  1. Tap the 3-dot menu (â‹®) in the top-right corner of the browser.
inovermyhead
Everything posted by inovermyhead
  1. @Athlon, Yes, I'm familiar with the unsigned certificate warning. No, this is not what I'm getting. After first clearing the browser cache, I usually get a completely blank, white browser screen; when I reload or refresh this, I get the Safari error that it can't connect. @noobmuch Same "can't connect" error with or without the Admin Console open. And when the AC is open, it's active/works fine - current status for sensors devices and turns devices on and off as directed
  2. I carefully followed the instructions for uprading my eisy to OS 14.3/IoX6 - everything seemed to go smoothly and fairly quickly: The time between when UD Mobile notified me "upgrade in progress" to "PG3 is starting" was only 14 minutes. After the upgrade I can log into the AC with IoX Launcher, either via IoX or Portal, and it does show IoX 6.0.0. Commands via the AC and Alexa, work; node servers are connected (notifications from UD Mobile) and are showing current data. However, I can't open either PG3x or eisy.local: Safari reports "Safari can't establish a secure connection to the server"eisy.local" I did reboot eisy after the upgrade and cleared the browser cache. What went wrong or what do I do next? Seems like I got the upgrade, without getting any of the benefits of eisy.ui.... Thanks.
  3. @geddy, will do🙂
  4. @Geddy Thanks for the suggestion: I checked all of my plugins and the log level for a couple were set at "error" or "critical" level . I've now got them all at "warning". I can rule out a router problem: two weeks ago my custom router (Untangle running on a Supermicro 1U) failed (I think an HDD problem but haven't had a chance to do a real diagnosis yet) so I switched to a backup - an old Linksys WRT54G - and the offline/online notifications have continued.
  5. @bwdavis7, yes, I've been getting the offline/online notifications well before 2/1. I don't recall exactly when I started noticing these, since I was just deleting them. Part of the impetus for "fixing" the issue and posting on the forum is that I will be going on a long international trip soon and wanted to delete unnecessary push notifications that will incur roaming data charges. Did you recently add or update your eisy? While I've had my eisy for nearly a year, it was only in December that I finally sat down and migrated everything from my trusty but old ISY994. Extending from @Geddy's thinking could it be a plugin that's causing this? I have installed: ISYLink, Weatherflow, Wireless Tags, Holidays, Webcontrol832, AVremote, Roku Media Player, Push, Sun, ISY Portal, Nanoleaf, Presence, Backup, Ecobee, TimeData, UnifPresence and Kasa (some outdated from ISY994/PG2)
  6. @bwdavis7, no, no match between your offline/online times and mine. @Geddy, yes same versions of UDx, isy and PG3x. I haven't tried (but will) a hardpower off restart on my easy. However, the fact that my cycle/notification times don't match those of bwdavis7 AND that the offline/online notifications have been going on for me for some time (I just finally got tired enough of this to post in the forum) would suggest that the problem is local to individual eisys, not something at UD's end, correct?
  7. @flsenior - same here: During the eisy "offline" periods I can and have other internet services going, like Amazon Music. So the problem is not at the ISP end... Sort of reassuring to hear that others are observing the same issue; suggesting that it's not something unique to my setup. Thanks.
  8. I’m getting frequent UD Portal notifications that my eisy is offline, then a few minutes later that it’s back online. The notifications seem to come in random spurts, sometimes many (6-10) in a day, sometimes none. And the offline to back online interval is always 8 or 9 minutes. The eisy is on a wired Ethernet connection, not Wi-Fi. So far I haven’t been able to discern any pattern or obvious cause for the notifications. Anybody have any clues or suggestions for what to check?
  9. I'm finally getting around to moving from my venerable ISY994 to EISY. The migration instructions are clear and I've updated both IoX and the EISY to the latest versions (5.8.4), and also PG3x to its latest version (3.2.27). I have a number of node servers using the original Polyglot and talking to the ISY994. I realize that many (all?) of these can't be immediately migrated to PG3x versions, so I would like to check on the configuration details of these before moving to the PG3x versions on the EISY. However, I'm having trouble accessing Polyglot to see these older node servers: http://"ISY IP address":8080 doesn't work - "can't open the page because the server isn't responding" What am I missing or doing wrong? I saw references in some threads that once one updates to PG3x, it's no longer possible to see the PG2 home page? If this is correct, then why or how do Polyglot or PG2 node servers continue to run (in my case on the ISY994. Thanks, John
  10. KDFC.com out of SF
  11. I have a question about using antenna extension cables for the ZMatter board My Polisy is on a shelf in a computer rack in the basement. Because the equipment above and below shelf is much deeper than the Polisy, the Zwave and Zigbee antennas (from the ZMatter board) would have to be horizontal and surrounded by the grounded metal rack and computer cases - not good for range according to UD tech support. So I would like to add short (~1 M) extension cables to get the antennas out of the rack and vertical. I looked up the specs for sma extension cables, typically rg316 cable. At Zwave and Zigbee frequencies (Zwave = 908-920 MHz; Zigbee = 902-908 MHz & 2.4 Ghz), the attenuation would be ~1.25-1.90 db/1 M, so not much. For any of you with real rf experience, have I missed anything important? I did notice that the ZMatter board antenna extension cables to the Polisy case are rp-sma. Thanks
  12. @TechmanYes, I was thinking the same. For some reason my IoP seems pretty resolutely stuck on v5.4.0. I just wanted to make sure I wasn't missing something. Thanks.
