wrj0
Everything posted by wrj0
  1. wrj0 replied to wrj0's topic in Wake-On-Lan
    @Ross Need to select the name set in the Wake On Lan plugin, that you want to wake. In the Wake On Lan plugin, my first Configuration Parameter (name) is U59LAN1. The second field in the Configuration Parameter is the MAC/ip, e.g.,: 7C:83:34:xx:yy:zz/192.168.x.y My test program: WakeU59 - [ID 01BF][Parent 0080][Not Enabled] If - No Conditions - (To add one, press 'Schedule' or 'Condition') Then Set 'Plugins / U59LAN1' Send WOL Else - No Actions - (To add one, press 'Action') #Disabled
Run manually as needed
  2. wrj0 replied to wrj0's topic in Wake-On-Lan
    After updating eisy to the 10/16 releases, and migrating Wake On Lan again, that plugin is once again functional.
  3. wrj0 replied to wrj0's topic in Wake-On-Lan
    Not yet.
  4. I have Wake On Lan ver 1.0.3 installed on my eisy; it's been running fine for a couple of years. Today I performed the "Migrate from PG3" on all of my PG3 nodeservers/plugins. All of the plugins migrated, except for Wake On Lan, which reported: "Migration failed: No valid license found for Wake-On-Lan null edition." Details in PG3>Dashboard>Wake On Lan shows: Wake-On-Lan(2) Current Status: Connected Current Version: 1.0.3 [Production] I have stopped and restarted the plugin. Anything I can do to allow this plugin to migrate? Thanks.
  5. Since the eisy.local page shows "Plugins (Beta)" I had not previously performed the migration from PG3X to eisy. Opening "Plugins beta" showed a tab "Migrate PG3 plugins." After performing that migration, Backup now shows a Green check next to Plugin Data Files. Thanks all for your feedback, comments and suggestions. What an amazing, helpful forum!
  6. Not sure migration is my problem; eisy migration from PG3 to PG3X was performed in 2023.
  7. Seeing an error when creating a Backup using eisy.local > System > Backup & Recovery. Only noticed this after doing the recent Beta update. loX 6.1.2_7 UDX 5.0.0_4 PG3X 3.4.25 eisy Ul 1.3.9 The backup completes but shows this error: What am I missing or doing wrong?
  8. wrj0 replied to Panda88's topic in Blink
    @Panda88 Thanks for implementing tokens so we don't have to enter that pesky 2FA after each reboot. Nice work.
  9. Updated ST-Inventory today from v1.0.12 to 1.0.13. Plugin status now shows: Disconnected. Rebooted eisy running v6.1.1. Allowed time for both short & long poll times to pass. Allow ISY Access by Plugin is Enabled. ST-Inventory status continues to show: Current Status: Disconnected Current Version: 1.0.13 / Standard [Production] Suggestions on how to resolve will be appreciated.
  10. My first eisy upgraded without any issues, following the upgrade procedure. The second eisy completed the upgrade, but after two reboots, eisy.ui was reported as not found. After performing 6x presses of the multifunction button to shut down the eisy, pulling and reconnecting power, the eisy booted fine and eisy.ui is now accessible.
  11. wrj0 replied to alambertus's topic in Blink
    Update to 0.6.19 worked fine. Received 2FA on first restart. Thanks @Panda88
  12. Same kind of problems here syncing. UDM 4.45.24, isy-6.0.5_10 Think I'll wait for the permanent solution before syncing via cell service.
  13. wrj0 replied to bmercier's topic in eisy-ui
    My eisy upgrade via the AC from isy-6.0.5_1 proceeded without any problems. sysconfig.txt now shows: eisyui-1.0.1 pg3x-3.4.17 And my.isy.io shows and opens the new eisy-ui option. Nice work UDI.
