twired
  1. Yes, on a few of the new wall plugs, there is no air-gap option. So turning the breaker off/on fixed those devices. I agree it is unusual. I have been using insteon (and x10) for over 20 years and never had this happen before. It did not appear to be a spike on the line, since my surge protector in the panel was not affected. I was hoping to better understand what happened and why disconnecting power alone would fix it.
  2. To be clear, all I did was air-gap the devices and they worked fine. I did not have to restore the devices. That is what I want to better understand. I would have thought a restore was required, but it was not.
  3. So that would clear out memory, links, etc. Does the eisy then automatically reload everything instantaneously?
  4. After brief power outage all of my Insteon switches and some plug-ins started working erratically. Lights flickering or not responding when on/off tapped. LEDs on switches and plugs flickering for several seconds after on/off. Performing an "air-gap" or removing power briefly restored everything to normal operation. Can someone with a better understanding of the underlying technology please help me understand what could have caused this and more importantly, why removing power (air gap) fixed it? Thanks
  5. Turned out I had a similar problem once before. A simple unplug the power and restart fixed it.
  6. Never had this problem before. The IoX launcher does not find the eisy. On UD Mobile it connects, but using the IoX Launcher on my Windows computer shows blank. I have cleared the Java cache and reloaded the launcher from the website, with no change.
  7. Thank you paulbates! Given my comfort level with the old ISY, I never even realized polyglot was installed and plugins available. I have set up notifications through UD mobile and all is working. I am so glad to not have to mess with ATT and email to TXT.
  8. Does the plug in require polyglot? I have not installed it and have 0 experience with it. Just an old long time isy/eisy user. Reluctant to jump into that unless it is fairly straightforward.
  9. I have tried both txt and mms with no success, from multiple email addresses. And my previous experience working with ATT seems futile. Any other alternatives? Does UD support messages initiated from programs, or only system messages? I cannot find any documentation on that.
  10. Over the last week email-to-text has stopped working on ATT. This happens no matter where the email is initiated, not just eisy. It appears this is not a unique problem. I have set up a unique ATT email in eisy address for the text message. Had gmail before and ran into problems there as well. The system rarely triggers a message except when I am testing new programs. Does anyone know a fix or good alternative? I am currently not a Polyglot user, so plug-ins may be too complex. Open to suggestions.
  11. After firmware update and disabling programs to run at restart, the problem seems to have gone away for now at least. I have ordered new open/close sensor and IOLink from Insteon and am waiting for it to arrive. I will install those, and install a voltage regulator to assure IOLInk sees 5v vs 12V. Also will rewrite programs as suggested by paulbates. After all that if the issue arises again I will submit a ticket on potential system reboots. I went back thru the event log and saw that on July 23 (while traveling) when this happened the first time, it triggered 7 times in 9 hours before I could disable the all the associated programs thru UDMobile. Since re-enabling the programs in early Aug it has happened twice. Was there anything crazy going on with eisy's or portal on July 23? Still perplexed, but very appreciative of all the help provided!
  12. Ok. Several programs were set to run at restart. I have disabled those. Is there any condition when a program should run at re-start? One of the programs is probably the culprit. I have an override program that turns the security program off when a certain button is pushed. It was set to run at restart. That has been disabled to not run at restart. But none of the IF conditions were true at restart. So not sure this is the smoking gun However if the issue is caused by a restart, that begs the question, why does my system keep restarting randomly? Is there a way to see history on when the eisy restarts? The re-boot today after firmware upgrade show starting exactly 1 min before the message and light on/off issue happened. I think we are on to something. Thanks so much for your help. Hopefully we can determine the reason of restarts and solve that as well. I really appreciate your expertise and help.
  13. paulbates, thanks for your feedback. I will make the change to control vs. status and test it. As for the 150 times, I am flashing llights for that many times before stopping the flashing. Good point on putting them in a scene. That is much more straight forward. But I do not see how those changes will address the random Else trigger unless as IndyMike suggested, the IOLinc is doing a random very fast On/off creating a jumble of traffic. But it appears not really random, always happening at xx:02. Still perplexed.
  14. I have upgraded the firmware. Interesting...exactly 1 min after the reboot finished (as shown in system status), the Else section of the program triggered. Could this somehow be related to the eisy rebooting periodically? IndyMike, I agree, no idea how this Else is triggered. To answer your questions: 1. I am making the assumption that only Else triggered based on no email, not lights turning on/off, etc. 2. No other program calls the ELSE. 3. No query program on IOLinc. Here is what the log showed when it triggered after reboot. The actions are directly from the ELSE section other than the last Hall Cans-Den-3-way Off command. No idea what is causing that.
  15. Geddy, thanks for the reply. I will update the firmware in the next couple of days. I have had some conflicts arise here. I ordered a door sensor today and will replace that as well. Even with new battery and restore, still no heartbeat. The really perplexing thing is the ELSE triggering on the security program, and the timing of the triggers. I will be back on here after firmware update. Thanks
