:08 [polyglot] info: Settings Saved Successfully. 4/29/2022, 11:05:08 [polyglot] error: ISY: connection failed. Retrying... Error: connect ECONNREFUSED 192.168.86.51:80 4/29/2022, 11:05:09 [polyglot] error: ISY: connection failed. Retrying... Error: connect ECONNREFUSED 192.168.86.51:80 4/29/2022, 11:05:09 [polyglot] error: ISY: connection exceeded max re-tries. Aborting. Error: connect ECONNREFUSED 192.168.86.51:80 4/29/2022, 11:05:09 [polyglot] error: Get Version HTTP Error: RequestError: Error: connect ECONNREFUSED 192.168.86.51:80 4/29/2022, 11:05:09 [polyglot] error: ISY: Failed to get version.
  10. So my raspberry Pie crapped out and I am trying to rebuild Hue, Bond, and Ambient weather nodes. I have Hue and Bond added but they are not populating in the Polisy. I have rebooted multiple times and just not showing up. Not sure what else to try.
  11. My Raspberry pie took a dump and trying to load my Hue into PG3. When I try to install the node server I get this below messge. Node server install of Hue failed with message: NOT NULL constraint failed: Node server.branch
  12. kowaj replied to kowaj's topic in IoX Support
    Thanks all. It seems it was the Query issue except 3 dimmers in my basement. I had to delete the spokens and add them back. Now time to figure out why my programs are not running.
  13. kowaj replied to kowaj's topic in IoX Support
    looks like the only way it works is if I say a percentage of light level.
  14. kowaj posted a topic in IoX Support
    Hello sorry to bother you all again. I have mostly everything working after migrating to Polisy but Alexa is not working properly. My lights copied over and they are in my Alexa group but when I am in the room with the lights I can only turn off insteon lights. It will not turn on Insteon lights that are in that group. Any ideas?
  15. Got it working not sure how thanks for assistance all!
  16. Get NodeDef ZWave 0 Sat 2022/03/26 12:23:01 System Unknown 0 null Sat 2022/03/26 12:48:45 PM System Unknown 0 null Sat 2022/03/26 12:48:45 PM System Unknown Get NodeDef ZWave 0 Sat 2022/03/26 12:53:14 System Unknown 0 null Sat 2022/03/26 01:16:32 PM System Unknown 0 null Sat 2022/03/26 01:16:32 PM System Unknown 0 null Sat 2022/03/26 01:17:20 PM System Unknown 0 null Sat 2022/03/26 01:17:20 PM System Unknown Get NodeDef ZWave 0 Sat 2022/03/26 13:17:43 System Unknown
  17. Plugged it into my desktop. Comes up in device manager.
  18. Restored from my ISY. good idea on disabling query. I am about to test the dongle on the pc. Maybe it is messed up. PLM is USB.
  19. No. I ordered this right from UD and it saw it mentioned the forums that it is the version they tested the stick with.
  20. zooz s2 stick 700. 5.4.1. Yes I checked z-wave in admin console. waiting for the log to download right now. It takes forever to boot back up shows the system busy menu for a while.
  21. I have been able to get insteon to work but the Z-wave dongle will not come online. I just get z-wave dongle not responding. Any ideas? I tried switching ports, disabling insteon and rebooting. Nohting...
  22. kowaj replied to kowaj's topic in Polisy
    Thanks it works and ordered the pro!
  23. kowaj posted a topic in Polisy
    Is there still an active coupon code for the Polisy? I tried Z9F44G4R but stated it was expired.
  24. I have rebooted several times and it still seems to have issues updating neighbors. Did this function change in the 5.3.3 release?