  14. I also had trouble adding the Cync bulb directly to UDM. So, first added it to the Apple Home app which allowed the bulb to be added to UDM without any trouble. After scanning the Matter code for the Cync bulb into the Home app, select 'Turn On Paring Mode' and Copy the provided pairing setup code. Then open UDM, in Settings -> Matter, Select Add Matter Device with Setup Code and paste the copied code into UDM. UDM added the Cync bulb that functions fine in IoX.
  15. My two Talentcell UPS also failed in just under two years. Lousy battery connections that are welded in place. IMG_5020 2.HEIC
  16. wrj0 replied to alambertus's topic in Blink
    Blink 0.6.6 is working fine with my eisy. Thanks for the update.
  17. wrj0 replied to alambertus's topic in Blink
    @Panda88 0.6.5 is working great! Thanks for the fast response and your effort to fix the new authorization issue. Well done.
  18. wrj0 replied to alambertus's topic in Blink
    That’s got to be tough on you. Thanks for finding the problem; hope you find that it’s an easy fix.
  19. wrj0 replied to alambertus's topic in Blink
    Will do. Thanks.
  20. wrj0 replied to alambertus's topic in Blink
    Ran the IoX update twice, then a reinstall All plugins in PG3. Restarted the Blink plugin. Still, no 2FA received. Same error showing in debug log shown below. Any other suggestions? Thanks. 2025-12-05 13:48:08.839 Thread-14 (systemPoll) udi_interface INFO udiBlinkController:systemPoll: System Poll executing: longPoll 2025-12-05 13:48:08.840 Thread-14 (systemPoll) udi_interface ERROR BlinkSystem:wrapper: Error executing async method refresh: 'NoneType' object has no attribute 'base_url'
  21. wrj0 replied to alambertus's topic in Blink
    Thanks. I'll run the IoX upgrade again. Only reinstalled the Blink plugin but will try the reinstall ALL after an IoX upgrade.
  22. wrj0 replied to alambertus's topic in Blink
    I managed to break my Blink plugin connection to eisy. Plugin version: 0.6.4. It had been running fine for a week under IoX 5.9.1 and allowed eisy programs to arm and disarm the Blink devices. Yesterday, I upgraded the eisy IoX to version 6.0.3. Programs and plugins except Blink seem to be running properly. When I restart the Blink plugin, or restart or power cycle eisy, I do not receive a 2FA code from the Blink servers. I do however receive a 2FA code if I try to change a setting in the Blink app. Blink plugin configuration remains the same as it was in IoX 5.91 - Blink app password has not been changed. I have tried deleting the AUTH_KEY field in the plugin and restarted the Blink plugin, but no 2FA code is received. Debug log excerpt is shown below. I'm not sure how to correct the ERROR shown. Suggestions on how to correct this will be greatly appreciated. Thanks. 2025-12-05 07:42:52.787 MQTT udi_interface.interface DEBUG interface:_message: QUEUING incoming message longPoll 2025-12-05 07:42:52.787 Command udi_interface.interface DEBUG interface:_parseInput: DEQUEING longPoll 2025-12-05 07:42:52.787 Command udi_interface.interface DEBUG interface:_handleInput: PROCESS longPoll message {} from Polyglot 2025-12-05 07:42:52.788 Thread-62 (systemPoll) udi_interface INFO udiBlinkController:systemPoll: System Poll executing: longPoll 2025-12-05 07:42:52.788 Thread-62 (systemPoll) udi_interface ERROR BlinkSystem:wrapper: Error executing async method refresh: 'NoneType' object has no attribute 'base_url'
  23. wrj0 replied to alambertus's topic in Blink
    @Panda88 I agree - Nice Work! Many thanks for getting the Blink Authorization to work again. It's great to have eisy be able to Arm/Disarm Blink motion, especially when combined with eisy Geofence capability to arm/disarm these cameras when entering or leaving the premise. Really appreciate your digging into this issue.
  24. Ticket opened, UDI performed diagnostics. Ticket response was: Marking this as solved. Terrific support by UDI!
  25. Will do. Thanks, Javi.