  13. @Techman Still no luck: I unplugged the Polisy for >30s, plugged it back in and let it reboot. Then cleared the java cache, restarted IoX Launcher from start.jnlp. Polisy IoP is still v5.4.0. How do I do an update, since 5.4.0 doesn't have the "upgrade packages" option?
  14. Possibly relevant: I have Polyglot v2 still installed. And when I open Polyglot v3 (policy:3000/dashboard) under "ISYs" it shows only my ISY994, not the IoP instance. However, IoX Launcher does show both the ISY 994 and the Policy IoP (which is also still showing as v 5.4.0)
  15. No luck. I pushed the reset "button" on the front of the Policy (a paper clip into the hole and felt a click). The left most light on the Policy went from flashing to solid. I waited several minutes, then cleared the Java cache (applications, resources, deleted applications), restarted IoX Launcher (from downloaded start.jnlp file) and opened the IoP admin console. It still shows v 5.4.0
  16. I just received my ZMatter board this afternoon and have hit a snag getting ready to install it: The UDI instructions say to check the Policy OS via ssh. Mine is FreeBSD 13.0-RELEASE-p6, instead of 13.1 (as later instructions for IoP indicate it should be be). So I tried the "Upgrade Process - As of July 2002" in the wiki. With the IoX Launcher, I open the admin console for IoP; however there is no "Upgrade Packages" under configuration/system. With some forum sleuthing I saw that this is because IoP is only v5.4.0, and the "Upgrade Packages" was added in v5.4.4. I tried the "automatically upgrade Policy to 5.4.4" option under help but this doesn't work. The admin console closes, then I cleared the Java cache. After finding the IoX Launcher file again (clearing the Java cache deletes this) and waiting a few minutes, I reopen the IoP admin console - and it still says v5.4.0. I've tried restarting the Polisy; no improvement. What am I missing or not understanding?
  17. @javi. Sorry, I did not mean to hijack this thread. I will start a new one. Unfortunately, your instructions did not resolve the problem….
  18. Another subscription problem, possibly related: My iPhone (iOS14.7.1) is not/will not connect to the Portal (UD Mobile 0.6.1): When I open the app I get two error notifications "System: Valley Lane (the name of my system) Error, then "Could not get get Portal credentials. Portal is not set". When I go to Settings/ ISY Portal Accounts and click on the account there and then "continue", I get "Starting subscription", then again quickly "Could not get get Portal credentials. Portal is not set". I do have a Portal subscription, recently renewed - and UD Mobile and the Portal connection are working fine on my iPad (iOS14.8.1) with no error messages . On the account page (on the iPhone) and clicking "login", I get the circular icon, then eventually "ERROR Authorization Tokens are Null" Clearly something amiss with my Portal account settings on the iPhone but how do I fix this? Other than this hiccup, UD Mobile has been flawless and getting better with each update. Thanks, John
  19. Just an added comment since I also access the AC from a Mac. I’ve had no problems. I recently upgraded my iMac 27 from Catalina to Big Sur (11.4) and the AC window opens normally with the boxes for both username and password. Could it be a problem with your AC version? I’m using 5.3.3
  20. Sorry, I'm a novice at network things: What should the Unifi_host URL to the Unifi Controller look like? I have two Unifi Access Points - no Ubiquiti router, guardian or switches. I access the Unifi controller via a OSX application (image below), which prompts me to open a browser tab. Once I do this, the URL for the tab is: https://localhost:8443/manage/account/login?redirect=%2Fmanage. However, putting this URL in as the Unifi_host parameter doesn't work (nor does it work just pasting the URL into a new browser tab....) I'm confused. Thanks.
  21. The new UnifiPresence nodeserver looks very useful, however, I'm sorry I don't understand the custom configuration parameters listed in the GitHub page. Unifi_host = ?, Unifiport = ? (I don't see any port specification anywhere in the Controller?). Unifi_userid = Is this the username for logging into the Controller? Unifi_password = Is this the password associated with the aforementioned user id, or the password for logging into the wifi network? Unifi_siteid = Is this the name/SSID of my local wifi network? About the only parameter I am certain of is the mac_device = MAC address of my cell phone. Thanks
  22. Not at all @danbutter, following your directions, including the crontab restart line, I got Nodelink up and running on Ubuntu VM on my TrueNas server!n Many thanks. @io_guy are you still adding devices to Nodelink? I would love to have a way to control my Velux skylights via their KLF 200; they have published an API... I do have a KLF200 for testing; however I'm not skilled enough to write a nodeserver. Thanks
  23. Going through several of my existing programs I now see comments added to the effect of "Warning: Unrecognized Action (program may not run) <cmd NODE="24801" ID="DOF"/>" I believe but am not certain that some or all of these may have arisen when I updated to V5.3; however I'm not sure what to do with them? Searching the Main/network window in the ACI can't find "nodes" with these numbers? Is the node number irrelevant and what I need to do is check the program line right before the warning?
  24. I would like to add the execution of a program to an Alexa routine. I see in the portal instructions that a program can be turned on (execute then statements) or off (execute the else statements). But when setting this up in the portal should the program be defined in the Alexa category as a scene or switch (presumably not as a light, outlet or device with open/close syntax)? Or does it matter?
  25. bpwwer, Thanks, I will start with the GitHub and npm modules.
